[U-Boot] [PATCH] powerpc/85xx: Fix SRIO LAW setup on corenet_ds boards
In funciton board_early_init_r(), serdes does not initialize yet. variable "serdes_prtcl_map" in function is_serdes_configured() does not initialize. sRIO will always be disable.
In the original code, there is a undefined variable gur if SRIO is not defined.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com Signed-off-by: Lian Minghuan B31939@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/corenet_ds/corenet_ds.c | 47 ++++++++++++++++-------------- 1 files changed, 25 insertions(+), 22 deletions(-)
diff --git a/board/freescale/corenet_ds/corenet_ds.c b/board/freescale/corenet_ds/corenet_ds.c index 3cdefb3..48d95d6 100644 --- a/board/freescale/corenet_ds/corenet_ds.c +++ b/board/freescale/corenet_ds/corenet_ds.c @@ -23,6 +23,7 @@ #include <common.h> #include <command.h> #include <netdev.h> +#include <linux/compiler.h> #include <asm/mmu.h> #include <asm/processor.h> #include <asm/cache.h> @@ -120,28 +121,6 @@ int board_early_init_r(void) set_liodns(); setup_portals();
-#ifdef CONFIG_SRIO1 - if (is_serdes_configured(SRIO1)) { - set_next_law(CONFIG_SYS_RIO1_MEM_PHYS, LAW_SIZE_256M, - LAW_TRGT_IF_RIO_1); - } else { - printf (" SRIO1: disabled\n"); - } -#else - setbits_be32(&gur->devdisr, FSL_CORENET_DEVDISR_SRIO1); /* disable */ -#endif - -#ifdef CONFIG_SRIO2 - if (is_serdes_configured(SRIO2)) { - set_next_law(CONFIG_SYS_RIO2_MEM_PHYS, LAW_SIZE_256M, - LAW_TRGT_IF_RIO_2); - } else { - printf (" SRIO2: disabled\n"); - } -#else - setbits_be32(&gur->devdisr, FSL_CORENET_DEVDISR_SRIO2); /* disable */ -#endif - return 0; }
@@ -164,10 +143,34 @@ static const char *serdes_clock_to_string(u32 clock) int misc_init_r(void) { serdes_corenet_t *srds_regs = (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; + __maybe_unused ccsr_gur_t *gur; u32 actual[NUM_SRDS_BANKS]; unsigned int i; u8 sw3;
+ gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); +#ifdef CONFIG_SRIO1 + if (is_serdes_configured(SRIO1)) { + set_next_law(CONFIG_SYS_RIO1_MEM_PHYS, LAW_SIZE_256M, + LAW_TRGT_IF_RIO_1); + } else { + printf (" SRIO1: disabled\n"); + } +#else + setbits_be32(&gur->devdisr, FSL_CORENET_DEVDISR_SRIO1); /* disable */ +#endif + +#ifdef CONFIG_SRIO2 + if (is_serdes_configured(SRIO2)) { + set_next_law(CONFIG_SYS_RIO2_MEM_PHYS, LAW_SIZE_256M, + LAW_TRGT_IF_RIO_2); + } else { + printf (" SRIO2: disabled\n"); + } +#else + setbits_be32(&gur->devdisr, FSL_CORENET_DEVDISR_SRIO2); /* disable */ +#endif + /* Warn if the expected SERDES reference clocks don't match the * actual reference clocks. This needs to be done after calling * p4080_erratum_serdes8(), since that function may modify the clocks.
Dear Kumar Gala,
In message 1282139990-17758-1-git-send-email-galak@kernel.crashing.org you wrote:
Please fix the typos when applying. Thanks.
On Aug 18, 2010, at 9:21 AM, Wolfgang Denk wrote:
Dear Kumar Gala,
applied and fixed commit message.
- k
Kumar Gala
