[U-Boot-Users] [PATCH] Fix do_bootm_linux() so that multi-file images with FDT blob boot.
Fix the following issues in do_bootm_linux() that prevent booting the kernel from a mulit-file image (kernel + initrd + blob): - incorrect initrd address and length calculation - incorrect blob address calculation
Also, make minor updates to the U-Boot's output and to the coding style.
Signed-off-by: Bartlomiej Sieka tur@semihalf.com --- Tested on two MPC5200B-based boards, one using CONFIG_OF_FLAT_TREE (still), the other using CONFIG_OF_LIBFDT. On each board the mulit-file image was booted from an address in RAM, as well as in Flash.
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index bcb927f..4aca783 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -724,9 +724,8 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, if (tail) { data += 4 - tail; } - - len = ntohl(len_ptr[1]); - + len = ntohl (((image_header_t *)data)->ih_size); + data = data + sizeof(image_header_t); } else { /* * no initrd image @@ -817,27 +816,32 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, int i;
/* skip kernel length, initrd length, and terminator */ - of_data = (ulong)(&len_ptr[3]); + of_flat_tree = (char *)(&len_ptr[3]); /* skip any additional image length fields */ for (i=2; len_ptr[i]; ++i) - of_data += 4; + of_flat_tree += 4; /* add kernel length, and align */ - of_data += ntohl(len_ptr[0]); + of_flat_tree += ntohl(len_ptr[0]); if (tail) { - of_data += 4 - tail; + of_flat_tree += 4 - tail; }
/* add initrd length, and align */ tail = ntohl(len_ptr[1]) % 4; - of_data += ntohl(len_ptr[1]); + of_flat_tree += ntohl(len_ptr[1]); if (tail) { - of_data += 4 - tail; + of_flat_tree += 4 - tail; }
+ /* move the blob if it is in flash (set of_data to !null) */ + if (addr2info ((ulong)of_flat_tree) != NULL) + of_data = (ulong)of_flat_tree; + + #if defined(CONFIG_OF_FLAT_TREE) - if (*((ulong *)(of_flat_tree + sizeof(image_header_t))) != OF_DT_HEADER) { + if (*((ulong *)(of_flat_tree)) != OF_DT_HEADER) { #else - if (fdt_check_header(of_flat_tree + sizeof(image_header_t)) != 0) { + if (fdt_check_header (of_flat_tree) != 0) { #endif puts ("ERROR: image is not a fdt - " "must RESET the board to recover.\n"); @@ -845,9 +849,11 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, }
#if defined(CONFIG_OF_FLAT_TREE) - if (((struct boot_param_header *)of_data)->totalsize != ntohl(len_ptr[2])) { + if (((struct boot_param_header *)of_flat_tree)->totalsize != + ntohl (len_ptr[2])) { #else - if (be32_to_cpu(fdt_totalsize(of_data)) != ntohl(len_ptr[2])) { + if (be32_to_cpu (fdt_totalsize (of_flat_tree)) != + ntohl(len_ptr[2])) { #endif puts ("ERROR: fdt size != image size - " "must RESET the board to recover.\n"); @@ -957,6 +963,7 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, "must RESET the board to recover.\n"); do_reset (cmdtp, flag, argc, argv); } + puts ("OK\n"); } /* * Add the chosen node if it doesn't exist, add the env and bd_t @@ -1011,6 +1018,7 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, printf (" Loading Device Tree to %08lx, end %08lx ... ", of_start, of_start + of_len - 1); memmove ((void *)of_start, (void *)of_data, of_len); + puts ("OK\n"); } /* * Create the /chosen node and modify the blob with board specific
I thought this bug has already been fixed. Are the initrd address and length calculations broken again?
I don't know - I have tested today's U-Boot (60174746) and multi-file image booting didn't work:
## Booting image at ff180000 ... Image Name: Kernel + initial ram disk + FDT Created: 2007-08-31 12:24:07 UTC Image Type: PowerPC Linux Multi-File Image (gzip compressed) Data Size: 2894640 Bytes = 2.8 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 1351205 Bytes = 1.3 MB Image 1: 1531127 Bytes = 1.5 MB Image 2: 12288 Bytes = 12 kB Verifying Checksum ... OK Uncompressing Multi-File Image ... OK ERROR: image is not a fdt - must RESET the board to recover.
I might have missed a patch, though - could you provide a pointer to the fix that you have in mind?
Regards, Bartlomiej
http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=commit;h=9877d7dcd1eebe...
Timur,
As I said - I have tested today's ToT U-Boot - which contains the above patch - and observed the problem. And more importantly, the patch is not related to booting mulit-image files, which is the scenario I am dealing with.
Regards, Bartlomiej
Fix incorrect blob address calculation in do_bootm_linux() that prevents booting the kernel from a multi-file image (kernel + initrd + blob).
Signed-off-by: Bartlomiej Sieka tur@semihalf.com --- My previous patch was wrong in "fixing" the initrd length. do_bootm_linux() expects the initial ramdisk embedded in a multi-file image to be a raw compressed initrd (like ramdisk_image.gz), and not an U-Boot image (like uRamdisk).
Tested on two MPC5200B-based boards, one using CONFIG_OF_FLAT_TREE (still), the other using CONFIG_OF_LIBFDT. On each board the multi-file image was booted from an address in RAM, as well as in Flash.
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index bcb927f..9d99262 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -817,27 +817,32 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, int i;
+ /* move the blob if it is in flash (set of_data to !null) */ + if (addr2info ((ulong)of_flat_tree) != NULL) + of_data = (ulong)of_flat_tree; + + #if defined(CONFIG_OF_FLAT_TREE) - if (*((ulong *)(of_flat_tree + sizeof(image_header_t))) != OF_DT_HEADER) { + if (*((ulong *)(of_flat_tree)) != OF_DT_HEADER) { #else - if (fdt_check_header(of_flat_tree + sizeof(image_header_t)) != 0) { + if (fdt_check_header (of_flat_tree) != 0) { #endif puts ("ERROR: image is not a fdt - " "must RESET the board to recover.\n"); @@ -845,9 +850,11 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, }
#if defined(CONFIG_OF_FLAT_TREE) - if (((struct boot_param_header *)of_data)->totalsize != ntohl(len_ptr[2])) { + if (((struct boot_param_header *)of_flat_tree)->totalsize != + ntohl (len_ptr[2])) { #else - if (be32_to_cpu(fdt_totalsize(of_data)) != ntohl(len_ptr[2])) { + if (be32_to_cpu (fdt_totalsize (of_flat_tree)) != + ntohl(len_ptr[2])) { #endif puts ("ERROR: fdt size != image size - " "must RESET the board to recover.\n"); @@ -957,6 +964,7 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, "must RESET the board to recover.\n"); do_reset (cmdtp, flag, argc, argv); } + puts ("OK\n"); } /* * Add the chosen node if it doesn't exist, add the env and bd_t @@ -1011,6 +1019,7 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, printf (" Loading Device Tree to %08lx, end %08lx ... ", of_start, of_start + of_len - 1); memmove ((void *)of_start, (void *)of_data, of_len); + puts ("OK\n"); } /* * Create the /chosen node and modify the blob with board specific
Applied, thanks.
Bartlomiej Sieka
Timur Tabi
