[U-Boot] [PATCH v2 1/2] Kconfig: Migrate CONFIG_BUILD_TARGET
Migrate CONFIG_BUILD_TARGET into Kconfig.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - build target type 'u-boot.itb' when SPL_LOAD_FIT being used
Kconfig | 13 +++++++++++++ README | 7 ------- arch/arm/mach-mvebu/include/mach/config.h | 5 ----- configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/ib62x0_defconfig | 1 + configs/nsa310s_defconfig | 1 + configs/sheevaplug_defconfig | 1 + include/configs/SBx81LIFKW.h | 1 - include/configs/SBx81LIFXCAT.h | 1 - include/configs/ib62x0.h | 3 --- include/configs/mv-plug-common.h | 3 --- include/configs/nsa310s.h | 3 --- include/configs/rcar-gen3-common.h | 1 - include/configs/socfpga_common.h | 3 --- include/configs/sunxi-common.h | 1 - scripts/config_whitelist.txt | 1 - 20 files changed, 21 insertions(+), 29 deletions(-)
diff --git a/Kconfig b/Kconfig index aff7b2e00a..15b79259a8 100644 --- a/Kconfig +++ b/Kconfig @@ -224,6 +224,19 @@ config BUILD_ROM which are not shipped in the U-Boot source tree. Please, see doc/README.x86 for details.
+config BUILD_TARGET + string "Build target special images" + default "u-boot-with-spl.sfp" if ARCH_SOCFPGA + default "u-boot-spl.kwb" if ARCH_MVEBU && SPL_BUILD + default "u-boot-elf.srec" if RCAR_GEN3 + default "u-boot.itb" if SPL_LOAD_FIT && ARCH_SUNXI + help + Some SoCs need special image types (e.g. U-Boot binary + with a special header) as build targets. By defining + CONFIG_BUILD_TARGET in the SoC / board header, this + special image will be automatically built upon calling + make / buildman. + endmenu # General setup
menu "Boot images" diff --git a/README b/README index 17d56b8034..01ad69e926 100644 --- a/README +++ b/README @@ -1998,13 +1998,6 @@ The following options need to be configured: 200 ms.
- Configuration Management: - CONFIG_BUILD_TARGET - - Some SoCs need special image types (e.g. U-Boot binary - with a special header) as build targets. By defining - CONFIG_BUILD_TARGET in the SoC / board header, this - special image will be automatically built upon calling - make / buildman.
CONFIG_IDENT_STRING
diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index f165d10018..e3235fc67e 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -40,11 +40,6 @@ #define CONFIG_SYS_KWD_CONFIG arch/arm/mach-mvebu/kwbimage.cfg #endif /* CONFIG_SYS_KWD_CONFIG */
-/* Add target to build it automatically upon "make" */ -#ifdef CONFIG_SPL -#define CONFIG_BUILD_TARGET "u-boot-spl.kwb" -#endif - /* end of 16M scrubbed by training in bootrom */ #define CONFIG_SYS_INIT_SP_ADDR 0x00FF0000
diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index e0ce1595c5..52bb70ae8c 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SBx81LIFKW=y CONFIG_IDENT_STRING="\nSBx81LIFKW" # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_MISC_INIT_R=y diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 4a6e05844f..b322ab0959 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SBx81LIFXCAT=y CONFIG_IDENT_STRING="\nSBx81LIFXCAT" # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_MISC_INIT_R=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index d3263cf9cd..762521f97d 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING="\nMarvell-DreamPlug" CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 352403e573..b72174eada 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_DS109=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set CONFIG_HUSH_PARSER=y +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_CMD_FLASH is not set CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 9998e48ab9..7726f9a769 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING="\nMarvell-GuruPlug" CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 985d85e027..03987a4ff1 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_IB62X0=y CONFIG_IDENT_STRING=" RaidSonic ICY BOX IB-NAS62x0" CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ib62x0 => " diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index eb29a70157..971d33b33d 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NSA310S=y CONFIG_NR_DRAM_BANKS=2 CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="nsa310s => " diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 04b00cdea9..33cced9c48 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -7,6 +7,7 @@ CONFIG_IDENT_STRING="\nMarvell-Sheevaplug" CONFIG_NR_DRAM_BANKS=2 # CONFIG_SYS_MALLOC_F is not set CONFIG_BOOTDELAY=3 +CONFIG_BUILD_TARGET="u-boot.kwb" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index 07b65f89f9..d62fd35e81 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -13,7 +13,6 @@ #define CONFIG_KW88F6281 1 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg -#define CONFIG_BUILD_TARGET "u-boot.kwb"
/* additions for new ARM relocation support */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index d73752c7f9..3c8c216d89 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -13,7 +13,6 @@ #define CONFIG_KW88F6281 1 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ #define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg -#define CONFIG_BUILD_TARGET "u-boot.kwb"
/* additions for new ARM relocation support */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index f8d3c3b63f..5e54441c73 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -15,9 +15,6 @@ #define CONFIG_KW88F6281 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
-/* Add target to build it automatically upon "make" */ -#define CONFIG_BUILD_TARGET "u-boot.kwb" - /* * Compression configuration */ diff --git a/include/configs/mv-plug-common.h b/include/configs/mv-plug-common.h index f424e2cc6c..486650f183 100644 --- a/include/configs/mv-plug-common.h +++ b/include/configs/mv-plug-common.h @@ -13,9 +13,6 @@ #define CONFIG_KW88F6281 1 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
-/* Add target to build it automatically upon "make" */ -#define CONFIG_BUILD_TARGET "u-boot.kwb" - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 1ca9a01754..eb465e0690 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -15,9 +15,6 @@ #define CONFIG_KW88F6702 1 /* SOC Name */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
-/* add target to build it automatically upon "make" */ -#define CONFIG_BUILD_TARGET "u-boot.kwb" - /* compression configuration */ #define CONFIG_BZIP2
diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 6c2fa6a63c..06d5d3219c 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -12,7 +12,6 @@ #include <asm/arch/rmobile.h>
#define CONFIG_REMAKE_ELF -#define CONFIG_BUILD_TARGET "u-boot-elf.srec"
/* boot option */
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index bd8f5c8c41..d3dd2eabac 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -14,9 +14,6 @@
#define CONFIG_TIMESTAMP /* Print image info with timestamp */
-/* add target to build it automatically upon "make" */ -#define CONFIG_BUILD_TARGET "u-boot-with-spl.sfp" - /* * Memory configurations */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 9819d9980c..f0c8daad72 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -32,7 +32,6 @@ #endif
#ifdef CONFIG_ARM64 -#define CONFIG_BUILD_TARGET "u-boot.itb" #define CONFIG_SYS_BOOTM_LEN (32 << 20) #endif
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 527050de97..17c4b482c7 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -181,7 +181,6 @@ CONFIG_BS_SIZE CONFIG_BTB CONFIG_BUFNO_AUTO_INCR_BIT CONFIG_BUILD_ENVCRC -CONFIG_BUILD_TARGET CONFIG_BUS_WIDTH CONFIG_BZIP2 CONFIG_CADDY2
Tom or anyone,
On Fri, Jan 18, 2019 at 12:53 PM Jagan Teki jagan@amarulasolutions.com wrote:
Any comments, if all OK. then these would be good go.
On Fri, Feb 01, 2019 at 10:06:31PM +0530, Jagan Teki wrote:
Tom or anyone,
I'm reviewing this now along with 2/2 and the kirkwood patch.
Hi Jagan,
I've just tried this out on x530 and db-88f6820-amc (both ARCH_MVEBU).
<snip>
It looks like this doesn't work as expected. Perhaps because SPL_BUILD is a bit special. Should this hang of CONFIG_SPL or CONFIG_SUPPORT_SPL instead?
help
make / buildman.
Hi Chris,
On 11.02.19 02:11, Chris Packham wrote:
Hi Jagan,
<snip>
Baruch already spotted this problem and did send a patch to fix this issue:
http://patchwork.ozlabs.org/patch/1037973/
Seems to be identical to yours I'll pick it up quickly to fix this build problem.
Thanks, Stefan
On Mon, Feb 11, 2019 at 7:06 PM Stefan Roese sr@denx.de wrote:
Hi Chris,
Hi Jagan,
<snip>
OK thanks. I didn't search before sending. I've marked my patch as superseded in patchwork.
Chris Packham
Jagan Teki
Stefan Roese
