Re: [U-Boot] [PATCH v5 1/4] riscv: Add kconfig option to run U-Boot in S-mode
Subject: [PATCH v5 1/4] riscv: Add kconfig option to run U-Boot in S-mode
This patch adds kconfig option RISCV_SMODE to run U-Boot in S-mode. When this opition is enabled we use s<xyz> CSRs instead of m<xyz> CSRs.
It is important to note that there is no equivalent S-mode CSR for misa and mhartid CSRs so we expect M-mode runtime firmware (BBL or equivalent) to emulate misa and mhartid CSR read.
In-future, we will have more patches to avoid accessing misa and mhartid CSRs from S-mode.
Signed-off-by: Anup Patel anup@brainfault.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Lukas Auer lukas.auer@aisec.fraunhofer.de
arch/riscv/Kconfig | 5 +++++ arch/riscv/cpu/start.S | 33 ++++++++++++++++++++++++++++ arch/riscv/include/asm/encoding.h | 2 ++ arch/riscv/lib/interrupts.c | 36 +++++++++++++++++++++++-------- 4 files changed, 67 insertions(+), 9 deletions(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 3e0af55e71..732a357a99 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -55,6 +55,11 @@ config RISCV_ISA_C config RISCV_ISA_A def_bool y
+config RISCV_SMODE
bool "Run in S-Mode"
help
Enable this option to build U-Boot for RISC-V S-Mode
config 32BIT bool
diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 15e1b8199a..704190f946 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -41,10 +41,18 @@ _start: li t0, CONFIG_SYS_SDRAM_BASE SREG a2, 0(t0) la t0, trap_entry +#ifdef CONFIG_RISCV_SMODE
csrw stvec, t0
+#else csrw mtvec, t0 +#endif
/* mask all interrupts */
csrw sie, zero
+#else csrw mie, zero +#endif
/* Enable cache */ jal icache_enable
@@ -166,7 +174,11 @@ fix_rela_dyn: */ la t0, trap_entry add t0, t0, t6 +#ifdef CONFIG_RISCV_SMODE
csrw stvec, t0
clear_bss: la t0, __bss_start /* t0 <- rel __bss_start in FLASH */ @@ -238,17 +250,34 @@ trap_entry: SREG x29, 29*REGBYTES(sp) SREG x30, 30*REGBYTES(sp) SREG x31, 31*REGBYTES(sp) +#ifdef CONFIG_RISCV_SMODE
csrr a0, scause
csrr a1, sepc
+#else csrr a0, mcause csrr a1, mepc +#endif mv a2, sp jal handle_trap +#ifdef CONFIG_RISCV_SMODE
csrw sepc, a0
+#else csrw mepc, a0 +#endif
+#ifdef CONFIG_RISCV_SMODE +/*
- Remain in S-mode after sret
li t0, SSTATUS_SPP
csrs sstatus, t0
+#else /*
- Remain in M-mode after mret
*/ li t0, MSTATUS_MPP csrs mstatus, t0 +#endif
It only the difference between s and m in csr. The code seem to be duplicate too much. Can you implement it in macro ? or consider to separate it in different .S file
It may too complex to maintain in the future.
B.R Rick
LREG x1, 1*REGBYTES(sp) LREG x2, 2*REGBYTES(sp) LREG x3, 3*REGBYTES(sp)
@@ -281,4 +310,8 @@ trap_entry: LREG x30, 30*REGBYTES(sp) LREG x31, 31*REGBYTES(sp) addi sp, sp, 32*REGBYTES +#ifdef CONFIG_RISCV_SMODE
sret
+#else mret +#endif diff --git a/arch/riscv/include/asm/encoding.h b/arch/riscv/include/asm/encoding.h index 9ea50ce640..153f5af2ff 100644 --- a/arch/riscv/include/asm/encoding.h +++ b/arch/riscv/include/asm/encoding.h @@ -143,6 +143,8 @@ # define MCAUSE_CAUSE MCAUSE32_CAUSE #endif
+#define SCAUSE_INT MCAUSE_INT
#define RISCV_PGSHIFT 12 #define RISCV_PGSIZE BIT(RISCV_PGSHIFT)
diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index 903a1c4cd5..8793f233d0 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -34,17 +34,35 @@ int disable_interrupts(void) return 0; }
-ulong handle_trap(ulong mcause, ulong epc, struct pt_regs *regs) +ulong handle_trap(ulong cause, ulong epc, struct pt_regs *regs) {
ulong is_int;
ulong is_irq, irq;
is_int = (mcause & MCAUSE_INT);
if ((is_int) && ((mcause & MCAUSE_CAUSE) == IRQ_M_EXT))
external_interrupt(0); /* handle_m_ext_interrupt */
else if ((is_int) && ((mcause & MCAUSE_CAUSE) == IRQ_M_TIMER))
timer_interrupt(0); /* handle_m_timer_interrupt */
else
_exit_trap(mcause, epc, regs);
is_irq = (cause & SCAUSE_INT);
irq = (cause & ~SCAUSE_INT);
+#else
is_irq = (cause & MCAUSE_INT);
irq = (cause & ~MCAUSE_INT);
if (is_irq) {
switch (irq) {
case IRQ_M_EXT:
case IRQ_S_EXT:
external_interrupt(0); /* handle external interrupt */
break;
case IRQ_M_TIMER:
case IRQ_S_TIMER:
timer_interrupt(0); /* handle timer interrupt */
break;
default:
_exit_trap(cause, epc, regs);
break;
} else {
} return epc;
2.17.1
+config RISCV_SMODE
help
config 32BIT bool
csrw stvec, t0
csrw sie, zero
csrw stvec, t0
csrr a0, scause
csrr a1, sepc
csrw sepc, a0
li t0, SSTATUS_SPP
csrs sstatus, t0
+#else /*
Here are few reasons why not to do this: 1. We don't have same set of CSRs for M-mode and S-mode. For certain, M-mode CSRs we don't have any corresponding S-mode CSRs. 2. Number of CSRs for each mode are really few so there won't be much #ifdef in code. Having separate .S will be total overkill and too much code duplication. 3. Using macro would mean we use incomplete CSR names examples: "status" for "mstatus"/"sstatus", "epc" for "mepc"/"sepc", etc. This means we cannot grep code for use of a CSR. I think this is less readable compared to using #ifdef
Despite above reasons, above can always be attempted as separate patch.
Regards, Anup
+config RISCV_SMODE
help
config 32BIT bool
csrw stvec, t0
csrw sie, zero
csrw stvec, t0
csrr a0, scause
csrr a1, sepc
csrw sepc, a0
li t0, SSTATUS_SPP
csrs sstatus, t0
+#else /*
- We don't have same set of CSRs for M-mode and S-mode. For
On AArch64, we determine the current EL during runtime and then branch to respective labels for different ELs (see the switch_el macro for asm as well as current_el() for C).
Wouldn't it make sense to attempt something similar with S-mode, so that the same binary can run either in M or in S depending on how it was started?
Alex
+config RISCV_SMODE
help
config 32BIT bool
csrw stvec, t0
csrw sie, zero
csrw stvec, t0
csrr a0, scause
csrr a1, sepc
csrw sepc, a0
li t0, SSTATUS_SPP
csrs sstatus, t0
+#else /*
As-per my understand, there is no direct way of knowing current execution mode in RISC-V at runtime.
Of course, software can step from M to S/U using mret OR from S to U using sret. Further software running in U-mode can do ecall to S-mode and S-mode can do ecall to M-mode.
Software is generally written for a particular execution mode (M, S, or U).
Regards, Anup
Anup Patel anup@brainfault.org 於 2018年11月27日 週二 下午8:38寫道:
+config RISCV_SMODE
help
config 32BIT bool
csrw stvec, t0
csrw sie, zero
csrw stvec, t0
csrr a0, scause
csrr a1, sepc
csrw sepc, a0
li t0, SSTATUS_SPP
csrs sstatus, t0
+#else /*
Hi Anup
I mean it is not a good way to switch s and m mode like that #ifdef CONFIG_RISCV_SMODE csrw sepc, a0 #else csrw mepc, a0 #endif
You can use ## to get stvec ot mtvec in different CONFIG It can be refered to some kernel code as below: glue.h #define ____glue(name,fn) name##fn #define __glue(name,fn) ____glue(name,fn)
glue-proc.h #ifdef CONFIG_CPU_ARM720T #define CPU_NAME cpu_arm720 #else #define CPU_NAME cpu_arm7tdmi #endif
#define cpu_proc_init __glue(CPU_NAME,_proc_init)
Then It will compile as cpu_arm720_proc_init or cpu_arm7tdmi_proc_init in different configuration. stvec and mtvce can be implement by the same way.
B.R Rick
Regards, Anup
> Subject: [PATCH v5 1/4] riscv: Add kconfig option to run U-Boot in S-mode > > This patch adds kconfig option RISCV_SMODE to run U-Boot in S-mode. When this > opition is enabled we use s<xyz> CSRs instead of m<xyz> CSRs. > > It is important to note that there is no equivalent S-mode CSR for misa and > mhartid CSRs so we expect M-mode runtime firmware (BBL or equivalent) to > emulate misa and mhartid CSR read. > > In-future, we will have more patches to avoid accessing misa and mhartid CSRs > from S-mode. > > Signed-off-by: Anup Patel anup@brainfault.org > Reviewed-by: Bin Meng bmeng.cn@gmail.com > Tested-by: Bin Meng bmeng.cn@gmail.com > Reviewed-by: Lukas Auer lukas.auer@aisec.fraunhofer.de > --- > arch/riscv/Kconfig | 5 +++++ > arch/riscv/cpu/start.S | 33 ++++++++++++++++++++++++++++ > arch/riscv/include/asm/encoding.h | 2 ++ > arch/riscv/lib/interrupts.c | 36 +++++++++++++++++++++++-------- > 4 files changed, 67 insertions(+), 9 deletions(-) > > diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 3e0af55e71..732a357a99 > 100644 > --- a/arch/riscv/Kconfig > +++ b/arch/riscv/Kconfig > @@ -55,6 +55,11 @@ config RISCV_ISA_C > config RISCV_ISA_A > def_bool y > > +config RISCV_SMODE > + bool "Run in S-Mode" > + help > + Enable this option to build U-Boot for RISC-V S-Mode > + > config 32BIT > bool > > diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index > 15e1b8199a..704190f946 100644 > --- a/arch/riscv/cpu/start.S > +++ b/arch/riscv/cpu/start.S > @@ -41,10 +41,18 @@ _start: > li t0, CONFIG_SYS_SDRAM_BASE > SREG a2, 0(t0) > la t0, trap_entry > +#ifdef CONFIG_RISCV_SMODE > + csrw stvec, t0 > +#else > csrw mtvec, t0 > +#endif > > /* mask all interrupts */ > +#ifdef CONFIG_RISCV_SMODE > + csrw sie, zero > +#else > csrw mie, zero > +#endif > > /* Enable cache */ > jal icache_enable > @@ -166,7 +174,11 @@ fix_rela_dyn: > */ > la t0, trap_entry > add t0, t0, t6 > +#ifdef CONFIG_RISCV_SMODE > + csrw stvec, t0 > +#else > csrw mtvec, t0 > +#endif > > clear_bss: > la t0, __bss_start /* t0 <- rel __bss_start in FLASH */ > @@ -238,17 +250,34 @@ trap_entry: > SREG x29, 29*REGBYTES(sp) > SREG x30, 30*REGBYTES(sp) > SREG x31, 31*REGBYTES(sp) > +#ifdef CONFIG_RISCV_SMODE > + csrr a0, scause > + csrr a1, sepc > +#else > csrr a0, mcause > csrr a1, mepc > +#endif > mv a2, sp > jal handle_trap > +#ifdef CONFIG_RISCV_SMODE > + csrw sepc, a0 > +#else > csrw mepc, a0 > +#endif > > +#ifdef CONFIG_RISCV_SMODE > +/* > + * Remain in S-mode after sret > + */ > + li t0, SSTATUS_SPP > + csrs sstatus, t0 > +#else > /* > * Remain in M-mode after mret > */ > li t0, MSTATUS_MPP > csrs mstatus, t0 > +#endif
Hi Anup
I had understood your suggestion previously.
Though I am not fan of this approach, I will change it anyway.
Thanks, Anup
Alexander Graf
Anup Patel
Rick Chen
