[U-Boot] [PATCH] sunxi: Add support for NanoPi M1 board
NanoPi M1 is a board based on Allwinner H3 CPU.
This commit adds the support for this platform with: - a device tree which enables UART, LEDs, GPIO key switch, 3 USB host ports and the SD-card - a defconfig file for minimal support - a section in MAINTAINERS (add myself)
Based on the orangepi-pc and the device tree from the kernel.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun8i-h3-nanopi-m1.dts | 163 ++++++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 ++ configs/nanopi_m1_defconfig | 18 ++++ 4 files changed, 187 insertions(+) create mode 100644 arch/arm/dts/sun8i-h3-nanopi-m1.dts create mode 100644 configs/nanopi_m1_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ce34e3eeff..a0d9c2724a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -302,6 +302,7 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-pc-plus.dtb \ sun8i-h3-orangepi-plus.dtb \ sun8i-h3-orangepi-plus2e.dtb \ + sun8i-h3-nanopi-m1.dtb \ sun8i-h3-nanopi-neo.dtb \ sun8i-h3-nanopi-neo-air.dtb dtb-$(CONFIG_MACH_SUN50I_H5) += \ diff --git a/arch/arm/dts/sun8i-h3-nanopi-m1.dts b/arch/arm/dts/sun8i-h3-nanopi-m1.dts new file mode 100644 index 0000000000..05b533051c --- /dev/null +++ b/arch/arm/dts/sun8i-h3-nanopi-m1.dts @@ -0,0 +1,163 @@ +/* + * Copyright (C) 2017 Mylène Josserand mylene.josserand@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-h3.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "FriendlyArm NanoPi M1"; + compatible = "friendlyarm,nanopi-m1", "allwinner,sun8i-h3"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&leds_npi>, <&leds_r_npi>; + + status { + label = "nanopi:blue:status"; + gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + pwr { + label = "nanopi:green:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + }; + + r_gpio_keys { + compatible = "gpio-keys"; + input-name = "k1"; + pinctrl-names = "default"; + pinctrl-0 = <&sw_r_npi>; + + k1@0 { + label = "k1"; + linux,code = <KEY_POWER>; + gpios = <&r_pio 0 3 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&ehci1 { + status = "okay"; +}; + +&ehci2 { + status = "okay"; +}; + +&ehci3 { + status = "okay"; +}; + +&mmc0 { + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 */ + cd-inverted; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; + status = "okay"; + vmmc-supply = <®_vcc3v3>; +}; + +&ohci1 { + status = "okay"; +}; + +&ohci2 { + status = "okay"; +}; + +&ohci3 { + status = "okay"; +}; + +&pio { + leds_npi: led_pins@0 { + allwinner,pins = "PA10"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +&r_pio { + leds_r_npi: led_pins@0 { + allwinner,pins = "PL10"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + + sw_r_npi: key_pins@0 { + allwinner,pins = "PL3"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usbphy { + /* USB VBUS is always on */ + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 2a712fe4b5..f916160ef9 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -227,6 +227,11 @@ M: Siarhei Siamashka siarhei.siamashka@gmail.com S: Maintained F: configs/MSI_Primo81_defconfig
+NANOPI-M1 BOARD +M: Mylène Josserand mylene.josserand@free-electrons.com +S: Maintained +F: configs/nanopi_m1_defconfig + NANOPI-NEO BOARD M: Jelle van der Waa jelle@vdwaa.nl S: Maintained diff --git a/configs/nanopi_m1_defconfig b/configs/nanopi_m1_defconfig new file mode 100644 index 0000000000..611c089df0 --- /dev/null +++ b/configs/nanopi_m1_defconfig @@ -0,0 +1,18 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN8I_H3=y +CONFIG_DRAM_CLK=408 +CONFIG_DRAM_ZQ=3881979 +CONFIG_DRAM_ODT_EN=y +CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_ISO_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y
Hi Mylene,
- sun8i-h3-nanopi-m1.dtb \ sun8i-h3-nanopi-neo.dtb \ sun8i-h3-nanopi-neo-air.dtb
- Copyright (C) 2017 Mylène Josserand mylene.josserand@free-electrons.com
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- model = "FriendlyArm NanoPi M1";
- compatible = "friendlyarm,nanopi-m1", "allwinner,sun8i-h3";
- aliases {
serial0 = &uart0;
- chosen {
- leds {
status {
pwr {
- r_gpio_keys {
input-name = "k1";
k1@0 {
label = "k1";
+&ehci1 {
- status = "okay";
+&ehci2 {
- status = "okay";
+&ehci3 {
- status = "okay";
+&mmc0 {
- bus-width = <4>;
- cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 */
- cd-inverted;
- pinctrl-names = "default";
- pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>;
- status = "okay";
- vmmc-supply = <®_vcc3v3>;
+&ohci1 {
- status = "okay";
+&ohci2 {
- status = "okay";
+&ohci3 {
- status = "okay";
+&pio {
- leds_npi: led_pins@0 {
+&r_pio {
- leds_r_npi: led_pins@0 {
- sw_r_npi: key_pins@0 {
+&uart0 {
- pinctrl-0 = <&uart0_pins_a>;
- status = "okay";
+&usbphy {
- /* USB VBUS is always on */
- status = "okay";
The way we usually handle things is by syncing the DT with the kernel's. We already have a device tree in the kernel for this board, so this would mean bringing it to U-Boot, and then adding your device tree.
And I would love to see any patch improving the Linux DT ;)
What do you need that option for?
Thanks! Maxime
Hi Maxime,
Thank you for the review!
On 19/04/2017 16:57, Maxime Ripard wrote:
Hi Mylene,
- whole.
conditions:
- aliases {
serial0 = &uart0;
- chosen {
- leds {
status {
pwr {
- r_gpio_keys {
input-name = "k1";
k1@0 {
label = "k1";
+&ehci1 {
- status = "okay";
+&ehci2 {
- status = "okay";
+&ehci3 {
- status = "okay";
+&mmc0 {
- bus-width = <4>;
- cd-inverted;
- status = "okay";
+&ohci1 {
- status = "okay";
+&ohci2 {
- status = "okay";
+&ohci3 {
- status = "okay";
+&pio {
+&r_pio {
+&uart0 {
- status = "okay";
+&usbphy {
- status = "okay";
I based it on the one from the kernel but as it handles a nanopi.dtsi, I "merged" the nanopi-m1.dts and nanopi.dtsi files to this one. Should I create a nanopi.dtsi and update also the nanopi-neo to include it?
Sure :)
Right, I do not think it is needed. I will remove it.
Maxime Ripard
Mylene Josserand
Mylène Josserand
