[U-Boot] [PATCH RESEND] ahci: dm: Fix memory allocation for uclass private data
Allocate manually the uclass private data in ahci_init_dm(). Don't do this in the declaration of the scsi uclass driver with .per_device_auto_alloc_size because it is AHCI specific.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
Since the last merge of u-boot-dm, the DM driver for AHCI on OMAP5 paltforms is broken. This patche fixes the issue. It had previsouly been sent as part of a series "dm: ahci: Fix dwc_ahci".
Jean-Jacques
drivers/ata/ahci.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/ata/ahci.c b/drivers/ata/ahci.c index 6da412d..1d88472 100644 --- a/drivers/ata/ahci.c +++ b/drivers/ata/ahci.c @@ -1090,7 +1090,13 @@ int ahci_init(void __iomem *base)
int ahci_init_dm(struct udevice *dev, void __iomem *base) { - struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct ahci_uc_priv *uc_priv; + + uc_priv = calloc(1, sizeof(struct ahci_uc_priv)); + if (!uc_priv) + return -ENOMEM; + + dev->uclass_priv = uc_priv;
return ahci_init_common(uc_priv, base); }
Jean-Jacques
This should be fixed in patches that are pending. Can you please check u-boot-dm/ata2-working?
Also we should not allocate the private data - DM does it automatically.
if (!uc_priv)
return -ENOMEM;
dev->uclass_priv = uc_priv; return ahci_init_common(uc_priv, base);
1.9.1
Jean-Jacques Hiblot
