[U-Boot] [PATCH] ARM: socfpga: Clean up Kconfig entries
Shuffle the default Kconfig entries around so it is not such a mess. No functional change.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org --- arch/arm/Kconfig | 20 +++++++++++++++----- arch/arm/mach-socfpga/Kconfig | 30 ------------------------------ 2 files changed, 15 insertions(+), 35 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index c9d6e0a424..532aa41a87 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -733,14 +733,24 @@ config ARCH_SNAPDRAGON
config ARCH_SOCFPGA bool "Altera SOCFPGA family" + select ARCH_EARLY_INIT_R + select ARCH_MISC_INIT select CPU_V7A - select SUPPORT_SPL - select OF_CONTROL - select SPL_OF_CONTROL select DM select ENABLE_ARM_SOC_BOOT0_HOOK - select ARCH_EARLY_INIT_R - select ARCH_MISC_INIT + select OF_CONTROL + select SPL_LIBCOMMON_SUPPORT + select SPL_LIBDISK_SUPPORT + select SPL_LIBGENERIC_SUPPORT + select SPL_MMC_SUPPORT if DM_MMC + select SPL_NAND_SUPPORT if SPL_NAND_DENALI + select SPL_OF_CONTROL + select SPL_SERIAL_SUPPORT + select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT + select SPL_SPI_SUPPORT if DM_SPI + select SPL_WATCHDOG_SUPPORT + select SUPPORT_SPL + select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE select SYS_THUMB_BUILD imply CMD_MTDPARTS imply CRC32_VERIFY diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index afc38d5da9..824c9fc2ba 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -1,35 +1,5 @@ if ARCH_SOCFPGA
-config SPL_LIBCOMMON_SUPPORT - default y - -config SPL_LIBDISK_SUPPORT - default y - -config SPL_LIBGENERIC_SUPPORT - default y - -config SPL_MMC_SUPPORT - default y if DM_MMC - -config SPL_NAND_SUPPORT - default y if SPL_NAND_DENALI - -config SPL_SERIAL_SUPPORT - default y - -config SPL_SPI_FLASH_SUPPORT - default y if SPL_SPI_SUPPORT - -config SPL_SPI_SUPPORT - default y if DM_SPI - -config SPL_WATCHDOG_SUPPORT - default y - -config SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE - default y - config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE default 0xa2
select SUPPORT_SPL
select OF_CONTROL
select OF_CONTROL
select SUPPORT_SPL
default y
default y
default y
default y if DM_MMC
default y
default y if DM_SPI
default y
default y
-- 2.16.2
Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com
Ley Foon Tan
