Pull request for UEFI sub-system for efi-2020-04-rc5
Hello Tom,
this replaces the efi-2020-04-rc4-6 pull request.
I have added another patch for checking OF_CONTROL as a prerequisite for a Python test.
Gitlab CI and Travis CI showed no problems:
https://gitlab.denx.de/u-boot/custodians/u-boot-efi/pipelines/2568 https://travis-ci.org/github/xypron2/u-boot/builds/668892252
Best regards
Heinrich
The following changes since commit 350c44dfb99017e9147ee07d37a40626bde62250:
Merge branch '2020-03-27-master-imports' (2020-03-27 17:54:38 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2020-04-rc5
for you to fetch changes up to 67357553ad59eb9b4f412412252e02868ceb16dc:
test/py: test_efi_grub_net() requires OF_CONTROL (2020-03-30 20:27:42 +0200)
---------------------------------------------------------------- Pull request for UEFI sub-system for efi-2020-04-rc5
This series fixes:
* UEFI Python tests CONFIG_OF_CONTROL=y. * int to pointer cast warning for cmd/efidebug.c * memory reservation even if fdt node is disabled
Now that the Python test is fixed reintroduce the reverted patch for vexpress_ca9x4 to enable EFI_LOADER and define the dtb file name.
---------------------------------------------------------------- Heinrich Schuchardt (4): test/py: UEFI helloworld requires OF_CONTROL cmd: efidebug: fix int to pointer cast efi_loader: only reserve memory if fdt node enabled test/py: test_efi_grub_net() requires OF_CONTROL
Kristian Amlie (1): vexpress_ca9x4: Enable use of correct DTB file and restore EFI loader.
cmd/bootefi.c | 3 ++- cmd/efidebug.c | 8 +++++--- configs/vexpress_ca9x4_defconfig | 2 +- include/configs/vexpress_common.h | 3 ++- test/py/tests/test_efi_loader.py | 6 ++++-- 5 files changed, 14 insertions(+), 8 deletions(-)
On Tue, Mar 31, 2020 at 08:20:16AM +0200, Heinrich Schuchardt wrote:
Hello Tom,
Best regards
Heinrich
