[PATCH] net: gem: Reduce timeout of mdio phy idle status check
Timeout for checking mdio phy idle status is 20seconds. In case of errors this timeout will be too much. Reduce it to 100ms.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/net/zynq_gem.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index c309c3c95499..033021f1cbfc 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -110,6 +110,8 @@
#define ZYNQ_GEM_DCFG_DBG6_DMA_64B BIT(23)
+#define MDIO_IDLE_TIMEOUT_MS 100 + /* Use MII register 1 (MII status register) to detect PHY */ #define PHY_DETECT_REG 1
@@ -225,7 +227,7 @@ static int phy_setup_op(struct zynq_gem_priv *priv, u32 phy_addr, u32 regnum, int err;
err = wait_for_bit_le32(®s->nwsr, ZYNQ_GEM_NWSR_MDIOIDLE_MASK, - true, 20000, false); + true, MDIO_IDLE_TIMEOUT_MS, false); if (err) return err;
@@ -238,7 +240,7 @@ static int phy_setup_op(struct zynq_gem_priv *priv, u32 phy_addr, u32 regnum, writel(mgtcr, ®s->phymntnc);
-- 2.33.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Michal Simek
Ramon Fried
