[U-Boot] [PATCH v2] ls1021a: QSPI: update the node for QSPI support
Add the name for register space and memory space. <0x1550000 0x10000 > is the QSPI register space. <0x40000000 0x4000000> is the QSPI memory space.
Signed-off-by: Yuan Yao yao.yuan@nxp.com --- Changed in v2: Updated the commit message. --- arch/arm/dts/ls1021a.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/ls1021a.dtsi b/arch/arm/dts/ls1021a.dtsi index 119b1af..37be169 100644 --- a/arch/arm/dts/ls1021a.dtsi +++ b/arch/arm/dts/ls1021a.dtsi @@ -176,6 +176,7 @@ #size-cells = <0>; reg = <0x1550000 0x10000>, <0x40000000 0x4000000>; + reg-names = "QuadSPI", "QuadSPI-memory"; num-cs = <2>; big-endian; status = "disabled";
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
york sun
Yuan Yao
