[U-Boot] [USB EHCI PATCH 1/2] USB ehci remove infinite loop and use handshake function
USB ehci code cleanup. Use handshake instead of infinite while loop to check the STD_ASS status
Signed-off-by: Michael Trimarchi trimarchimichael@yahoo.it
--- drivers/usb/usb_ehci_core.c | 53 ++++++++++++++++++++++--------------------- 1 files changed, 27 insertions(+), 26 deletions(-)
diff --git a/drivers/usb/usb_ehci_core.c b/drivers/usb/usb_ehci_core.c index 07e9a6b..21fd7d0 100644 --- a/drivers/usb/usb_ehci_core.c +++ b/drivers/usb/usb_ehci_core.c @@ -28,7 +28,7 @@ #include "usb_ehci.h"
int rootdev; -struct ehci_hccr *hccr; /* R/O registers, not need for volatile */ +struct ehci_hccr *hccr; /* R/O registers, not need for volatile */ volatile struct ehci_hcor *hcor;
static uint16_t portreset; @@ -106,20 +106,19 @@ static struct descriptor { #define ehci_is_TDI() (0) #endif
-static int handshake(uint32_t *ptr, uint32_t mask, uint32_t done, int msec) +static int handshake(uint32_t *ptr, uint32_t mask, uint32_t done, int usec) { uint32_t result; do { result = ehci_readl(ptr); - debug("handshake read reg(%x)=%x\n", (uint32_t)ptr, result); if (result == ~(uint32_t)0) return -1; result &= mask; if (result == done) return 0; - wait_ms(1); - msec--; - } while (msec > 0); + udelay(1); + usec--; + } while (usec > 0); return -1; }
@@ -138,21 +137,21 @@ static int ehci_reset(void) cmd = ehci_readl(&hcor->or_usbcmd); cmd |= CMD_RESET; ehci_writel(&hcor->or_usbcmd, cmd); - ret = handshake((uint32_t *)&hcor->or_usbcmd, CMD_RESET, 0, 250); + ret = handshake((uint32_t *)&hcor->or_usbcmd, CMD_RESET, 0, 250 * 1000); if (ret < 0) { printf("EHCI fail to reset\n"); goto out; }
-#if defined(CONFIG_EHCI_IS_TDI) - reg_ptr = (uint32_t *)((u8 *)hcor + USBMODE); - tmp = ehci_readl(reg_ptr); - tmp |= USBMODE_CM_HC; -#if defined(CONFIG_EHCI_MMIO_BIG_ENDIAN) - tmp |= USBMODE_BE; -#endif - ehci_writel(reg_ptr, tmp); -#endif + if (ehci_is_TDI()) { + reg_ptr = (uint32_t *)((u8 *)hcor + USBMODE); + tmp = ehci_readl(reg_ptr); + tmp |= USBMODE_CM_HC; + #if defined(CONFIG_EHCI_MMIO_BIG_ENDIAN) + tmp |= USBMODE_BE; + #endif + ehci_writel(reg_ptr, tmp); + } out: return ret; } @@ -224,7 +223,7 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, uint32_t endpt, token, usbsts; uint32_t c, toggle; uint32_t cmd; - uint32_t sts; + int ret = 0;
debug("dev=%p, pipe=%lx, buffer=%p, length=%d, req=%p\n", dev, pipe, buffer, length, req); @@ -340,10 +339,11 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, cmd |= CMD_ASE; ehci_writel(&hcor->or_usbcmd, cmd);
- sts = ehci_readl(&hcor->or_usbsts); - while ((sts & STD_ASS) == 0) { - sts = ehci_readl(&hcor->or_usbsts); - udelay(10); + ret = handshake((uint32_t *)&hcor->or_usbsts, STD_ASS, STD_ASS, + 100 * 1000); + if (ret < 0) { + printf("EHCI fail timeout STD_ASS set\n"); + goto fail; }
/* Wait for TDs to be processed. */ @@ -360,10 +360,11 @@ ehci_submit_async(struct usb_device *dev, unsigned long pipe, void *buffer, cmd &= ~CMD_ASE; ehci_writel(&hcor->or_usbcmd, cmd);
- sts = ehci_readl(&hcor->or_usbsts); - while ((sts & STD_ASS) != 0) { - sts = ehci_readl(&hcor->or_usbsts); - udelay(10); + ret = handshake((uint32_t *)&hcor->or_usbsts, STD_ASS, 0, + 100 * 1000); + if (ret < 0) { + printf("EHCI fail timeout STD_ASS reset\n"); + goto fail; }
qh_list.qh_link = cpu_to_hc32((uint32_t)&qh_list | QH_LINK_TYPE_QH); @@ -536,7 +537,7 @@ ehci_submit_root(struct usb_device *dev, unsigned long pipe, void *buffer, /* force reset to complete */ reg = reg & ~(EHCI_PS_PR | EHCI_PS_CLEAR); ehci_writel(status_reg, reg); - ret = handshake(status_reg, EHCI_PS_PR, 0, 2); + ret = handshake(status_reg, EHCI_PS_PR, 0, 2 * 1000); if (!ret) tmpbuf[0] |= USB_PORT_STAT_RESET; else
if (result == ~(uint32_t)0) return -1; result &= mask; if (result == done) return 0;debug("handshake read reg(%x)=%x\n", (uint32_t)ptr, result);
wait_ms(1);
msec--;
udelay(1);
usec--;
- } while (usec > 0); return -1;
- ret = handshake((uint32_t *)&hcor->or_usbcmd, CMD_RESET, 0, 250 * 1000); if (ret < 0) { printf("EHCI fail to reset\n"); goto out; }
-#endif
-#endif
- if (ehci_is_TDI()) {
I prefer that the "#if" stays in column 0.
tmp |= USBMODE_BE;
Indentation problem.
Best regards, Stefan
wait_ms(1);
msec--;
udelay(1);
usec--;
-#endif
-#endif
Yes, thanks.
tmp |= USBMODE_BE;
Regards Michael
michael
Michael Trimarchi
Stefan Roese
