[U-Boot] [PATCH v5 1/2] vf610twr: Add default environment in line with other Freescale boards
This adds a default environment which should be able to support both 3.0.15 from Timesys and upcoming 3.11.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v5: - remove mem=128M param (Alison/Andy/Fabio)
Changes in v4: - revert sys text address change (Alison) - add mem=128M to bootargs/netargs (Andy)
Changes in v3: - add dt boot support - use ttyLP1 as console - change loadaddr and sys text as iMX6SL - NOTE: It needs to be boot tested as I don't have the board
Changes in v2: - fix console for ttymxc1 (Fabio)
include/configs/vf610twr.h | 91 +++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 89 insertions(+), 2 deletions(-)
diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 77fe893..af772ca 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -83,8 +83,96 @@
#define CONFIG_BOOTDELAY 3
+#define CONFIG_LOADADDR 0x82000000 #define CONFIG_SYS_TEXT_BASE 0x3f008000
+#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "console=ttyLP1\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=vf610-twr.dtb\0" \ + "fdt_addr=0x81000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "update_sd_firmware_filename=u-boot.imx\0" \ + "update_sd_firmware=" \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "if mmc dev ${mmcdev}; then " \ + "if ${get_cmd} ${update_sd_firmware_filename}; then " \ + "setexpr fw_sz ${filesize} / 0x200; " \ + "setexpr fw_sz ${fw_sz} + 1; " \ + "mmc write ${loadaddr} 0x2 ${fw_sz}; " \ + "fi; " \ + "fi\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + /* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ @@ -101,8 +189,7 @@ #define CONFIG_SYS_MEMTEST_START 0x80010000 #define CONFIG_SYS_MEMTEST_END 0x87C00000
-#define CONFIG_SYS_LOAD_ADDR 0x80010000 - +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR #define CONFIG_SYS_HZ 1000
We've been dropping SoC name from U-Boot prompt as it increase complexity for automatic testing and makes line longer for no good reason.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
include/configs/vf610twr.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index af772ca..5012fc8 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -177,7 +177,7 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#define CONFIG_SYS_PROMPT "Vybrid U-Boot > " +#define CONFIG_SYS_PROMPT "=> " #undef CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE \
Tested-by: Andy Voltz andy.voltz@timesys.com
Best regards, Stefano Babic
I boot tested these patches using a yocto build. With our kernel I interrupted the autoboot and override mmcargs to include mem=128M argument.
Then I replaced kernel on the SD card with a linux-next uImage & dtb. That worked without any change to the environment.
For both tests I used twr-vf65gs10 tower kit.
Regards
Andy Voltz
Otavio Salvador
Stefano Babic
