[U-Boot] [RFC PATCH u-boot v2] ARM: arch-meson: build memory banks using reported memory from registers
As discussed at [1], the Amlogic Meson GX SoCs can embed a BL31 firmware and a secondary BL32 firmware. Since mid-2017, the reserved memory address of the BL31 firmware was moved and grown for security reasons.
But mainline U-boot and Linux has the old address and size fixed.
These SoCs have a register interface to get the two firmware reserved memory start and sizes.
This patch adds a dynamic reservation of the memory zones in the device tree bootmem reserved memory zone used by the kernel in early boot. To be complete, the memory zones are also added to the EFI reserved zones.
[1] http://lists.infradead.org/pipermail/linux-amlogic/2017-October/004860.html
Changes since v1: - switch to fdt rsv mem table and efi reserve memory - replaced in_le32 by readl()
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/include/asm/arch-meson/gxbb.h | 17 +++++ arch/arm/mach-meson/board.c | 117 ++++++++++++++++++++++++++++++--- board/amlogic/odroid-c2/odroid-c2.c | 7 ++ board/amlogic/p212/p212.c | 7 ++ configs/odroid-c2_defconfig | 1 + configs/p212_defconfig | 1 + include/configs/meson-gxbb-common.h | 2 +- 7 files changed, 143 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-meson/gxbb.h b/arch/arm/include/asm/arch-meson/gxbb.h index 74d5290..117f796 100644 --- a/arch/arm/include/asm/arch-meson/gxbb.h +++ b/arch/arm/include/asm/arch-meson/gxbb.h @@ -7,10 +7,27 @@ #ifndef __GXBB_H__ #define __GXBB_H__
+#define GXBB_FIRMWARE_MEM_SIZE 0x1000000 + +#define GXBB_AOBUS_BASE 0xc8100000 #define GXBB_PERIPHS_BASE 0xc8834400 #define GXBB_HIU_BASE 0xc883c000 #define GXBB_ETH_BASE 0xc9410000
+/* Always-On Peripherals registers */ +#define GXBB_AO_ADDR(off) (GXBB_AOBUS_BASE + ((off) << 2)) + +#define GXBB_AO_SEC_GP_CFG0 GXBB_AO_ADDR(0x90) +#define GXBB_AO_SEC_GP_CFG3 GXBB_AO_ADDR(0x93) +#define GXBB_AO_SEC_GP_CFG4 GXBB_AO_ADDR(0x94) +#define GXBB_AO_SEC_GP_CFG5 GXBB_AO_ADDR(0x95) + +#define GXBB_AO_MEM_SIZE_MASK 0xFFFF0000 +#define GXBB_AO_MEM_SIZE_SHIFT 16 +#define GXBB_AO_BL31_RSVMEM_SIZE_MASK 0xFFFF0000 +#define GXBB_AO_BL31_RSVMEM_SIZE_SHIFT 16 +#define GXBB_AO_BL32_RSVMEM_SIZE_MASK 0xFFFF + /* Peripherals registers */ #define GXBB_PERIPHS_ADDR(off) (GXBB_PERIPHS_BASE + ((off) << 2))
diff --git a/arch/arm/mach-meson/board.c b/arch/arm/mach-meson/board.c index e89c6aa..24733e1 100644 --- a/arch/arm/mach-meson/board.c +++ b/arch/arm/mach-meson/board.c @@ -11,6 +11,9 @@ #include <asm/arch/sm.h> #include <asm/armv8/mmu.h> #include <asm/unaligned.h> +#include <linux/sizes.h> +#include <efi_loader.h> +#include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -34,16 +37,114 @@ int dram_init(void) return 0; }
-int dram_init_banksize(void) +phys_size_t get_effective_memsize(void) { - /* Reserve first 16 MiB of RAM for firmware */ - gd->bd->bi_dram[0].start = 0x1000000; - gd->bd->bi_dram[0].size = 0xf000000; - /* Reserve 2 MiB for ARM Trusted Firmware (BL31) */ - gd->bd->bi_dram[1].start = 0x10000000; - gd->bd->bi_dram[1].size = gd->ram_size - 0x10200000; - return 0; + /* Size is reported in MiB, convert it in bytes */ + return ((readl(GXBB_AO_SEC_GP_CFG0) & GXBB_AO_MEM_SIZE_MASK) + >> GXBB_AO_MEM_SIZE_SHIFT) * SZ_1M; +} + +#ifdef CONFIG_MESON_GXBB +/* + * Early Meson GXBB Firmware revision did not provide the reserved + * memory zones in the registers, keep fixed memory zone handling. + */ + +void ft_cpu_setup(void *fdt, bd_t *bd) +{ + int ret; + + /* Add first 16MiB reserved zone */ + ret = fdt_add_mem_rsv(fdt, 0, GXBB_FIRMWARE_MEM_SIZE); + if (ret) + printf("Could not reserve zone @ 0x0\n"); + +#if defined(CONFIG_EFI_LOADER) + efi_add_memory_map(0, ALIGN(GXBB_FIRMWARE_MEM_SIZE, EFI_PAGE_SIZE) + >> EFI_PAGE_SHIFT, + EFI_RESERVED_MEMORY_TYPE, false); +#endif + + /* Add BL31 reserved zone */ + ret = fdt_add_mem_rsv(fdt, 0x10000000, 0x200000); + if (ret) + printf("Could not reserve BL1 zone @ 0x10000000\n"); + +#if defined(CONFIG_EFI_LOADER) + efi_add_memory_map(0x10000000, + ALIGN(0x200000, EFI_PAGE_SIZE) + >> EFI_PAGE_SHIFT, + EFI_RESERVED_MEMORY_TYPE, false); +#endif +} +#endif + +#ifdef CONFIG_MESON_GXL +void ft_cpu_setup(void *fdt, bd_t *bd) +{ + u64 bl31_size, bl31_start; + u64 bl32_size, bl32_start; + u32 reg; + int ret; + + /* + * Get ARM Trusted Firmware reserved memory zones in : + * - AO_SEC_GP_CFG3: bl32 & bl31 size in KiB, can be 0 + * - AO_SEC_GP_CFG5: bl31 physical start address, can be NULL + * - AO_SEC_GP_CFG4: bl32 physical start address, can be NULL + */ + + reg = readl(GXBB_AO_SEC_GP_CFG3); + + bl31_size = ((reg & GXBB_AO_BL31_RSVMEM_SIZE_MASK) + >> GXBB_AO_BL31_RSVMEM_SIZE_SHIFT) * SZ_1K; + bl32_size = (reg & GXBB_AO_BL32_RSVMEM_SIZE_MASK) * SZ_1K; + + bl31_start = readl(GXBB_AO_SEC_GP_CFG5); + bl32_start = readl(GXBB_AO_SEC_GP_CFG4); + + /* Add first 16MiB reserved zone */ + ret = fdt_add_mem_rsv(fdt, 0, GXBB_FIRMWARE_MEM_SIZE); + if (ret) + printf("Could not reserve zone @ 0x0\n"); + +#if defined(CONFIG_EFI_LOADER) + efi_add_memory_map(0, ALIGN(GXBB_FIRMWARE_MEM_SIZE, EFI_PAGE_SIZE) + >> EFI_PAGE_SHIFT, + EFI_RESERVED_MEMORY_TYPE, false); +#endif + + /* Add BL31 reserved zone */ + if (bl31_start && bl31_size) { + ret = fdt_add_mem_rsv(fdt, bl31_start, bl31_size); + if (ret) + printf("Could not reserve BL1 zone @ 0x%llx\n", + bl31_start); + +#if defined(CONFIG_EFI_LOADER) + efi_add_memory_map(bl31_start, + ALIGN(bl31_size, EFI_PAGE_SIZE) + >> EFI_PAGE_SHIFT, + EFI_RESERVED_MEMORY_TYPE, false); +#endif + } + + /* Add BL32 reserved zone */ + if (bl32_start && bl32_size) { + ret = fdt_add_mem_rsv(fdt, bl32_start, bl32_size); + if (ret) + printf("Could not reserve BL2 zone @ 0x%llx\n", + bl32_start); + +#if defined(CONFIG_EFI_LOADER) + efi_add_memory_map(bl32_start, + ALIGN(bl32_size, EFI_PAGE_SIZE) + >> EFI_PAGE_SHIFT, + EFI_RESERVED_MEMORY_TYPE, false); +#endif + } } +#endif
void reset_cpu(ulong addr) { diff --git a/board/amlogic/odroid-c2/odroid-c2.c b/board/amlogic/odroid-c2/odroid-c2.c index eac04d8..a9ca34c 100644 --- a/board/amlogic/odroid-c2/odroid-c2.c +++ b/board/amlogic/odroid-c2/odroid-c2.c @@ -60,3 +60,10 @@ int misc_init_r(void)
return 0; } + +int ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + + return 0; +} diff --git a/board/amlogic/p212/p212.c b/board/amlogic/p212/p212.c index ece8096..abd4f76 100644 --- a/board/amlogic/p212/p212.c +++ b/board/amlogic/p212/p212.c @@ -56,3 +56,10 @@ int misc_init_r(void)
return 0; } + +int ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + + return 0; +} diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index f7f8016..4615e03 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_SETUP=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/p212_defconfig b/configs/p212_defconfig index d4b5349..b6e788b 100644 --- a/configs/p212_defconfig +++ b/configs/p212_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_SETUP=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y diff --git a/include/configs/meson-gxbb-common.h b/include/configs/meson-gxbb-common.h index d88d42d..c2b306a 100644 --- a/include/configs/meson-gxbb-common.h +++ b/include/configs/meson-gxbb-common.h @@ -10,7 +10,7 @@
#define CONFIG_CPU_ARMV8 #define CONFIG_REMAKE_ELF -#define CONFIG_NR_DRAM_BANKS 2 +#define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MAXARGS 32 #define CONFIG_SYS_MALLOC_LEN (32 << 20)
Changes since v1:
- /* Size is reported in MiB, convert it in bytes */
- return ((readl(GXBB_AO_SEC_GP_CFG0) & GXBB_AO_MEM_SIZE_MASK)
- Early Meson GXBB Firmware revision did not provide the reserved
- memory zones in the registers, keep fixed memory zone handling.
- int ret;
- /* Add first 16MiB reserved zone */
- ret = fdt_add_mem_rsv(fdt, 0, GXBB_FIRMWARE_MEM_SIZE);
- if (ret)
- efi_add_memory_map(0, ALIGN(GXBB_FIRMWARE_MEM_SIZE, EFI_PAGE_SIZE)
>> EFI_PAGE_SHIFT,
Could you make a sub function that does most of this and then have only one set of #if defined ?
Would anyone mind if efi_add_memory_map had a default 'null' implementation if !CONFIG_EFI_LOADER ?
- /* Add BL31 reserved zone */
- ret = fdt_add_mem_rsv(fdt, 0x10000000, 0x200000);
- if (ret)
- efi_add_memory_map(0x10000000,
>> EFI_PAGE_SHIFT,
+#endif +} +#endif
Can we reduce the pre-processor load here, I'm not even sure we're testing the entire file can be compiled.
you're mixing #ifdef and #if defined.
- u64 bl31_size, bl31_start;
- u64 bl32_size, bl32_start;
- u32 reg;
- int ret;
- reg = readl(GXBB_AO_SEC_GP_CFG3);
- bl31_size = ((reg & GXBB_AO_BL31_RSVMEM_SIZE_MASK)
- bl32_size = (reg & GXBB_AO_BL32_RSVMEM_SIZE_MASK) * SZ_1K;
- bl31_start = readl(GXBB_AO_SEC_GP_CFG5);
- bl32_start = readl(GXBB_AO_SEC_GP_CFG4);
- if (ret)
>> EFI_PAGE_SHIFT,
- if (bl31_start && bl31_size) {
if (ret)
bl31_start);
>> EFI_PAGE_SHIFT,
- /* Add BL32 reserved zone */
- if (bl32_start && bl32_size) {
if (ret)
bl32_start);
>> EFI_PAGE_SHIFT,
} +#endif
return 0; }
- ft_cpu_setup(blob, bd);
return 0; }
Changes since v1:
Seems a good idea.
Would anyone mind if efi_add_memory_map had a default 'null' implementation if !CONFIG_EFI_LOADE>
Well, the 2 uses-cases are very different... but I can try to rework a little.
Will fix.
return 0; }
return 0; }
Ben Dooks
Neil Armstrong
