[PATCH] sunxi: Add Inet 86V Rev 2 support
Add Inet 86V Rev 2 support, based upon Inet 86VS.
Missing things: - Accelerometer (MXC6225X) - Touchpanel (Sitronix SL1536) - Nand (29F32G08CBACA) - Camera (HCWY0308)
Signed-off-by: Alexandre GRIVEAUX agriveaux@deutnet.info --- arch/arm/dts/Makefile | 3 ++- arch/arm/dts/sun5i-a13-inet-86v-rev2.dts | 17 +++++++++++++++ configs/inet86v_rev2_defconfig | 27 ++++++++++++++++++++++++ 3 files changed, 46 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun5i-a13-inet-86v-rev2.dts create mode 100644 configs/inet86v_rev2_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 6915783d9c..7a0f1c0484 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -444,7 +444,8 @@ dtb-$(CONFIG_MACH_SUN5I) += \ sun5i-a13-q8-tablet.dtb \ sun5i-a13-utoo-p66.dtb \ sun5i-gr8-chip-pro.dtb \ - sun5i-r8-chip.dtb + sun5i-r8-chip.dtb \ + sun5i-a13-inet-86v-rev2.dtb dtb-$(CONFIG_MACH_SUN6I) += \ sun6i-a31-app4-evb1.dtb \ sun6i-a31-colombus.dtb \ diff --git a/arch/arm/dts/sun5i-a13-inet-86v-rev2.dts b/arch/arm/dts/sun5i-a13-inet-86v-rev2.dts new file mode 100644 index 0000000000..9b4c5349f0 --- /dev/null +++ b/arch/arm/dts/sun5i-a13-inet-86v-rev2.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 Alexandre Griveaux agriveaux@deutnet.info + * + * Minimal dts file for the iNet 86V + */ + +/dts-v1/; + +#include "sun5i-a13.dtsi" +#include "sun5i-reference-design-tablet.dtsi" + +/ { + model = "iNET 86V Rev 02"; + compatible = "primux,inet86v-rev2", "allwinner,sun5i-a13"; + +}; diff --git a/configs/inet86v_rev2_defconfig b/configs/inet86v_rev2_defconfig new file mode 100644 index 0000000000..f8dbd14c0b --- /dev/null +++ b/configs/inet86v_rev2_defconfig @@ -0,0 +1,27 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN5I=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +# CONFIG_MACH_SUN5I=y +CONFIG_DRAM_CLK=432 +CONFIG_MMC0_CD_PIN="PG0" +CONFIG_USB0_VBUS_PIN="PG12" +CONFIG_USB0_VBUS_DET="PG1" +CONFIG_USB0_ID_DET="PG2" +CONFIG_AXP_GPIO=y +# CONFIG_VIDEO_HDMI is not set +CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" +CONFIG_VIDEO_LCD_POWER="AXP0-0" +CONFIG_VIDEO_LCD_BL_EN="AXP0-1" +CONFIG_VIDEO_LCD_BL_PWM="PB2" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_USE_PREBOOT=y +CONFIG_SPL_I2C_SUPPORT=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-86v-rev2" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_CONS_INDEX=2 +CONFIG_USB_MUSB_HOST=y +CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
Missing things:
- Camera (HCWY0308)
Is it is copy from Linux, if yes please specific sha1?
sun5i-r8-chip.dtb
sun5i-r8-chip.dtb \
- Copyright 2020 Alexandre Griveaux agriveaux@deutnet.info
- Minimal dts file for the iNet 86V
+/dts-v1/;
few of the configs now supported via kconfig, so please rebase u-boot-sunxi/master
Jagan.
Jagan Teki
