[PATCH] wandboard: Convert to watchdog driver model
Commit 68dcbdd594d4 ("ARM: imx: Add weak default reset_cpu()") caused the 'reset' command in U-Boot to not cause a board reset.
Fix it by switching to the watchdog driver model via sysreset, which is the preferred method for implementing the watchdog reset.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi | 10 ++++++++++ configs/wandboard_defconfig | 3 +++ 2 files changed, 13 insertions(+)
diff --git a/arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi b/arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi index 46c4b3b31f4a..80921e80123f 100644 --- a/arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi +++ b/arch/arm/dts/imx6qdl-wandboard-u-boot.dtsi @@ -6,4 +6,14 @@ aliases { mmc0 = &usdhc3; }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + bootph-pre-ram; + }; +}; + +&wdog1 { + bootph-pre-ram; }; diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 168e2f086008..e9deab38038f 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -75,6 +75,8 @@ CONFIG_DM_PMIC_PFUZE100=y CONFIG_SCSI=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_VIDEO=y @@ -88,3 +90,4 @@ CONFIG_IMX_HDMI=y CONFIG_SPLASH_SCREEN=y CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_BMP_16BPP=y +CONFIG_IMX_WATCHDOG=y
Applied, thanks.
Fabio Estevam
