[U-Boot] [PATCH 1/2] part_dos: align disk buffers on cache line to enable DMA and cache
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- disk/part_dos.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/disk/part_dos.c b/disk/part_dos.c index b5bcb37..c028aaf 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -87,7 +87,7 @@ static int test_block_type(unsigned char *buffer)
int test_part_dos (block_dev_desc_t *dev_desc) { - unsigned char buffer[dev_desc->blksz]; + ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buffer, dev_desc->blksz);
if ((dev_desc->block_read(dev_desc->dev, 0, 1, (ulong *) buffer) != 1) || (buffer[DOS_PART_MAGIC_OFFSET + 0] != 0x55) || @@ -102,7 +102,7 @@ int test_part_dos (block_dev_desc_t *dev_desc) static void print_partition_extended (block_dev_desc_t *dev_desc, int ext_part_sector, int relative, int part_num) { - unsigned char buffer[dev_desc->blksz]; + ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buffer, dev_desc->blksz); dos_partition_t *pt; int i;
@@ -166,7 +166,7 @@ static int get_partition_info_extended (block_dev_desc_t *dev_desc, int ext_part int relative, int part_num, int which_part, disk_partition_t *info) { - unsigned char buffer[dev_desc->blksz]; + ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buffer, dev_desc->blksz); dos_partition_t *pt; int i;
Acked-by: Mike Frysinger vapier@gentoo.org -mike
On 03.03.2012 23:02, Eric Nelson wrote:
Signed-off-by: Eric Nelsoneric.nelson@boundarydevices.com
Anybody likes to comment/apply this patch?
Many thanks!
Dirk
- ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buffer, dev_desc->blksz); dos_partition_t *pt; int i;
On Sat, 3 Mar 2012 15:02:20 -0700 Eric Nelson eric.nelson@boundarydevices.com wrote:
Applied to u-boot-staging/agust@denx.de, thanks!
Anatolij
Anatolij Gustschin
Dirk Behme
Eric Nelson
Mike Frysinger
