[U-Boot-Users] [PATCH 16/18] include/configs: Catch some CONFIG_CMD_* conversion stragglers.
Use new CONFIG_CMD_* in lwmon5.h board config file. Fix CONFIG_CMD_* typo braindamage in omap1510inn.h
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/lwmon5.h | 57 +++++++++++++++++++++------------------- include/configs/omap1510inn.h | 2 - 2 files changed, 30 insertions(+), 29 deletions(-)
diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index c6f67fe..13cbed5 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -216,9 +216,6 @@ /* Comment this out to enable USB 1.1 device */ #define USB_2_0_DEVICE
-#define CMD_USB CFG_CMD_USB -#else -#define CMD_USB 0 /* no USB on 440GRx */ #endif /* CONFIG_440EPX */
/* Partitions */ @@ -226,36 +223,42 @@ #define CONFIG_DOS_PARTITION #define CONFIG_ISO_PARTITION
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_DIAG | \ - CFG_CMD_EEPROM | \ - CFG_CMD_ELF | \ - CFG_CMD_FAT | \ - CFG_CMD_I2C | \ - CFG_CMD_IRQ | \ - CFG_CMD_MII | \ - CFG_CMD_NET | \ - CFG_CMD_NFS | \ - CFG_CMD_PCI | \ - CFG_CMD_PING | \ - CFG_CMD_REGINFO | \ - CFG_CMD_SDRAM | \ - CMD_USB)
-#define CONFIG_SUPPORT_VFAT +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SDRAM + +#ifdef CONFIG_440EPX +#define CONFIG_CMD_USB +#endif
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h>
/*----------------------------------------------------------------------- * Miscellaneous configurable options *----------------------------------------------------------------------*/ +#define CONFIG_SUPPORT_VFAT + #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -418,7 +421,7 @@ *----------------------------------------------------------------------*/ #define CFG_DCACHE_SIZE (32<<10) /* For AMCC 440 CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
@@ -430,7 +433,7 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/omap1510inn.h b/include/configs/omap1510inn.h index 11fdb47..9f4be5c 100644 --- a/include/configs/omap1510inn.h +++ b/include/configs/omap1510inn.h @@ -86,8 +86,6 @@ #define CONFIG_BAUDRATE 115200 #define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL -
/* * Command line configuration.
Jon Loeliger
