Re: [U-Boot-Users] Re: [PATCH] Make System IO Config Registers board configurable on MPC83xx
Wolfgang.
That is very convincing. So for the special case of setting RCW to boot from lowmem vector, all is well. And I guess there is no great harm in that restriction.
When RCW set to boot from himem vector though, the 83xx maps in the _last_ 8M of the flash chip, not the first, so the remap_flash_by_law* routines end up mapping u-boot out from under us. But OK; we just won't do that then.
I still stand by by compaint though: if you're going to remap flash according to CFG_FLASH_BASE in start.S, then the 8M hardcoded size is annoying.
back to LAW0 on a builtin assumption of 8M size, placing the starting address thereof to the CFG_FLASH_BASE location (in their case, 0xfe00_0000); then do jumping arithmetic based on that value and TEXT_BASE.
Which works in the Freescale-ADS case, as they have an 8M flash chip.
It also works in case of the TQM8349 board, which uses 32 MB:
U-Boot 1.1.4 (Nov 17 2005 - 00:14:36) MPC83XX
Clock configuration: Coherent System Bus: 266 MHz Core: 533 MHz Local Bus: 33 MHz CPU: MPC83xx, Rev: 1.1 at 533.328 MHz Board: TQM834x PCI1: 32 bit, 33 MHz I2C: ready DTT: 1 is 28 C DRAM: 256 MB FLASH: 32 MB PCI: Bus Dev VenId DevId Class Int In: serial Out: serial Err: serial Net: TSEC0, TSEC1
Type "run flash_nfs" to mount root filesystem over NFS
Hit any key to stop autoboot: 0 => fli
Bank # 1: CFI conformant FLASH (32 x 16) Size: 32 MB in 256 Sectors Erase timeout 16384 ms, write timeout 0 ms, buffer write timeout 4096 ms, buffer size 32 Sector Start Addresses: 80000000 (RO) 80020000 (RO) 80040000 (RO) 80060000 80080000 800A0000 800C0000 800E0000 80100000 80120000 80140000 80160000 80180000 801A0000 801C0000 ...
David Updegraff
