[PATCH v2] lib: Improve _parse_integer_fixup_radix base 16 detection
Base autodetection is failing for this case: if test 257 -gt 3ae; then echo first; else echo second; fi
It is because base for 3ae is recognized by _parse_integer_fixup_radix() as 10. The patch is checking all chars to make sure that they are not 'a' or up. If they are base needs to be in hex.
Signed-off-by: Michal Simek michal.simek@xilinx.com Signed-off-by: Shiril Tichkule shirilt@xlinx.com Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2: - Fix end of string to be \0 instead of \n - Detect hex by checking chars between a-f to avoid cases like number follow by ;
lib/strto.c | 19 ++++++++++++++++++- 1 file changed, 18 insertions(+), 1 deletion(-)
diff --git a/lib/strto.c b/lib/strto.c index 55ff9f7437d5..4ac79f46a5e2 100644 --- a/lib/strto.c +++ b/lib/strto.c @@ -22,9 +22,26 @@ static const char *_parse_integer_fixup_radix(const char *s, unsigned int *base) *base = 16; else *base = 8; - } else + } else { + int i; + *base = 10; + + for (i = 0; ; i++) { + char var = s[i]; + + if (var == '\0') + break; + + if ((var >= 'a' && var <= 'f') || + (var >= 'A' && var <= 'F')) { + *base = 16; + break; + } + } + } } + if (*base == 16 && s[0] == '0' && tolower(s[1]) == 'x') s += 2; return s;
char var = s[i];
if (var == '\0')
break;
*base = 16;
break;
int i = 0; char var;
do { var = tolower(s[i++]); if (...) { *base = 16; break; } } while (var);
or alike?
Is this relevant?
char var = s[i];
if (var == '\0')
break;
*base = 16;
break;
or alike?
not a problem with this.
Is this relevant?
it can be removed from this patch but I can't see any issue with it to making code more readable.
M
Hold on!
char var = s[i];
if (var == '\0')
break;
*base = 16;
break;
Actually your code and commit message are unaligned. In the code you stop on the *first* hex character without checking the rest.
Hold on!
char var = s[i];
if (var == '\0')
break;
*base = 16;
break;
That's correct because base is detected as 10 at this stage.
The question is if make sense to check all chars because if there is one char between a<= <=f then you are sure that it is not base 10.
And if you want to check all of them then you need to also detect chars like ';' which can be there as you see above.
Thanks, Michal
Andy Shevchenko
Michal Simek
