[U-Boot-Users] [PATCH] Fixed an OF-tree off-by-one bug when adding a new property name.
This bug will cause the kernel booting to pause a long time.
Signed-off-by: Zhang Wei wei.zhang@freescale.com Signed-off-by: Jon Loeliger jdl@freescale.com ---
Note: This patch is on top of the patches supplied by Matthew McClintock. Specifically, [PATCH 2/11] of June 27, 2006 with Subject: Patch to modify ft_build.c to update flat device trees in place
CHANGELOG:
* Fix an off-by-one bug in OF-tree property handling. Patch by Zhang Wei, 28 Aug 2006
common/ft_build.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/ft_build.c b/common/ft_build.c index b5a997c..b5937e3 100644 --- a/common/ft_build.c +++ b/common/ft_build.c @@ -103,7 +103,7 @@ void ft_prop(struct ft_cxt *cxt, const c if (off == -1) { memcpy(cxt->p_end, name, strlen(name) + 1); off = cxt->p_end - cxt->p; - cxt->p_end += strlen(name) + 2; + cxt->p_end += strlen(name) + 1; }
/* now put offset from beginning of *STRUCTURE* */
jdl@freescale.com
