[U-Boot-Users] [PATCH] [ads5121] Added support for FDT.
Signed-off-by: Grzegorz Bernacki gjb@semihalf.com --- board/ads5121/ads5121.c | 8 ++++++++ cpu/mpc512x/cpu.c | 21 +++++++++++++++++++++ include/asm-ppc/u-boot.h | 3 +++ include/configs/ads5121.h | 8 ++++++++ lib_ppc/board.c | 3 +++ 5 files changed, 43 insertions(+), 0 deletions(-)
diff --git a/board/ads5121/ads5121.c b/board/ads5121/ads5121.c index f275ce7..46be6a5 100644 --- a/board/ads5121/ads5121.c +++ b/board/ads5121/ads5121.c @@ -184,3 +184,11 @@ int checkboard (void) brd_rev, cpld_rev); return 0; } + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ diff --git a/cpu/mpc512x/cpu.c b/cpu/mpc512x/cpu.c index accae6e..6421a51 100644 --- a/cpu/mpc512x/cpu.c +++ b/cpu/mpc512x/cpu.c @@ -32,6 +32,10 @@ #include <mpc512x.h> #include <asm/processor.h>
+#if defined(CONFIG_OF_LIBFDT) +#include <fdt_support.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
int checkcpu (void) @@ -125,3 +129,20 @@ void watchdog_reset (void) enable_interrupts (); } #endif + +#ifdef CONFIG_OF_LIBFDT +void ft_cpu_setup(void *blob, bd_t *bd) +{ + char * cpu_path = "/cpus/" OF_CPU; + char * eth_path = "/" OF_SOC "/ethernet@2800"; + + do_fixup_by_path_u32(blob, cpu_path, "timebase-frequency", OF_TBCLK, 1); + do_fixup_by_path_u32(blob, cpu_path, "bus-frequency", bd->bi_busfreq, 1); + do_fixup_by_path_u32(blob, cpu_path, "ref-frequency", CFG_MPC512X_CLKIN, 1); + do_fixup_by_path_u32(blob, cpu_path, "clock-frequency", bd->bi_intfreq, 1); + do_fixup_by_path_u32(blob, "/" OF_SOC, "bus-frequency", bd->bi_ipsfreq, 1); + do_fixup_by_path_u32(blob, "/" OF_SOC, "ref-frequency", CFG_MPC512X_CLKIN, 1); + do_fixup_by_path(blob, eth_path, "address", bd->bi_enetaddr, 6, 0); + do_fixup_by_path(blob, eth_path, "local-mac-address", bd->bi_enetaddr, 6, 0); +} +#endif diff --git a/include/asm-ppc/u-boot.h b/include/asm-ppc/u-boot.h index bd9b6f7..2b31814 100644 --- a/include/asm-ppc/u-boot.h +++ b/include/asm-ppc/u-boot.h @@ -74,6 +74,9 @@ typedef struct bd_info { unsigned long bi_sccfreq; /* SCC_CLK Freq, in MHz */ unsigned long bi_vco; /* VCO Out from PLL, in MHz */ #endif +#if defined(CONFIG_MPC512X) + unsigned long bi_ipsfreq; /* IPS Bus Freq, in MHz */ +#endif /* CONFIG_MPC512X */ #if defined(CONFIG_MPC5xxx) unsigned long bi_ipbfreq; /* IPB Bus Freq, in MHz */ unsigned long bi_pcifreq; /* PCI Bus Freq, in MHz */ diff --git a/include/configs/ads5121.h b/include/configs/ads5121.h index 58060a8..11e7e44 100644 --- a/include/configs/ads5121.h +++ b/include/configs/ads5121.h @@ -407,4 +407,12 @@
#define CONFIG_BOOTCOMMAND "run flash_self"
+#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +#define OF_CPU "PowerPC,5121@0" +#define OF_SOC "soc5121@80000000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc5121@80000000/serial@11300" + #endif /* __CONFIG_H */ diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 9aa67f9..207cf36 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -555,6 +555,9 @@ void board_init_f (ulong bootflag) bd->bi_sccfreq = gd->scc_clk; bd->bi_vco = gd->vco_out; #endif /* CONFIG_CPM2 */ +#if defined(CONFIG_MPC512X) + bd->bi_ipsfreq = gd->ipb_clk; +#endif /* CONFIG_MPC512X */ #if defined(CONFIG_MPC5xxx) bd->bi_ipbfreq = gd->ipb_clk; bd->bi_pcifreq = gd->pci_clk;
Signed-off-by: Grzegorz Bernacki gjb@semihalf.com --- include/common.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/common.h b/include/common.h index 493417f..1bc33f5 100644 --- a/include/common.h +++ b/include/common.h @@ -462,7 +462,7 @@ int prt_8260_clks (void); #elif defined(CONFIG_MPC5xxx) int prt_mpc5xxx_clks (void); #endif -#if defined(CONFIG_MPC512x) +#if defined(CONFIG_MPC512X) int prt_mpc512xxx_clks (void); #endif #if defined(CONFIG_MPC8220)
Signed-off-by: Grzegorz Bernacki gjb@semihalf.com --- cpu/mpc512x/fec.c | 2 +- cpu/mpc512x/i2c.c | 12 ++++++------ cpu/mpc512x/serial.c | 2 +- cpu/mpc512x/speed.c | 4 ++-- include/asm-ppc/global_data.h | 2 +- lib_ppc/board.c | 2 +- 6 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/cpu/mpc512x/fec.c b/cpu/mpc512x/fec.c index 675b7a2..c226a8a 100644 --- a/cpu/mpc512x/fec.c +++ b/cpu/mpc512x/fec.c @@ -299,7 +299,7 @@ int mpc512x_fec_init_phy (struct eth_device *dev, bd_t * bis) * Set MII_SPEED = (1/(mii_speed * 2)) * System Clock * and do not drop the Preamble. */ - fec->eth->mii_speed = (((gd->ipb_clk / 1000000) / 5) + 1) << 1; + fec->eth->mii_speed = (((gd->ips_clk / 1000000) / 5) + 1) << 1;
/* * Reset PHY, then delay 300ns diff --git a/cpu/mpc512x/i2c.c b/cpu/mpc512x/i2c.c index 00e28d6..56ba443 100644 --- a/cpu/mpc512x/i2c.c +++ b/cpu/mpc512x/i2c.c @@ -236,7 +236,7 @@ static int mpc_get_fdr (int speed) if (fdr == -1) { ulong best_speed = 0; ulong divider; - ulong ipb, scl; + ulong ips, scl; ulong bestmatch = 0xffffffffUL; int best_i = 0, best_j = 0, i, j; int SCL_Tap[] = { 9, 10, 12, 15, 5, 6, 7, 8}; @@ -251,18 +251,18 @@ static int mpc_get_fdr (int speed) {126, 128} };
- ipb = gd->ipb_clk; + ips = gd->ips_clk; for (i = 7; i >= 0; i--) { for (j = 7; j >= 0; j--) { scl = 2 * (scltap[j].scl2tap + (SCL_Tap[i] - 1) * scltap[j].tap2tap + 2); - if (ipb <= speed*scl) { - if ((speed*scl - ipb) < bestmatch) { - bestmatch = speed*scl - ipb; + if (ips <= speed*scl) { + if ((speed*scl - ips) < bestmatch) { + bestmatch = speed*scl - ips; best_i = i; best_j = j; - best_speed = ipb/scl; + best_speed = ips/scl; } } } diff --git a/cpu/mpc512x/serial.c b/cpu/mpc512x/serial.c index 200ff2c..8a21404 100644 --- a/cpu/mpc512x/serial.c +++ b/cpu/mpc512x/serial.c @@ -86,7 +86,7 @@ int serial_init(void) psc->mode = PSC_MODE_1_STOPBIT;
/* calculate dividor for setting PSC CTUR and CTLR registers */ - baseclk = (gd->ipb_clk + 8) / 16; + baseclk = (gd->ips_clk + 8) / 16; div = (baseclk + (gd->baudrate / 2)) / gd->baudrate;
psc->ctur = (div >> 8) & 0xff; diff --git a/cpu/mpc512x/speed.c b/cpu/mpc512x/speed.c index a609827..99e3495 100644 --- a/cpu/mpc512x/speed.c +++ b/cpu/mpc512x/speed.c @@ -96,7 +96,7 @@ int get_clocks (void) ips_clk = 0; }
- gd->ipb_clk = ips_clk; + gd->ips_clk = ips_clk; gd->csb_clk = csb_clk; gd->cpu_clk = core_clk; gd->bus_clk = csb_clk; @@ -118,7 +118,7 @@ int do_clocks (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) printf ("Clock configuration:\n"); printf (" CPU: %4d MHz\n", gd->cpu_clk / 1000000); printf (" Coherent System Bus: %4d MHz\n", gd->csb_clk / 1000000); - printf (" IPS Bus: %4d MHz\n", gd->ipb_clk / 1000000); + printf (" IPS Bus: %4d MHz\n", gd->ips_clk / 1000000); printf (" DDR: %4d MHz\n", 2 * gd->csb_clk / 1000000); return 0; } diff --git a/include/asm-ppc/global_data.h b/include/asm-ppc/global_data.h index 05aee74..46bc0b2 100644 --- a/include/asm-ppc/global_data.h +++ b/include/asm-ppc/global_data.h @@ -86,7 +86,7 @@ typedef struct global_data { unsigned long pci_clk; #endif #if defined(CONFIG_MPC512X) - u32 ipb_clk; + u32 ips_clk; u32 csb_clk; #endif /* CONFIG_MPC512X */ #if defined(CONFIG_MPC8220) diff --git a/lib_ppc/board.c b/lib_ppc/board.c index 207cf36..f6b8bdc 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -556,7 +556,7 @@ void board_init_f (ulong bootflag) bd->bi_vco = gd->vco_out; #endif /* CONFIG_CPM2 */ #if defined(CONFIG_MPC512X) - bd->bi_ipsfreq = gd->ipb_clk; + bd->bi_ipsfreq = gd->ips_clk; #endif /* CONFIG_MPC512X */ #if defined(CONFIG_MPC5xxx) bd->bi_ipbfreq = gd->ipb_clk;
Applied, thanks.
Applied, thanks.
Applied, thanks.
Grzegorz Bernacki
