[U-Boot] [RFC PATCH] SPL: allow fall-back to SDP boot
When SDP is enabled, allow it to be invoked as a fall-back to allow re-programming a board with a full U-Boot loaded over USB.
Signed-off-by: Eric Nelson eric@nelint.com --- Since SDP loading is triggered through BOOT_DEVICE_BOARD, I'm not sure if this should be specific to SDP.
common/spl/spl.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 76c1963..5bbd4ed 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -373,6 +373,9 @@ static int boot_from_devices(struct spl_image_info *spl_image,
void board_init_r(gd_t *dummy1, ulong dummy2) { +#ifdef CONFIG_SPL_USB_SDP_SUPPORT + int i; +#endif u32 spl_boot_list[] = { BOOT_DEVICE_NONE, BOOT_DEVICE_NONE, @@ -417,6 +420,15 @@ void board_init_r(gd_t *dummy1, ulong dummy2) #endif board_boot_order(spl_boot_list);
+#ifdef CONFIG_SPL_USB_SDP_SUPPORT + for (i = 0; i < ARRAY_SIZE(spl_boot_list); i++) { + if (spl_boot_list[i] == BOOT_DEVICE_NONE) { + spl_boot_list[i] = BOOT_DEVICE_BOARD; + break; + } + } +#endif + if (boot_from_devices(&spl_image, spl_boot_list, ARRAY_SIZE(spl_boot_list))) { puts("SPL: failed to boot from all boot devices\n");
Eric Nelson
