[U-Boot] [PATCH] Add information about return values of xxx_eth_register() in documentation
As discussed on mailing list, <0 indicates failure, >=0 indicates number of interfaces found.
Also added blurb about private data
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- doc/README.drivers.eth | 21 +++++++++++++-------- 1 files changed, 13 insertions(+), 8 deletions(-)
diff --git a/doc/README.drivers.eth b/doc/README.drivers.eth index 7f21909..e06d3ad 100644 --- a/doc/README.drivers.eth +++ b/doc/README.drivers.eth @@ -25,9 +25,9 @@ system handling, but ultimately they will call the driver-specific register function which in turn takes care of initializing that particular instance.
Keep in mind that you should code the driver to avoid storing state in global -data as someone might want to hook up two of the same devices to one board. If -the state is maintained as global data, it makes using both of those devices -impossible. +data as someone might want to hook up two of the same devices to one board. +Any such information that is specific to an interface should be stored in a +private, driver-defined data structure and pointed to by eth->priv (see below).
So the call graph at this stage would look something like: board_init() @@ -77,15 +77,20 @@ int ape_register(bd_t *bis, int iobase) miiphy_register(dev->name, ape_mii_read, ape_mii_write); #endif
- return 0; + return 1; }
The exact arguments needed to initialize your device are up to you. If you need to pass more/less arguments, that's fine. You should also add the -prototype for your new register function to include/netdev.h. You might notice -that many drivers seem to use xxx_initialize() rather than xxx_register(). -This is the old naming convention and should be avoided as it causes confusion -with the driver-specific init function. +prototype for your new register function to include/netdev.h. + +The return value for this function should be as follows: +< 0 - failure (hardware failure, not probe failure) +>=0 - number of interfaces detected + +You might notice that many drivers seem to use xxx_initialize() rather than +xxx_register(). This is the old naming convention and should be avoided as it +causes confusion with the driver-specific init function.
Other than locating the MAC address in dedicated hardware storage, you should not touch the hardware in anyway. That step is handled in the driver-specific
Mike,
I'm going to go ahead and put this in the net repo. If you don't like it, let me know and we'll back it out.
regards, Ben
makes sense to me, thanks -mike
Ben Warren
Mike Frysinger
