[U-Boot] [PATCH 0/2] fix build error for pantheon and armada100
For the CONFIG_SYS_CACHELINE_SIZE is required to be defined defaultly. Add it to pantheon and armada100 accordingly.
Lei Wen (2): pantheon: define CONFIG_SYS_CACHELINE_SIZE armada100: define CONFIG_SYS_CACHELINE_SIZE
arch/arm/include/asm/arch-armada100/config.h | 2 ++ arch/arm/include/asm/arch-pantheon/config.h | 2 ++ 2 files changed, 4 insertions(+), 0 deletions(-)
By default, on Pantheon SoC DCache Lnd ICache line lengths are 32 bytes long
Signed-off-by: Lei Wen leiwen@marvell.com --- arch/arm/include/asm/arch-pantheon/config.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-pantheon/config.h b/arch/arm/include/asm/arch-pantheon/config.h index d10583d..e4fce7d 100644 --- a/arch/arm/include/asm/arch-pantheon/config.h +++ b/arch/arm/include/asm/arch-pantheon/config.h @@ -28,6 +28,8 @@ #include <asm/arch/pantheon.h>
#define CONFIG_ARM926EJS 1 /* Basic Architecture */ +/* default Dcache Line length for pantheon */ +#define CONFIG_SYS_CACHELINE_SIZE 32
#define CONFIG_SYS_TCLK (14745600) /* NS16550 clk config */ #define CONFIG_SYS_HZ_CLOCK (3250000) /* Timer Freq. 3.25MHZ */
-----Original Message----- From: Lei Wen [mailto:leiwen@marvell.com] Sent: Monday, October 31, 2011 8:36 PM To: Prafulla Wadaskar; u-boot@lists.denx.de Subject: [PATCH 1/2] pantheon: define CONFIG_SYS_CACHELINE_SIZE
Applied to u-boot-marvell.git master branch
Regards.. Prafulla . . .
By default, on Armada100 SoC DCache Lnd ICache line lengths are 32 bytes long
Signed-off-by: Lei Wen leiwen@marvell.com --- arch/arm/include/asm/arch-armada100/config.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-armada100/config.h b/arch/arm/include/asm/arch-armada100/config.h index d2094e5..637f313 100644 --- a/arch/arm/include/asm/arch-armada100/config.h +++ b/arch/arm/include/asm/arch-armada100/config.h @@ -33,6 +33,8 @@
#include <asm/arch/armada100.h> #define CONFIG_ARM926EJS 1 /* Basic Architecture */ +/* default Dcache Line length for armada100 */ +#define CONFIG_SYS_CACHELINE_SIZE 32
-----Original Message----- From: Lei Wen [mailto:leiwen@marvell.com] Sent: Monday, October 31, 2011 8:36 PM To: Prafulla Wadaskar; u-boot@lists.denx.de Subject: [PATCH 2/2] armada100: define CONFIG_SYS_CACHELINE_SIZE
Lei Wen
Prafulla Wadaskar
