[PATCH] mtd: rawnand: fsl_elbc: Fix reading address pointer from DT
During compilation gcc throws warning:
drivers/mtd/nand/raw/fsl_elbc_nand.c: In function ‘fsl_elbc_nand_probe’: drivers/mtd/nand/raw/fsl_elbc_nand.c:841:31: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] return fsl_elbc_chip_init(0, (void *)dev_read_addr(dev), dev); ^
Fix it by using dev_read_addr_ptr() function which returns pointer instead of dev_read_addr() which returns integer type.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/mtd/nand/raw/fsl_elbc_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/raw/fsl_elbc_nand.c b/drivers/mtd/nand/raw/fsl_elbc_nand.c index 48a3687f2728..4a07cf854fff 100644 --- a/drivers/mtd/nand/raw/fsl_elbc_nand.c +++ b/drivers/mtd/nand/raw/fsl_elbc_nand.c @@ -839,7 +839,7 @@ void board_nand_init(void)
static int fsl_elbc_nand_probe(struct udevice *dev) { - return fsl_elbc_chip_init(0, (void *)dev_read_addr(dev), dev); + return fsl_elbc_chip_init(0, dev_read_addr_ptr(dev), dev); }
static const struct udevice_id fsl_elbc_nand_dt_ids[] = {
Hi Pali
2.20.1
Reviewed-by: Dario Binacchi dario.binacchi@amarulasolutions.com
Thanks and regards, Dario
On Mon, Aug 22, 2022 at 11:06 AM Dario Binacchi dario.binacchi@amarulasolutions.com wrote:
Hi Pali
2.20.1
Applied thanks
Thanks and regards, Dario --
Dario Binacchi
Embedded Linux Developer
Amarula Solutions SRL
Via Le Canevare 30, 31100 Treviso, Veneto, IT
T. +39 042 243 5310 info@amarulasolutions.com
www.amarulasolutions.com
Dario Binacchi
Michael Nazzareno Trimarchi
Pali Rohár
