[U-Boot] [PATCH] dm: remove pre reloc properties in SPL and TPL device tree
We can remove the pre reloc property in SPL and TPL device-tree: - u-boot,dm-pre-reloc - u-boot,dm-spl - u-boot,dm-tpl As only the needed node are kept by fdtgrep (1st pass).
The associated function (XXX_pre_reloc) are simple for SPL/TPL: return always true.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
Patch created after some remarks on previous http://patchwork.ozlabs.org/patch/1035797/
I check the current code and I found a way to reduce the SPL device tree size: remove the un-necessary pre reloc parameters in SPL/TPL DT (as the node check is already managed by fdtgrep)
But I need to change the DM code to avoid the check on presence of this parameters...
On my board stm32mp1-ev1, the SPL device tree is reduced by 790 bytes (11149 to 10419) and the SPL binary u-boot-spl.stm32 by 798 bytes (64745 to 63947); the boot is not broken and I have the expected delta between generated device tree.
But I don't sure that I see all the side impact of the code change in SPL/TPL.
PS: I already see a side effect on this patch, because all node are now bounded in SPL/TPL, it is no more needed to TAG all the device tree path but only the last needed children. But in this case phandle for parent node are not keep.
drivers/core/ofnode.c | 16 ++++++++-------- drivers/core/util.c | 31 +++++++++++++++---------------- scripts/Makefile.lib | 1 + 3 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 0e584c1..5a109dd 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -700,18 +700,18 @@ int ofnode_read_simple_size_cells(ofnode node)
bool ofnode_pre_reloc(ofnode node) { +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_TPL_BUILD) + /* for SPL and TPL the remaining nodes after the fdtgrep 1st pass + * had property dm-pre-reloc or u-boot,dm-spl/tpl. + * They are removed in final dtb (fdtgrep 2nd pass) + */ + return true; +#else if (ofnode_read_bool(node, "u-boot,dm-pre-reloc")) return true; if (ofnode_read_bool(node, "u-boot,dm-pre-proper")) return true;
-#ifdef CONFIG_TPL_BUILD - if (ofnode_read_bool(node, "u-boot,dm-tpl")) - return true; -#elif defined(CONFIG_SPL_BUILD) - if (ofnode_read_bool(node, "u-boot,dm-spl")) - return true; -#else /* * In regular builds individual spl and tpl handling both * count as handled pre-relocation for later second init. @@ -719,9 +719,9 @@ bool ofnode_pre_reloc(ofnode node) if (ofnode_read_bool(node, "u-boot,dm-spl") || ofnode_read_bool(node, "u-boot,dm-tpl")) return true; -#endif
return false; +#endif }
int ofnode_read_resource(ofnode node, uint index, struct resource *res) diff --git a/drivers/core/util.c b/drivers/core/util.c index 27a6848..451f772 100644 --- a/drivers/core/util.c +++ b/drivers/core/util.c @@ -33,16 +33,15 @@ int list_count_items(struct list_head *head)
bool dm_fdt_pre_reloc(const void *blob, int offset) { +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_TPL_BUILD) + /* for SPL and TPL the remaining nodes after the fdtgrep 1st pass + * had property dm-pre-reloc or u-boot,dm-spl/tpl. + * They are removed in final dtb (fdtgrep 2nd pass) + */ + return true; +#else if (fdt_getprop(blob, offset, "u-boot,dm-pre-reloc", NULL)) return true; - -#ifdef CONFIG_TPL_BUILD - if (fdt_getprop(blob, offset, "u-boot,dm-tpl", NULL)) - return true; -#elif defined(CONFIG_SPL_BUILD) - if (fdt_getprop(blob, offset, "u-boot,dm-spl", NULL)) - return true; -#else /* * In regular builds individual spl and tpl handling both * count as handled pre-relocation for later second init. @@ -57,16 +56,16 @@ bool dm_fdt_pre_reloc(const void *blob, int offset)
bool dm_ofnode_pre_reloc(ofnode node) { +#if defined(CONFIG_SPL_BUILD) || defined(CONFIG_TPL_BUILD) + /* for SPL and TPL the remaining nodes after the fdtgrep 1st pass + * had property dm-pre-reloc or u-boot,dm-spl/tpl. + * They are removed in final dtb (fdtgrep 2nd pass) + */ + return true; +#else if (ofnode_read_bool(node, "u-boot,dm-pre-reloc")) return true;
-#ifdef CONFIG_TPL_BUILD - if (ofnode_read_bool(node, "u-boot,dm-tpl")) - return true; -#elif defined(CONFIG_SPL_BUILD) - if (ofnode_read_bool(node, "u-boot,dm-spl")) - return true; -#else /* * In regular builds individual spl and tpl handling both * count as handled pre-relocation for later second init. @@ -74,7 +73,7 @@ bool dm_ofnode_pre_reloc(ofnode node) if (ofnode_read_bool(node, "u-boot,dm-spl") || ofnode_read_bool(node, "u-boot,dm-tpl")) return true; -#endif
return false; +#endif } diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index a5b57fc..3f4c86e 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -524,4 +524,5 @@ quiet_cmd_fdtgrep = FDTGREP $@ cmd_fdtgrep = $(objtree)/tools/fdtgrep $(fdtgrep_props) -RT $< \ -n /chosen -n /config -O dtb | \ $(objtree)/tools/fdtgrep -r -O dtb - -o $@ \ + -P u-boot,dm-pre-reloc -P u-boot,dm-spl -P u-boot,dm-tpl \ $(addprefix -P ,$(subst $",,$(CONFIG_OF_SPL_REMOVE_PROPS)))
Hi Patrick,
On Mon, 11 Feb 2019 at 19:50, Patrick Delaunay patrick.delaunay@st.com wrote:
- u-boot,dm-spl
- u-boot,dm-tpl
Yes that makes sense. I suppose we could enhance fdtgrep to handle this.
return true;
return true;
return true;
return false;
+#endif }
This function should really be removed. We should be able to use the ofnode version always.
return true;
return true;
return true;
return true;
return true;
return true;
return false;
-P u-boot,dm-pre-reloc -P u-boot,dm-spl -P u-boot,dm-tpl \ $(addprefix -P ,$(subst $\",,$(CONFIG_OF_SPL_REMOVE_PROPS)))
-- 2.7.4
Is there a documentation update you can do to describe how things now work?
Hi Simon,
From: Simon Glass sjg@chromium.org Sent: mardi 19 mars 2019 02:25
Hi Patrick,
- u-boot,dm-spl
- u-boot,dm-tpl
Probably but I checked the code but I don't found a way to handle with lidfdt.
I think is completely handle when a region is dumped (for father mode with FDT_REG_SUPERNODES) in dump_fdt_regions is doen without any property (including phandle), only FDT_BEGIN_NODE and FDT_END_NODE are used
=> p.want = WANT_NODES_ONLY vs WANT_NODES_AND_PROPS
return true;
return true;
return true;
return false;
+#endif }
Ok, I migrate the 2 calls of the function = drivers/clk/at91/pmc.c:64: !dm_fdt_pre_reloc(fdt, offset)) drivers/clk/altera/clk-arria10.c:257: if (pre_reloc_only && !dm_fdt_pre_reloc(fdt, offset))
and remove the function dm_fdt_pre_reloc in a separet patchset (today I think)
=> [PATCH 0/3] remove dm_fdt_pre_reloc, replaced by dm_ofnode_pre_reloc http://patchwork.ozlabs.org/project/uboot/list/?series=98272
PS: it is already done for dm_ofnode_pre_reloc() in http://patchwork.ozlabs.org/patch/1035799
return true;
return true;
return true;
return true;
return true;
return true;
return false;
- u-boot,dm-tpl \ $(addprefix -P ,$(subst
2.7.4
Yes I can try it ....
which documentation files is the correct place for you ?
In "Pre-Relocation Support" chapter of doc/ driver-model/README (as 'u-boot,dm-spl' and 'u-boot,dm-tpl' are only described here)
Or in doc/README.SPL and doc/READMETPL ?
Regards Patrick
Hi Patrick,
On Wed, 20 Mar 2019 at 11:24, Patrick DELAUNAY patrick.delaunay@st.com wrote:
Hi Simon,
Hi Patrick,
- u-boot,dm-spl
- u-boot,dm-tpl
return true;
return true;
return true;
return false;
+#endif }
return true;
return true;
return true;
return true;
return true;
return true;
return false;
2.7.4
Yes this seems better...
but perhaps add a link to the above from these, too?
- SImon
Patrick DELAUNAY
Patrick Delaunay
