[U-Boot] [PATCH v2 0/5] env: Add support for environment files
At present U-Boot environment variables, and thus scripts, are defined by CONFIG_EXTRA_ENV_SETTINGS. It is painful to add large amounts of text to this file and dealing with quoting and newlines is harder than it should be. It would be better if we could just type the script into a text file and have it included by U-Boot.
This series adds a feature that brings in a .env file associated with the board config, if present. To use it, create a file in a board/<vendor>/env directory called <board>.env (or common.env if you want the same environment for all boards for that vendor).
The environment variables should be of the form "var=value". Values can extend to multiple lines. See the README under 'Environment Variables:' for more information and an example.
After discussion on the mailing list the .emv file was moved from include/configs to board/. See here:
http://patchwork.ozlabs.org/patch/237120/
There was also talk of using the C preprocessor for these boards. I tried this out and found it to be extremely useful. In fact without it, the scripts probably cannot move from the config header file, since many scripts are put together based on information from CONFIG variables.
Another discussion was compatibility with the environment commands 'env export -t' and 'env import -t'. This series permits these to be used and the environment is exported and imported as expected. I have dropped the ugly \0 approach in favour of a more flexible awk script for parsing the environment file. The environment commands use \ at the end of a line for continuation which works nicely with this feature. I have added a patch to 'run' so that it runs the entire script, not just the first line. A nice benefit is that there is no longer any need to put ';' at the end of every line - in other words U-Boot scripts become proper scripts with multiple lines instead of messy and fragile continuations.
As an example, I have converted most of the tegra environment over to this new approach on an RFC basis.
Changes in v2: - Add additional include to env_embedded to deal with its dirty trick - Add dependency rule so that the environment is rebuilt when it changes - Add information and updated example script to README - Add new patch to adjust 'run' command to better support testing - Add new patch to get 'env import/export' working on sandbox - Add new patch to illustrate the impact on Tegra environment - Add separate patch to enable C preprocessor for environment files - Enable var+=value form to simplify composing variables in multiple steps - Move .env file from include/configs to board/ - Use awk script to process environment since it is much easier on the brain
Simon Glass (5): sandbox: Support 'env import' and 'env export' Make 'run' use run_command_list() instead of run_command() Allow U-Boot scripts to be placed in a .env file env: Allow environment files to use the C preprocessor RFC: tegra: Convert to using environment files
Makefile | 31 +++++++++- README | 49 +++++++++++++++ board/nvidia/env/common.env | 79 ++++++++++++++++++++++++ common/cmd_nvedit.c | 31 ++++++---- common/env_embedded.c | 1 + common/main.c | 2 +- config.mk | 2 + include/configs/tegra-common-post.h | 120 +----------------------------------- include/env_default.h | 2 + mkconfig | 6 ++ tools/scripts/env2string.awk | 49 +++++++++++++++ 11 files changed, 238 insertions(+), 134 deletions(-) create mode 100644 board/nvidia/env/common.env create mode 100644 tools/scripts/env2string.awk
Adjust the code for these commands so that they work on sandbox.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Add new patch to get 'env import/export' working on sandbox
common/cmd_nvedit.c | 31 ++++++++++++++++++------------- 1 file changed, 18 insertions(+), 13 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 2478c95..e8493c2 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -49,6 +49,7 @@ #include <watchdog.h> #include <linux/stddef.h> #include <asm/byteorder.h> +#include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -864,7 +865,8 @@ static int do_env_export(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { char buf[32]; - char *addr, *cmd, *res; + ulong addr; + char *ptr, *cmd, *res; size_t size = 0; ssize_t len; env_t *envp; @@ -909,10 +911,11 @@ NXTARG: ; if (argc < 1) return CMD_RET_USAGE;
- addr = (char *)simple_strtoul(argv[0], NULL, 16); + addr = simple_strtoul(argv[0], NULL, 16); + ptr = map_sysmem(addr, size);
if (size) - memset(addr, '\0', size); + memset(ptr, '\0', size);
argc--; argv++; @@ -920,7 +923,7 @@ NXTARG: ; if (sep) { /* export as text file */ len = hexport_r(&env_htab, sep, H_MATCH_KEY | H_MATCH_IDENT, - &addr, size, argc, argv); + &ptr, size, argc, argv); if (len < 0) { error("Cannot export environment: errno = %d\n", errno); return 1; @@ -931,12 +934,12 @@ NXTARG: ; return 0; }
- envp = (env_t *)addr; + envp = (env_t *)ptr;
if (chk) /* export as checksum protected block */ res = (char *)envp->data; else /* export as raw binary data */ - res = addr; + res = ptr;
len = hexport_r(&env_htab, '\0', H_MATCH_KEY | H_MATCH_IDENT, @@ -978,7 +981,8 @@ sep_err: static int do_env_import(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - char *cmd, *addr; + ulong addr; + char *cmd, *ptr; char sep = '\n'; int chk = 0; int fmt = 0; @@ -1022,12 +1026,13 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag, if (!fmt) printf("## Warning: defaulting to text format\n");
- addr = (char *)simple_strtoul(argv[0], NULL, 16); + addr = simple_strtoul(argv[0], NULL, 16); + ptr = map_sysmem(addr, 0);
if (argc == 2) { size = simple_strtoul(argv[1], NULL, 16); } else { - char *s = addr; + char *s = ptr;
size = 0;
@@ -1047,7 +1052,7 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag,
if (chk) { uint32_t crc; - env_t *ep = (env_t *)addr; + env_t *ep = (env_t *)ptr;
size -= offsetof(env_t, data); memcpy(&crc, &ep->crc, sizeof(crc)); @@ -1056,11 +1061,11 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag, puts("## Error: bad CRC, import failed\n"); return 1; } - addr = (char *)ep->data; + ptr = (char *)ep->data; }
- if (himport_r(&env_htab, addr, size, sep, del ? 0 : H_NOCLEAR, - 0, NULL) == 0) { + if (himport_r(&env_htab, ptr, size, sep, del ? 0 : H_NOCLEAR, 0, + NULL) == 0) { error("Environment import failed: errno = %d\n", errno); return 1; }
In the case where an environment variable spans multiple lines, we should use run_command_list() so that all lines are executed. This shold be backwards compatible with existing behaviour for existing scripts.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Add new patch to adjust 'run' command to better support testing
common/main.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/main.c b/common/main.c index 56da214..3b7f2f7 100644 --- a/common/main.c +++ b/common/main.c @@ -1560,7 +1560,7 @@ int do_run (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) return 1; }
- if (run_command(arg, flag) != 0) + if (run_command_list(arg, -1, flag) != 0) return 1; } return 0;
Add a feature that brings in a .env file associated with the board config, if present. To use it, create a file in a board/<vendor>/env directory called <board>.env (or common.env if you want the same environment for all boards).
Comments are not permitted in the environment with this commit.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Add additional include to env_embedded to deal with its dirty trick - Add dependency rule so that the environment is rebuilt when it changes - Add information and updated example script to README - Move .env file from include/configs to board/ - Use awk script to process environment since it is much easier on the brain
Makefile | 30 +++++++++++++++++++++++++++++- README | 34 ++++++++++++++++++++++++++++++++++ common/env_embedded.c | 1 + config.mk | 2 ++ include/env_default.h | 2 ++ mkconfig | 6 ++++++ tools/scripts/env2string.awk | 43 +++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 117 insertions(+), 1 deletion(-) create mode 100644 tools/scripts/env2string.awk
diff --git a/Makefile b/Makefile index 693b3f2..9dae750 100644 --- a/Makefile +++ b/Makefile @@ -695,7 +695,7 @@ $(obj)include/autoconf.mk.dep: $(obj)include/config.h include/common.h $(CC) -x c -DDO_DEPS_ONLY -M $(CFLAGS) $(CPPFLAGS) \ -MQ $(obj)include/autoconf.mk include/common.h > $@
-$(obj)include/autoconf.mk: $(obj)include/config.h +$(obj)include/generated/autoconf.mk.base: $(obj)include/config.h @$(XECHO) Generating $@ ; \ set -e ; \ : Extract the config macros ; \ @@ -703,6 +703,34 @@ $(obj)include/autoconf.mk: $(obj)include/config.h sed -n -f tools/scripts/define2mk.sed > $@.tmp && \ mv $@.tmp $@
+# We expect '<board>.env' but failing that will use 'common.env' +ENV_HEADER := $(obj)include/generated/environment.h +ENV_DIR := $(if $(VENDOR),$(VENDOR)/env,$(BOARD)/env) +ENV_FILE_BOARD := $(src)board/${ENV_DIR}/$(BOARD).env +ENV_FILE_COMMON := $(src)board/${ENV_DIR}/common.env +ENV_FILE := $(if $(wildcard $(ENV_FILE_BOARD)),$(ENV_FILE_BOARD),$(ENV_FILE_COMMON)) + +# Regenerate the environment if it changes +$(obj)include/generated/environment.in: $(obj)include/generated/autoconf.mk.base \ + $(wildcard $(ENV_FILE)) + if [ -f "$(ENV_FILE)" ]; then \ + cat $(ENV_FILE) >$@ ; \ + else \ + echo -n >$@ ; \ + fi + +$(obj)include/generated/environment.inc: $(obj)include/generated/environment.in + @$(XECHO) Generating $@ ; \ + set -e ; \ + : Process the environment file ; \ + echo -n "CONFIG_EXTRA_ENV_TEXT=" >$@ ; \ + echo -n "#define CONFIG_EXTRA_ENV_TEXT " >$(ENV_HEADER) ; \ + awk -f tools/scripts/env2string.awk $< | \ + tee -a $(ENV_HEADER) >>$@ ; \ + +$(obj)include/autoconf.mk: $(obj)include/generated/environment.inc + cat $(obj)include/generated/autoconf.mk.base $< >$@ + $(obj)include/generated/generic-asm-offsets.h: $(obj)include/autoconf.mk.dep \ $(obj)lib/asm-offsets.s @$(XECHO) Generating $@ diff --git a/README b/README index cd0336c..2c8a8c9 100644 --- a/README +++ b/README @@ -4363,6 +4363,40 @@ environment. As long as you don't save the environment you are working with an in-memory copy. In case the Flash area containing the environment is erased by accident, a default environment is provided.
+The default environment is created in include/env_default.h, and can be +augmented by various CONFIG defines. See that file for details. In +particular you can define CONFIG_EXTRA_ENV_SETTINGS in your board file +to add environment variables (see 'CONFIG_EXTRA_ENV_SETTINGS' above +for details). + +It is also possible to create an environment file with the name +board/<vendor>/env/<board>.env for your board. If that file is not present +then U-Boot will look for board/<vendor>/env/common.env so that you can +have a common environment for all vendor boards. + +This is a plain text file where you can type your environment variables in +the form 'var=value'. Blank lines and multi-line variables are supported. + +For example, for snapper9260 you would create a text file called +board/bluewater/env/snapper9260.env containing the environment text. + +>>> +bootcmd= + if [ -z ${tftpserverip} ]; then + echo "Use 'setenv tftpserverip a.b.c.d' to set IP address." + fi + + usb start; setenv autoload n; bootp; + tftpboot ${tftpserverip}: + bootm +failed= + echo boot failed - please check your image +<<< + +The resulting environment can be exported and importing using the +'env export/import -t' commands. + + Some configuration options can be set using Environment Variables.
List of environment variables (most likely not complete): diff --git a/common/env_embedded.c b/common/env_embedded.c index 52bc687..c8e7ee9 100644 --- a/common/env_embedded.c +++ b/common/env_embedded.c @@ -24,6 +24,7 @@ #ifndef __ASSEMBLY__ #define __ASSEMBLY__ /* Dirty trick to get only #defines */ #endif +#include <generated/environment.h> #define __ASM_STUB_PROCESSOR_H__ /* don't include asm/processor. */ #include <config.h> #undef __ASSEMBLY__ diff --git a/config.mk b/config.mk index ddf350e..26385da 100644 --- a/config.mk +++ b/config.mk @@ -181,8 +181,10 @@ sinclude $(TOPDIR)/$(CPUDIR)/$(SOC)/config.mk # include SoC specific rules endif ifdef VENDOR BOARDDIR = $(VENDOR)/$(BOARD) +ENVDIR=${vendor}/env else BOARDDIR = $(BOARD) +ENVDIR=${board}/env endif ifdef BOARD sinclude $(TOPDIR)/board/$(BOARDDIR)/config.mk # include board specific rules diff --git a/include/env_default.h b/include/env_default.h index 39c5b7c..a394df5 100644 --- a/include/env_default.h +++ b/include/env_default.h @@ -137,6 +137,8 @@ const uchar default_environment[] = { #ifdef CONFIG_EXTRA_ENV_SETTINGS CONFIG_EXTRA_ENV_SETTINGS #endif + /* This is created in the Makefile */ + CONFIG_EXTRA_ENV_TEXT "\0" #ifdef DEFAULT_ENV_INSTANCE_EMBEDDED } diff --git a/mkconfig b/mkconfig index 73f852e..7c286a7 100755 --- a/mkconfig +++ b/mkconfig @@ -141,8 +141,10 @@ fi # Assign board directory to BOARDIR variable if [ -z "${vendor}" ] ; then BOARDDIR=${board} + ENVDIR=${board}/env else BOARDDIR=${vendor}/${board} + ENVDIR=${vendor}/env fi
# @@ -171,10 +173,14 @@ echo "#define CONFIG_SYS_BOARD "${board}"" >> config.h
cat << EOF >> config.h #define CONFIG_BOARDDIR board/$BOARDDIR +#define CONFIG_ENVDIR board/$ENVDIR #include <config_cmd_defaults.h> #include <config_defaults.h> #include <configs/${CONFIG_NAME}.h> #include <asm/config.h> +#if !defined(DO_DEPS_ONLY) && !defined(__ASSEMBLY__) +#include <generated/environment.h> +#endif #include <config_fallbacks.h> #include <config_uncmd_spl.h> EOF diff --git a/tools/scripts/env2string.awk b/tools/scripts/env2string.awk new file mode 100644 index 0000000..2d167c0 --- /dev/null +++ b/tools/scripts/env2string.awk @@ -0,0 +1,43 @@ +# +# Sed script to parse a text file containing an environment and convert it +# to a C string which can be compiled into U-Boot. +# + +# We begin and end with " +BEGIN { + # env holds the env variable we are currently processing + env = ""; + ORS = "" + print """ +} + +{ + # Quote quotes + gsub(""", "\"") + + # Is this the start of a new environment variable? + if (match($0, "^([^ =][^ =]*)=(.*)", arr)) { + if (length(env) != 0) { + # Record the value of the variable now completed + vars[var] = env + } + var = arr[1] + env = arr[2] + } else { + # Change newline to \n + env = env "\n" $0; + } +} + +END { + # Record the value of the variable now completed + if (length(env) != 0) { + vars[var] = env + } + + # Print out all the variables + for (var in vars) { + print var "=" vars[var] "\0"; + } + print """ +}
I'm not entirely sure how useful common.env is.
Consider that many different Tegra boards, from different vendors, all share the same environment. For example boards/compulab/trimslice shares the core environment with boards/nvidia/*. IIUC, common.env wouldn't work in this case, since the vendor is different. To solve that, we could easily symlink board/compulab/env/trimslice.env -> board/nvidia/env/something.env. But in that case, why not always rely on creating symlinks, instead of having the common.env fallback work too? Also consider that compulab makes a ton of boards only some of which use Tegra, so even a common.env in board/compulab/env wouldn't be that useful.
- @$(XECHO) Generating $@ ; \
- set -e ; \
- : Process the environment file ; \
- echo -n "CONFIG_EXTRA_ENV_TEXT=" >$@ ; \
- echo -n "#define CONFIG_EXTRA_ENV_TEXT " >$(ENV_HEADER) ; \
- awk -f tools/scripts/env2string.awk $< | \
That generates two different files. Doesn't this confuse make a bit, since if make needs to create $(ENV_HEADER) (which isn't $@ for that rule) it won't know how to? I've certainly seen problems due to similar make setups in the past. Perhaps even though it's a bit extra build-time work, the two files should be generated separately? Or, is there some reason here that there won't be a problem?
+>>> +bootcmd=
- if [ -z ${tftpserverip} ]; then
- fi
- usb start; setenv autoload n; bootp;
- tftpboot ${tftpserverip}:
- bootm
+failed=
- echo boot failed - please check your image
Presumably the parser looks for something like /^[A-Z]=/i to know when to "switch" to a new environment variable. Is some form of escaping useful if you want to include that form of text in your environment variable's value? If the parser is somehow smarter than that, it might be worth explaining the syntax structure a little more above.
I'm not sure what the " means at the end of that line.
Hi Stephen,
[well perhaps it is time to get back to this]
I find symlinks a pain in the source tree. I think they should be the exception rather than the rule. This feature hear mirrors the current board/<vendor>/common directory which is fairly widely used.
$ ls board/*/common -d |wc -l 21
I feel that Compulab can do their own common file if they want it. A file common to all Tegra perhaps belongs in arch/arm/.. somewhere?
set -e ; \
Yes I will separate it. I agree it's a bit icky in that if someone manually deletes one file they may not get the other. The speed-up is small.
+>>> +bootcmd=
fi
bootm
+failed=
The match string is a little more basic than that since there are few restrictions on environment variable names as far as I know:
I'll add some more details to the commit message - but the idea is to indent your environment to avoid problems.
I'll improve that comment.
On 10/20/2013 09:47 PM, Simon Glass wrote:
Hi Stephen,
I find symlinks a pain in the source tree. I think they should be the exception rather than the rule. This feature here mirrors the current board/<vendor>/common directory which is fairly widely used.
Well, we use includes rather than symlinks, e.g. put the following into boards/compulab/env/trimslice.env:
#include <boards/nvidia/env/something.env>
I'd rather as many board worked the same way as possible; that makes it much easier for distros, and even developers. We shouldn't go out of our way to make that hard.
That might be a better location, yes.
In many cases environment variables need access to the U-Boot CONFIG variables to select different options. Enable this so that the environment scripts can be as useful as the ones currently in the board config files.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Add separate patch to enable C preprocessor for environment files - Enable var+=value form to simplify composing variables in multiple steps
Makefile | 3 ++- README | 17 ++++++++++++++++- tools/scripts/env2string.awk | 6 ++++++ 3 files changed, 24 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index 9dae750..89ac4c5 100644 --- a/Makefile +++ b/Makefile @@ -714,7 +714,8 @@ ENV_FILE := $(if $(wildcard $(ENV_FILE_BOARD)),$(ENV_FILE_BOARD),$(ENV_FILE_COMM $(obj)include/generated/environment.in: $(obj)include/generated/autoconf.mk.base \ $(wildcard $(ENV_FILE)) if [ -f "$(ENV_FILE)" ]; then \ - cat $(ENV_FILE) >$@ ; \ + $(CPP) -P $(CFLAGS) -x assembler-with-cpp -D__ASSEMBLY__ \ + -include $(obj)include/config.h $(ENV_FILE) -o $@; \ else \ echo -n >$@ ; \ fi diff --git a/README b/README index 2c8a8c9..6711cd0 100644 --- a/README +++ b/README @@ -4376,12 +4376,25 @@ have a common environment for all vendor boards.
This is a plain text file where you can type your environment variables in the form 'var=value'. Blank lines and multi-line variables are supported. +To add additional text to a variable you can use var+=value. This text is +merged into the variable during the make process and made available as a +single value to U-Boot.
For example, for snapper9260 you would create a text file called board/bluewater/env/snapper9260.env containing the environment text.
+This file can include C-style comments. Blank lines and multi-line +variables are supported, and you can use normal C preprocessor directives +and CONFIG defines from your board config also. +
+stdout=serial +#ifdef CONFIG_LCD +stdout+=,lcd +#endif bootcmd= + /* U-Boot script for booting */ + if [ -z ${tftpserverip} ]; then echo "Use 'setenv tftpserverip a.b.c.d' to set IP address." fi @@ -4390,7 +4403,9 @@ bootcmd= tftpboot ${tftpserverip}: bootm failed= - echo boot failed - please check your image + /* Print a message when boot fails */ + echo CONFIG_SYS_BOARD boot failed - please check your image + echo Load address is CONFIG_SYS_LOAD_ADDR <<<
The resulting environment can be exported and importing using the diff --git a/tools/scripts/env2string.awk b/tools/scripts/env2string.awk index 2d167c0..d647cf3 100644 --- a/tools/scripts/env2string.awk +++ b/tools/scripts/env2string.awk @@ -23,6 +23,12 @@ BEGIN { } var = arr[1] env = arr[2] + + # Deal with += + if (match(var, "(.*)[+]$", var_arr)) { + var = var_arr[1] + env = vars[var] env + } } else { # Change newline to \n env = env "\n" $0;
The addition of += seems like a separate change to enabling pre-processing, but I guess they're both simple enough and this is a new features, perhaps it's not a big deal.
I guess -undef doesn't make sense here, since config.h could well rely on standard pre-defined macros.
Does it make sense to -D __UBOOT_CONFIG__ rather than, or in addition to, -D __ASSEMBLY__ here, so headers can tell what they're being included for? The series I sent for dtc+cpp did -D __DTS__ for similar reasons.
# Deal with +=
var = var_arr[1]
env = vars[var] env
Does this work if you write just:
foo+=bar
rather than:
foo= foo+=bar
It might be worth allowing the former syntax, so you don't need to explicitly assign empty values before a sequence of ifdef'd += operations. If the above blows up, at least a descriptive error message might be useful.
Hi Stephen,
Yes it is separate but I was concerned about not creating too many patches for the same feature.
In some cases yes.
Will do.
# Deal with +=
var = var_arr[1]
env = vars[var] env
foo+=bar
rather than:
foo= foo+=bar
Yes that works for me. With awk variable appear when used which helps here.
This seems more intuitive that the current #define way of doing things. The resulting code is shorter, avoids the quoting and line continuation pain, and also improves the clumsy way that stdio variables are created:
#ifdef CONFIG_VIDEO_TEGRA #define STDOUT_LCD ",lcd" #else #define STDOUT_LCD "" #endif
... #define TEGRA_DEVICE_SETTINGS \ "stdout=serial" STDOUT_LCD "\0" \ ...
The MEM_LAYOUT_ENV_SETTINGS variable is left in the header files, since it depends on the SOC type and we probably don't want to add .emv files for each board at this stage.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Add new patch to illustrate the impact on Tegra environment
board/nvidia/env/common.env | 79 ++++++++++++++++++++++++ include/configs/tegra-common-post.h | 120 +----------------------------------- 2 files changed, 80 insertions(+), 119 deletions(-) create mode 100644 board/nvidia/env/common.env
diff --git a/board/nvidia/env/common.env b/board/nvidia/env/common.env new file mode 100644 index 0000000..aca36a5 --- /dev/null +++ b/board/nvidia/env/common.env @@ -0,0 +1,79 @@ +#ifndef CONFIG_BOOTCOMMAND +rootpart=1 +script_boot= + if load ${devtype} ${devnum}:${rootpart} + ${scriptaddr} ${prefix}${script}; then + echo ${script} found! Executing ... + source ${scriptaddr} + fi + +scan_boot= + echo Scanning ${devtype} ${devnum}... + for prefix in ${boot_prefixes}; do + for script in ${boot_scripts}; do + run script_boot + done + done + +boot_targets= +boot_prefixes=/ /boot/ +boot_scripts=boot.scr.uimg boot.scr + +#ifdef CONFIG_CMD_MMC +mmc_boot= + setenv devtype mmc + if mmc dev ${devnum}; then + run scan_boot + fi +bootcmd_mmc0=setenv devnum 0; run mmc_boot +bootcmd_mmc1=setenv devnum 1; run mmc_booxt +boot_targets+= mmc1 mmc0 +#endif + +#ifdef CONFIG_CMD_USB +#define BOOTCMD_INIT_USB run usb_init +usb_init= + if ${usb_need_init}; then + set usb_need_init false + usb start 0 + fi +usb_boot= + setenv devtype usb + BOOTCMD_INIT_USB + if usb dev ${devnum}; then + run scan_boot + fi +bootcmd_usb0=setenv devnum 0; run usb_boot +boot_targets+= usb0 +#else +#define BOOTCMD_INIT_USB +#endif + +#ifdef CONFIG_CMD_DHCP +bootcmd_dhcp= + BOOTCMD_INIT_USB + if dhcp ${scriptaddr} boot.scr.uimg; then + source ${scriptaddr} + fi +boot_targets+= dhcp +#endif + +bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done +#endif + +/* Decide on values for stdio */ +stdin=serial +stdout=serial +stderr=serial + +#ifdef CONFIG_TEGRA_KEYBOARD +stdin+=,tegra-kbc +#endif + +#ifdef CONFIG_USB_KEYBOARD +stdin+=,usbkbd +#endif + +#ifdef CONFIG_VIDEO_TEGRA +stdout+=,lcd +#endif diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index 6ed2fde..e14a0e1 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -24,131 +24,13 @@ #ifndef __TEGRA_COMMON_POST_H #define __TEGRA_COMMON_POST_H
-#ifdef CONFIG_BOOTCOMMAND - -#define BOOTCMDS_COMMON "" - -#else - -#ifdef CONFIG_CMD_MMC -#define BOOTCMDS_MMC \ - "mmc_boot=" \ - "setenv devtype mmc; " \ - "if mmc dev ${devnum}; then " \ - "run scan_boot; " \ - "fi\0" \ - "bootcmd_mmc0=setenv devnum 0; run mmc_boot;\0" \ - "bootcmd_mmc1=setenv devnum 1; run mmc_boot;\0" -#define BOOT_TARGETS_MMC "mmc1 mmc0" -#else -#define BOOTCMDS_MMC "" -#define BOOT_TARGETS_MMC "" -#endif - -#ifdef CONFIG_CMD_USB -#define BOOTCMD_INIT_USB "run usb_init; " -#define BOOTCMDS_USB \ - "usb_init=" \ - "if ${usb_need_init}; then " \ - "set usb_need_init false; " \ - "usb start 0; " \ - "fi\0" \ - \ - "usb_boot=" \ - "setenv devtype usb; " \ - BOOTCMD_INIT_USB \ - "if usb dev ${devnum}; then " \ - "run scan_boot; " \ - "fi\0" \ - \ - "bootcmd_usb0=setenv devnum 0; run usb_boot;\0" -#define BOOT_TARGETS_USB "usb0" -#else -#define BOOTCMD_INIT_USB "" -#define BOOTCMDS_USB "" -#define BOOT_TARGETS_USB "" -#endif - -#ifdef CONFIG_CMD_DHCP -#define BOOTCMDS_DHCP \ - "bootcmd_dhcp=" \ - BOOTCMD_INIT_USB \ - "if dhcp ${scriptaddr} boot.scr.uimg; then "\ - "source ${scriptaddr}; " \ - "fi\0" -#define BOOT_TARGETS_DHCP "dhcp" -#else -#define BOOTCMDS_DHCP "" -#define BOOT_TARGETS_DHCP "" -#endif - -#define BOOTCMDS_COMMON \ - "rootpart=1\0" \ - \ - "script_boot=" \ - "if load ${devtype} ${devnum}:${rootpart} " \ - "${scriptaddr} ${prefix}${script}; then " \ - "echo ${script} found! Executing ...;" \ - "source ${scriptaddr};" \ - "fi;\0" \ - \ - "scan_boot=" \ - "echo Scanning ${devtype} ${devnum}...; " \ - "for prefix in ${boot_prefixes}; do " \ - "for script in ${boot_scripts}; do " \ - "run script_boot; " \ - "done; " \ - "done;\0" \ - \ - "boot_targets=" \ - BOOT_TARGETS_MMC " " \ - BOOT_TARGETS_USB " " \ - BOOT_TARGETS_DHCP " " \ - "\0" \ - \ - "boot_prefixes=/ /boot/\0" \ - \ - "boot_scripts=boot.scr.uimg boot.scr\0" \ - \ - BOOTCMDS_MMC \ - BOOTCMDS_USB \ - BOOTCMDS_DHCP - -#define CONFIG_BOOTCOMMAND \ - "for target in ${boot_targets}; do run bootcmd_${target}; done" - -#endif - -#ifdef CONFIG_TEGRA_KEYBOARD -#define STDIN_KBD_KBC ",tegra-kbc" -#else -#define STDIN_KBD_KBC "" -#endif - #ifdef CONFIG_USB_KEYBOARD -#define STDIN_KBD_USB ",usbkbd" #define CONFIG_SYS_USB_EVENT_POLL #define CONFIG_PREBOOT "usb start" -#else -#define STDIN_KBD_USB "" #endif
-#ifdef CONFIG_VIDEO_TEGRA -#define STDOUT_LCD ",lcd" -#else -#define STDOUT_LCD "" -#endif - -#define TEGRA_DEVICE_SETTINGS \ - "stdin=serial" STDIN_KBD_KBC STDIN_KBD_USB "\0" \ - "stdout=serial" STDOUT_LCD "\0" \ - "stderr=serial" STDOUT_LCD "\0" \ - "" - #define CONFIG_EXTRA_ENV_SETTINGS \ - TEGRA_DEVICE_SETTINGS \ - MEM_LAYOUT_ENV_SETTINGS \ - BOOTCMDS_COMMON + MEM_LAYOUT_ENV_SETTINGS
#if defined(CONFIG_TEGRA20_SFLASH) || defined(CONFIG_TEGRA20_SLINK) || defined(CONFIG_TEGRA114_SPI) #define CONFIG_FDT_SPI
Presumably e.g. seaboard.env could #include "tegra20.env" in order to allow *.env to define MEM_LAYOUT_ENV_SETTINGS?
BTW, what's the #include -I path for these files? Perhaps it's worth setting it up as board/$vendor/$board/env board/$vendor/env arch/$arch/env to match the dtc+cpp patches I posted?
The first two lines there have no space after = and the last has space after +=. Does that get stripped? Should it?
-#else
Overall this change seems reasonable, but as I alluded to earlier, removing this from tegra-common-post.h will break Tegra boards for vendors other than NVIDIA. I guess that's part of why this patch is RFC.
Hi Stephen,
Hmmm maybe.
We could do that. I can't think of a down-side, but we need to decide on where these files should go and what each directory should contain. I am thinking that perhaps arch/arm/env might make sense and arch/arm/cpu/armv7/env also.
On the other hand, I'm really not keen to take this all to far on a first pass, and gain experience with it before building in lots of bells and whistles.
We do need that space. There is no stripping done here as it reduces flexibility.
-#else
Yes, that patch would need a bit of testing plus coming up with a solution to the problem you identified (see my comments above).
Stephen Warren
