[U-Boot-Users] [PATCH] ARM: AT91RM9200 based boards config cleanup
Signed-off-by: Ladislav Michl ladis@linux-mips.org
Remove nowhere used struct bd_info_ext, remove trailing whitespaces, fix indentation.
diff --git a/include/configs/at91rm9200dk.h b/include/configs/at91rm9200dk.h index a65c5f3..96dbe4b 100644 --- a/include/configs/at91rm9200dk.h +++ b/include/configs/at91rm9200dk.h @@ -170,8 +170,8 @@
#define CONFIG_HAS_DATAFLASH 1 #define CFG_SPI_WRITE_TOUT (5*CFG_HZ) -#define CFG_MAX_DATAFLASH_BANKS 2 -#define CFG_MAX_DATAFLASH_PAGES 16384 +#define CFG_MAX_DATAFLASH_BANKS 2 +#define CFG_MAX_DATAFLASH_PAGES 16384 #define CFG_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* Logical adress for CS0 */ #define CFG_DATAFLASH_LOGIC_ADDR_CS3 0xD0000000 /* Logical adress for CS3 */
@@ -213,35 +213,16 @@ #define CFG_U_BOOT_SIZE 0x10000 /* 64 KBytes */ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */
-#define CFG_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } +#define CFG_BAUDRATE_TABLE { 115200, 19200, 38400, 57600, 9600 }
#define CFG_PROMPT "U-Boot> " /* Monitor Command Prompt */ #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ #define CFG_MAXARGS 16 /* max number of command args */ #define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */
-#ifndef __ASSEMBLY__ -/*----------------------------------------------------------------------- - * Board specific extension for bd_info - * - * This structure is embedded in the global bd_info (bd_t) structure - * and can be used by the board specific code (eg board/...) - */ - -struct bd_info_ext { - /* helper variable for board environment handling - * - * env_crc_valid == 0 => uninitialised - * env_crc_valid > 0 => environment crc in flash is valid - * env_crc_valid < 0 => environment crc in flash is invalid - */ - int env_crc_valid; -}; -#endif - #define CFG_HZ 1000 #define CFG_HZ_CLOCK AT91C_MASTER_CLOCK/2 /* AT91C_TC0_CMR is implicitly set to */ - /* AT91C_TC_TIMER_DIV1_CLOCK */ + /* AT91C_TC_TIMER_DIV1_CLOCK */
#define CONFIG_STACKSIZE (32*1024) /* regular stack */
diff --git a/include/configs/cmc_pu2.h b/include/configs/cmc_pu2.h index f32c8c2..d22d350 100644 --- a/include/configs/cmc_pu2.h +++ b/include/configs/cmc_pu2.h @@ -148,7 +148,7 @@
#define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM 0x20000000 -#define PHYS_SDRAM_SIZE 0x1000000 /* 16 megs */ +#define PHYS_SDRAM_SIZE 0x1000000 /* 16 megs */
#define CFG_MEMTEST_START PHYS_SDRAM #define CFG_MEMTEST_END CFG_MEMTEST_START + PHYS_SDRAM_SIZE - 262144 @@ -186,25 +186,6 @@ #define CFG_MAXARGS 32 /* max number of command args */ #define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */
-#ifndef __ASSEMBLY__ -/*----------------------------------------------------------------------- - * Board specific extension for bd_info - * - * This structure is embedded in the global bd_info (bd_t) structure - * and can be used by the board specific code (eg board/...) - */ - -struct bd_info_ext { - /* helper variable for board environment handling - * - * env_crc_valid == 0 => uninitialised - * env_crc_valid > 0 => environment crc in flash is valid - * env_crc_valid < 0 => environment crc in flash is invalid - */ - int env_crc_valid; -}; -#endif /* __ASSEMBLY__ */ - #define CFG_HZ 1000 #define CFG_HZ_CLOCK (AT91C_MASTER_CLOCK/2) /* AT91C_TC0_CMR is implicitly set to */ /* AT91C_TC_TIMER_DIV1_CLOCK */ diff --git a/include/configs/csb637.h b/include/configs/csb637.h index 976dae3..f93c3bc 100644 --- a/include/configs/csb637.h +++ b/include/configs/csb637.h @@ -170,8 +170,8 @@
#undef CONFIG_HAS_DATAFLASH #define CFG_SPI_WRITE_TOUT (5*CFG_HZ) -#define CFG_MAX_DATAFLASH_BANKS 0 -#define CFG_MAX_DATAFLASH_PAGES 16384 +#define CFG_MAX_DATAFLASH_BANKS 0 +#define CFG_MAX_DATAFLASH_PAGES 16384 #define CFG_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* Logical adress for CS0 */ #define CFG_DATAFLASH_LOGIC_ADDR_CS3 0xD0000000 /* Logical adress for CS3 */
@@ -209,35 +209,16 @@
#define CFG_LOAD_ADDR 0x21000000 /* default load address */
-#define CFG_BAUDRATE_TABLE {115200, 57600, 38400, 19200, 9600 } +#define CFG_BAUDRATE_TABLE { 115200, 57600, 38400, 19200, 9600 }
diff --git a/include/configs/mp2usb.h b/include/configs/mp2usb.h index ea5a44b..294221f 100644 --- a/include/configs/mp2usb.h +++ b/include/configs/mp2usb.h @@ -47,7 +47,7 @@
#define CFG_ATMEL_PLL_INIT_BUG 1 #ifndef CONFIG_SKIP_LOWLEVEL_INIT -#define CFG_USE_MAIN_OSCILLATOR 1 +#define CFG_USE_MAIN_OSCILLATOR 1 /* flash */ #define MC_PUIA_VAL 0x00000000 #define MC_PUP_VAL 0x00000000 @@ -216,25 +216,6 @@ #define CFG_DEVICE_DEREGISTER /* needs device_deregister */ #define LITTLEENDIAN 1 /* used by usb_ohci.c */
Applied, thanks.
Ladislav Michl
