[U-Boot] PSCI for H3
Hi everyone,
I got my Orange Pi PC booting U-boot now, using Hans' sunxi-wip branch that includes Jens' patches.
For PSCI and SMP, it seems the H3 follows the structure of previous sun8i SoCs. The CPUCFG registers line up. The manual doesn't have the PRCM, so I'll have to dig through the SDK.
One other thing is the SMTA, or Secure Memory Touch Arbiter, which we last encountered issues with on the A31s. This controls non-secure access to a whole bunch of peripherals, which we'll need to enable for Linux to run non-secure.
Anyway, this is just a preliminary evaluation of the work needed for PSCI. Nothing has actually been done or tested.
Regards ChenYu
Hi everyone,
(Resent with my correct email address...)
Regards ChenYu
On 16/11/15 07:26, Chen-Yu Tsai wrote:
Hi everyone,
There is also register 0x2f0 in the CCU, it defaults to disabling non-secure access to all clock registers.
Jens
Hi everyone,
Jens
How about just enabling SMP on Allwinner H3 in an old unfashionable way while all these non-secure access limiters are still being under investigation?
diff --git a/arch/arm/boot/dts/sun8i-h3.dtsi b/arch/arm/boot/dts/sun8i-h3.dtsi index 0faa38a..d23ed84 100644 --- a/arch/arm/boot/dts/sun8i-h3.dtsi +++ b/arch/arm/boot/dts/sun8i-h3.dtsi @@ -51,6 +51,7 @@ cpus { #address-cells = <1>; #size-cells = <0>; + enable-method = "allwinner,sun6i-a31";
cpu@0 { compatible = "arm,cortex-a7"; @@ -591,5 +592,15 @@ interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; }; + + prcm@01f01400 { + compatible = "allwinner,sun8i-h3-prcm"; + reg = <0x01f01400 0x200>; + }; + + cpucfg@01f01c00 { + compatible = "allwinner,sun8i-h3-cpuconfig"; + reg = <0x01f01c00 0x300>; + }; }; }; diff --git a/arch/arm/mach-sunxi/platsmp.c b/arch/arm/mach-sunxi/platsmp.c index e8483ec..8ca4064 100644 --- a/arch/arm/mach-sunxi/platsmp.c +++ b/arch/arm/mach-sunxi/platsmp.c @@ -44,6 +44,9 @@ static void __init sun6i_smp_prepare_cpus(unsigned int max_cpus) struct device_node *node;
node = of_find_compatible_node(NULL, NULL, "allwinner,sun6i-a31-prcm"); + if (!node) + node = of_find_compatible_node(NULL, NULL, + "allwinner,sun8i-h3-prcm"); if (!node) { pr_err("Missing A31 PRCM node in the device tree\n"); return; @@ -57,6 +60,9 @@ static void __init sun6i_smp_prepare_cpus(unsigned int max_cpus)
node = of_find_compatible_node(NULL, NULL, "allwinner,sun6i-a31-cpuconfig"); + if (!node) + node = of_find_compatible_node(NULL, NULL, + "allwinner,sun8i-h3-cpuconfig"); if (!node) { pr_err("Missing A31 CPU config node in the device tree\n"); return;
On Wed, Dec 23, 2015 at 6:14 PM, Siarhei Siamashka siarhei.siamashka@gmail.com wrote:
Hi everyone,
Jens
I'm not against it, though I was considering removing the SMP code.
BTW, without docs on the PRCM, do we know if the H3 has the same power clamps as the A31? FYI the A23 SMP code is the same as A31, just without the power clamps.
Thanks ChenYu
enable-method = "allwinner,sun6i-a31"; cpu@0 { compatible = "arm,cortex-a7";
prcm@01f01400 {
cpucfg@01f01c00 {
if (!node)
if (!node)
-- 2.4.10
-- Best regards, Siarhei Siamashka
Hi everyone,
Jens
Yes. I inspected the kernel sources from the Allwinner SDK and it looks like A31 and H3 are taking exactly the same code path (using the same ifdef guards everywhere): https://github.com/allwinner-zh/linux-3.4-sunxi/blob/55599b8209bb7150140e4d4...
"SUN8IW1 = A31" and "SUN8IW7 = H3" according to http://linux-sunxi.org/Allwinner_SoC_Family#2013_naming_scheme_change
I'll also try to see if I can get PSCI working on H3, but it seems to be a real PITA to debug. Also some parts of the H3 documentation are missing (PRCM is a good example) and if there happens to be an undocumented configuration knob responsible to allowing non-secure access to some important resource, then we hit a brick wall...
Hi everyone,
Jens
I'd really prefer not to.
This ends up being dead code that no-one uses, but we can't really remove. Adding support for the H3 support would only delay that removal once again.
What controller are you having issues accessing?
Thanks, Maxime
On Mon, Dec 28, 2015 at 1:16 AM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
Hi everyone,
Jens
So I finished H3 PSCI support. For the moment everything seems to work. Though given the limited number of peripherals supported and used, that may not be complete.
For now the patches are available at
https://github.com/wens/u-boot-sunxi/tree/h3-psci
I'll find some time to post them.
Regards ChenYu
participants (5)
Chen-Yu Tsai
Jens Kuske
Maxime Ripard
Siarhei Siamashka
wens Tsai
