[U-Boot] Pull request for UEFI sub-system for efi-2020-01-rc1 (2)
The following changes since commit c83b1bb923421e95e499b22b010d2f9f463c1226:
Merge tag 'dm-pull-15oct19' of https://gitlab.denx.de/u-boot/custodians/u-boot-dm (2019-10-16 18:10:31 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2020-01-rc1-2
for you to fetch changes up to 5cc349bb09eefaf43e250b2c7a8fc5a61c595715:
efi_loader: enable CONFIG_CMD_NVEDIT_EFI on QEMU (2019-10-17 19:19:56 +0200)
Gitlab CI shows no problems: https://gitlab.denx.de/u-boot/custodians/u-boot-efi/pipelines/1002
---------------------------------------------------------------- Pull request for UEFI sub-system for efi-2020-01-rc1 (2)
Install the simple file protocol only if there is a file system on the partition.
Enable CONFIG_CMD_NVEDIT_EFI on QEMU.
---------------------------------------------------------------- AKASHI Takahiro (5): efi_loader: device_path: check against file path length fs: export fs_close() fs: clean up around fs_type fs: add fs_get_type() for current filesystem type efi_loader: disk: install FILE_SYSTEM_PROTOCOL only if available
Heinrich Schuchardt (2): fs: update fs_close() description efi_loader: enable CONFIG_CMD_NVEDIT_EFI on QEMU
configs/qemu-riscv32_defconfig | 1 + configs/qemu-riscv32_smode_defconfig | 1 + configs/qemu-riscv64_defconfig | 1 + configs/qemu-riscv64_smode_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu_arm64_defconfig | 1 + configs/qemu_arm_defconfig | 1 + fs/fs.c | 18 ++++++++++++++---- include/fs.h | 22 ++++++++++++++++++++++ lib/efi_loader/efi_device_path.c | 11 +++++++++-- lib/efi_loader/efi_disk.c | 24 +++++++++++++++++++++++- 12 files changed, 76 insertions(+), 7 deletions(-)
