Re: [PATCH] riscv: timer: Add support for an early timer
Hi Pragnesh,
From: Pragnesh Patel [mailto:pragnesh.patel@sifive.com] Sent: Tuesday, November 17, 2020 7:05 PM To: u-boot@lists.denx.de Cc: atish.patra@wdc.com; palmerdabbelt@google.com; bmeng.cn@gmail.com; paul.walmsley@sifive.com; anup.patel@wdc.com; sagar.kadam@sifive.com; Rick Jian-Zhi Chen(陳建志); Pragnesh Patel; Palmer Dabbelt; Sean Anderson; Simon Glass; Bin Meng Subject: [PATCH] riscv: timer: Add support for an early timer
Added support for timer_early_get_count() and timer_early_get_rate() This is mostly useful in tracing.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com
drivers/timer/andes_plmt_timer.c | 21 ++++++++++++++++++++- drivers/timer/riscv_timer.c | 21 ++++++++++++++++++++- drivers/timer/sifive_clint_timer.c | 21 ++++++++++++++++++++- include/configs/ax25-ae350.h | 5 +++++ include/configs/sifive-fu540.h | 5 +++++ 5 files changed, 70 insertions(+), 3 deletions(-)
I verify with ae350_rv64_defconfig
make FTRACE=1 ae350_rv64_defconfig make FTRACE=1
and it boot fail as below:
U-Boot 2021.01-rc2-00140-geb42715 (Nov 24 2020 - 15:02:18 +0800)
DRAM: 1 GiB trace: enabled
DO you have any suggestions ?
Thanks, Rick
diff --git a/drivers/timer/andes_plmt_timer.c b/drivers/timer/andes_plmt_timer.c index cec86718c7..74b795c97a 100644 --- a/drivers/timer/andes_plmt_timer.c +++ b/drivers/timer/andes_plmt_timer.c @@ -17,11 +17,30 @@ /* mtime register */ #define MTIME_REG(base) ((ulong)(base))
-static u64 andes_plmt_get_count(struct udevice *dev) +static u64 notrace andes_plmt_get_count(struct udevice *dev) { return readq((void __iomem *)MTIME_REG(dev->priv)); }
+#if CONFIG_IS_ENABLED(RISCV_MMODE) +/**
- timer_early_get_rate() - Get the timer rate before driver model
+unsigned long notrace timer_early_get_rate(void) +{
return RISCV_MMODE_TIMER_FREQ;
- timer_early_get_count() - Get the timer count before driver model
+u64 notrace timer_early_get_count(void) +{
return readq((void __iomem *)MTIME_REG(RISCV_MMODE_TIMERBASE));
+} +#endif
static const struct timer_ops andes_plmt_ops = { .get_count = andes_plmt_get_count, }; diff --git a/drivers/timer/riscv_timer.c b/drivers/timer/riscv_timer.c index 21ae184057..a0f71ca897 100644 --- a/drivers/timer/riscv_timer.c +++ b/drivers/timer/riscv_timer.c @@ -16,7 +16,7 @@ #include <timer.h> #include <asm/csr.h>
-static u64 riscv_timer_get_count(struct udevice *dev) +static u64 notrace riscv_timer_get_count(struct udevice *dev) { __maybe_unused u32 hi, lo;
@@ -31,6 +31,25 @@ static u64 riscv_timer_get_count(struct udevice *dev) return ((u64)hi << 32) | lo; }
+#if CONFIG_IS_ENABLED(RISCV_SMODE) +/**
return RISCV_SMODE_TIMER_FREQ;
return riscv_timer_get_count(NULL);
+} +#endif
static int riscv_timer_probe(struct udevice *dev) { struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); diff --git a/drivers/timer/sifive_clint_timer.c b/drivers/timer/sifive_clint_timer.c index 00ce0f08d6..9ae05a0e7e 100644 --- a/drivers/timer/sifive_clint_timer.c +++ b/drivers/timer/sifive_clint_timer.c @@ -14,11 +14,30 @@ /* mtime register */ #define MTIME_REG(base) ((ulong)(base) + 0xbff8)
-static u64 sifive_clint_get_count(struct udevice *dev) +static u64 notrace sifive_clint_get_count(struct udevice *dev) { return readq((void __iomem *)MTIME_REG(dev->priv)); }
+} +#endif
static const struct timer_ops sifive_clint_ops = { .get_count = sifive_clint_get_count, }; diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index b2606e794d..bd9c371f83 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -17,6 +17,11 @@ #endif #endif
+#define RISCV_MMODE_TIMERBASE 0xe6000000 +#define RISCV_MMODE_TIMER_FREQ 60000000
+#define RISCV_SMODE_TIMER_FREQ 60000000
- CPU and Board Configuration Options
*/ diff --git a/include/configs/sifive-fu540.h b/include/configs/sifive-fu540.h index c1c79db147..0d69d1c548 100644 --- a/include/configs/sifive-fu540.h +++ b/include/configs/sifive-fu540.h @@ -36,6 +36,11 @@
#define CONFIG_STANDALONE_LOAD_ADDR 0x80200000
+#define RISCV_MMODE_TIMERBASE 0x2000000 +#define RISCV_MMODE_TIMER_FREQ 1000000
+#define RISCV_SMODE_TIMER_FREQ 1000000
/* Environment options */
#ifndef CONFIG_SPL_BUILD
2.17.1
Hi Rick,
-----Original Message----- From: Rick Chen rickchen36@gmail.com Sent: 24 November 2020 13:08 To: Pragnesh Patel pragnesh.patel@openfive.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Atish Patra atish.patra@wdc.com; Bin Meng bmeng.cn@gmail.com; Paul Walmsley ( Sifive) paul.walmsley@sifive.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@openfive.com; Palmer Dabbelt palmer@dabbelt.com; Simon Glass sjg@chromium.org; rick rick@andestech.com; Alan Kao alankao@andestech.com; Leo Liang ycliang@andestech.com Subject: Re: [PATCH] riscv: timer: Add support for an early timer
[External Email] Do not click links or attachments unless you recognize the sender and know the content is safe
Hi Pragnesh,
bmeng.cn@gmail.com;
Please enable CONFIG_TIMER_EARLY=y in ae350_rv64_defconfig
Actually in v2, I will make TRACE to select TIMER_EARLY like below,
--- a/lib/Kconfig +++ b/lib/Kconfig @@ -210,6 +210,7 @@ config BITREVERSE config TRACE bool "Support for tracing of function calls and timing" imply CMD_TRACE + select TIMER_EARLY
Let me know if you have any suggestion.
Thanks, Rick
+*/ unsigned long notrace timer_early_get_rate(void) {
return RISCV_MMODE_TIMER_FREQ; }
+u64 notrace timer_early_get_count(void) {
+*)MTIME_REG(RISCV_MMODE_TIMERBASE)); +} +#endif
return RISCV_SMODE_TIMER_FREQ; }
return riscv_timer_get_count(NULL); } #endif
2.17.1
Hi Pragnesh
Hi Rick,
Hi Pragnesh,
bmeng.cn@gmail.com;
select TIMER_EARLY
OK.
After add CONFIG_TIMER_EARLY, U-Boot boots ok. But When I try to booting kernel with FTRACE=1, following are the test stats:
ae350_rv64_spl_defconfig without FTRACE=1, kernel booting is ok. ae350_rv64_spl_defconfig with FTRACE=1, kernel booting fail. ae350_rv64_defconfig with FTRACE=1, kernel booting is ok
The failure case seems not reasonable. Any suggestions ?
Thanks, Rick
Thanks, Rick
2.17.1
Hi Rick,
-----Original Message----- From: Rick Chen rickchen36@gmail.com Sent: 26 November 2020 14:44 To: Pragnesh Patel pragnesh.patel@openfive.com Cc: Simon Glass sjg@chromium.org; U-Boot Mailing List <u- boot@lists.denx.de>; Atish Patra atish.patra@wdc.com; Bin Meng bmeng.cn@gmail.com; Paul Walmsley ( Sifive) paul.walmsley@sifive.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@openfive.com; Palmer Dabbelt palmer@dabbelt.com; rick rick@andestech.com; Alan Kao alankao@andestech.com; Leo Liang ycliang@andestech.com Subject: Re: [PATCH] riscv: timer: Add support for an early timer
Hi Pragnesh
Hi Rick,
Hi Pragnesh,
bmeng.cn@gmail.com;
select TIMER_EARLY
OK.
Strange, Can you please tell me which steps you follow and also send some debug logs if possible.
Thanks, Rick
Thanks, Rick
+model
*dev)
+model
+model
2.17.1
Hi, Pragnesh
Hi Rick,
Hi Pragnesh
Hi Rick,
Hi Pragnesh,
bmeng.cn@gmail.com;
select TIMER_EARLY
OK.
Following are the configurations, steps and debug logs:
+++ b/configs/ae350_rv64_defconfig q+CONFIG_TRACE=y +CONFIG_TRACE_BUFFER_SIZE=0x01000000 +CONFIG_TRACE_CALL_DEPTH_LIMIT=15 +CONFIG_CMD_TRACE=y +CONFIG_TIMER_EARLY=y
+++ b/configs/ae350_rv64_spl_defconfig +CONFIG_TRACE=y +CONFIG_TRACE_BUFFER_SIZE=0x01000000 +CONFIG_TRACE_CALL_DEPTH_LIMIT=15 +CONFIG_CMD_TRACE=y +CONFIG_TIMER_EARLY=y
//////////////////////////////////////////////// case 1 /////////////////////////////////////////////////// ae350_rv64_defconfig with FTRACE=1, kernel booting is ok //////////////////////////////////////////////// case 1 /////////////////////////////////////////////////// make FTRACE=1 ae350_rv64_defconfig make FTRACE=1 /////////////////////////////////////////////////////////////////////////////////////////////////////////////// U-Boot 2021.01-rc2-00139-gb3d3d69-dirty (Nov 25 2020 - 11:14:28 +0800)
DRAM: 1 GiB trace: enabled Flash: 64 MiB MMC: mmc@f0e00000: 0 Loading Environment from SPIFlash... SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB OK In: serial@f0300000 Out: serial@f0300000 Err: serial@f0300000 Net: no alias for ethernet0 Warning: mac@e0100000 (eth0) using random MAC address - de:fa:3e:1b:11:42 eth0: mac@e0100000 Hit any key to stop autoboot: 0 RISC-V # fatload mmc 0:1 0x20000000 ae350_rv64_smp_4_no_fd_coherent.dtb 6455 bytes read in 67 ms (93.8 KiB/s) RISC-V # fatload mmc 0:1 0x00600000 bootm_ae350_rv64_smp_bbl.bin 22518836 bytes read in 11915 ms (1.8 MiB/s) RISC-V # bootm 0x00600000 - 0x20000000 ## Booting kernel from Legacy Image at 00600000 ... Image Name: Image Type: RISC-V Linux Kernel Image (uncompressed) Data Size: 22518772 Bytes = 21.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 20000000 Booting using the fdt blob at 0x20000000 Loading Kernel Image Loading Device Tree to 000000001effb000, end 000000001efff936 ... OK
Starting kernel ...(fake run for tracing)
Starting kernel ...
OF: fdt: Ignoring memory range 0x0 - 0x200000 Linux version 4.17.0-00253-g49136e10bcb2 (sqa@atcsqa07) (gcc version 7.3.0 (2019-04-06_nds64le-linux-glibc-v5_experimental)) #1 SMP PREEMPT Sat Apr 6 23:41:49 CST 2019 bootconsole [early0] enabled Initial ramdisk at: 0x (ptrval) (13665712 bytes) Zone ranges: DMA32 [mem 0x0000000000200000-0x000000003fffffff] Normal empty Movable zone start for each node Early memory node ranges ... ...
//////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// ae350_rv64_spl_defconfig with FTRACE=1, kernel booting fail //////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// make FTRACE=1 ae350_rv64_spl_defconfig make FTRACE=1 /////////////////////////////////////////////////////////////////////////////////////////////////////////////// U-Boot SPL 2020.10-rc2-00175-gfa50824 (Sep 15 2020 - 19:26:29 +0800) Trying to boot from MMC1 U-Boot SPL 2021.01-rc2-00139-gb3d3d69-dirty (Nov 25 2020 - 13:48:05 +0800) Trying to boot from RAM U-Boot 2021.01-rc2-00139-gb3d3d69-dirty (Nov 25 2020 - 13:48:05 +0800) DRAM: 1 GiB trace: enabled Flash: 64 MiB MMC: mmc@f0e00000: 0 Loading Environment from SPIFlash... SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB OK In: serial@f0300000 Out: serial@f0300000 Err: serial@f0300000 Net: no alias for ethernet0 Warning: mac@e0100000 (eth0) using random MAC address - 36:86:da:0f:8e:8d eth0: mac@e0100000 Hit any key to stop autoboot: 0 27689996 bytes read in 15024 ms (1.8 MiB/s) 6435 bytes read in 25 ms (251 KiB/s) ## Booting kernel from Legacy Image at 00600000 ... Image Name: Image Type: RISC-V Linux Kernel Image (uncompressed) Data Size: 27689932 Bytes = 26.4 MiB Load Address: 00200000 Entry Point: 00200000 Verifying Checksum ... OK ## Flattened Device Tree blob at 20000000 Booting using the fdt blob at 0x20000000 Loading Kernel Image Loading Device Tree to 000000001effb000, end 000000001efff922 ... OK
Starting kernel ...
(hang here)
//////////////////////////////////////////////// case 3 /////////////////////////////////////////////////// ae350_rv64_spl_defconfig without FTRACE=1, kernel booting ok //////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// make ae350_rv64_spl_defconfig make ///////////////////////////////////////////////////////////////////////////////////////////////////////////////
U-Boot SPL 2021.01-rc2-00139-gb3d3d69-dirty (Nov 25 2020 - 11:25:30 +0800) Trying to boot from RAM U-Boot 2021.01-rc2-00139-gb3d3d69-dirty (Nov 25 2020 - 11:25:30 +0800) DRAM: 1 GiB trace: enabled Flash: 64 MiB MMC: mmc@f0e00000: 0 Loading Environment from SPIFlash... SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB OK In: serial@f0300000 Out: serial@f0300000 Err: serial@f0300000 Net: no alias for ethernet0 Warning: mac@e0100000 (eth0) using random MAC address - 6a:1a:a0:e2:cc:d8 eth0: mac@e0100000 Hit any key to stop autoboot: 0 27689996 bytes read in 9333 ms (2.8 MiB/s) 6435 bytes read in 15 ms (418.9 KiB/s) ## Booting kernel from Legacy Image at 00600000 ... Image Name: Image Type: RISC-V Linux Kernel Image (uncompressed) Data Size: 27689932 Bytes = 26.4 MiB Load Address: 00200000 Entry Point: 00200000 Verifying Checksum ... OK ## Flattened Device Tree blob at 20000000 Booting using the fdt blob at 0x20000000 Loading Kernel Image Loading Device Tree to 000000001effb000, end 000000001efff922 ... OK
Starting kernel ...
[ 0.000000] OF: fdt: Ignoring memory range 0x0 - 0x200000 [ 0.000000] Linux version 5.4.0-00137-g5601822 (rick@atcsqa06) (gcc version 7.4.0 (2020-07-29_nds64le-linux-glibc-v5d-532904c2315e)) #56 SMP PREEMPT Thu Nov 19 18:06:46 CST 2020 [ 0.000000] initrd not found or empty - disabling initrd [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000000200000-0x000000003fffffff] [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges ... ////////////////////////////////////////////////// end //////////////////////////////////////////////////////////
Thanks, Rick
Thanks, Rick
Thanks, Rick
+model
*dev)
+model
+model
2.17.1
Hi Rick,
//////////////////////////////////////////////// case 1 /////////////////////////////////////////////////// ae350_rv64_defconfig with FTRACE=1, kernel booting is ok //////////////////////////////////////////////// case 1 /////////////////////////////////////////////////// make FTRACE=1 ae350_rv64_defconfig make FTRACE=1 ////////////////////////////////////////////////////////////////////////////////////// ///////////////////////// U-Boot 2021.01-rc2-00139-gb3d3d69-dirty (Nov 25 2020 - 11:14:28 +0800)
Starting kernel ...
//////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// ae350_rv64_spl_defconfig with FTRACE=1, kernel booting fail //////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// make FTRACE=1 ae350_rv64_spl_defconfig make FTRACE=1 ////////////////////////////////////////////////////////////////////////////////////// ///////////////////////// U-Boot SPL 2020.10-rc2-00175-gfa50824 (Sep 15 2020 - 19:26:29 +0800) Trying to boot from MMC1 U-Boot SPL 2021.01-rc2-00139-gb3d3d69-dirty (Nov 25 2020 - 13:48:05 +0800) Trying to boot from RAM U-Boot 2021.01-rc2-00139-gb3d3d69-dirty (Nov 25 2020 - 13:48:05 +0800) DRAM: 1 GiB trace: enabled Flash: 64 MiB MMC: mmc@f0e00000: 0 Loading Environment from SPIFlash... SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB OK In: serial@f0300000 Out: serial@f0300000 Err: serial@f0300000 Net: no alias for ethernet0 Warning: mac@e0100000 (eth0) using random MAC address - 36:86:da:0f:8e:8d eth0: mac@e0100000 Hit any key to stop autoboot: 0 27689996 bytes read in 15024 ms (1.8 MiB/s) 6435 bytes read in 25 ms (251 KiB/s) ## Booting kernel from Legacy Image at 00600000 ... Image Name: Image Type: RISC-V Linux Kernel Image (uncompressed) Data Size: 27689932 Bytes = 26.4 MiB Load Address: 00200000 Entry Point: 00200000 Verifying Checksum ... OK ## Flattened Device Tree blob at 20000000 Booting using the fdt blob at 0x20000000 Loading Kernel Image Loading Device Tree to 000000001effb000, end 000000001efff922 ... OK
Starting kernel ...
(hang here)
Thanks for the logs.
From logs, I can't find where it got stuck. Can you please use gdb to see where it got stuck ?
Meanwhile I will give it a try on HiFive Unleashed board.
//////////////////////////////////////////////// case 3 /////////////////////////////////////////////////// ae350_rv64_spl_defconfig without FTRACE=1, kernel booting ok //////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// make ae350_rv64_spl_defconfig make ////////////////////////////////////////////////////////////////////////////////////// /////////////////////////
Starting kernel ...
Thanks, Rick
Thanks, Rick
Thanks, Rick
+model
*dev)
+model
+model
2.17.1
Hi Rick,
//////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// ae350_rv64_spl_defconfig with FTRACE=1, kernel booting fail //////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// make FTRACE=1 ae350_rv64_spl_defconfig make FTRACE=1 /////////////////////////////////////////////////////////////////////// /////////////// /////////////////////////
(hang here)
On HiFive Unleashed it works fine with tracing.
U-Boot 2021.01-rc2-00049-gb2a38d1d0f (Dec 01 2020 - 15:04:41 +0530) CPU: rv64imafdc Model: SiFive HiFive Unleashed A00 DRAM: 8 GiB trace: enabled MMC: spi@10050000:mmc@0: 0 Loading Environment from SPIFlash... SF: Detected is25wp256 with page size 256 Bytes, erase size 4 KiB, total 32 MiB *** Warning - bad CRC, using default environment In: serial@10010000 Out: serial@10010000 Err: serial@10010000 Net: eth0: ethernet@10090000 Hit any key to stop autoboot: 0 => => trace stats 178,750 function sites 25,359,991 function calls 1 untracked function calls 1,278,927 traced function calls (24358307 dropped due to overflow) 19 maximum observed call depth 15 call depth limit 25,238,922 calls not traced due to depth => fatload mmc 0:3 0x86000000 hifive-unleashed-a00.dtb 7199 bytes read in 27 ms (259.8 KiB/s) => fatload mmc 0:3 0x84000000 uImage 21421212 bytes read in 19496 ms (1 MiB/s) => bootm 0x84000000 - 0x86000000 ## Booting kernel from Legacy Image at 84000000 ... Image Name: Linux Image Type: RISC-V Linux Kernel Image (uncompressed) Data Size: 21421148 Bytes = 20.4 MiB Load Address: 80200000 Entry Point: 80200000 Verifying Checksum ... OK ## Flattened Device Tree blob at 86000000 Booting using the fdt blob at 0x86000000 Loading Kernel Image Using Device Tree in place at 0000000086000000, end 0000000086004c1e Starting kernel ...(fake run for tracing) Starting kernel ... [ 0.000000] OF: fdt: Ignoring memory range 0x80000000 - 0x80200000 [ 0.000000] Linux version 5.8.0-rc3-16077-g9ebcfadb0610-dirty (pragneshp@sachinj2-OptiPlex-7010) (riscv64-unknown-linux-gnu-gcc (crosstool-NG 1.24.0.37-3f461da) 9.2.0, GNU ld (crosstool-NG 1.24.0.37-3f461da) 2.32) #34 SMP Tue Jul 21 15:56:29 IST 2020 [ 0.000000] initrd not found or empty - disabling initrd [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000080200000-0x00000000ffffffff] [ 0.000000] Normal [mem 0x0000000100000000-0x000000027fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080200000-0x000000027fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x000000027fffffff] .... Welcome to Buildroot buildroot login: root Password:
Hi Pragnesh
Hi Rick,
(hang here)
Please check about the CI failure item Job #95.56 https://travis-ci.org/github/rickchen36/u-boot-riscv/jobs/748298543
Thanks, Rick
Hi Rick,
-----Original Message----- From: Rick Chen rickchen36@gmail.com Sent: 10 December 2020 08:36 To: Pragnesh Patel pragnesh.patel@openfive.com Cc: Simon Glass sjg@chromium.org; U-Boot Mailing List <u- boot@lists.denx.de>; Atish Patra atish.patra@wdc.com; Bin Meng bmeng.cn@gmail.com; Paul Walmsley ( Sifive) paul.walmsley@sifive.com; Anup Patel anup.patel@wdc.com; Sagar Kadam sagar.kadam@openfive.com; Palmer Dabbelt palmer@dabbelt.com; rick rick@andestech.com; Alan Kao alankao@andestech.com; Leo Liang ycliang@andestech.com Subject: Re: [PATCH] riscv: timer: Add support for an early timer
Hi Pragnesh
Hi Rick,
//////////////////////////////////////////////// case 1 /////////////////////////////////////////////////// ae350_rv64_defconfig with FTRACE=1, kernel booting is ok //////////////////////////////////////////////// case 1 /////////////////////////////////////////////////// make FTRACE=1 ae350_rv64_defconfig make FTRACE=1 //////////////////////////////////////////////////////////////////// ///
//////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// ae350_rv64_spl_defconfig with FTRACE=1, kernel booting fail //////////////////////////////////////////////// case 2 /////////////////////////////////////////////////// make FTRACE=1 ae350_rv64_spl_defconfig make FTRACE=1 //////////////////////////////////////////////////////////////////// /// /////////////// /////////////////////////
(hang here)
(pragneshp@sachinj2-OptiPlex-7010) (riscv64-unknown-linux-gnu-gcc (crosstool- NG 1.24.0.37-3f461da) 9.2.0, GNU ld (crosstool-NG 1.24.0.37-3f461da) 2.32) #34 SMP Tue Jul 21 15:56:29 IST 2020
0x000000027fffffff]
This is due to 'RISCV_MMODE_TIMER_FREQ' undeclared
I will update "include/configs/qemu-riscv.h" in v2 as below,
--- a/include/configs/qemu-riscv.h +++ b/include/configs/qemu-riscv.h @@ -29,6 +29,11 @@
+#define RISCV_MMODE_TIMERBASE 0x2000000 +#define RISCV_MMODE_TIMER_FREQ 1000000 + +#define RISCV_SMODE_TIMER_FREQ 1000000 +
Thanks, Rick
Hi Rick, [....]
Can you please enable debug logs by adding below in ae350_rv64_spl_defconfig ?
CONFIG_LOG=y CONFIG_LOG_MAX_LEVEL=9 CONFIG_LOG_DEFAULT_LEVEL=9 CONFIG_LOG_CONSOLE=y CONFIG_SPL_LOG=y CONFIG_SPL_LOG_MAX_LEVEL=9 CONFIG_SPL_LOG_CONSOLE=y
Starting kernel ...
Starting kernel ...
(hang here)
Starting kernel ...
Thanks, Rick
Thanks, Rick
Thanks, Rick
+model
*dev)
+model
+model
2.17.1
Pragnesh Patel
Rick Chen
