[PATCH] clk: imx8m: register ARM A55 core clock
Register ARM A55 core clock for i.MX 8M Mini, Nano and Plus.
Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- drivers/clk/imx/clk-imx8mm.c | 6 ++++++ drivers/clk/imx/clk-imx8mn.c | 7 +++++++ drivers/clk/imx/clk-imx8mp.c | 7 +++++++ 3 files changed, 20 insertions(+)
diff --git a/drivers/clk/imx/clk-imx8mm.c b/drivers/clk/imx/clk-imx8mm.c index e538f047b3..8d98fbaaa9 100644 --- a/drivers/clk/imx/clk-imx8mm.c +++ b/drivers/clk/imx/clk-imx8mm.c @@ -21,6 +21,8 @@ static const char * const sys_pll1_bypass_sels[] = {"sys_pll1", "sys_pll1_ref_se static const char * const sys_pll2_bypass_sels[] = {"sys_pll2", "sys_pll2_ref_sel", }; static const char * const sys_pll3_bypass_sels[] = {"sys_pll3", "sys_pll3_ref_sel", };
+static const char * const imx8mm_arm_core_sels[] = {"arm_a53_src", "arm_pll_out", }; + static const char * const imx8mm_a53_sels[] = {"clock-osc-24m", "arm_pll_out", "sys_pll2_500m", "sys_pll2_1000m", "sys_pll1_800m", "sys_pll1_400m", "audio_pll1_out", "sys_pll3_out", }; @@ -417,6 +419,10 @@ static int imx8mm_clk_probe(struct udevice *dev) imx_clk_gate4("qspi_root_clk", "qspi", base + 0x42f0, 0)); #endif
+ clk_dm(IMX8MM_CLK_ARM, + imx_clk_mux2("arm_core", base + 0x9880, 24, 1, + imx8mm_arm_core_sels, + ARRAY_SIZE(imx8mm_arm_core_sels))); return 0; }
diff --git a/drivers/clk/imx/clk-imx8mn.c b/drivers/clk/imx/clk-imx8mn.c index 8911e342f1..3de03e1f3b 100644 --- a/drivers/clk/imx/clk-imx8mn.c +++ b/drivers/clk/imx/clk-imx8mn.c @@ -23,6 +23,8 @@ static const char * const sys_pll1_bypass_sels[] = {"sys_pll1", "sys_pll1_ref_se static const char * const sys_pll2_bypass_sels[] = {"sys_pll2", "sys_pll2_ref_sel", }; static const char * const sys_pll3_bypass_sels[] = {"sys_pll3", "sys_pll3_ref_sel", };
+static const char * const imx8mn_arm_core_sels[] = {"arm_a53_src", "arm_pll_out", }; + static const char * const imx8mn_a53_sels[] = {"clock-osc-24m", "arm_pll_out", "sys_pll2_500m", "sys_pll2_1000m", "sys_pll1_800m", "sys_pll1_400m", "audio_pll1_out", "sys_pll3_out", }; @@ -403,6 +405,11 @@ static int imx8mn_clk_probe(struct udevice *dev) imx_clk_gate4("ecspi3_root_clk", "ecspi3", base + 0x4090, 0)); #endif
+ clk_dm(IMX8MN_CLK_ARM, + imx_clk_mux2("arm_core", base + 0x9880, 24, 1, + imx8mn_arm_core_sels, + ARRAY_SIZE(imx8mn_arm_core_sels))); + return 0; }
diff --git a/drivers/clk/imx/clk-imx8mp.c b/drivers/clk/imx/clk-imx8mp.c index 6b18483c81..32ea60f11e 100644 --- a/drivers/clk/imx/clk-imx8mp.c +++ b/drivers/clk/imx/clk-imx8mp.c @@ -21,6 +21,8 @@ static const char * const sys_pll1_bypass_sels[] = {"sys_pll1", "sys_pll1_ref_se static const char * const sys_pll2_bypass_sels[] = {"sys_pll2", "sys_pll2_ref_sel", }; static const char * const sys_pll3_bypass_sels[] = {"sys_pll3", "sys_pll3_ref_sel", };
+static const char * const imx8mp_arm_core_sels[] = {"arm_a53_src", "arm_pll_out", }; + static const char * const imx8mp_a53_sels[] = {"clock-osc-24m", "arm_pll_out", "sys_pll2_500m", "sys_pll2_1000m", "sys_pll1_800m", "sys_pll1_400m", "audio_pll1_out", "sys_pll3_out", }; @@ -354,6 +356,11 @@ static int imx8mp_clk_probe(struct udevice *dev)
clk_dm(IMX8MP_CLK_USDHC3_ROOT, imx_clk_gate4("usdhc3_root_clk", "usdhc3", base + 0x45e0, 0));
+ clk_dm(IMX8MP_CLK_ARM, + imx_clk_mux2("arm_core", base + 0x9880, 24, 1, + imx8mp_arm_core_sels, + ARRAY_SIZE(imx8mp_arm_core_sels))); + return 0; }
All those SoCs are A53 , which matches the patch, not the commit description. Please fix the commit description.
Hi Marek,
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Thursday, July 25, 2024 9:53 PM To: Z.Q. Hou zhiqiang.hou@nxp.com; u-boot@lists.denx.de; trini@konsulko.com; lukma@denx.de; seanga2@gmail.com; festevam@gmail.com; Peng Fan peng.fan@nxp.com Subject: Re: [PATCH] clk: imx8m: register ARM A55 core clock
Yes, will fix. Thanks!
Zhiqiang
Z.Q. Hou
Zhiqiang Hou
