[U-Boot] [PATCH v1] net: use block layer in net driver
At present the MMC subsystem maintains its own list of MMC devices. This cannot work with driver model when CONFIG_BLK is enabled, use blk_dread to replace previous mmc read interface,
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- drivers/net/phy/cortina.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/phy/cortina.c b/drivers/net/phy/cortina.c index a04a118f90..2337c3403c 100644 --- a/drivers/net/phy/cortina.c +++ b/drivers/net/phy/cortina.c @@ -176,7 +176,7 @@ void cs4340_upload_firmware(struct phy_device *phydev) printf("MMC read: dev # %u, block # %u, count %u ...\n", dev, blk, cnt); mmc_init(mmc); - (void)mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, + (void)blk_dread(mmc_get_blk_desc(mmc), blk, cnt, addr); } #endif
Should this be switching on CONFIG_BLK or CONFIG_DM_MMC or something.
#endif
2.17.1
On Thu, May 9, 2019 at 3:02 PM Joe Hershberger joe.hershberger@gmail.com wrote:
Any word?
#endif
2.17.1
-----Original Message----- From: Joe Hershberger [mailto:joe.hershberger@gmail.com] Sent: 2019年6月1日 19:16 To: Yinbo Zhu yinbo.zhu@nxp.com Cc: York Sun york.sun@nxp.com; u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Ran Wang ran.wang_1@nxp.com Subject: [EXT] Re: [U-Boot] [PATCH v1] net: use block layer in net driver
Caution: EXT Email
*phydev)
cnt,
Any word?
Yes, need enable above two config. And default uboot had enabled them.
Regards, Yinbo
#endif
2.17.1
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fli
sts.denx.de%2Flistinfo%2Fu-boot&data=02%7C01%7Cyinbo.zhu%40nxp.c
om%7Cf4dd39cb85174bb474e208d6e682980b%7C686ea1d3bc2b4c6fa92cd9 9c5c30
1635%7C0%7C1%7C636949845952441371&sdata=PJGcNYuSLsAndJaGTBe khmEN
sad96LwmV92jLec5mrs%3D&reserved=0
Caution: EXT Email
*phydev)
cnt,
Any word?
OK, if this depends on them, even if they are default, this block should check for the option in v2. Also, if there is still a use-case for the "mmc->block_dev.block_read" that exists with different or fewer options, then that could also be a config option instead of replaced.
Thanks, -Joe
Regards, Yinbo
#endif
2.17.1
-----Original Message----- From: Joe Hershberger [mailto:joe.hershberger@gmail.com] Sent: 2019年6月10日 23:41 To: Yinbo Zhu yinbo.zhu@nxp.com Cc: York Sun york.sun@nxp.com; u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Jiafei Pan jiafei.pan@nxp.com; Ran Wang ran.wang_1@nxp.com; Y.b. Lu yangbo.lu@nxp.com Subject: Re: [EXT] Re: [U-Boot] [PATCH v1] net: use block layer in net driver
Caution: EXT Email
Caution: EXT Email
*phydev)
count %u ...\n",
blk,
cnt,
something.
Any word?
Thanks, -Joe
Hi joe,
In fact, above change is only depend on BLK config, I have mistake about previous word, and I will apply your advice send v3 patch to upstream.
Yinbo
Regards, Yinbo
#endif
2.17.1
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F% 2Fli
9c5c30
khmEN
Joe Hershberger
Yinbo Zhu
