[GIT PULL] please pull fsl-qoirq-2022-7-29
Hi Tom,
Please pull fsl-qoriq-2022-7-29
---------------------------------------- mpc85xx: support for generating QorIQ pre-PBL eSDHC boot sector p1_p2_rdb_pc: Remove I-flag from second L2 SRAM mapping p1_p2_rdb_pc: Fix parsing inverted bits from boot input data p1_p2_rdb_pc: Simplify SPL offset macros ----------------------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-fsl-qoriq/-/pipelines/12929
Thanks, Peng.
The following changes since commit 87069c79e830b2ab909537946a1e1db0e5fe7d8c:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-mmc (2022-07-27 07:00:54 -0400)
https://source.denx.de/u-boot/custodians/u-boot-fsl-qoriq.git tags/fsl-qoriq-2022-7-29
for you to fetch changes up to 3982e761dcdec45db17207dee3851397fe23f45d:
board: freescale: p1_p2_rdb_pc: Simplify SPL offset macros (2022-07-29 19:49:13 +0800)
---------------------------------------------------------------- Pali Rohár (4): powerpc: mpc85xx: Add support for generating QorIQ pre-PBL eSDHC boot sector board: freescale: p1_p2_rdb_pc: Remove I-flag from second L2 SRAM mapping board: freescale: p1_p2_rdb_pc: Fix parsing inverted bits from boot input data board: freescale: p1_p2_rdb_pc: Simplify SPL offset macros
arch/powerpc/cpu/mpc85xx/Kconfig | 53 +++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/start.S | 94 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 8 ++++++++ arch/powerpc/cpu/mpc85xx/u-boot.lds | 8 ++++++++ board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 6 ++++-- board/freescale/p1_p2_rdb_pc/tlb.c | 4 ++-- include/configs/p1_p2_rdb_pc.h | 12 ++++++------ 7 files changed, 175 insertions(+), 10 deletions(-)
Peng Fan
