[U-Boot] [PATCH] board: da8xxevm: Fix Environmental CRC error
When the spi_flash_probe_bus_cs() was previously called, it was called using 0's for two values where CONFIG_ENV_SPI_MAX_HZ and CONFIG_ENV_SPI_MODE are now used. When changed this caused the environment to fail the CRC check and the default was used. This patch defines both of these values back 0.
Fixes: 25a17652c9c2 ("fix: env: Fix the SPI flash device setup for DM mode")
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index ba878eb13b..14a3046f19 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -124,8 +124,9 @@ #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE #define CONFIG_SF_DEFAULT_SPEED 30000000 -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #endif +#define CONFIG_ENV_SPI_MAX_HZ 0 +#define CONFIG_ENV_SPI_MODE 0
#ifdef CONFIG_USE_SPIFLASH #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8000
Adam Ford
