[PATCH V6 00/20] board: ti: Add support for BeaglePlay
Alright, 6th time is a charm ;) Hopefully this takes care of all the un-addressed concerns we have had. Thanks all for pitching in, reviewing and improving and I will stop finding things to cleanup (promise).
Baseline: 7c6b18fb5494 (origin/next) Merge branch '2023-08-24-enable-more-features-in-qemu-arm' into next Full series available: https://github.com/nmenon/fix-k3-dt-u-boot/commits/beagleplay-v6 Boot Logs: https://gist.github.com/nmenon/8be4106e2d0b572aa5e77d93476095b4
Caveats: * Networking: pending https://lore.kernel.org/all/20230822121350.51324-1-rogerq@kernel.org/ * 32kclk and usb: pending: https://lore.kernel.org/u-boot/20230725185253.2123433-4-nm@ti.com/ OR https://github.com/nmenon/fix-k3-dt-u-boot/commit/853b29d63c1ca642be316f1afb... being properly resolved (NOTE: without this patch, wlan is broken in Linux as the 32kclk from SoC is incorrectly supplied to wlan as 25MHz) * There seems to be a bug in Linux kernel with sdhci that seems to depend on u-boot initialization of sdhci for functionality (TI internal actions already triggered). * buildman discussion about config fragments: https://lore.kernel.org/all/CAPnjgZ14CUVt=rM943hh9PQUhK9LJDgZYPxUsATYQe3wwOU... * Documentation that we can copy paste: https://lore.kernel.org/all/20230824154036.3650607-1-nm@ti.com/ and followon in kernel.org: https://lore.kernel.org/all/149528e1-062b-ebed-aa25-d37be5fe5894@iogearbox.n... if it all percolates back down to u-boot tree, should be trivial cleanup. * Build fails with binman implementation for TI SoCs - Neha will take care of https://lore.kernel.org/all/227d74cf-9e95-4f5f-af96-49d054cde7aa@ti.com/ * This series picks up Jan's patch for working around Device Manager not compliant with EFI specification reqs and applies it to am62x_sk (TI internal action already triggered) https://lore.kernel.org/all/20230825011623.c74qqidp6wgvc5kl@plaza/ * I noticed that when drivers like the am654_sdhci.c uses deffered_probe, the default probe function does'nt fail https://source.denx.de/u-boot/u-boot/-/blob/master/boot/bootflow.c#L279 So ends up attempting for each of the boot_targets even if mmc dev dev_id would fail. Not really sure how to solve it, so will leave it here. (the https://gist.github.com/nmenon/8be4106e2d0b572aa5e77d93476095b4#file-beaglep... should show a bunch of 'MMC: no card present' each of which costs around 1 second.
Changes since V5: * New patches to clean up mmc.env to sync with BOOTSTD operations yet enable easier non-U-Boot developer experience for uEnv.txt and optimize access to non-plugged in sd-card. * Picked up Jan's patch[1] as part of this series. * Introduced default_findfdt.env as review comment * Saw Simon's feedback on uSD boot, and documented that as well, will be good for new devs to have that info in one flow. * Quick overall diff: https://gist.github.com/nmenon/6d934f4e1092aa293a771d26b0f2bff7
V5: https://lore.kernel.org/all/20230824031101.3460411-1-nm@ti.com/ V4: https://lore.kernel.org/all/20230822184135.2328409-1-nm@ti.com/ V3: https://lore.kernel.org/all/20230815164440.2713726-1-nm@ti.com/ V2: https://lore.kernel.org/u-boot/20230727234446.3651836-1-nm@ti.com/ V1: https://lore.kernel.org/all/20230725185253.2123433-1-nm@ti.com/
Jan Kiszka (1): configs: am62x_evm_a53_defconfig: Disable semi-functional PSCI reset support
Nishanth Menon (18): include: env: ti: mmc: envboot/mmcboot: Check result of mmc dev before proceeding include: env: ti: mmc: envboot: Only attempt boot.scr if BOOTSTD is not enabled include: configs: ti_armv7_common: Add documentation for protected section include: configs: am62x_evm: Drop unused SDRAM address include: configs: am62x_evm: Wrap distroboot with CONFIG_DISTRO_DEFAULTS board: ti: am62x: am62x.env: Add explicit boot_targets configs: am62x_evm_a53_defconfig: Switch to bootstd include: configs: am62x_evm: Drop distro_bootcmd usage include: env: ti: ti_armv7_common.env: Rename to ti_common.env include: env: ti: Add a generic default_findfdt.env board: ti: am62x: am62x.env: Use default findfdt arm: mach-k3: am625_init: Use IS_ENABLED() arm: mach-k3: am625_init: Convert rtc_erratumi2327_init to static configs: am62x_evm*: Enable EMMC_BOOT configuration arm: mach-k3: am625: Add support for UDA FS arm: dts: k3-am625-sk-binman: Add labels for unsigned binary board: ti: am62x: Add am62x_beagleplay_* defconfigs and env file doc: board: ti: Add BeaglePlay documentation
Robert Nelson (1): arm: dts: Add k3-am625-beagleplay
arch/arm/dts/Makefile | 2 + .../dts/k3-am625-beagleplay-ddr4-1600MTs.dtsi | 2195 +++++++++++++++++ arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 195 ++ arch/arm/dts/k3-am625-beagleplay.dts | 758 ++++++ arch/arm/dts/k3-am625-r5-beagleplay.dts | 86 + arch/arm/dts/k3-am625-sk-binman.dtsi | 4 +- arch/arm/mach-k3/am625_init.c | 49 +- board/siemens/iot2050/iot2050.env | 2 +- board/ti/am62ax/am62ax.env | 2 +- board/ti/am62x/MAINTAINERS | 7 + board/ti/am62x/am62x.env | 8 +- board/ti/am62x/beagleplay.env | 19 + board/ti/am62x/beagleplay_a53.config | 55 + board/ti/am62x/beagleplay_r5.config | 15 + board/ti/am64x/am64x.env | 2 +- board/ti/am65x/am65x.env | 2 +- board/ti/j721e/j721e.env | 2 +- board/ti/j721s2/j721s2.env | 2 +- board/ti/ks2_evm/k2e_evm.env | 2 +- board/ti/ks2_evm/k2g_evm.env | 2 +- board/ti/ks2_evm/k2hk_evm.env | 2 +- board/ti/ks2_evm/k2l_evm.env | 2 +- configs/am62x_evm_a53_defconfig | 7 +- configs/am62x_evm_r5_defconfig | 1 + doc/board/ti/am62x_beagleplay.rst | 322 +++ doc/board/ti/img/beagleplay_emmc.svg | 697 ++++++ doc/board/ti/k3.rst | 1 + include/configs/am62x_evm.h | 6 - include/configs/ti_armv7_common.h | 2 +- include/env/ti/default_findfdt.env | 12 + include/env/ti/mmc.env | 12 +- .../ti/{ti_armv7_common.env => ti_common.env} | 0 32 files changed, 4419 insertions(+), 54 deletions(-) create mode 100644 arch/arm/dts/k3-am625-beagleplay-ddr4-1600MTs.dtsi create mode 100644 arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-beagleplay.dts create mode 100644 arch/arm/dts/k3-am625-r5-beagleplay.dts create mode 100644 board/ti/am62x/beagleplay.env create mode 100644 board/ti/am62x/beagleplay_a53.config create mode 100644 board/ti/am62x/beagleplay_r5.config create mode 100644 doc/board/ti/am62x_beagleplay.rst create mode 100644 doc/board/ti/img/beagleplay_emmc.svg create mode 100644 include/env/ti/default_findfdt.env rename include/env/ti/{ti_armv7_common.env => ti_common.env} (100%)
[1] https://lore.kernel.org/all/c93b19ed-43fe-44a2-9726-371fb9d2f825@web.de/
If mmc dev reports that the device is not present, there is no point in proceeding further to attempt to load the files.
Signed-off-by: Nishanth Menon nm@ti.com --- new patch - noticed a series of 'MMC: no card present' in boot log and was wondering why, now I know - shaves off 2 seconds or so into boot process.
include/env/ti/mmc.env | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/include/env/ti/mmc.env b/include/env/ti/mmc.env index 6fb47fb26673..b8eb51ca1744 100644 --- a/include/env/ti/mmc.env +++ b/include/env/ti/mmc.env @@ -15,7 +15,7 @@ loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenvfile} loadimage=load ${devtype} ${bootpart} ${loadaddr} ${bootdir}/${bootfile} loadfdt=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/dtb/${fdtfile} get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/dtb/${name_fdt} -envboot=mmc dev ${mmcdev}; +envboot=if mmc dev ${mmcdev}; then if mmc rescan; then echo SD/MMC found on device ${mmcdev}; if run loadbootscript; then @@ -31,6 +31,7 @@ envboot=mmc dev ${mmcdev}; fi; fi; fi; + fi; mmcloados= if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run get_fdt_mmc; then @@ -45,7 +46,7 @@ mmcloados= else bootz; fi; -mmcboot=mmc dev ${mmcdev}; +mmcboot=if mmc dev ${mmcdev}; then devnum=${mmcdev}; devtype=mmc; if mmc rescan; then @@ -58,7 +59,8 @@ mmcboot=mmc dev ${mmcdev}; run mmcloados; fi; fi; -fi; + fi; + fi;
init_mmc=run args_all args_mmc get_overlay_mmc=
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
- fi;
- fi;
- fi;
init_mmc=run args_all args_mmc get_overlay_mmc= -- 2.40.0
Signed-off-by: Nishanth Menon nm@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
For the series, applied to u-boot/next, thanks!
'script' bootmethod that should be used with CONFIG_BOOTSTD.
Since Simon educated me to realize that the published documentation can be stale and bootmeths=script does indeed work for some time despite what the docs say..
include/env/ti/mmc.env | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/env/ti/mmc.env b/include/env/ti/mmc.env index b8eb51ca1744..0256a2d2aaca 100644 --- a/include/env/ti/mmc.env +++ b/include/env/ti/mmc.env @@ -5,7 +5,9 @@ args_mmc=run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} rw rootfstype=${mmcrootfstype} +#ifndef CONFIG_BOOTSTD loadbootscript=load mmc ${mmcdev} ${loadaddr} boot.scr +#endif bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr} bootenvfile=uEnv.txt @@ -18,7 +20,7 @@ get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/dtb/${name_fdt} envboot=if mmc dev ${mmcdev}; then if mmc rescan; then echo SD/MMC found on device ${mmcdev}; - if run loadbootscript; then + if test -n "${loadbootscript}" && run loadbootscript; then run bootscript; else if run loadbootenv; then
else if run loadbootenv; thenif test -n "${loadbootscript}" && run loadbootscript; then run bootscript;
-- 2.40.0
Make the section protected by CONFIG_DISTRO_DEFAULTS macro clear.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way.
V5: https://lore.kernel.org/r/20230824031101.3460411-2-nm@ti.com include/configs/ti_armv7_common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index dbbeff34ba82..4e30d0d2ddf8 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -200,7 +200,7 @@ #define CFG_EXTRA_ENV_SETTINGS \ BOOTENV
-#endif +#endif /* CONFIG_DISTRO_DEFAULTS */
#endif /* CONFIG_ARM64 */
Drop unused macro. This was meant for a second region of DDR which we do not need for AM62x evm configurations.
V5: https://lore.kernel.org/r/20230824031101.3460411-3-nm@ti.com include/configs/am62x_evm.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/include/configs/am62x_evm.h b/include/configs/am62x_evm.h index 44180dc7687b..379e0c13a395 100644 --- a/include/configs/am62x_evm.h +++ b/include/configs/am62x_evm.h @@ -12,9 +12,6 @@ #include <config_distro_bootcmd.h> #include <env/ti/mmc.h>
-/* DDR Configuration */ -#define CFG_SYS_SDRAM_BASE1 0x880000000 - /* Now for the remaining common defines */ #include <configs/ti_armv7_common.h>
-- 2.40.0
Wrap the distro_boot options with CONFIG_DISTRO_DEFAULTS.
This is an intermediate step for us to switch over to CONFIG_BOOTSTD_DEFAULTS and drop this section in follow on patches.
Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way.
V5: https://lore.kernel.org/r/20230824031101.3460411-4-nm@ti.com
include/configs/am62x_evm.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/am62x_evm.h b/include/configs/am62x_evm.h index 379e0c13a395..81d7658cdb0d 100644 --- a/include/configs/am62x_evm.h +++ b/include/configs/am62x_evm.h @@ -9,8 +9,10 @@ #ifndef __CONFIG_AM625_EVM_H #define __CONFIG_AM625_EVM_H
+#ifdef CONFIG_DISTRO_DEFAULTS #include <config_distro_bootcmd.h> #include <env/ti/mmc.h> +#endif
2.40.0
Add explicit boot_targets to indicate the specific boot sequence to follow.
NOTE: The non-standard ti_mmc emulates what is done for distro_boot. With bootstd, this will eventually need to be replaced by equivalent class.
V5: https://lore.kernel.org/r/20230824031101.3460411-5-nm@ti.com board/ti/am62x/am62x.env | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/ti/am62x/am62x.env b/board/ti/am62x/am62x.env index f2dc87893a92..1cf56dbd8128 100644 --- a/board/ti/am62x/am62x.env +++ b/board/ti/am62x/am62x.env @@ -11,6 +11,7 @@ args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 ${mtdparts} run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}
+boot_targets=ti_mmc mmc0 mmc1 usb pxe dhcp boot=mmc mmcdev=1 bootpart=1:2
+boot_targets=ti_mmc mmc0 mmc1 usb pxe dhcp boot=mmc mmcdev=1 bootpart=1:2 -- 2.40.0
Switch to using bootstd. Note with this change, we will stop using distro_bootcmd and instead depend entirely on bootflow method of starting the system up.
Suggested-by: Tom Rini trini@konsulko.com Suggested-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way. V5: https://lore.kernel.org/r/20230824031101.3460411-6-nm@ti.com configs/am62x_evm_a53_defconfig | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index d55caabe22c9..1807df8bbee9 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -28,8 +28,9 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run envboot; run distro_bootcmd;" +CONFIG_BOOTSTD_FULL=y +CONFIG_BOOTSTD_DEFAULTS=y +CONFIG_BOOTCOMMAND="run envboot; bootflow scan -lb" CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80c80000
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index d55caabe22c9..1807df8bbee9 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -28,8 +28,9 @@ CONFIG_SPL_SPI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run envboot; run distro_bootcmd;" +CONFIG_BOOTSTD_FULL=y +CONFIG_BOOTSTD_DEFAULTS=y +CONFIG_BOOTCOMMAND="run envboot; bootflow scan -lb" CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80c80000 -- 2.40.0
Hello Nishanth,
Suggested-by: Tom Rini trini@konsulko.com Suggested-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
could you please suggest which distro have you used for testing?
After U-Boot update to v2024.01 Buildroot is not booting any more:
--- U-Boot 2024.01 (Feb 15 2024 - 01:43:17 +0100)
SoC: AM62X SR1.0 HS-FS Model: Texas Instruments AM625 SK DRAM: 2 GiB Core: 56 devices, 23 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'uEnv.txt' Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': No EFI system partition No EFI system partition Failed to persist EFI variables Scanning bootdev 'mmc@fa00000.bootdev': Scanning bootdev 'mmc@fa10000.bootdev': Unknown uclass 'usb' in label link up on port 1, speed 100, full duplex BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 ... ---
I suppose TI's BSP has older U-Boot... So it's not providing necessary script for BOOTSTD, I suppose?
On 17.02.24 04:11, Alexander Sverdlin wrote:
Hello Nishanth,
You can make the BeagleBone boot via EFI, but it requires a hybrid partition table (ROM loader want DOS, EFI needs GPT). A Debian integration with this can be found for Isar [1] in this series [2]. It's only using upstream sources (plus still one u-boot patch to get wifi working).
If you want legacy script booting, I suspect you need to flip some extra switches explicitly by now.
Jan
[1] https://github.com/ilbers/isar/ [2] https://patchwork.isar-build.org/project/isar/list/?series=1049
Hi Jan!
Thanks for the hints! I'm wondering, if this was a deliberate "let's stop booting all the pre-existing embedded distros" decision? (buildroot, yocto/meta-ti...)
On 17.02.24 12:36, Alexander Sverdlin wrote:
Hi Jan!
FWIW, I'm not seeing other boot methods being specifically disabled in beagleplay in 2024.01 or even newer. I didn't try the result, but this may actually be some other issue and real bug, nothing obviously intended.
My personal observation is that continuous integration testings with all-upstream components is not really a common thing. I saw that with multiple active SoCs from various vendors.
Jan
Hi Jan!
I'm not even sure about this anymore, though there is still a bug, just a different one:
... U-Boot 2024.04-rc2-00040-g3e6f2a94bfc (Feb 20 2024 - 08:42:59 +0100)
SoC: AM62X SR1.0 GP Model: BeagleBoard.org BeaglePlay DRAM: 2 GiB Core: 98 devices, 27 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2 Loading Environment from nowhere... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Net: No ethernet found.
Press SPACE to abort autoboot in 2 seconds => print bootmeths bootmeths=script extlinux efi pxe => bootflow scan -l Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning bootdev 'mmc@fa00000.bootdev': 0 efi ready mmc 2 mmc@fa00000.bootdev.part_ efi/boot/bootaa64.efi Scanning bootdev 'mmc@fa10000.bootdev': 1 extlinux ready mmc 1 mmc@fa10000.bootdev.part_ /extlinux/extlinux.conf Unknown uclass 'usb' in label "Synchronous Abort" handler, esr 0x86000004, far 0x3030303030303840 elr: 3030302fb0bc0840 lr : 3030302fb0bc0840 (reloc) elr: 3030303030303840 lr : 3030303030303840 x0 : 00000000ffffffed x1 : 0000000000000000 x2 : 0000000000000002 x3 : 00000000ffb49d30 x4 : 00000000fffd4c00 x5 : 00000000ffb49d50 x6 : 0000000000000000 x7 : 00000000ffb4e890 x8 : 0000000000006924 x9 : 00000000ffb1212c x10: 0000000000000003 x11: 0000000000006914 x12: 00000000ffb1221c x13: 00000000ffb12b40 x14: 00000000ffb12b40 x15: 00000000ffb12535 x16: 00000000fff8a9d4 x17: 0000000000000000 x18: 00000000ffb23da0 x19: 0000314074726f70 x20: 00000000fffed000 x21: 00000000fffef000 x22: 0000000000000000 x23: 00000000fffef000 x24: 00000000fffef000 x25: 0000000000000000 x26: 00000000fffc7174 x27: 0000000000000000 x28: 0000000000000000 x29: 74656e7265687465
Same with 2024.01 release.
Jan
Hi Jan!
I am pretty sure ethernet is not enabled in upstream u-boot.
It was more of a "lets standardize one way of booting across all ARM devices as much as we can" effort - EBBR and others inclusive. To that effort, distro_boot and bootstd have made significant steps forward. NOTE: yocto, buildroot etc will need a few tweaks to get things operational unfortunately. BUT, note: bootstd was what beagleplay was introduced upstream as default in the first place - so all we are finding is that introduced behavior.
boot_targets=mmc1 mmc0 usb pxe
networking ran into some significant challenges. I was hoping to get networking merged but the series got offset and network never made it.. Dropping pxe from boot_targets
=> setenv boot_targets mmc1 mmc0 usb => print bootmeths bootmeths=script extlinux efi pxe => print boot_targets boot_targets=mmc1 mmc0 usb => bootflow scan -l Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning bootdev 'mmc@fa00000.bootdev': 0 extlinux ready mmc 1 mmc@fa00000.bootdev.part_ /extlinux/extlinux.conf Scanning bootdev 'mmc@fa10000.bootdev': 1 extlinux ready mmc 1 mmc@fa10000.bootdev.part_ /extlinux/extlinux.conf Unknown uclass 'usb' in label No more bootdevs --- ----------- ------ -------- ---- ------------------------ ---------------- (2 bootflows, 2 valid) =>
For what it is worth, https://software-dl.ti.com/cicd-report/upstream/ -> we are trying to do that on TI side, though it is still in infancy and test coverage is still more to be desired.
Hello Jan,
With some limitation we have this running in Toradex since a couple of years, we do integrate latest mainline kernel/u-boot and OE master layers and run all that through our Lava test suite on real hardware.
It has challenges, even getting the build to succeed is not obvious and requires continuous care, but we do spot regression on RC releases and we actively report and/or contribute fixes for it.
Unfortunately the test results are still not published on some website and are only internal, but we are working on making this available.
Looking forward to have more players doing it, starting from the SoC vendors!
Francesco
On 21.02.24 10:10, Francesco Dolcini wrote:
Hello Jan,
This is great to hear an highly welcome!
One challenge of this is definitely to get the information to the right people, ideally without requiring too much manual effort (as that is often the most limited resource) while not overloading the target audience with too many false or inaccurate reports.
Jan
Now that BOOTSTD is used by default, drop un-used header file inclusion.
Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way. V5: https://lore.kernel.org/r/20230824031101.3460411-7-nm@ti.com include/configs/am62x_evm.h | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/include/configs/am62x_evm.h b/include/configs/am62x_evm.h index 81d7658cdb0d..c8fe59b75313 100644 --- a/include/configs/am62x_evm.h +++ b/include/configs/am62x_evm.h @@ -9,11 +9,6 @@ #ifndef __CONFIG_AM625_EVM_H #define __CONFIG_AM625_EVM_H
-#ifdef CONFIG_DISTRO_DEFAULTS -#include <config_distro_bootcmd.h> -#include <env/ti/mmc.h> -#endif - /* Now for the remaining common defines */ #include <configs/ti_armv7_common.h>
-- 2.40.0
ti_armv7_common does not make any more sense as it is used by armv7 and armv8 TI based platforms.
Reported-by: Tom Rini trini@konsulko.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way. V5: https://lore.kernel.org/r/20230824031101.3460411-8-nm@ti.com board/siemens/iot2050/iot2050.env | 2 +- board/ti/am62ax/am62ax.env | 2 +- board/ti/am62x/am62x.env | 2 +- board/ti/am64x/am64x.env | 2 +- board/ti/am65x/am65x.env | 2 +- board/ti/j721e/j721e.env | 2 +- board/ti/j721s2/j721s2.env | 2 +- board/ti/ks2_evm/k2e_evm.env | 2 +- board/ti/ks2_evm/k2g_evm.env | 2 +- board/ti/ks2_evm/k2hk_evm.env | 2 +- board/ti/ks2_evm/k2l_evm.env | 2 +- include/env/ti/{ti_armv7_common.env => ti_common.env} | 0 12 files changed, 11 insertions(+), 11 deletions(-) rename include/env/ti/{ti_armv7_common.env => ti_common.env} (100%)
diff --git a/board/siemens/iot2050/iot2050.env b/board/siemens/iot2050/iot2050.env index caa9f80e3fca..8bbd7abe98f0 100644 --- a/board/siemens/iot2050/iot2050.env +++ b/board/siemens/iot2050/iot2050.env @@ -6,7 +6,7 @@ * Jan Kiszka jan.kiszka@siemens.com */
-#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env>
usb_pgood_delay=900
diff --git a/board/ti/am62ax/am62ax.env b/board/ti/am62ax/am62ax.env index 3f7c333fa404..bfed7f360844 100644 --- a/board/ti/am62ax/am62ax.env +++ b/board/ti/am62ax/am62ax.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/mmc.env>
default_device_tree=ti/k3-am62a7-sk.dtb diff --git a/board/ti/am62x/am62x.env b/board/ti/am62x/am62x.env index 1cf56dbd8128..1ef948df83d7 100644 --- a/board/ti/am62x/am62x.env +++ b/board/ti/am62x/am62x.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/mmc.env>
default_device_tree=ti/k3-am625-sk.dtb diff --git a/board/ti/am64x/am64x.env b/board/ti/am64x/am64x.env index 1567907fcbdc..68e42222b7f1 100644 --- a/board/ti/am64x/am64x.env +++ b/board/ti/am64x/am64x.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/mmc.env> #include <env/ti/k3_dfu.env>
diff --git a/board/ti/am65x/am65x.env b/board/ti/am65x/am65x.env index 755bff2707c8..286b9c300c05 100644 --- a/board/ti/am65x/am65x.env +++ b/board/ti/am65x/am65x.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/mmc.env> #include <env/ti/k3_dfu.env> #if CONFIG_CMD_REMOTEPROC diff --git a/board/ti/j721e/j721e.env b/board/ti/j721e/j721e.env index 2f2fb0591279..8cc8232fc131 100644 --- a/board/ti/j721e/j721e.env +++ b/board/ti/j721e/j721e.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/mmc.env> #include <env/ti/ufs.env> #include <env/ti/k3_dfu.env> diff --git a/board/ti/j721s2/j721s2.env b/board/ti/j721s2/j721s2.env index 6825b1469854..64e3d9da85f0 100644 --- a/board/ti/j721s2/j721s2.env +++ b/board/ti/j721s2/j721s2.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/mmc.env> #include <env/ti/ufs.env> #include <env/ti/k3_dfu.env> diff --git a/board/ti/ks2_evm/k2e_evm.env b/board/ti/ks2_evm/k2e_evm.env index a145db53e5fa..3dbb7934c59a 100644 --- a/board/ti/ks2_evm/k2e_evm.env +++ b/board/ti/ks2_evm/k2e_evm.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/ti_armv7_keystone2.env>
findfdt=setenv fdtfile ${name_fdt} diff --git a/board/ti/ks2_evm/k2g_evm.env b/board/ti/ks2_evm/k2g_evm.env index 4f4941dd0907..2b500fc6edf6 100644 --- a/board/ti/ks2_evm/k2g_evm.env +++ b/board/ti/ks2_evm/k2g_evm.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/ti_armv7_keystone2.env> #include <env/ti/mmc.env>
diff --git a/board/ti/ks2_evm/k2hk_evm.env b/board/ti/ks2_evm/k2hk_evm.env index 0714a51090ef..9991b76f8fcc 100644 --- a/board/ti/ks2_evm/k2hk_evm.env +++ b/board/ti/ks2_evm/k2hk_evm.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/ti_armv7_keystone2.env>
findfdt=setenv fdtfile ${name_fdt} diff --git a/board/ti/ks2_evm/k2l_evm.env b/board/ti/ks2_evm/k2l_evm.env index e8a803a4ed76..4e2debca4bde 100644 --- a/board/ti/ks2_evm/k2l_evm.env +++ b/board/ti/ks2_evm/k2l_evm.env @@ -1,4 +1,4 @@ -#include <env/ti/ti_armv7_common.env> +#include <env/ti/ti_common.env> #include <env/ti/ti_armv7_keystone2.env>
findfdt=setenv fdtfile ${name_fdt} diff --git a/include/env/ti/ti_armv7_common.env b/include/env/ti/ti_common.env similarity index 100% rename from include/env/ti/ti_armv7_common.env rename to include/env/ti/ti_common.env
ti_mmc bootmethod uses a findfdt routine that is expected to be implemented by all platforms.
Define a default findfdt based on configured DEFAULT_DEVICE_TREE option for u-boot. This saves duplication across multiple boards and handles architecture folder location changes centrally.
TI ARMV7 platforms will need to override default_device_tree_subarch in the env file to point to the appropriate platform. Note: default "omap" is used to cater to "most common" default.
Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- Changes: * Made it as default_findfdt as discussed in review.
V5: https://lore.kernel.org/r/20230824031101.3460411-9-nm@ti.com include/env/ti/default_findfdt.env | 12 ++++++++++++ 1 file changed, 12 insertions(+) create mode 100644 include/env/ti/default_findfdt.env
diff --git a/include/env/ti/default_findfdt.env b/include/env/ti/default_findfdt.env new file mode 100644 index 000000000000..a2b51dd923bb --- /dev/null +++ b/include/env/ti/default_findfdt.env @@ -0,0 +1,12 @@ +default_device_tree=CONFIG_DEFAULT_DEVICE_TREE +default_device_tree_arch=ti +#ifdef CONFIG_ARM64 +findfdt= + setenv name_fdt ${default_device_tree_arch}/${default_device_tree}.dtb; + setenv fdtfile ${name_fdt} +#else +default_device_tree_subarch=omap +findfdt= + setenv name_fdt ${default_device_tree_arch}/${default_device_tree_subarch}/${default_device_tree}.dtb; + setenv fdtfile ${name_fdt} +#endif
Changes:
- Made it as default_findfdt as discussed in review.
- setenv name_fdt ${default_device_tree_arch}/${default_device_tree}.dtb;
- setenv fdtfile ${name_fdt}
- setenv name_fdt ${default_device_tree_arch}/${default_device_tree_subarch}/${default_device_tree}.dtb;
2.40.0
Use the default findfdt using CONFIG_DEFAULT_DEVICE_TREE
Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change that picking up Review, tested by and using new include file.
V5: https://lore.kernel.org/r/20230824031101.3460411-10-nm@ti.com board/ti/am62x/am62x.env | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/board/ti/am62x/am62x.env b/board/ti/am62x/am62x.env index 1ef948df83d7..3b79ae1b3f0d 100644 --- a/board/ti/am62x/am62x.env +++ b/board/ti/am62x/am62x.env @@ -1,10 +1,7 @@ #include <env/ti/ti_common.env> +#include <env/ti/default_findfdt.env> #include <env/ti/mmc.env>
-default_device_tree=ti/k3-am625-sk.dtb -findfdt= - setenv name_fdt ${default_device_tree}; - setenv fdtfile ${name_fdt} name_kern=Image console=ttyS2,115200n8 args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000
name_kern=Image console=ttyS2,115200n8 args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 -- 2.40.0
Drop the #ifdeffery and use IS_ENABLED() inline check and let the compiler do it's thing.
Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way. V5: https://lore.kernel.org/r/20230824031101.3460411-11-nm@ti.com arch/arm/mach-k3/am625_init.c | 35 +++++++++++++++++------------------ 1 file changed, 17 insertions(+), 18 deletions(-)
diff --git a/arch/arm/mach-k3/am625_init.c b/arch/arm/mach-k3/am625_init.c index 0e5d44269ebf..165bca6885ef 100644 --- a/arch/arm/mach-k3/am625_init.c +++ b/arch/arm/mach-k3/am625_init.c @@ -121,10 +121,10 @@ void board_init_f(ulong dummy) struct udevice *dev; int ret;
-#if defined(CONFIG_CPU_V7R) - setup_k3_mpu_regions(); - rtc_erratumi2327_init(); -#endif + if (IS_ENABLED(CONFIG_CPU_V7R)) { + setup_k3_mpu_regions(); + rtc_erratumi2327_init(); + }
/* * Cannot delay this further as there is a chance that @@ -156,29 +156,28 @@ void board_init_f(ulong dummy)
preloader_console_init();
-#ifdef CONFIG_K3_EARLY_CONS /* * Allow establishing an early console as required for example when * doing a UART-based boot. Note that this console may not "survive" * through a SYSFW PM-init step and will need a re-init in some way * due to changing module clock frequencies. */ - early_console_init(); -#endif + if (IS_ENABLED(CONFIG_K3_EARLY_CONS)) + early_console_init();
-#if defined(CONFIG_K3_LOAD_SYSFW) /* * Configure and start up system controller firmware. Provide * the U-Boot console init function to the SYSFW post-PM configuration * callback hook, effectively switching on (or over) the console * output. */ - ret = is_rom_loaded_sysfw(&bootdata); - if (!ret) - panic("ROM has not loaded TIFS firmware\n"); + if (IS_ENABLED(CONFIG_K3_LOAD_SYSFW)) { + ret = is_rom_loaded_sysfw(&bootdata); + if (!ret) + panic("ROM has not loaded TIFS firmware\n");
- k3_sysfw_loader(true, NULL, NULL); -#endif + k3_sysfw_loader(true, NULL, NULL); + }
/* * Force probe of clk_k3 driver here to ensure basic default clock @@ -209,11 +208,11 @@ void board_init_f(ulong dummy) enable_mcu_esm_reset(); }
-#if defined(CONFIG_K3_AM64_DDRSS) - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) - panic("DRAM init failed: %d\n", ret); -#endif + if (IS_ENABLED(CONFIG_K3_AM64_DDRSS)) { + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) + panic("DRAM init failed: %d\n", ret); + } spl_enable_dcache(); }
The erratum is called locally, make it static, drop the #ifdeffery since it will only be called in R5 build and mark it potentially unused to stop compiler screaming at us.
While at this, drop the redundant return for a void function.
Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way. V5: https://lore.kernel.org/r/20230824031101.3460411-12-nm@ti.com arch/arm/mach-k3/am625_init.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/arch/arm/mach-k3/am625_init.c b/arch/arm/mach-k3/am625_init.c index 165bca6885ef..499cb57267b9 100644 --- a/arch/arm/mach-k3/am625_init.c +++ b/arch/arm/mach-k3/am625_init.c @@ -80,8 +80,6 @@ static __maybe_unused void enable_mcu_esm_reset(void) writel(stat, CTRLMMR_MCU_RST_CTRL); }
-#if defined(CONFIG_CPU_V7R) - /* * RTC Erratum i2327 Workaround for Silicon Revision 1 * @@ -94,7 +92,7 @@ static __maybe_unused void enable_mcu_esm_reset(void) * * https://www.ti.com/lit/er/sprz487c/sprz487c.pdf */ -void rtc_erratumi2327_init(void) +static __maybe_unused void rtc_erratumi2327_init(void) { u32 counter;
@@ -112,9 +110,7 @@ void rtc_erratumi2327_init(void) */ writel(K3RTC_KICK0_UNLOCK_VALUE, REG_K3RTC_KICK0); writel(K3RTC_KICK1_UNLOCK_VALUE, REG_K3RTC_KICK1); - return; } -#endif
void board_init_f(ulong dummy) {
Enable EMMC boot support for AM62x evm base configuration.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way. V5: https://lore.kernel.org/r/20230824031101.3460411-13-nm@ti.com configs/am62x_evm_a53_defconfig | 1 + configs/am62x_evm_r5_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 1807df8bbee9..112125673699 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -70,6 +70,7 @@ CONFIG_TI_K3_NAVSS_UDMA=y CONFIG_TI_SCI_PROTOCOL=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ADMA=y CONFIG_SPL_MMC_SDHCI_ADMA=y diff --git a/configs/am62x_evm_r5_defconfig b/configs/am62x_evm_r5_defconfig index 3c5f36729842..489ee943fe31 100644 --- a/configs/am62x_evm_r5_defconfig +++ b/configs/am62x_evm_r5_defconfig @@ -92,6 +92,7 @@ CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_SPL_MISC=y CONFIG_ESM_K3=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ADMA=y CONFIG_SPL_MMC_SDHCI_ADMA=y
While boot partition support with EMMC boot is useful, it is constrained by the size of boot hardware partition itself.
In the case of K3 devices, tispl images can contain OP-TEE images that can substantially vary in size and the u-boot image itself can vary over time as we enable various features.
So use the CSD information in the case of EMMC_BOOT configuration being enabled to pick boot partition or UDA FS mode operation to pick.
If EMMC_BOOT is disabled, then depend on filesystem configuration to pick data from UDA.
While at this, drop the extraneous whitespace.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way. V5: https://lore.kernel.org/r/20230824031101.3460411-14-nm@ti.com V4: https://lore.kernel.org/r/20230822184135.2328409-4-nm@ti.com arch/arm/mach-k3/am625_init.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/am625_init.c b/arch/arm/mach-k3/am625_init.c index 499cb57267b9..8fa36f7b913e 100644 --- a/arch/arm/mach-k3/am625_init.c +++ b/arch/arm/mach-k3/am625_init.c @@ -220,9 +220,15 @@ u32 spl_mmc_boot_mode(struct mmc *mmc, const u32 boot_device) u32 bootmode_cfg = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK) >> MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT;
- switch (bootmode) { case BOOT_DEVICE_EMMC: + if (IS_ENABLED(CONFIG_SUPPORT_EMMC_BOOT)) { + if (spl_mmc_emmc_boot_partition(mmc)) + return MMCSD_MODE_EMMCBOOT; + return MMCSD_MODE_FS; + } + if (IS_ENABLED(CONFIG_SPL_FS_FAT) || IS_ENABLED(CONFIG_SPL_FS_EXT4)) + return MMCSD_MODE_FS; return MMCSD_MODE_EMMCBOOT; case BOOT_DEVICE_MMC: if (bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_FS_RAW_MASK)
At this point, system shutdown is not supported by the DM firmware that TF-A calls. As we can't de-select only this feature[1], declare complete PSCI reset support as non-functional so that we don't signal incomplete support to the OS via EFI runtime services. This makes power-off under Linux work again when booting via EFI.
[1] https://uefi.org/specs/UEFI/2.9_A/08_Services_Runtime_Services.html?highligh... Signed-off-by: Jan Kiszka jan.kiszka@siemens.com Signed-off-by: Nishanth Menon nm@ti.com --- New patch picked from Jan https://lore.kernel.org/all/c93b19ed-43fe-44a2-9726-371fb9d2f825@web.de/ Changes: - modify am62x_evm as common change. - slight update to $subject and commit message
configs/am62x_evm_a53_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 112125673699..a2729c1d0e36 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y +# CONFIG_PSCI_RESET is not set # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 112125673699..a2729c1d0e36 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -25,6 +25,7 @@ CONFIG_SPL_FS_FAT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y +# CONFIG_PSCI_RESET is not set # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -- 2.40.0
Add labels for unsigned binary to permit over-ride.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way. V5: https://lore.kernel.org/r/20230824031101.3460411-15-nm@ti.com V4: https://lore.kernel.org/r/20230822184135.2328409-6-nm@ti.com V3: https://lore.kernel.org/all/20230815164440.2713726-2-nm@ti.com/ V2: https://lore.kernel.org/u-boot/20230727234446.3651836-2-nm@ti.com/ V1: https://lore.kernel.org/all/20230725185253.2123433-3-nm@ti.com/ arch/arm/dts/k3-am625-sk-binman.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/k3-am625-sk-binman.dtsi b/arch/arm/dts/k3-am625-sk-binman.dtsi index a35d6418c25f..41277bf4bfdb 100644 --- a/arch/arm/dts/k3-am625-sk-binman.dtsi +++ b/arch/arm/dts/k3-am625-sk-binman.dtsi @@ -389,7 +389,7 @@ type = "flat_dt"; arch = "arm"; compression = "none"; - blob { + spl_am625_sk_dtb_unsigned: blob { filename = SPL_AM625_SK_DTB; }; }; @@ -438,7 +438,7 @@ type = "flat_dt"; arch = "arm"; compression = "none"; - blob { + am625_sk_dtb_unsigned: blob { filename = AM625_SK_DTB; }; hash {
BeagleBoard.org BeaglePlay is an easy to use, affordable open source hardware single board computer based on the Texas Instruments AM625 SoC that allows you to create connected devices that work even at long distances using IEEE 802.15.4g LR-WPAN and IEEE 802.3cg 10Base-T1L. Expansion is provided over open standards based mikroBUS, Grove and QWIIC headers among other interfaces.
This board family can be identified by the 24c32 eeprom:
[aa 55 33 ee 01 37 00 10 2e 00 42 45 41 47 4c 45 |.U3..7....BEAGLE|] [50 4c 41 59 2d 41 30 2d 00 00 30 32 30 30 37 38 |PLAY-A0-..020078|]
https://beagleplay.org/ https://git.beagleboard.org/beagleplay/beagleplay
baseline of base device tree is v6.5-rc1.
Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Robert Nelson robertcnelson@gmail.com Co-developed-by: Nishanth Menon nm@ti.com Signed-off-by: Nishanth Menon nm@ti.com --- No change other than picking up reviews, tested tags along the way. V5: https://lore.kernel.org/r/20230824031101.3460411-16-nm@ti.com V4: https://lore.kernel.org/r/20230822184135.2328409-7-nm@ti.com V3: https://lore.kernel.org/all/20230815164440.2713726-3-nm@ti.com/ V2: https://lore.kernel.org/u-boot/20230727234446.3651836-3-nm@ti.com/ V1: https://lore.kernel.org/all/20230725185253.2123433-5-nm@ti.com/
arch/arm/dts/Makefile | 2 + .../dts/k3-am625-beagleplay-ddr4-1600MTs.dtsi | 2195 +++++++++++++++++ arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 195 ++ arch/arm/dts/k3-am625-beagleplay.dts | 758 ++++++ arch/arm/dts/k3-am625-r5-beagleplay.dts | 86 + board/ti/am62x/MAINTAINERS | 7 + 6 files changed, 3243 insertions(+) create mode 100644 arch/arm/dts/k3-am625-beagleplay-ddr4-1600MTs.dtsi create mode 100644 arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-beagleplay.dts create mode 100644 arch/arm/dts/k3-am625-r5-beagleplay.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 85fd5b1157b1..bd61a3527082 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1334,6 +1334,8 @@ dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \
dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-sk.dtb \ k3-am625-r5-sk.dtb \ + k3-am625-beagleplay.dtb \ + k3-am625-r5-beagleplay.dtb \ k3-am625-verdin-wifi-dev.dtb \ k3-am625-verdin-r5.dtb
diff --git a/arch/arm/dts/k3-am625-beagleplay-ddr4-1600MTs.dtsi b/arch/arm/dts/k3-am625-beagleplay-ddr4-1600MTs.dtsi new file mode 100644 index 000000000000..3d7a41c27d7e --- /dev/null +++ b/arch/arm/dts/k3-am625-beagleplay-ddr4-1600MTs.dtsi @@ -0,0 +1,2195 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * https://beagleboard.org/play + * + * Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2022-2023 Robert Nelson, BeagleBoard.org Foundation + * + * This file was generated with the + * AM62x SysConfig DDR Subsystem Register Configuration Tool v0.09.06 + * Thu Feb 09 2023 11:57:18 GMT-0600 (Central Standard Time) + * DDR Part number: K4AAG165WA-BCWE K4A4G165WF-BCTD + * DDR Type: DDR4 + * Frequency = 800MHz (1600MTs) + * Density: 16Gb + * Number of Ranks: 1 + */ + +#define DDRSS_PLL_FHS_CNT 6 +#define DDRSS_PLL_FREQUENCY_1 400000000 +#define DDRSS_PLL_FREQUENCY_2 400000000 + +#define DDRSS_CTL_0_DATA 0x00000A00 +#define DDRSS_CTL_1_DATA 0x00000000 +#define DDRSS_CTL_2_DATA 0x00000000 +#define DDRSS_CTL_3_DATA 0x00000000 +#define DDRSS_CTL_4_DATA 0x00000000 +#define DDRSS_CTL_5_DATA 0x00000000 +#define DDRSS_CTL_6_DATA 0x00000000 +#define DDRSS_CTL_7_DATA 0x000890B8 +#define DDRSS_CTL_8_DATA 0x00000000 +#define DDRSS_CTL_9_DATA 0x00000000 +#define DDRSS_CTL_10_DATA 0x00000000 +#define DDRSS_CTL_11_DATA 0x000890B8 +#define DDRSS_CTL_12_DATA 0x00000000 +#define DDRSS_CTL_13_DATA 0x00000000 +#define DDRSS_CTL_14_DATA 0x00000000 +#define DDRSS_CTL_15_DATA 0x000890B8 +#define DDRSS_CTL_16_DATA 0x00000000 +#define DDRSS_CTL_17_DATA 0x00000000 +#define DDRSS_CTL_18_DATA 0x00000000 +#define DDRSS_CTL_19_DATA 0x01010100 +#define DDRSS_CTL_20_DATA 0x01000100 +#define DDRSS_CTL_21_DATA 0x01000110 +#define DDRSS_CTL_22_DATA 0x02010002 +#define DDRSS_CTL_23_DATA 0x00027100 +#define DDRSS_CTL_24_DATA 0x00061A80 +#define DDRSS_CTL_25_DATA 0x04000400 +#define DDRSS_CTL_26_DATA 0x00000400 +#define DDRSS_CTL_27_DATA 0x00000000 +#define DDRSS_CTL_28_DATA 0x00000000 +#define DDRSS_CTL_29_DATA 0x00000000 +#define DDRSS_CTL_30_DATA 0x00000000 +#define DDRSS_CTL_31_DATA 0x00000000 +#define DDRSS_CTL_32_DATA 0x00000000 +#define DDRSS_CTL_33_DATA 0x00000000 +#define DDRSS_CTL_34_DATA 0x00000000 +#define DDRSS_CTL_35_DATA 0x00000000 +#define DDRSS_CTL_36_DATA 0x00000000 +#define DDRSS_CTL_37_DATA 0x00000000 +#define DDRSS_CTL_38_DATA 0x0400091C +#define DDRSS_CTL_39_DATA 0x1C1C1C1C +#define DDRSS_CTL_40_DATA 0x0400091C +#define DDRSS_CTL_41_DATA 0x1C1C1C1C +#define DDRSS_CTL_42_DATA 0x0400091C +#define DDRSS_CTL_43_DATA 0x1C1C1C1C +#define DDRSS_CTL_44_DATA 0x05050404 +#define DDRSS_CTL_45_DATA 0x00002706 +#define DDRSS_CTL_46_DATA 0x0602001D +#define DDRSS_CTL_47_DATA 0x05001D0B +#define DDRSS_CTL_48_DATA 0x00270605 +#define DDRSS_CTL_49_DATA 0x0602001D +#define DDRSS_CTL_50_DATA 0x05001D0B +#define DDRSS_CTL_51_DATA 0x00270605 +#define DDRSS_CTL_52_DATA 0x0602001D +#define DDRSS_CTL_53_DATA 0x07001D0B +#define DDRSS_CTL_54_DATA 0x00180807 +#define DDRSS_CTL_55_DATA 0x0400DB60 +#define DDRSS_CTL_56_DATA 0x07070009 +#define DDRSS_CTL_57_DATA 0x00001808 +#define DDRSS_CTL_58_DATA 0x0400DB60 +#define DDRSS_CTL_59_DATA 0x07070009 +#define DDRSS_CTL_60_DATA 0x00001808 +#define DDRSS_CTL_61_DATA 0x0400DB60 +#define DDRSS_CTL_62_DATA 0x03000009 +#define DDRSS_CTL_63_DATA 0x0D0C0002 +#define DDRSS_CTL_64_DATA 0x0D0C0D0C +#define DDRSS_CTL_65_DATA 0x01010000 +#define DDRSS_CTL_66_DATA 0x03191919 +#define DDRSS_CTL_67_DATA 0x0B0B0B0B +#define DDRSS_CTL_68_DATA 0x00000B0B +#define DDRSS_CTL_69_DATA 0x00000101 +#define DDRSS_CTL_70_DATA 0x00000000 +#define DDRSS_CTL_71_DATA 0x01000000 +#define DDRSS_CTL_72_DATA 0x01180803 +#define DDRSS_CTL_73_DATA 0x00001860 +#define DDRSS_CTL_74_DATA 0x00000118 +#define DDRSS_CTL_75_DATA 0x00001860 +#define DDRSS_CTL_76_DATA 0x00000118 +#define DDRSS_CTL_77_DATA 0x00001860 +#define DDRSS_CTL_78_DATA 0x00000005 +#define DDRSS_CTL_79_DATA 0x00000000 +#define DDRSS_CTL_80_DATA 0x00000000 +#define DDRSS_CTL_81_DATA 0x00000000 +#define DDRSS_CTL_82_DATA 0x00000000 +#define DDRSS_CTL_83_DATA 0x00000000 +#define DDRSS_CTL_84_DATA 0x00000000 +#define DDRSS_CTL_85_DATA 0x00000000 +#define DDRSS_CTL_86_DATA 0x00000000 +#define DDRSS_CTL_87_DATA 0x00090009 +#define DDRSS_CTL_88_DATA 0x00000009 +#define DDRSS_CTL_89_DATA 0x00000000 +#define DDRSS_CTL_90_DATA 0x00000000 +#define DDRSS_CTL_91_DATA 0x00000000 +#define DDRSS_CTL_92_DATA 0x00000000 +#define DDRSS_CTL_93_DATA 0x00000000 +#define DDRSS_CTL_94_DATA 0x00010001 +#define DDRSS_CTL_95_DATA 0x00040001 +#define DDRSS_CTL_96_DATA 0x04000120 +#define DDRSS_CTL_97_DATA 0x04000120 +#define DDRSS_CTL_98_DATA 0x01200120 +#define DDRSS_CTL_99_DATA 0x01200120 +#define DDRSS_CTL_100_DATA 0x00000000 +#define DDRSS_CTL_101_DATA 0x00000000 +#define DDRSS_CTL_102_DATA 0x00000000 +#define DDRSS_CTL_103_DATA 0x00000000 +#define DDRSS_CTL_104_DATA 0x00000000 +#define DDRSS_CTL_105_DATA 0x00000000 +#define DDRSS_CTL_106_DATA 0x03010000 +#define DDRSS_CTL_107_DATA 0x00010000 +#define DDRSS_CTL_108_DATA 0x00000000 +#define DDRSS_CTL_109_DATA 0x01000000 +#define DDRSS_CTL_110_DATA 0x80104002 +#define DDRSS_CTL_111_DATA 0x00040003 +#define DDRSS_CTL_112_DATA 0x00040005 +#define DDRSS_CTL_113_DATA 0x00030000 +#define DDRSS_CTL_114_DATA 0x00050004 +#define DDRSS_CTL_115_DATA 0x00000004 +#define DDRSS_CTL_116_DATA 0x00040003 +#define DDRSS_CTL_117_DATA 0x00040005 +#define DDRSS_CTL_118_DATA 0x00000000 +#define DDRSS_CTL_119_DATA 0x00061800 +#define DDRSS_CTL_120_DATA 0x00061800 +#define DDRSS_CTL_121_DATA 0x00061800 +#define DDRSS_CTL_122_DATA 0x00061800 +#define DDRSS_CTL_123_DATA 0x00061800 +#define DDRSS_CTL_124_DATA 0x00000000 +#define DDRSS_CTL_125_DATA 0x0000AAA0 +#define DDRSS_CTL_126_DATA 0x00061800 +#define DDRSS_CTL_127_DATA 0x00061800 +#define DDRSS_CTL_128_DATA 0x00061800 +#define DDRSS_CTL_129_DATA 0x00061800 +#define DDRSS_CTL_130_DATA 0x00061800 +#define DDRSS_CTL_131_DATA 0x00000000 +#define DDRSS_CTL_132_DATA 0x0000AAA0 +#define DDRSS_CTL_133_DATA 0x00061800 +#define DDRSS_CTL_134_DATA 0x00061800 +#define DDRSS_CTL_135_DATA 0x00061800 +#define DDRSS_CTL_136_DATA 0x00061800 +#define DDRSS_CTL_137_DATA 0x00061800 +#define DDRSS_CTL_138_DATA 0x00000000 +#define DDRSS_CTL_139_DATA 0x0000AAA0 +#define DDRSS_CTL_140_DATA 0x00000000 +#define DDRSS_CTL_141_DATA 0x00000000 +#define DDRSS_CTL_142_DATA 0x00000000 +#define DDRSS_CTL_143_DATA 0x00000000 +#define DDRSS_CTL_144_DATA 0x00000000 +#define DDRSS_CTL_145_DATA 0x00000000 +#define DDRSS_CTL_146_DATA 0x00000000 +#define DDRSS_CTL_147_DATA 0x00000000 +#define DDRSS_CTL_148_DATA 0x00000000 +#define DDRSS_CTL_149_DATA 0x00000000 +#define DDRSS_CTL_150_DATA 0x00000000 +#define DDRSS_CTL_151_DATA 0x00000000 +#define DDRSS_CTL_152_DATA 0x00000000 +#define DDRSS_CTL_153_DATA 0x00000000 +#define DDRSS_CTL_154_DATA 0x00000000 +#define DDRSS_CTL_155_DATA 0x00000000 +#define DDRSS_CTL_156_DATA 0x080C0000 +#define DDRSS_CTL_157_DATA 0x080C080C +#define DDRSS_CTL_158_DATA 0x08000000 +#define DDRSS_CTL_159_DATA 0x00000808 +#define DDRSS_CTL_160_DATA 0x000E0000 +#define DDRSS_CTL_161_DATA 0x00080808 +#define DDRSS_CTL_162_DATA 0x0E000000 +#define DDRSS_CTL_163_DATA 0x08080800 +#define DDRSS_CTL_164_DATA 0x00000000 +#define DDRSS_CTL_165_DATA 0x0000080E +#define DDRSS_CTL_166_DATA 0x00040003 +#define DDRSS_CTL_167_DATA 0x00000007 +#define DDRSS_CTL_168_DATA 0x00000000 +#define DDRSS_CTL_169_DATA 0x00000000 +#define DDRSS_CTL_170_DATA 0x00000000 +#define DDRSS_CTL_171_DATA 0x00000000 +#define DDRSS_CTL_172_DATA 0x00000000 +#define DDRSS_CTL_173_DATA 0x00000000 +#define DDRSS_CTL_174_DATA 0x01000000 +#define DDRSS_CTL_175_DATA 0x00000000 +#define DDRSS_CTL_176_DATA 0x00001500 +#define DDRSS_CTL_177_DATA 0x0000100E +#define DDRSS_CTL_178_DATA 0x00000000 +#define DDRSS_CTL_179_DATA 0x00000000 +#define DDRSS_CTL_180_DATA 0x00000001 +#define DDRSS_CTL_181_DATA 0x00000002 +#define DDRSS_CTL_182_DATA 0x00000C00 +#define DDRSS_CTL_183_DATA 0x00001000 +#define DDRSS_CTL_184_DATA 0x00000C00 +#define DDRSS_CTL_185_DATA 0x00001000 +#define DDRSS_CTL_186_DATA 0x00000C00 +#define DDRSS_CTL_187_DATA 0x00001000 +#define DDRSS_CTL_188_DATA 0x00000000 +#define DDRSS_CTL_189_DATA 0x00000000 +#define DDRSS_CTL_190_DATA 0x00000000 +#define DDRSS_CTL_191_DATA 0x00000000 +#define DDRSS_CTL_192_DATA 0x00000000 +#define DDRSS_CTL_193_DATA 0x00000000 +#define DDRSS_CTL_194_DATA 0x00000000 +#define DDRSS_CTL_195_DATA 0x00000000 +#define DDRSS_CTL_196_DATA 0x00000000 +#define DDRSS_CTL_197_DATA 0x00000000 +#define DDRSS_CTL_198_DATA 0x00000000 +#define DDRSS_CTL_199_DATA 0x00000000 +#define DDRSS_CTL_200_DATA 0x00000000 +#define DDRSS_CTL_201_DATA 0x00000000 +#define DDRSS_CTL_202_DATA 0x00000000 +#define DDRSS_CTL_203_DATA 0x00000000 +#define DDRSS_CTL_204_DATA 0x00042400 +#define DDRSS_CTL_205_DATA 0x00000301 +#define DDRSS_CTL_206_DATA 0x00000000 +#define DDRSS_CTL_207_DATA 0x00000424 +#define DDRSS_CTL_208_DATA 0x00000301 +#define DDRSS_CTL_209_DATA 0x00000000 +#define DDRSS_CTL_210_DATA 0x00000424 +#define DDRSS_CTL_211_DATA 0x00000301 +#define DDRSS_CTL_212_DATA 0x00000000 +#define DDRSS_CTL_213_DATA 0x00000424 +#define DDRSS_CTL_214_DATA 0x00000301 +#define DDRSS_CTL_215_DATA 0x00000000 +#define DDRSS_CTL_216_DATA 0x00000424 +#define DDRSS_CTL_217_DATA 0x00000301 +#define DDRSS_CTL_218_DATA 0x00000000 +#define DDRSS_CTL_219_DATA 0x00000424 +#define DDRSS_CTL_220_DATA 0x00000301 +#define DDRSS_CTL_221_DATA 0x00000000 +#define DDRSS_CTL_222_DATA 0x00000000 +#define DDRSS_CTL_223_DATA 0x00000000 +#define DDRSS_CTL_224_DATA 0x00000000 +#define DDRSS_CTL_225_DATA 0x00000000 +#define DDRSS_CTL_226_DATA 0x00000000 +#define DDRSS_CTL_227_DATA 0x00000000 +#define DDRSS_CTL_228_DATA 0x00000000 +#define DDRSS_CTL_229_DATA 0x00000000 +#define DDRSS_CTL_230_DATA 0x00000000 +#define DDRSS_CTL_231_DATA 0x00000000 +#define DDRSS_CTL_232_DATA 0x00000000 +#define DDRSS_CTL_233_DATA 0x00000000 +#define DDRSS_CTL_234_DATA 0x00000000 +#define DDRSS_CTL_235_DATA 0x00000000 +#define DDRSS_CTL_236_DATA 0x00001401 +#define DDRSS_CTL_237_DATA 0x00001401 +#define DDRSS_CTL_238_DATA 0x00001401 +#define DDRSS_CTL_239_DATA 0x00001401 +#define DDRSS_CTL_240_DATA 0x00001401 +#define DDRSS_CTL_241_DATA 0x00001401 +#define DDRSS_CTL_242_DATA 0x00000493 +#define DDRSS_CTL_243_DATA 0x00000493 +#define DDRSS_CTL_244_DATA 0x00000493 +#define DDRSS_CTL_245_DATA 0x00000493 +#define DDRSS_CTL_246_DATA 0x00000493 +#define DDRSS_CTL_247_DATA 0x00000493 +#define DDRSS_CTL_248_DATA 0x00000000 +#define DDRSS_CTL_249_DATA 0x00000000 +#define DDRSS_CTL_250_DATA 0x00000000 +#define DDRSS_CTL_251_DATA 0x00000000 +#define DDRSS_CTL_252_DATA 0x00000000 +#define DDRSS_CTL_253_DATA 0x00000000 +#define DDRSS_CTL_254_DATA 0x00000000 +#define DDRSS_CTL_255_DATA 0x00000000 +#define DDRSS_CTL_256_DATA 0x00000000 +#define DDRSS_CTL_257_DATA 0x00000000 +#define DDRSS_CTL_258_DATA 0x00000000 +#define DDRSS_CTL_259_DATA 0x00000000 +#define DDRSS_CTL_260_DATA 0x00000000 +#define DDRSS_CTL_261_DATA 0x00000000 +#define DDRSS_CTL_262_DATA 0x00000000 +#define DDRSS_CTL_263_DATA 0x00000000 +#define DDRSS_CTL_264_DATA 0x00000000 +#define DDRSS_CTL_265_DATA 0x00000000 +#define DDRSS_CTL_266_DATA 0x00000000 +#define DDRSS_CTL_267_DATA 0x00000000 +#define DDRSS_CTL_268_DATA 0x00000000 +#define DDRSS_CTL_269_DATA 0x00000000 +#define DDRSS_CTL_270_DATA 0x00000000 +#define DDRSS_CTL_271_DATA 0x00000000 +#define DDRSS_CTL_272_DATA 0x00000000 +#define DDRSS_CTL_273_DATA 0x00000000 +#define DDRSS_CTL_274_DATA 0x00000000 +#define DDRSS_CTL_275_DATA 0x00000000 +#define DDRSS_CTL_276_DATA 0x00000000 +#define DDRSS_CTL_277_DATA 0x00010000 +#define DDRSS_CTL_278_DATA 0x00000000 +#define DDRSS_CTL_279_DATA 0x00000000 +#define DDRSS_CTL_280_DATA 0x00000000 +#define DDRSS_CTL_281_DATA 0x00000101 +#define DDRSS_CTL_282_DATA 0x00000000 +#define DDRSS_CTL_283_DATA 0x00000000 +#define DDRSS_CTL_284_DATA 0x00000000 +#define DDRSS_CTL_285_DATA 0x00000000 +#define DDRSS_CTL_286_DATA 0x00000000 +#define DDRSS_CTL_287_DATA 0x00000000 +#define DDRSS_CTL_288_DATA 0x00000000 +#define DDRSS_CTL_289_DATA 0x00000000 +#define DDRSS_CTL_290_DATA 0x0C181511 +#define DDRSS_CTL_291_DATA 0x00000304 +#define DDRSS_CTL_292_DATA 0x00000000 +#define DDRSS_CTL_293_DATA 0x00000000 +#define DDRSS_CTL_294_DATA 0x00000000 +#define DDRSS_CTL_295_DATA 0x00000000 +#define DDRSS_CTL_296_DATA 0x00000000 +#define DDRSS_CTL_297_DATA 0x00000000 +#define DDRSS_CTL_298_DATA 0x00000000 +#define DDRSS_CTL_299_DATA 0x00000000 +#define DDRSS_CTL_300_DATA 0x00000000 +#define DDRSS_CTL_301_DATA 0x00000000 +#define DDRSS_CTL_302_DATA 0x00000000 +#define DDRSS_CTL_303_DATA 0x00000000 +#define DDRSS_CTL_304_DATA 0x00000000 +#define DDRSS_CTL_305_DATA 0x00040000 +#define DDRSS_CTL_306_DATA 0x00800200 +#define DDRSS_CTL_307_DATA 0x00000000 +#define DDRSS_CTL_308_DATA 0x02000400 +#define DDRSS_CTL_309_DATA 0x00000080 +#define DDRSS_CTL_310_DATA 0x00040000 +#define DDRSS_CTL_311_DATA 0x00800200 +#define DDRSS_CTL_312_DATA 0x00000000 +#define DDRSS_CTL_313_DATA 0x00000000 +#define DDRSS_CTL_314_DATA 0x00000000 +#define DDRSS_CTL_315_DATA 0x00000100 +#define DDRSS_CTL_316_DATA 0x01010000 +#define DDRSS_CTL_317_DATA 0x00000000 +#define DDRSS_CTL_318_DATA 0x3FFF0000 +#define DDRSS_CTL_319_DATA 0x000FFF00 +#define DDRSS_CTL_320_DATA 0xFFFFFFFF +#define DDRSS_CTL_321_DATA 0x00FFFF00 +#define DDRSS_CTL_322_DATA 0x0A000000 +#define DDRSS_CTL_323_DATA 0x0001FFFF +#define DDRSS_CTL_324_DATA 0x01010101 +#define DDRSS_CTL_325_DATA 0x01010101 +#define DDRSS_CTL_326_DATA 0x00000118 +#define DDRSS_CTL_327_DATA 0x00000C01 +#define DDRSS_CTL_328_DATA 0x00000000 +#define DDRSS_CTL_329_DATA 0x00000000 +#define DDRSS_CTL_330_DATA 0x00000000 +#define DDRSS_CTL_331_DATA 0x01000000 +#define DDRSS_CTL_332_DATA 0x00000100 +#define DDRSS_CTL_333_DATA 0x00010000 +#define DDRSS_CTL_334_DATA 0x00000000 +#define DDRSS_CTL_335_DATA 0x00000000 +#define DDRSS_CTL_336_DATA 0x00000000 +#define DDRSS_CTL_337_DATA 0x00000000 +#define DDRSS_CTL_338_DATA 0x00000000 +#define DDRSS_CTL_339_DATA 0x00000000 +#define DDRSS_CTL_340_DATA 0x00000000 +#define DDRSS_CTL_341_DATA 0x00000000 +#define DDRSS_CTL_342_DATA 0x00000000 +#define DDRSS_CTL_343_DATA 0x00000000 +#define DDRSS_CTL_344_DATA 0x00000000 +#define DDRSS_CTL_345_DATA 0x00000000 +#define DDRSS_CTL_346_DATA 0x00000000 +#define DDRSS_CTL_347_DATA 0x00000000 +#define DDRSS_CTL_348_DATA 0x00000000 +#define DDRSS_CTL_349_DATA 0x00000000 +#define DDRSS_CTL_350_DATA 0x00000000 +#define DDRSS_CTL_351_DATA 0x00000000 +#define DDRSS_CTL_352_DATA 0x00000000 +#define DDRSS_CTL_353_DATA 0x00000000 +#define DDRSS_CTL_354_DATA 0x00000000 +#define DDRSS_CTL_355_DATA 0x00000000 +#define DDRSS_CTL_356_DATA 0x00000000 +#define DDRSS_CTL_357_DATA 0x00000000 +#define DDRSS_CTL_358_DATA 0x00000000 +#define DDRSS_CTL_359_DATA 0x00000000 +#define DDRSS_CTL_360_DATA 0x00000000 +#define DDRSS_CTL_361_DATA 0x00000000 +#define DDRSS_CTL_362_DATA 0x00000000 +#define DDRSS_CTL_363_DATA 0x00000000 +#define DDRSS_CTL_364_DATA 0x00000000 +#define DDRSS_CTL_365_DATA 0x00000000 +#define DDRSS_CTL_366_DATA 0x00000000 +#define DDRSS_CTL_367_DATA 0x00000000 +#define DDRSS_CTL_368_DATA 0x00000000 +#define DDRSS_CTL_369_DATA 0x00000000 +#define DDRSS_CTL_370_DATA 0x0C000000 +#define DDRSS_CTL_371_DATA 0x060C0606 +#define DDRSS_CTL_372_DATA 0x06060C06 +#define DDRSS_CTL_373_DATA 0x00010101 +#define DDRSS_CTL_374_DATA 0x02000000 +#define DDRSS_CTL_375_DATA 0x05020101 +#define DDRSS_CTL_376_DATA 0x00000505 +#define DDRSS_CTL_377_DATA 0x02020200 +#define DDRSS_CTL_378_DATA 0x02020202 +#define DDRSS_CTL_379_DATA 0x02020202 +#define DDRSS_CTL_380_DATA 0x02020202 +#define DDRSS_CTL_381_DATA 0x00000000 +#define DDRSS_CTL_382_DATA 0x00000000 +#define DDRSS_CTL_383_DATA 0x04000100 +#define DDRSS_CTL_384_DATA 0x1E000004 +#define DDRSS_CTL_385_DATA 0x000030C0 +#define DDRSS_CTL_386_DATA 0x00000200 +#define DDRSS_CTL_387_DATA 0x00000200 +#define DDRSS_CTL_388_DATA 0x00000200 +#define DDRSS_CTL_389_DATA 0x00000200 +#define DDRSS_CTL_390_DATA 0x0000DB60 +#define DDRSS_CTL_391_DATA 0x0001E780 +#define DDRSS_CTL_392_DATA 0x0C0D0302 +#define DDRSS_CTL_393_DATA 0x001E090A +#define DDRSS_CTL_394_DATA 0x000030C0 +#define DDRSS_CTL_395_DATA 0x00000200 +#define DDRSS_CTL_396_DATA 0x00000200 +#define DDRSS_CTL_397_DATA 0x00000200 +#define DDRSS_CTL_398_DATA 0x00000200 +#define DDRSS_CTL_399_DATA 0x0000DB60 +#define DDRSS_CTL_400_DATA 0x0001E780 +#define DDRSS_CTL_401_DATA 0x0C0D0302 +#define DDRSS_CTL_402_DATA 0x001E090A +#define DDRSS_CTL_403_DATA 0x000030C0 +#define DDRSS_CTL_404_DATA 0x00000200 +#define DDRSS_CTL_405_DATA 0x00000200 +#define DDRSS_CTL_406_DATA 0x00000200 +#define DDRSS_CTL_407_DATA 0x00000200 +#define DDRSS_CTL_408_DATA 0x0000DB60 +#define DDRSS_CTL_409_DATA 0x0001E780 +#define DDRSS_CTL_410_DATA 0x0C0D0302 +#define DDRSS_CTL_411_DATA 0x0000090A +#define DDRSS_CTL_412_DATA 0x00000000 +#define DDRSS_CTL_413_DATA 0x0302000A +#define DDRSS_CTL_414_DATA 0x01000500 +#define DDRSS_CTL_415_DATA 0x01010001 +#define DDRSS_CTL_416_DATA 0x00010001 +#define DDRSS_CTL_417_DATA 0x01010001 +#define DDRSS_CTL_418_DATA 0x02010000 +#define DDRSS_CTL_419_DATA 0x00000200 +#define DDRSS_CTL_420_DATA 0x02000201 +#define DDRSS_CTL_421_DATA 0x00000000 +#define DDRSS_CTL_422_DATA 0x00202020 +#define DDRSS_PI_0_DATA 0x00000A00 +#define DDRSS_PI_1_DATA 0x00000000 +#define DDRSS_PI_2_DATA 0x00000000 +#define DDRSS_PI_3_DATA 0x01000000 +#define DDRSS_PI_4_DATA 0x00000001 +#define DDRSS_PI_5_DATA 0x00010064 +#define DDRSS_PI_6_DATA 0x00000000 +#define DDRSS_PI_7_DATA 0x00000000 +#define DDRSS_PI_8_DATA 0x00000000 +#define DDRSS_PI_9_DATA 0x00000000 +#define DDRSS_PI_10_DATA 0x00000000 +#define DDRSS_PI_11_DATA 0x00000000 +#define DDRSS_PI_12_DATA 0x00000000 +#define DDRSS_PI_13_DATA 0x00010001 +#define DDRSS_PI_14_DATA 0x00000000 +#define DDRSS_PI_15_DATA 0x00010001 +#define DDRSS_PI_16_DATA 0x00000005 +#define DDRSS_PI_17_DATA 0x00000000 +#define DDRSS_PI_18_DATA 0x00000000 +#define DDRSS_PI_19_DATA 0x00000000 +#define DDRSS_PI_20_DATA 0x00000000 +#define DDRSS_PI_21_DATA 0x00000000 +#define DDRSS_PI_22_DATA 0x00000000 +#define DDRSS_PI_23_DATA 0x00000000 +#define DDRSS_PI_24_DATA 0x280D0001 +#define DDRSS_PI_25_DATA 0x00000000 +#define DDRSS_PI_26_DATA 0x00010000 +#define DDRSS_PI_27_DATA 0x00003200 +#define DDRSS_PI_28_DATA 0x00000000 +#define DDRSS_PI_29_DATA 0x00000000 +#define DDRSS_PI_30_DATA 0x00060602 +#define DDRSS_PI_31_DATA 0x00000000 +#define DDRSS_PI_32_DATA 0x00000000 +#define DDRSS_PI_33_DATA 0x00000000 +#define DDRSS_PI_34_DATA 0x00000001 +#define DDRSS_PI_35_DATA 0x00000055 +#define DDRSS_PI_36_DATA 0x000000AA +#define DDRSS_PI_37_DATA 0x000000AD +#define DDRSS_PI_38_DATA 0x00000052 +#define DDRSS_PI_39_DATA 0x0000006A +#define DDRSS_PI_40_DATA 0x00000095 +#define DDRSS_PI_41_DATA 0x00000095 +#define DDRSS_PI_42_DATA 0x000000AD +#define DDRSS_PI_43_DATA 0x00000000 +#define DDRSS_PI_44_DATA 0x00000000 +#define DDRSS_PI_45_DATA 0x00010100 +#define DDRSS_PI_46_DATA 0x00000014 +#define DDRSS_PI_47_DATA 0x000007D0 +#define DDRSS_PI_48_DATA 0x00000300 +#define DDRSS_PI_49_DATA 0x00000000 +#define DDRSS_PI_50_DATA 0x00000000 +#define DDRSS_PI_51_DATA 0x01000000 +#define DDRSS_PI_52_DATA 0x00010101 +#define DDRSS_PI_53_DATA 0x01000000 +#define DDRSS_PI_54_DATA 0x00000000 +#define DDRSS_PI_55_DATA 0x00010000 +#define DDRSS_PI_56_DATA 0x00000000 +#define DDRSS_PI_57_DATA 0x00000000 +#define DDRSS_PI_58_DATA 0x00000000 +#define DDRSS_PI_59_DATA 0x00000000 +#define DDRSS_PI_60_DATA 0x00001400 +#define DDRSS_PI_61_DATA 0x00000000 +#define DDRSS_PI_62_DATA 0x01000000 +#define DDRSS_PI_63_DATA 0x00000404 +#define DDRSS_PI_64_DATA 0x00000001 +#define DDRSS_PI_65_DATA 0x0001010E +#define DDRSS_PI_66_DATA 0x02040100 +#define DDRSS_PI_67_DATA 0x00010000 +#define DDRSS_PI_68_DATA 0x00000034 +#define DDRSS_PI_69_DATA 0x00000000 +#define DDRSS_PI_70_DATA 0x00000000 +#define DDRSS_PI_71_DATA 0x00000000 +#define DDRSS_PI_72_DATA 0x00000000 +#define DDRSS_PI_73_DATA 0x00000000 +#define DDRSS_PI_74_DATA 0x00000000 +#define DDRSS_PI_75_DATA 0x00000005 +#define DDRSS_PI_76_DATA 0x01000000 +#define DDRSS_PI_77_DATA 0x04000100 +#define DDRSS_PI_78_DATA 0x00020000 +#define DDRSS_PI_79_DATA 0x00010002 +#define DDRSS_PI_80_DATA 0x00000001 +#define DDRSS_PI_81_DATA 0x00020001 +#define DDRSS_PI_82_DATA 0x00020002 +#define DDRSS_PI_83_DATA 0x00000000 +#define DDRSS_PI_84_DATA 0x00000000 +#define DDRSS_PI_85_DATA 0x00000000 +#define DDRSS_PI_86_DATA 0x00000000 +#define DDRSS_PI_87_DATA 0x00000000 +#define DDRSS_PI_88_DATA 0x00000000 +#define DDRSS_PI_89_DATA 0x00000000 +#define DDRSS_PI_90_DATA 0x00000000 +#define DDRSS_PI_91_DATA 0x00000300 +#define DDRSS_PI_92_DATA 0x0A090B0C +#define DDRSS_PI_93_DATA 0x04060708 +#define DDRSS_PI_94_DATA 0x01000005 +#define DDRSS_PI_95_DATA 0x00000800 +#define DDRSS_PI_96_DATA 0x00000000 +#define DDRSS_PI_97_DATA 0x00010008 +#define DDRSS_PI_98_DATA 0x00000000 +#define DDRSS_PI_99_DATA 0x0000AA00 +#define DDRSS_PI_100_DATA 0x00000000 +#define DDRSS_PI_101_DATA 0x00010000 +#define DDRSS_PI_102_DATA 0x00000000 +#define DDRSS_PI_103_DATA 0x00000000 +#define DDRSS_PI_104_DATA 0x00000000 +#define DDRSS_PI_105_DATA 0x00000000 +#define DDRSS_PI_106_DATA 0x00000000 +#define DDRSS_PI_107_DATA 0x00000000 +#define DDRSS_PI_108_DATA 0x00000000 +#define DDRSS_PI_109_DATA 0x00000000 +#define DDRSS_PI_110_DATA 0x00000000 +#define DDRSS_PI_111_DATA 0x00000000 +#define DDRSS_PI_112_DATA 0x00000000 +#define DDRSS_PI_113_DATA 0x00000000 +#define DDRSS_PI_114_DATA 0x00000000 +#define DDRSS_PI_115_DATA 0x00000000 +#define DDRSS_PI_116_DATA 0x00000000 +#define DDRSS_PI_117_DATA 0x00000000 +#define DDRSS_PI_118_DATA 0x00000000 +#define DDRSS_PI_119_DATA 0x00000000 +#define DDRSS_PI_120_DATA 0x00000000 +#define DDRSS_PI_121_DATA 0x00000000 +#define DDRSS_PI_122_DATA 0x00000000 +#define DDRSS_PI_123_DATA 0x00000000 +#define DDRSS_PI_124_DATA 0x00000008 +#define DDRSS_PI_125_DATA 0x00000000 +#define DDRSS_PI_126_DATA 0x00000000 +#define DDRSS_PI_127_DATA 0x00000000 +#define DDRSS_PI_128_DATA 0x00000000 +#define DDRSS_PI_129_DATA 0x00000000 +#define DDRSS_PI_130_DATA 0x00000000 +#define DDRSS_PI_131_DATA 0x00000000 +#define DDRSS_PI_132_DATA 0x00000000 +#define DDRSS_PI_133_DATA 0x00010100 +#define DDRSS_PI_134_DATA 0x00000000 +#define DDRSS_PI_135_DATA 0x00000000 +#define DDRSS_PI_136_DATA 0x00027100 +#define DDRSS_PI_137_DATA 0x00061A80 +#define DDRSS_PI_138_DATA 0x00000100 +#define DDRSS_PI_139_DATA 0x00000000 +#define DDRSS_PI_140_DATA 0x00000000 +#define DDRSS_PI_141_DATA 0x00000000 +#define DDRSS_PI_142_DATA 0x00000000 +#define DDRSS_PI_143_DATA 0x00000000 +#define DDRSS_PI_144_DATA 0x01000000 +#define DDRSS_PI_145_DATA 0x00010003 +#define DDRSS_PI_146_DATA 0x02000101 +#define DDRSS_PI_147_DATA 0x01030001 +#define DDRSS_PI_148_DATA 0x00010400 +#define DDRSS_PI_149_DATA 0x06000105 +#define DDRSS_PI_150_DATA 0x01070001 +#define DDRSS_PI_151_DATA 0x00000000 +#define DDRSS_PI_152_DATA 0x00000000 +#define DDRSS_PI_153_DATA 0x00000000 +#define DDRSS_PI_154_DATA 0x00010000 +#define DDRSS_PI_155_DATA 0x00000000 +#define DDRSS_PI_156_DATA 0x00000000 +#define DDRSS_PI_157_DATA 0x00000000 +#define DDRSS_PI_158_DATA 0x00000000 +#define DDRSS_PI_159_DATA 0x00010000 +#define DDRSS_PI_160_DATA 0x00000004 +#define DDRSS_PI_161_DATA 0x00000000 +#define DDRSS_PI_162_DATA 0x00000000 +#define DDRSS_PI_163_DATA 0x00000000 +#define DDRSS_PI_164_DATA 0x00007800 +#define DDRSS_PI_165_DATA 0x00780078 +#define DDRSS_PI_166_DATA 0x00141414 +#define DDRSS_PI_167_DATA 0x0000003A +#define DDRSS_PI_168_DATA 0x0000003A +#define DDRSS_PI_169_DATA 0x0004003A +#define DDRSS_PI_170_DATA 0x04000400 +#define DDRSS_PI_171_DATA 0xC8040009 +#define DDRSS_PI_172_DATA 0x0400091C +#define DDRSS_PI_173_DATA 0x00091CC8 +#define DDRSS_PI_174_DATA 0x001CC804 +#define DDRSS_PI_175_DATA 0x00000118 +#define DDRSS_PI_176_DATA 0x00001860 +#define DDRSS_PI_177_DATA 0x00000118 +#define DDRSS_PI_178_DATA 0x00001860 +#define DDRSS_PI_179_DATA 0x00000118 +#define DDRSS_PI_180_DATA 0x04001860 +#define DDRSS_PI_181_DATA 0x01010404 +#define DDRSS_PI_182_DATA 0x00001901 +#define DDRSS_PI_183_DATA 0x00190019 +#define DDRSS_PI_184_DATA 0x010C010C +#define DDRSS_PI_185_DATA 0x0000010C +#define DDRSS_PI_186_DATA 0x00000000 +#define DDRSS_PI_187_DATA 0x05000000 +#define DDRSS_PI_188_DATA 0x01010505 +#define DDRSS_PI_189_DATA 0x01010101 +#define DDRSS_PI_190_DATA 0x00181818 +#define DDRSS_PI_191_DATA 0x00000000 +#define DDRSS_PI_192_DATA 0x00000000 +#define DDRSS_PI_193_DATA 0x0D000000 +#define DDRSS_PI_194_DATA 0x0A0A0D0D +#define DDRSS_PI_195_DATA 0x0303030A +#define DDRSS_PI_196_DATA 0x00000000 +#define DDRSS_PI_197_DATA 0x00000000 +#define DDRSS_PI_198_DATA 0x00000000 +#define DDRSS_PI_199_DATA 0x00000000 +#define DDRSS_PI_200_DATA 0x00000000 +#define DDRSS_PI_201_DATA 0x00000000 +#define DDRSS_PI_202_DATA 0x00000000 +#define DDRSS_PI_203_DATA 0x00000000 +#define DDRSS_PI_204_DATA 0x00000000 +#define DDRSS_PI_205_DATA 0x00000000 +#define DDRSS_PI_206_DATA 0x00000000 +#define DDRSS_PI_207_DATA 0x00000000 +#define DDRSS_PI_208_DATA 0x00000000 +#define DDRSS_PI_209_DATA 0x0D090000 +#define DDRSS_PI_210_DATA 0x0D09000D +#define DDRSS_PI_211_DATA 0x0D09000D +#define DDRSS_PI_212_DATA 0x0000000D +#define DDRSS_PI_213_DATA 0x00000000 +#define DDRSS_PI_214_DATA 0x00000000 +#define DDRSS_PI_215_DATA 0x00000000 +#define DDRSS_PI_216_DATA 0x00000000 +#define DDRSS_PI_217_DATA 0x16000000 +#define DDRSS_PI_218_DATA 0x001600C8 +#define DDRSS_PI_219_DATA 0x001600C8 +#define DDRSS_PI_220_DATA 0x010100C8 +#define DDRSS_PI_221_DATA 0x00001B01 +#define DDRSS_PI_222_DATA 0x1F0F0053 +#define DDRSS_PI_223_DATA 0x05000001 +#define DDRSS_PI_224_DATA 0x001B0A0D +#define DDRSS_PI_225_DATA 0x1F0F0053 +#define DDRSS_PI_226_DATA 0x05000001 +#define DDRSS_PI_227_DATA 0x001B0A0D +#define DDRSS_PI_228_DATA 0x1F0F0053 +#define DDRSS_PI_229_DATA 0x05000001 +#define DDRSS_PI_230_DATA 0x00010A0D +#define DDRSS_PI_231_DATA 0x0C0B0700 +#define DDRSS_PI_232_DATA 0x000D0605 +#define DDRSS_PI_233_DATA 0x0000C570 +#define DDRSS_PI_234_DATA 0x0000001D +#define DDRSS_PI_235_DATA 0x180A0800 +#define DDRSS_PI_236_DATA 0x0B071C1C +#define DDRSS_PI_237_DATA 0x0D06050C +#define DDRSS_PI_238_DATA 0x0000C570 +#define DDRSS_PI_239_DATA 0x0000001D +#define DDRSS_PI_240_DATA 0x180A0800 +#define DDRSS_PI_241_DATA 0x0B071C1C +#define DDRSS_PI_242_DATA 0x0D06050C +#define DDRSS_PI_243_DATA 0x0000C570 +#define DDRSS_PI_244_DATA 0x0000001D +#define DDRSS_PI_245_DATA 0x180A0800 +#define DDRSS_PI_246_DATA 0x00001C1C +#define DDRSS_PI_247_DATA 0x000030C0 +#define DDRSS_PI_248_DATA 0x0001E780 +#define DDRSS_PI_249_DATA 0x000030C0 +#define DDRSS_PI_250_DATA 0x0001E780 +#define DDRSS_PI_251_DATA 0x000030C0 +#define DDRSS_PI_252_DATA 0x0001E780 +#define DDRSS_PI_253_DATA 0x04000400 +#define DDRSS_PI_254_DATA 0x03030400 +#define DDRSS_PI_255_DATA 0x00040003 +#define DDRSS_PI_256_DATA 0x04000400 +#define DDRSS_PI_257_DATA 0x0C080C08 +#define DDRSS_PI_258_DATA 0x00000C08 +#define DDRSS_PI_259_DATA 0x000890B8 +#define DDRSS_PI_260_DATA 0x00000000 +#define DDRSS_PI_261_DATA 0x00000000 +#define DDRSS_PI_262_DATA 0x00000000 +#define DDRSS_PI_263_DATA 0x00000120 +#define DDRSS_PI_264_DATA 0x000890B8 +#define DDRSS_PI_265_DATA 0x00000000 +#define DDRSS_PI_266_DATA 0x00000000 +#define DDRSS_PI_267_DATA 0x00000000 +#define DDRSS_PI_268_DATA 0x00000120 +#define DDRSS_PI_269_DATA 0x000890B8 +#define DDRSS_PI_270_DATA 0x00000000 +#define DDRSS_PI_271_DATA 0x00000000 +#define DDRSS_PI_272_DATA 0x00000000 +#define DDRSS_PI_273_DATA 0x02000120 +#define DDRSS_PI_274_DATA 0x00000080 +#define DDRSS_PI_275_DATA 0x00020000 +#define DDRSS_PI_276_DATA 0x00000080 +#define DDRSS_PI_277_DATA 0x00020000 +#define DDRSS_PI_278_DATA 0x00000080 +#define DDRSS_PI_279_DATA 0x00000000 +#define DDRSS_PI_280_DATA 0x00000000 +#define DDRSS_PI_281_DATA 0x00040404 +#define DDRSS_PI_282_DATA 0x00000000 +#define DDRSS_PI_283_DATA 0x02010102 +#define DDRSS_PI_284_DATA 0x67676767 +#define DDRSS_PI_285_DATA 0x00000202 +#define DDRSS_PI_286_DATA 0x00000000 +#define DDRSS_PI_287_DATA 0x00000000 +#define DDRSS_PI_288_DATA 0x00000000 +#define DDRSS_PI_289_DATA 0x00000000 +#define DDRSS_PI_290_DATA 0x00000000 +#define DDRSS_PI_291_DATA 0x0D100F00 +#define DDRSS_PI_292_DATA 0x0003020E +#define DDRSS_PI_293_DATA 0x00000001 +#define DDRSS_PI_294_DATA 0x01000000 +#define DDRSS_PI_295_DATA 0x00020201 +#define DDRSS_PI_296_DATA 0x00000000 +#define DDRSS_PI_297_DATA 0x00000424 +#define DDRSS_PI_298_DATA 0x00000301 +#define DDRSS_PI_299_DATA 0x00000000 +#define DDRSS_PI_300_DATA 0x00000000 +#define DDRSS_PI_301_DATA 0x00000000 +#define DDRSS_PI_302_DATA 0x00001401 +#define DDRSS_PI_303_DATA 0x00000493 +#define DDRSS_PI_304_DATA 0x00000000 +#define DDRSS_PI_305_DATA 0x00000424 +#define DDRSS_PI_306_DATA 0x00000301 +#define DDRSS_PI_307_DATA 0x00000000 +#define DDRSS_PI_308_DATA 0x00000000 +#define DDRSS_PI_309_DATA 0x00000000 +#define DDRSS_PI_310_DATA 0x00001401 +#define DDRSS_PI_311_DATA 0x00000493 +#define DDRSS_PI_312_DATA 0x00000000 +#define DDRSS_PI_313_DATA 0x00000424 +#define DDRSS_PI_314_DATA 0x00000301 +#define DDRSS_PI_315_DATA 0x00000000 +#define DDRSS_PI_316_DATA 0x00000000 +#define DDRSS_PI_317_DATA 0x00000000 +#define DDRSS_PI_318_DATA 0x00001401 +#define DDRSS_PI_319_DATA 0x00000493 +#define DDRSS_PI_320_DATA 0x00000000 +#define DDRSS_PI_321_DATA 0x00000424 +#define DDRSS_PI_322_DATA 0x00000301 +#define DDRSS_PI_323_DATA 0x00000000 +#define DDRSS_PI_324_DATA 0x00000000 +#define DDRSS_PI_325_DATA 0x00000000 +#define DDRSS_PI_326_DATA 0x00001401 +#define DDRSS_PI_327_DATA 0x00000493 +#define DDRSS_PI_328_DATA 0x00000000 +#define DDRSS_PI_329_DATA 0x00000424 +#define DDRSS_PI_330_DATA 0x00000301 +#define DDRSS_PI_331_DATA 0x00000000 +#define DDRSS_PI_332_DATA 0x00000000 +#define DDRSS_PI_333_DATA 0x00000000 +#define DDRSS_PI_334_DATA 0x00001401 +#define DDRSS_PI_335_DATA 0x00000493 +#define DDRSS_PI_336_DATA 0x00000000 +#define DDRSS_PI_337_DATA 0x00000424 +#define DDRSS_PI_338_DATA 0x00000301 +#define DDRSS_PI_339_DATA 0x00000000 +#define DDRSS_PI_340_DATA 0x00000000 +#define DDRSS_PI_341_DATA 0x00000000 +#define DDRSS_PI_342_DATA 0x00001401 +#define DDRSS_PI_343_DATA 0x00000493 +#define DDRSS_PI_344_DATA 0x00000000 +#define DDRSS_PHY_0_DATA 0x04C00000 +#define DDRSS_PHY_1_DATA 0x00000000 +#define DDRSS_PHY_2_DATA 0x00000200 +#define DDRSS_PHY_3_DATA 0x00000000 +#define DDRSS_PHY_4_DATA 0x00000000 +#define DDRSS_PHY_5_DATA 0x00000000 +#define DDRSS_PHY_6_DATA 0x00000000 +#define DDRSS_PHY_7_DATA 0x00000000 +#define DDRSS_PHY_8_DATA 0x00000001 +#define DDRSS_PHY_9_DATA 0x00000000 +#define DDRSS_PHY_10_DATA 0x00000000 +#define DDRSS_PHY_11_DATA 0x010101FF +#define DDRSS_PHY_12_DATA 0x00010000 +#define DDRSS_PHY_13_DATA 0x00C00004 +#define DDRSS_PHY_14_DATA 0x00CC0008 +#define DDRSS_PHY_15_DATA 0x00660201 +#define DDRSS_PHY_16_DATA 0x00000000 +#define DDRSS_PHY_17_DATA 0x00000000 +#define DDRSS_PHY_18_DATA 0x00000000 +#define DDRSS_PHY_19_DATA 0x0000AAAA +#define DDRSS_PHY_20_DATA 0x00005555 +#define DDRSS_PHY_21_DATA 0x0000B5B5 +#define DDRSS_PHY_22_DATA 0x00004A4A +#define DDRSS_PHY_23_DATA 0x00005656 +#define DDRSS_PHY_24_DATA 0x0000A9A9 +#define DDRSS_PHY_25_DATA 0x0000B7B7 +#define DDRSS_PHY_26_DATA 0x00004848 +#define DDRSS_PHY_27_DATA 0x00000000 +#define DDRSS_PHY_28_DATA 0x00000000 +#define DDRSS_PHY_29_DATA 0x08000000 +#define DDRSS_PHY_30_DATA 0x0F000008 +#define DDRSS_PHY_31_DATA 0x00000F0F +#define DDRSS_PHY_32_DATA 0x00E4E400 +#define DDRSS_PHY_33_DATA 0x00070820 +#define DDRSS_PHY_34_DATA 0x000C0020 +#define DDRSS_PHY_35_DATA 0x00062000 +#define DDRSS_PHY_36_DATA 0x00000000 +#define DDRSS_PHY_37_DATA 0x55555555 +#define DDRSS_PHY_38_DATA 0xAAAAAAAA +#define DDRSS_PHY_39_DATA 0x55555555 +#define DDRSS_PHY_40_DATA 0xAAAAAAAA +#define DDRSS_PHY_41_DATA 0x00005555 +#define DDRSS_PHY_42_DATA 0x01000100 +#define DDRSS_PHY_43_DATA 0x00800180 +#define DDRSS_PHY_44_DATA 0x00000000 +#define DDRSS_PHY_45_DATA 0x00000000 +#define DDRSS_PHY_46_DATA 0x00000000 +#define DDRSS_PHY_47_DATA 0x00000000 +#define DDRSS_PHY_48_DATA 0x00000000 +#define DDRSS_PHY_49_DATA 0x00000000 +#define DDRSS_PHY_50_DATA 0x00000000 +#define DDRSS_PHY_51_DATA 0x00000000 +#define DDRSS_PHY_52_DATA 0x00000000 +#define DDRSS_PHY_53_DATA 0x00000000 +#define DDRSS_PHY_54_DATA 0x00000000 +#define DDRSS_PHY_55_DATA 0x00000000 +#define DDRSS_PHY_56_DATA 0x00000000 +#define DDRSS_PHY_57_DATA 0x00000000 +#define DDRSS_PHY_58_DATA 0x00000000 +#define DDRSS_PHY_59_DATA 0x00000000 +#define DDRSS_PHY_60_DATA 0x00000000 +#define DDRSS_PHY_61_DATA 0x00000000 +#define DDRSS_PHY_62_DATA 0x00000000 +#define DDRSS_PHY_63_DATA 0x00000000 +#define DDRSS_PHY_64_DATA 0x00000000 +#define DDRSS_PHY_65_DATA 0x00000004 +#define DDRSS_PHY_66_DATA 0x00000000 +#define DDRSS_PHY_67_DATA 0x00000000 +#define DDRSS_PHY_68_DATA 0x00000000 +#define DDRSS_PHY_69_DATA 0x00000000 +#define DDRSS_PHY_70_DATA 0x00000000 +#define DDRSS_PHY_71_DATA 0x00000000 +#define DDRSS_PHY_72_DATA 0x041F07FF +#define DDRSS_PHY_73_DATA 0x00000000 +#define DDRSS_PHY_74_DATA 0x01CCB001 +#define DDRSS_PHY_75_DATA 0x2000CCB0 +#define DDRSS_PHY_76_DATA 0x20000140 +#define DDRSS_PHY_77_DATA 0x07FF0200 +#define DDRSS_PHY_78_DATA 0x0000DD01 +#define DDRSS_PHY_79_DATA 0x10100303 +#define DDRSS_PHY_80_DATA 0x10101010 +#define DDRSS_PHY_81_DATA 0x10101010 +#define DDRSS_PHY_82_DATA 0x00021010 +#define DDRSS_PHY_83_DATA 0x00100010 +#define DDRSS_PHY_84_DATA 0x00100010 +#define DDRSS_PHY_85_DATA 0x00100010 +#define DDRSS_PHY_86_DATA 0x00100010 +#define DDRSS_PHY_87_DATA 0x02020010 +#define DDRSS_PHY_88_DATA 0x51515041 +#define DDRSS_PHY_89_DATA 0x31804000 +#define DDRSS_PHY_90_DATA 0x04BF0340 +#define DDRSS_PHY_91_DATA 0x01008080 +#define DDRSS_PHY_92_DATA 0x04050001 +#define DDRSS_PHY_93_DATA 0x00000504 +#define DDRSS_PHY_94_DATA 0x42100010 +#define DDRSS_PHY_95_DATA 0x010C053E +#define DDRSS_PHY_96_DATA 0x000F0C14 +#define DDRSS_PHY_97_DATA 0x01000140 +#define DDRSS_PHY_98_DATA 0x007A0120 +#define DDRSS_PHY_99_DATA 0x00000C00 +#define DDRSS_PHY_100_DATA 0x000001CC +#define DDRSS_PHY_101_DATA 0x20100200 +#define DDRSS_PHY_102_DATA 0x00000005 +#define DDRSS_PHY_103_DATA 0x76543210 +#define DDRSS_PHY_104_DATA 0x00000008 +#define DDRSS_PHY_105_DATA 0x02800280 +#define DDRSS_PHY_106_DATA 0x02800280 +#define DDRSS_PHY_107_DATA 0x02800280 +#define DDRSS_PHY_108_DATA 0x02800280 +#define DDRSS_PHY_109_DATA 0x00000280 +#define DDRSS_PHY_110_DATA 0x00008000 +#define DDRSS_PHY_111_DATA 0x00800080 +#define DDRSS_PHY_112_DATA 0x00800080 +#define DDRSS_PHY_113_DATA 0x00800080 +#define DDRSS_PHY_114_DATA 0x00800080 +#define DDRSS_PHY_115_DATA 0x00800080 +#define DDRSS_PHY_116_DATA 0x00800080 +#define DDRSS_PHY_117_DATA 0x00800080 +#define DDRSS_PHY_118_DATA 0x00800080 +#define DDRSS_PHY_119_DATA 0x01000080 +#define DDRSS_PHY_120_DATA 0x01000000 +#define DDRSS_PHY_121_DATA 0x00000000 +#define DDRSS_PHY_122_DATA 0x00000000 +#define DDRSS_PHY_123_DATA 0x00080200 +#define DDRSS_PHY_124_DATA 0x00000000 +#define DDRSS_PHY_125_DATA 0x00000000 +#define DDRSS_PHY_126_DATA 0x00000000 +#define DDRSS_PHY_127_DATA 0x00000000 +#define DDRSS_PHY_128_DATA 0x00000000 +#define DDRSS_PHY_129_DATA 0x00000000 +#define DDRSS_PHY_130_DATA 0x00000000 +#define DDRSS_PHY_131_DATA 0x00000000 +#define DDRSS_PHY_132_DATA 0x00000000 +#define DDRSS_PHY_133_DATA 0x00000000 +#define DDRSS_PHY_134_DATA 0x00000000 +#define DDRSS_PHY_135_DATA 0x00000000 +#define DDRSS_PHY_136_DATA 0x00000000 +#define DDRSS_PHY_137_DATA 0x00000000 +#define DDRSS_PHY_138_DATA 0x00000000 +#define DDRSS_PHY_139_DATA 0x00000000 +#define DDRSS_PHY_140_DATA 0x00000000 +#define DDRSS_PHY_141_DATA 0x00000000 +#define DDRSS_PHY_142_DATA 0x00000000 +#define DDRSS_PHY_143_DATA 0x00000000 +#define DDRSS_PHY_144_DATA 0x00000000 +#define DDRSS_PHY_145_DATA 0x00000000 +#define DDRSS_PHY_146_DATA 0x00000000 +#define DDRSS_PHY_147_DATA 0x00000000 +#define DDRSS_PHY_148_DATA 0x00000000 +#define DDRSS_PHY_149_DATA 0x00000000 +#define DDRSS_PHY_150_DATA 0x00000000 +#define DDRSS_PHY_151_DATA 0x00000000 +#define DDRSS_PHY_152_DATA 0x00000000 +#define DDRSS_PHY_153_DATA 0x00000000 +#define DDRSS_PHY_154_DATA 0x00000000 +#define DDRSS_PHY_155_DATA 0x00000000 +#define DDRSS_PHY_156_DATA 0x00000000 +#define DDRSS_PHY_157_DATA 0x00000000 +#define DDRSS_PHY_158_DATA 0x00000000 +#define DDRSS_PHY_159_DATA 0x00000000 +#define DDRSS_PHY_160_DATA 0x00000000 +#define DDRSS_PHY_161_DATA 0x00000000 +#define DDRSS_PHY_162_DATA 0x00000000 +#define DDRSS_PHY_163_DATA 0x00000000 +#define DDRSS_PHY_164_DATA 0x00000000 +#define DDRSS_PHY_165_DATA 0x00000000 +#define DDRSS_PHY_166_DATA 0x00000000 +#define DDRSS_PHY_167_DATA 0x00000000 +#define DDRSS_PHY_168_DATA 0x00000000 +#define DDRSS_PHY_169_DATA 0x00000000 +#define DDRSS_PHY_170_DATA 0x00000000 +#define DDRSS_PHY_171_DATA 0x00000000 +#define DDRSS_PHY_172_DATA 0x00000000 +#define DDRSS_PHY_173_DATA 0x00000000 +#define DDRSS_PHY_174_DATA 0x00000000 +#define DDRSS_PHY_175_DATA 0x00000000 +#define DDRSS_PHY_176_DATA 0x00000000 +#define DDRSS_PHY_177_DATA 0x00000000 +#define DDRSS_PHY_178_DATA 0x00000000 +#define DDRSS_PHY_179_DATA 0x00000000 +#define DDRSS_PHY_180_DATA 0x00000000 +#define DDRSS_PHY_181_DATA 0x00000000 +#define DDRSS_PHY_182_DATA 0x00000000 +#define DDRSS_PHY_183_DATA 0x00000000 +#define DDRSS_PHY_184_DATA 0x00000000 +#define DDRSS_PHY_185_DATA 0x00000000 +#define DDRSS_PHY_186_DATA 0x00000000 +#define DDRSS_PHY_187_DATA 0x00000000 +#define DDRSS_PHY_188_DATA 0x00000000 +#define DDRSS_PHY_189_DATA 0x00000000 +#define DDRSS_PHY_190_DATA 0x00000000 +#define DDRSS_PHY_191_DATA 0x00000000 +#define DDRSS_PHY_192_DATA 0x00000000 +#define DDRSS_PHY_193_DATA 0x00000000 +#define DDRSS_PHY_194_DATA 0x00000000 +#define DDRSS_PHY_195_DATA 0x00000000 +#define DDRSS_PHY_196_DATA 0x00000000 +#define DDRSS_PHY_197_DATA 0x00000000 +#define DDRSS_PHY_198_DATA 0x00000000 +#define DDRSS_PHY_199_DATA 0x00000000 +#define DDRSS_PHY_200_DATA 0x00000000 +#define DDRSS_PHY_201_DATA 0x00000000 +#define DDRSS_PHY_202_DATA 0x00000000 +#define DDRSS_PHY_203_DATA 0x00000000 +#define DDRSS_PHY_204_DATA 0x00000000 +#define DDRSS_PHY_205_DATA 0x00000000 +#define DDRSS_PHY_206_DATA 0x00000000 +#define DDRSS_PHY_207_DATA 0x00000000 +#define DDRSS_PHY_208_DATA 0x00000000 +#define DDRSS_PHY_209_DATA 0x00000000 +#define DDRSS_PHY_210_DATA 0x00000000 +#define DDRSS_PHY_211_DATA 0x00000000 +#define DDRSS_PHY_212_DATA 0x00000000 +#define DDRSS_PHY_213_DATA 0x00000000 +#define DDRSS_PHY_214_DATA 0x00000000 +#define DDRSS_PHY_215_DATA 0x00000000 +#define DDRSS_PHY_216_DATA 0x00000000 +#define DDRSS_PHY_217_DATA 0x00000000 +#define DDRSS_PHY_218_DATA 0x00000000 +#define DDRSS_PHY_219_DATA 0x00000000 +#define DDRSS_PHY_220_DATA 0x00000000 +#define DDRSS_PHY_221_DATA 0x00000000 +#define DDRSS_PHY_222_DATA 0x00000000 +#define DDRSS_PHY_223_DATA 0x00000000 +#define DDRSS_PHY_224_DATA 0x00000000 +#define DDRSS_PHY_225_DATA 0x00000000 +#define DDRSS_PHY_226_DATA 0x00000000 +#define DDRSS_PHY_227_DATA 0x00000000 +#define DDRSS_PHY_228_DATA 0x00000000 +#define DDRSS_PHY_229_DATA 0x00000000 +#define DDRSS_PHY_230_DATA 0x00000000 +#define DDRSS_PHY_231_DATA 0x00000000 +#define DDRSS_PHY_232_DATA 0x00000000 +#define DDRSS_PHY_233_DATA 0x00000000 +#define DDRSS_PHY_234_DATA 0x00000000 +#define DDRSS_PHY_235_DATA 0x00000000 +#define DDRSS_PHY_236_DATA 0x00000000 +#define DDRSS_PHY_237_DATA 0x00000000 +#define DDRSS_PHY_238_DATA 0x00000000 +#define DDRSS_PHY_239_DATA 0x00000000 +#define DDRSS_PHY_240_DATA 0x00000000 +#define DDRSS_PHY_241_DATA 0x00000000 +#define DDRSS_PHY_242_DATA 0x00000000 +#define DDRSS_PHY_243_DATA 0x00000000 +#define DDRSS_PHY_244_DATA 0x00000000 +#define DDRSS_PHY_245_DATA 0x00000000 +#define DDRSS_PHY_246_DATA 0x00000000 +#define DDRSS_PHY_247_DATA 0x00000000 +#define DDRSS_PHY_248_DATA 0x00000000 +#define DDRSS_PHY_249_DATA 0x00000000 +#define DDRSS_PHY_250_DATA 0x00000000 +#define DDRSS_PHY_251_DATA 0x00000000 +#define DDRSS_PHY_252_DATA 0x00000000 +#define DDRSS_PHY_253_DATA 0x00000000 +#define DDRSS_PHY_254_DATA 0x00000000 +#define DDRSS_PHY_255_DATA 0x00000000 +#define DDRSS_PHY_256_DATA 0x04C00000 +#define DDRSS_PHY_257_DATA 0x00000000 +#define DDRSS_PHY_258_DATA 0x00000200 +#define DDRSS_PHY_259_DATA 0x00000000 +#define DDRSS_PHY_260_DATA 0x00000000 +#define DDRSS_PHY_261_DATA 0x00000000 +#define DDRSS_PHY_262_DATA 0x00000000 +#define DDRSS_PHY_263_DATA 0x00000000 +#define DDRSS_PHY_264_DATA 0x00000001 +#define DDRSS_PHY_265_DATA 0x00000000 +#define DDRSS_PHY_266_DATA 0x00000000 +#define DDRSS_PHY_267_DATA 0x010101FF +#define DDRSS_PHY_268_DATA 0x00010000 +#define DDRSS_PHY_269_DATA 0x00C00004 +#define DDRSS_PHY_270_DATA 0x00CC0008 +#define DDRSS_PHY_271_DATA 0x00660201 +#define DDRSS_PHY_272_DATA 0x00000000 +#define DDRSS_PHY_273_DATA 0x00000000 +#define DDRSS_PHY_274_DATA 0x00000000 +#define DDRSS_PHY_275_DATA 0x0000AAAA +#define DDRSS_PHY_276_DATA 0x00005555 +#define DDRSS_PHY_277_DATA 0x0000B5B5 +#define DDRSS_PHY_278_DATA 0x00004A4A +#define DDRSS_PHY_279_DATA 0x00005656 +#define DDRSS_PHY_280_DATA 0x0000A9A9 +#define DDRSS_PHY_281_DATA 0x0000B7B7 +#define DDRSS_PHY_282_DATA 0x00004848 +#define DDRSS_PHY_283_DATA 0x00000000 +#define DDRSS_PHY_284_DATA 0x00000000 +#define DDRSS_PHY_285_DATA 0x08000000 +#define DDRSS_PHY_286_DATA 0x0F000008 +#define DDRSS_PHY_287_DATA 0x00000F0F +#define DDRSS_PHY_288_DATA 0x00E4E400 +#define DDRSS_PHY_289_DATA 0x00070820 +#define DDRSS_PHY_290_DATA 0x000C0020 +#define DDRSS_PHY_291_DATA 0x00062000 +#define DDRSS_PHY_292_DATA 0x00000000 +#define DDRSS_PHY_293_DATA 0x55555555 +#define DDRSS_PHY_294_DATA 0xAAAAAAAA +#define DDRSS_PHY_295_DATA 0x55555555 +#define DDRSS_PHY_296_DATA 0xAAAAAAAA +#define DDRSS_PHY_297_DATA 0x00005555 +#define DDRSS_PHY_298_DATA 0x01000100 +#define DDRSS_PHY_299_DATA 0x00800180 +#define DDRSS_PHY_300_DATA 0x00000000 +#define DDRSS_PHY_301_DATA 0x00000000 +#define DDRSS_PHY_302_DATA 0x00000000 +#define DDRSS_PHY_303_DATA 0x00000000 +#define DDRSS_PHY_304_DATA 0x00000000 +#define DDRSS_PHY_305_DATA 0x00000000 +#define DDRSS_PHY_306_DATA 0x00000000 +#define DDRSS_PHY_307_DATA 0x00000000 +#define DDRSS_PHY_308_DATA 0x00000000 +#define DDRSS_PHY_309_DATA 0x00000000 +#define DDRSS_PHY_310_DATA 0x00000000 +#define DDRSS_PHY_311_DATA 0x00000000 +#define DDRSS_PHY_312_DATA 0x00000000 +#define DDRSS_PHY_313_DATA 0x00000000 +#define DDRSS_PHY_314_DATA 0x00000000 +#define DDRSS_PHY_315_DATA 0x00000000 +#define DDRSS_PHY_316_DATA 0x00000000 +#define DDRSS_PHY_317_DATA 0x00000000 +#define DDRSS_PHY_318_DATA 0x00000000 +#define DDRSS_PHY_319_DATA 0x00000000 +#define DDRSS_PHY_320_DATA 0x00000000 +#define DDRSS_PHY_321_DATA 0x00000004 +#define DDRSS_PHY_322_DATA 0x00000000 +#define DDRSS_PHY_323_DATA 0x00000000 +#define DDRSS_PHY_324_DATA 0x00000000 +#define DDRSS_PHY_325_DATA 0x00000000 +#define DDRSS_PHY_326_DATA 0x00000000 +#define DDRSS_PHY_327_DATA 0x00000000 +#define DDRSS_PHY_328_DATA 0x041F07FF +#define DDRSS_PHY_329_DATA 0x00000000 +#define DDRSS_PHY_330_DATA 0x01CCB001 +#define DDRSS_PHY_331_DATA 0x2000CCB0 +#define DDRSS_PHY_332_DATA 0x20000140 +#define DDRSS_PHY_333_DATA 0x07FF0200 +#define DDRSS_PHY_334_DATA 0x0000DD01 +#define DDRSS_PHY_335_DATA 0x10100303 +#define DDRSS_PHY_336_DATA 0x10101010 +#define DDRSS_PHY_337_DATA 0x10101010 +#define DDRSS_PHY_338_DATA 0x00021010 +#define DDRSS_PHY_339_DATA 0x00100010 +#define DDRSS_PHY_340_DATA 0x00100010 +#define DDRSS_PHY_341_DATA 0x00100010 +#define DDRSS_PHY_342_DATA 0x00100010 +#define DDRSS_PHY_343_DATA 0x02020010 +#define DDRSS_PHY_344_DATA 0x51515041 +#define DDRSS_PHY_345_DATA 0x31804000 +#define DDRSS_PHY_346_DATA 0x04BF0340 +#define DDRSS_PHY_347_DATA 0x01008080 +#define DDRSS_PHY_348_DATA 0x04050001 +#define DDRSS_PHY_349_DATA 0x00000504 +#define DDRSS_PHY_350_DATA 0x42100010 +#define DDRSS_PHY_351_DATA 0x010C053E +#define DDRSS_PHY_352_DATA 0x000F0C14 +#define DDRSS_PHY_353_DATA 0x01000140 +#define DDRSS_PHY_354_DATA 0x007A0120 +#define DDRSS_PHY_355_DATA 0x00000C00 +#define DDRSS_PHY_356_DATA 0x000001CC +#define DDRSS_PHY_357_DATA 0x20100200 +#define DDRSS_PHY_358_DATA 0x00000005 +#define DDRSS_PHY_359_DATA 0x76543210 +#define DDRSS_PHY_360_DATA 0x00000008 +#define DDRSS_PHY_361_DATA 0x02800280 +#define DDRSS_PHY_362_DATA 0x02800280 +#define DDRSS_PHY_363_DATA 0x02800280 +#define DDRSS_PHY_364_DATA 0x02800280 +#define DDRSS_PHY_365_DATA 0x00000280 +#define DDRSS_PHY_366_DATA 0x00008000 +#define DDRSS_PHY_367_DATA 0x00800080 +#define DDRSS_PHY_368_DATA 0x00800080 +#define DDRSS_PHY_369_DATA 0x00800080 +#define DDRSS_PHY_370_DATA 0x00800080 +#define DDRSS_PHY_371_DATA 0x00800080 +#define DDRSS_PHY_372_DATA 0x00800080 +#define DDRSS_PHY_373_DATA 0x00800080 +#define DDRSS_PHY_374_DATA 0x00800080 +#define DDRSS_PHY_375_DATA 0x01000080 +#define DDRSS_PHY_376_DATA 0x01000000 +#define DDRSS_PHY_377_DATA 0x00000000 +#define DDRSS_PHY_378_DATA 0x00000000 +#define DDRSS_PHY_379_DATA 0x00080200 +#define DDRSS_PHY_380_DATA 0x00000000 +#define DDRSS_PHY_381_DATA 0x00000000 +#define DDRSS_PHY_382_DATA 0x00000000 +#define DDRSS_PHY_383_DATA 0x00000000 +#define DDRSS_PHY_384_DATA 0x00000000 +#define DDRSS_PHY_385_DATA 0x00000000 +#define DDRSS_PHY_386_DATA 0x00000000 +#define DDRSS_PHY_387_DATA 0x00000000 +#define DDRSS_PHY_388_DATA 0x00000000 +#define DDRSS_PHY_389_DATA 0x00000000 +#define DDRSS_PHY_390_DATA 0x00000000 +#define DDRSS_PHY_391_DATA 0x00000000 +#define DDRSS_PHY_392_DATA 0x00000000 +#define DDRSS_PHY_393_DATA 0x00000000 +#define DDRSS_PHY_394_DATA 0x00000000 +#define DDRSS_PHY_395_DATA 0x00000000 +#define DDRSS_PHY_396_DATA 0x00000000 +#define DDRSS_PHY_397_DATA 0x00000000 +#define DDRSS_PHY_398_DATA 0x00000000 +#define DDRSS_PHY_399_DATA 0x00000000 +#define DDRSS_PHY_400_DATA 0x00000000 +#define DDRSS_PHY_401_DATA 0x00000000 +#define DDRSS_PHY_402_DATA 0x00000000 +#define DDRSS_PHY_403_DATA 0x00000000 +#define DDRSS_PHY_404_DATA 0x00000000 +#define DDRSS_PHY_405_DATA 0x00000000 +#define DDRSS_PHY_406_DATA 0x00000000 +#define DDRSS_PHY_407_DATA 0x00000000 +#define DDRSS_PHY_408_DATA 0x00000000 +#define DDRSS_PHY_409_DATA 0x00000000 +#define DDRSS_PHY_410_DATA 0x00000000 +#define DDRSS_PHY_411_DATA 0x00000000 +#define DDRSS_PHY_412_DATA 0x00000000 +#define DDRSS_PHY_413_DATA 0x00000000 +#define DDRSS_PHY_414_DATA 0x00000000 +#define DDRSS_PHY_415_DATA 0x00000000 +#define DDRSS_PHY_416_DATA 0x00000000 +#define DDRSS_PHY_417_DATA 0x00000000 +#define DDRSS_PHY_418_DATA 0x00000000 +#define DDRSS_PHY_419_DATA 0x00000000 +#define DDRSS_PHY_420_DATA 0x00000000 +#define DDRSS_PHY_421_DATA 0x00000000 +#define DDRSS_PHY_422_DATA 0x00000000 +#define DDRSS_PHY_423_DATA 0x00000000 +#define DDRSS_PHY_424_DATA 0x00000000 +#define DDRSS_PHY_425_DATA 0x00000000 +#define DDRSS_PHY_426_DATA 0x00000000 +#define DDRSS_PHY_427_DATA 0x00000000 +#define DDRSS_PHY_428_DATA 0x00000000 +#define DDRSS_PHY_429_DATA 0x00000000 +#define DDRSS_PHY_430_DATA 0x00000000 +#define DDRSS_PHY_431_DATA 0x00000000 +#define DDRSS_PHY_432_DATA 0x00000000 +#define DDRSS_PHY_433_DATA 0x00000000 +#define DDRSS_PHY_434_DATA 0x00000000 +#define DDRSS_PHY_435_DATA 0x00000000 +#define DDRSS_PHY_436_DATA 0x00000000 +#define DDRSS_PHY_437_DATA 0x00000000 +#define DDRSS_PHY_438_DATA 0x00000000 +#define DDRSS_PHY_439_DATA 0x00000000 +#define DDRSS_PHY_440_DATA 0x00000000 +#define DDRSS_PHY_441_DATA 0x00000000 +#define DDRSS_PHY_442_DATA 0x00000000 +#define DDRSS_PHY_443_DATA 0x00000000 +#define DDRSS_PHY_444_DATA 0x00000000 +#define DDRSS_PHY_445_DATA 0x00000000 +#define DDRSS_PHY_446_DATA 0x00000000 +#define DDRSS_PHY_447_DATA 0x00000000 +#define DDRSS_PHY_448_DATA 0x00000000 +#define DDRSS_PHY_449_DATA 0x00000000 +#define DDRSS_PHY_450_DATA 0x00000000 +#define DDRSS_PHY_451_DATA 0x00000000 +#define DDRSS_PHY_452_DATA 0x00000000 +#define DDRSS_PHY_453_DATA 0x00000000 +#define DDRSS_PHY_454_DATA 0x00000000 +#define DDRSS_PHY_455_DATA 0x00000000 +#define DDRSS_PHY_456_DATA 0x00000000 +#define DDRSS_PHY_457_DATA 0x00000000 +#define DDRSS_PHY_458_DATA 0x00000000 +#define DDRSS_PHY_459_DATA 0x00000000 +#define DDRSS_PHY_460_DATA 0x00000000 +#define DDRSS_PHY_461_DATA 0x00000000 +#define DDRSS_PHY_462_DATA 0x00000000 +#define DDRSS_PHY_463_DATA 0x00000000 +#define DDRSS_PHY_464_DATA 0x00000000 +#define DDRSS_PHY_465_DATA 0x00000000 +#define DDRSS_PHY_466_DATA 0x00000000 +#define DDRSS_PHY_467_DATA 0x00000000 +#define DDRSS_PHY_468_DATA 0x00000000 +#define DDRSS_PHY_469_DATA 0x00000000 +#define DDRSS_PHY_470_DATA 0x00000000 +#define DDRSS_PHY_471_DATA 0x00000000 +#define DDRSS_PHY_472_DATA 0x00000000 +#define DDRSS_PHY_473_DATA 0x00000000 +#define DDRSS_PHY_474_DATA 0x00000000 +#define DDRSS_PHY_475_DATA 0x00000000 +#define DDRSS_PHY_476_DATA 0x00000000 +#define DDRSS_PHY_477_DATA 0x00000000 +#define DDRSS_PHY_478_DATA 0x00000000 +#define DDRSS_PHY_479_DATA 0x00000000 +#define DDRSS_PHY_480_DATA 0x00000000 +#define DDRSS_PHY_481_DATA 0x00000000 +#define DDRSS_PHY_482_DATA 0x00000000 +#define DDRSS_PHY_483_DATA 0x00000000 +#define DDRSS_PHY_484_DATA 0x00000000 +#define DDRSS_PHY_485_DATA 0x00000000 +#define DDRSS_PHY_486_DATA 0x00000000 +#define DDRSS_PHY_487_DATA 0x00000000 +#define DDRSS_PHY_488_DATA 0x00000000 +#define DDRSS_PHY_489_DATA 0x00000000 +#define DDRSS_PHY_490_DATA 0x00000000 +#define DDRSS_PHY_491_DATA 0x00000000 +#define DDRSS_PHY_492_DATA 0x00000000 +#define DDRSS_PHY_493_DATA 0x00000000 +#define DDRSS_PHY_494_DATA 0x00000000 +#define DDRSS_PHY_495_DATA 0x00000000 +#define DDRSS_PHY_496_DATA 0x00000000 +#define DDRSS_PHY_497_DATA 0x00000000 +#define DDRSS_PHY_498_DATA 0x00000000 +#define DDRSS_PHY_499_DATA 0x00000000 +#define DDRSS_PHY_500_DATA 0x00000000 +#define DDRSS_PHY_501_DATA 0x00000000 +#define DDRSS_PHY_502_DATA 0x00000000 +#define DDRSS_PHY_503_DATA 0x00000000 +#define DDRSS_PHY_504_DATA 0x00000000 +#define DDRSS_PHY_505_DATA 0x00000000 +#define DDRSS_PHY_506_DATA 0x00000000 +#define DDRSS_PHY_507_DATA 0x00000000 +#define DDRSS_PHY_508_DATA 0x00000000 +#define DDRSS_PHY_509_DATA 0x00000000 +#define DDRSS_PHY_510_DATA 0x00000000 +#define DDRSS_PHY_511_DATA 0x00000000 +#define DDRSS_PHY_512_DATA 0x00000100 +#define DDRSS_PHY_513_DATA 0x00000000 +#define DDRSS_PHY_514_DATA 0x00000000 +#define DDRSS_PHY_515_DATA 0x00000000 +#define DDRSS_PHY_516_DATA 0x00000000 +#define DDRSS_PHY_517_DATA 0x00000100 +#define DDRSS_PHY_518_DATA 0x00000000 +#define DDRSS_PHY_519_DATA 0x00000000 +#define DDRSS_PHY_520_DATA 0x00000000 +#define DDRSS_PHY_521_DATA 0x00000000 +#define DDRSS_PHY_522_DATA 0x00000000 +#define DDRSS_PHY_523_DATA 0x00000000 +#define DDRSS_PHY_524_DATA 0x00000000 +#define DDRSS_PHY_525_DATA 0x00DCBA98 +#define DDRSS_PHY_526_DATA 0x00000000 +#define DDRSS_PHY_527_DATA 0x00000000 +#define DDRSS_PHY_528_DATA 0x00000000 +#define DDRSS_PHY_529_DATA 0x00000000 +#define DDRSS_PHY_530_DATA 0x00000000 +#define DDRSS_PHY_531_DATA 0x00000000 +#define DDRSS_PHY_532_DATA 0x00000000 +#define DDRSS_PHY_533_DATA 0x00000000 +#define DDRSS_PHY_534_DATA 0x00000000 +#define DDRSS_PHY_535_DATA 0x00000000 +#define DDRSS_PHY_536_DATA 0x00000000 +#define DDRSS_PHY_537_DATA 0x00000000 +#define DDRSS_PHY_538_DATA 0x00000000 +#define DDRSS_PHY_539_DATA 0x00000000 +#define DDRSS_PHY_540_DATA 0x0A418820 +#define DDRSS_PHY_541_DATA 0x103F0000 +#define DDRSS_PHY_542_DATA 0x000F0100 +#define DDRSS_PHY_543_DATA 0x0000000F +#define DDRSS_PHY_544_DATA 0x020002CC +#define DDRSS_PHY_545_DATA 0x00030000 +#define DDRSS_PHY_546_DATA 0x00000300 +#define DDRSS_PHY_547_DATA 0x00000300 +#define DDRSS_PHY_548_DATA 0x00000300 +#define DDRSS_PHY_549_DATA 0x00000300 +#define DDRSS_PHY_550_DATA 0x00000300 +#define DDRSS_PHY_551_DATA 0x42080010 +#define DDRSS_PHY_552_DATA 0x0000003E +#define DDRSS_PHY_553_DATA 0x00000000 +#define DDRSS_PHY_554_DATA 0x00000000 +#define DDRSS_PHY_555_DATA 0x00000000 +#define DDRSS_PHY_556_DATA 0x00000000 +#define DDRSS_PHY_557_DATA 0x00000000 +#define DDRSS_PHY_558_DATA 0x00000000 +#define DDRSS_PHY_559_DATA 0x00000000 +#define DDRSS_PHY_560_DATA 0x00000000 +#define DDRSS_PHY_561_DATA 0x00000000 +#define DDRSS_PHY_562_DATA 0x00000000 +#define DDRSS_PHY_563_DATA 0x00000000 +#define DDRSS_PHY_564_DATA 0x00000000 +#define DDRSS_PHY_565_DATA 0x00000000 +#define DDRSS_PHY_566_DATA 0x00000000 +#define DDRSS_PHY_567_DATA 0x00000000 +#define DDRSS_PHY_568_DATA 0x00000000 +#define DDRSS_PHY_569_DATA 0x00000000 +#define DDRSS_PHY_570_DATA 0x00000000 +#define DDRSS_PHY_571_DATA 0x00000000 +#define DDRSS_PHY_572_DATA 0x00000000 +#define DDRSS_PHY_573_DATA 0x00000000 +#define DDRSS_PHY_574_DATA 0x00000000 +#define DDRSS_PHY_575_DATA 0x00000000 +#define DDRSS_PHY_576_DATA 0x00000000 +#define DDRSS_PHY_577_DATA 0x00000000 +#define DDRSS_PHY_578_DATA 0x00000000 +#define DDRSS_PHY_579_DATA 0x00000000 +#define DDRSS_PHY_580_DATA 0x00000000 +#define DDRSS_PHY_581_DATA 0x00000000 +#define DDRSS_PHY_582_DATA 0x00000000 +#define DDRSS_PHY_583_DATA 0x00000000 +#define DDRSS_PHY_584_DATA 0x00000000 +#define DDRSS_PHY_585_DATA 0x00000000 +#define DDRSS_PHY_586_DATA 0x00000000 +#define DDRSS_PHY_587_DATA 0x00000000 +#define DDRSS_PHY_588_DATA 0x00000000 +#define DDRSS_PHY_589_DATA 0x00000000 +#define DDRSS_PHY_590_DATA 0x00000000 +#define DDRSS_PHY_591_DATA 0x00000000 +#define DDRSS_PHY_592_DATA 0x00000000 +#define DDRSS_PHY_593_DATA 0x00000000 +#define DDRSS_PHY_594_DATA 0x00000000 +#define DDRSS_PHY_595_DATA 0x00000000 +#define DDRSS_PHY_596_DATA 0x00000000 +#define DDRSS_PHY_597_DATA 0x00000000 +#define DDRSS_PHY_598_DATA 0x00000000 +#define DDRSS_PHY_599_DATA 0x00000000 +#define DDRSS_PHY_600_DATA 0x00000000 +#define DDRSS_PHY_601_DATA 0x00000000 +#define DDRSS_PHY_602_DATA 0x00000000 +#define DDRSS_PHY_603_DATA 0x00000000 +#define DDRSS_PHY_604_DATA 0x00000000 +#define DDRSS_PHY_605_DATA 0x00000000 +#define DDRSS_PHY_606_DATA 0x00000000 +#define DDRSS_PHY_607_DATA 0x00000000 +#define DDRSS_PHY_608_DATA 0x00000000 +#define DDRSS_PHY_609_DATA 0x00000000 +#define DDRSS_PHY_610_DATA 0x00000000 +#define DDRSS_PHY_611_DATA 0x00000000 +#define DDRSS_PHY_612_DATA 0x00000000 +#define DDRSS_PHY_613_DATA 0x00000000 +#define DDRSS_PHY_614_DATA 0x00000000 +#define DDRSS_PHY_615_DATA 0x00000000 +#define DDRSS_PHY_616_DATA 0x00000000 +#define DDRSS_PHY_617_DATA 0x00000000 +#define DDRSS_PHY_618_DATA 0x00000000 +#define DDRSS_PHY_619_DATA 0x00000000 +#define DDRSS_PHY_620_DATA 0x00000000 +#define DDRSS_PHY_621_DATA 0x00000000 +#define DDRSS_PHY_622_DATA 0x00000000 +#define DDRSS_PHY_623_DATA 0x00000000 +#define DDRSS_PHY_624_DATA 0x00000000 +#define DDRSS_PHY_625_DATA 0x00000000 +#define DDRSS_PHY_626_DATA 0x00000000 +#define DDRSS_PHY_627_DATA 0x00000000 +#define DDRSS_PHY_628_DATA 0x00000000 +#define DDRSS_PHY_629_DATA 0x00000000 +#define DDRSS_PHY_630_DATA 0x00000000 +#define DDRSS_PHY_631_DATA 0x00000000 +#define DDRSS_PHY_632_DATA 0x00000000 +#define DDRSS_PHY_633_DATA 0x00000000 +#define DDRSS_PHY_634_DATA 0x00000000 +#define DDRSS_PHY_635_DATA 0x00000000 +#define DDRSS_PHY_636_DATA 0x00000000 +#define DDRSS_PHY_637_DATA 0x00000000 +#define DDRSS_PHY_638_DATA 0x00000000 +#define DDRSS_PHY_639_DATA 0x00000000 +#define DDRSS_PHY_640_DATA 0x00000000 +#define DDRSS_PHY_641_DATA 0x00000000 +#define DDRSS_PHY_642_DATA 0x00000000 +#define DDRSS_PHY_643_DATA 0x00000000 +#define DDRSS_PHY_644_DATA 0x00000000 +#define DDRSS_PHY_645_DATA 0x00000000 +#define DDRSS_PHY_646_DATA 0x00000000 +#define DDRSS_PHY_647_DATA 0x00000000 +#define DDRSS_PHY_648_DATA 0x00000000 +#define DDRSS_PHY_649_DATA 0x00000000 +#define DDRSS_PHY_650_DATA 0x00000000 +#define DDRSS_PHY_651_DATA 0x00000000 +#define DDRSS_PHY_652_DATA 0x00000000 +#define DDRSS_PHY_653_DATA 0x00000000 +#define DDRSS_PHY_654_DATA 0x00000000 +#define DDRSS_PHY_655_DATA 0x00000000 +#define DDRSS_PHY_656_DATA 0x00000000 +#define DDRSS_PHY_657_DATA 0x00000000 +#define DDRSS_PHY_658_DATA 0x00000000 +#define DDRSS_PHY_659_DATA 0x00000000 +#define DDRSS_PHY_660_DATA 0x00000000 +#define DDRSS_PHY_661_DATA 0x00000000 +#define DDRSS_PHY_662_DATA 0x00000000 +#define DDRSS_PHY_663_DATA 0x00000000 +#define DDRSS_PHY_664_DATA 0x00000000 +#define DDRSS_PHY_665_DATA 0x00000000 +#define DDRSS_PHY_666_DATA 0x00000000 +#define DDRSS_PHY_667_DATA 0x00000000 +#define DDRSS_PHY_668_DATA 0x00000000 +#define DDRSS_PHY_669_DATA 0x00000000 +#define DDRSS_PHY_670_DATA 0x00000000 +#define DDRSS_PHY_671_DATA 0x00000000 +#define DDRSS_PHY_672_DATA 0x00000000 +#define DDRSS_PHY_673_DATA 0x00000000 +#define DDRSS_PHY_674_DATA 0x00000000 +#define DDRSS_PHY_675_DATA 0x00000000 +#define DDRSS_PHY_676_DATA 0x00000000 +#define DDRSS_PHY_677_DATA 0x00000000 +#define DDRSS_PHY_678_DATA 0x00000000 +#define DDRSS_PHY_679_DATA 0x00000000 +#define DDRSS_PHY_680_DATA 0x00000000 +#define DDRSS_PHY_681_DATA 0x00000000 +#define DDRSS_PHY_682_DATA 0x00000000 +#define DDRSS_PHY_683_DATA 0x00000000 +#define DDRSS_PHY_684_DATA 0x00000000 +#define DDRSS_PHY_685_DATA 0x00000000 +#define DDRSS_PHY_686_DATA 0x00000000 +#define DDRSS_PHY_687_DATA 0x00000000 +#define DDRSS_PHY_688_DATA 0x00000000 +#define DDRSS_PHY_689_DATA 0x00000000 +#define DDRSS_PHY_690_DATA 0x00000000 +#define DDRSS_PHY_691_DATA 0x00000000 +#define DDRSS_PHY_692_DATA 0x00000000 +#define DDRSS_PHY_693_DATA 0x00000000 +#define DDRSS_PHY_694_DATA 0x00000000 +#define DDRSS_PHY_695_DATA 0x00000000 +#define DDRSS_PHY_696_DATA 0x00000000 +#define DDRSS_PHY_697_DATA 0x00000000 +#define DDRSS_PHY_698_DATA 0x00000000 +#define DDRSS_PHY_699_DATA 0x00000000 +#define DDRSS_PHY_700_DATA 0x00000000 +#define DDRSS_PHY_701_DATA 0x00000000 +#define DDRSS_PHY_702_DATA 0x00000000 +#define DDRSS_PHY_703_DATA 0x00000000 +#define DDRSS_PHY_704_DATA 0x00000000 +#define DDRSS_PHY_705_DATA 0x00000000 +#define DDRSS_PHY_706_DATA 0x00000000 +#define DDRSS_PHY_707_DATA 0x00000000 +#define DDRSS_PHY_708_DATA 0x00000000 +#define DDRSS_PHY_709_DATA 0x00000000 +#define DDRSS_PHY_710_DATA 0x00000000 +#define DDRSS_PHY_711_DATA 0x00000000 +#define DDRSS_PHY_712_DATA 0x00000000 +#define DDRSS_PHY_713_DATA 0x00000000 +#define DDRSS_PHY_714_DATA 0x00000000 +#define DDRSS_PHY_715_DATA 0x00000000 +#define DDRSS_PHY_716_DATA 0x00000000 +#define DDRSS_PHY_717_DATA 0x00000000 +#define DDRSS_PHY_718_DATA 0x00000000 +#define DDRSS_PHY_719_DATA 0x00000000 +#define DDRSS_PHY_720_DATA 0x00000000 +#define DDRSS_PHY_721_DATA 0x00000000 +#define DDRSS_PHY_722_DATA 0x00000000 +#define DDRSS_PHY_723_DATA 0x00000000 +#define DDRSS_PHY_724_DATA 0x00000000 +#define DDRSS_PHY_725_DATA 0x00000000 +#define DDRSS_PHY_726_DATA 0x00000000 +#define DDRSS_PHY_727_DATA 0x00000000 +#define DDRSS_PHY_728_DATA 0x00000000 +#define DDRSS_PHY_729_DATA 0x00000000 +#define DDRSS_PHY_730_DATA 0x00000000 +#define DDRSS_PHY_731_DATA 0x00000000 +#define DDRSS_PHY_732_DATA 0x00000000 +#define DDRSS_PHY_733_DATA 0x00000000 +#define DDRSS_PHY_734_DATA 0x00000000 +#define DDRSS_PHY_735_DATA 0x00000000 +#define DDRSS_PHY_736_DATA 0x00000000 +#define DDRSS_PHY_737_DATA 0x00000000 +#define DDRSS_PHY_738_DATA 0x00000000 +#define DDRSS_PHY_739_DATA 0x00000000 +#define DDRSS_PHY_740_DATA 0x00000000 +#define DDRSS_PHY_741_DATA 0x00000000 +#define DDRSS_PHY_742_DATA 0x00000000 +#define DDRSS_PHY_743_DATA 0x00000000 +#define DDRSS_PHY_744_DATA 0x00000000 +#define DDRSS_PHY_745_DATA 0x00000000 +#define DDRSS_PHY_746_DATA 0x00000000 +#define DDRSS_PHY_747_DATA 0x00000000 +#define DDRSS_PHY_748_DATA 0x00000000 +#define DDRSS_PHY_749_DATA 0x00000000 +#define DDRSS_PHY_750_DATA 0x00000000 +#define DDRSS_PHY_751_DATA 0x00000000 +#define DDRSS_PHY_752_DATA 0x00000000 +#define DDRSS_PHY_753_DATA 0x00000000 +#define DDRSS_PHY_754_DATA 0x00000000 +#define DDRSS_PHY_755_DATA 0x00000000 +#define DDRSS_PHY_756_DATA 0x00000000 +#define DDRSS_PHY_757_DATA 0x00000000 +#define DDRSS_PHY_758_DATA 0x00000000 +#define DDRSS_PHY_759_DATA 0x00000000 +#define DDRSS_PHY_760_DATA 0x00000000 +#define DDRSS_PHY_761_DATA 0x00000000 +#define DDRSS_PHY_762_DATA 0x00000000 +#define DDRSS_PHY_763_DATA 0x00000000 +#define DDRSS_PHY_764_DATA 0x00000000 +#define DDRSS_PHY_765_DATA 0x00000000 +#define DDRSS_PHY_766_DATA 0x00000000 +#define DDRSS_PHY_767_DATA 0x00000000 +#define DDRSS_PHY_768_DATA 0x00000100 +#define DDRSS_PHY_769_DATA 0x00000000 +#define DDRSS_PHY_770_DATA 0x00000000 +#define DDRSS_PHY_771_DATA 0x00000000 +#define DDRSS_PHY_772_DATA 0x00000000 +#define DDRSS_PHY_773_DATA 0x00000100 +#define DDRSS_PHY_774_DATA 0x00000000 +#define DDRSS_PHY_775_DATA 0x00000000 +#define DDRSS_PHY_776_DATA 0x00000000 +#define DDRSS_PHY_777_DATA 0x00000000 +#define DDRSS_PHY_778_DATA 0x00000000 +#define DDRSS_PHY_779_DATA 0x00000000 +#define DDRSS_PHY_780_DATA 0x00000000 +#define DDRSS_PHY_781_DATA 0x00DCBA98 +#define DDRSS_PHY_782_DATA 0x00000000 +#define DDRSS_PHY_783_DATA 0x00000000 +#define DDRSS_PHY_784_DATA 0x00000000 +#define DDRSS_PHY_785_DATA 0x00000000 +#define DDRSS_PHY_786_DATA 0x00000000 +#define DDRSS_PHY_787_DATA 0x00000000 +#define DDRSS_PHY_788_DATA 0x00000000 +#define DDRSS_PHY_789_DATA 0x00000000 +#define DDRSS_PHY_790_DATA 0x00000000 +#define DDRSS_PHY_791_DATA 0x00000000 +#define DDRSS_PHY_792_DATA 0x00000000 +#define DDRSS_PHY_793_DATA 0x00000000 +#define DDRSS_PHY_794_DATA 0x00000000 +#define DDRSS_PHY_795_DATA 0x00000000 +#define DDRSS_PHY_796_DATA 0x16A4A0E6 +#define DDRSS_PHY_797_DATA 0x103F0000 +#define DDRSS_PHY_798_DATA 0x000F0000 +#define DDRSS_PHY_799_DATA 0x0000000F +#define DDRSS_PHY_800_DATA 0x020002CC +#define DDRSS_PHY_801_DATA 0x00030000 +#define DDRSS_PHY_802_DATA 0x00000300 +#define DDRSS_PHY_803_DATA 0x00000300 +#define DDRSS_PHY_804_DATA 0x00000300 +#define DDRSS_PHY_805_DATA 0x00000300 +#define DDRSS_PHY_806_DATA 0x00000300 +#define DDRSS_PHY_807_DATA 0x42080010 +#define DDRSS_PHY_808_DATA 0x0000003E +#define DDRSS_PHY_809_DATA 0x00000000 +#define DDRSS_PHY_810_DATA 0x00000000 +#define DDRSS_PHY_811_DATA 0x00000000 +#define DDRSS_PHY_812_DATA 0x00000000 +#define DDRSS_PHY_813_DATA 0x00000000 +#define DDRSS_PHY_814_DATA 0x00000000 +#define DDRSS_PHY_815_DATA 0x00000000 +#define DDRSS_PHY_816_DATA 0x00000000 +#define DDRSS_PHY_817_DATA 0x00000000 +#define DDRSS_PHY_818_DATA 0x00000000 +#define DDRSS_PHY_819_DATA 0x00000000 +#define DDRSS_PHY_820_DATA 0x00000000 +#define DDRSS_PHY_821_DATA 0x00000000 +#define DDRSS_PHY_822_DATA 0x00000000 +#define DDRSS_PHY_823_DATA 0x00000000 +#define DDRSS_PHY_824_DATA 0x00000000 +#define DDRSS_PHY_825_DATA 0x00000000 +#define DDRSS_PHY_826_DATA 0x00000000 +#define DDRSS_PHY_827_DATA 0x00000000 +#define DDRSS_PHY_828_DATA 0x00000000 +#define DDRSS_PHY_829_DATA 0x00000000 +#define DDRSS_PHY_830_DATA 0x00000000 +#define DDRSS_PHY_831_DATA 0x00000000 +#define DDRSS_PHY_832_DATA 0x00000000 +#define DDRSS_PHY_833_DATA 0x00000000 +#define DDRSS_PHY_834_DATA 0x00000000 +#define DDRSS_PHY_835_DATA 0x00000000 +#define DDRSS_PHY_836_DATA 0x00000000 +#define DDRSS_PHY_837_DATA 0x00000000 +#define DDRSS_PHY_838_DATA 0x00000000 +#define DDRSS_PHY_839_DATA 0x00000000 +#define DDRSS_PHY_840_DATA 0x00000000 +#define DDRSS_PHY_841_DATA 0x00000000 +#define DDRSS_PHY_842_DATA 0x00000000 +#define DDRSS_PHY_843_DATA 0x00000000 +#define DDRSS_PHY_844_DATA 0x00000000 +#define DDRSS_PHY_845_DATA 0x00000000 +#define DDRSS_PHY_846_DATA 0x00000000 +#define DDRSS_PHY_847_DATA 0x00000000 +#define DDRSS_PHY_848_DATA 0x00000000 +#define DDRSS_PHY_849_DATA 0x00000000 +#define DDRSS_PHY_850_DATA 0x00000000 +#define DDRSS_PHY_851_DATA 0x00000000 +#define DDRSS_PHY_852_DATA 0x00000000 +#define DDRSS_PHY_853_DATA 0x00000000 +#define DDRSS_PHY_854_DATA 0x00000000 +#define DDRSS_PHY_855_DATA 0x00000000 +#define DDRSS_PHY_856_DATA 0x00000000 +#define DDRSS_PHY_857_DATA 0x00000000 +#define DDRSS_PHY_858_DATA 0x00000000 +#define DDRSS_PHY_859_DATA 0x00000000 +#define DDRSS_PHY_860_DATA 0x00000000 +#define DDRSS_PHY_861_DATA 0x00000000 +#define DDRSS_PHY_862_DATA 0x00000000 +#define DDRSS_PHY_863_DATA 0x00000000 +#define DDRSS_PHY_864_DATA 0x00000000 +#define DDRSS_PHY_865_DATA 0x00000000 +#define DDRSS_PHY_866_DATA 0x00000000 +#define DDRSS_PHY_867_DATA 0x00000000 +#define DDRSS_PHY_868_DATA 0x00000000 +#define DDRSS_PHY_869_DATA 0x00000000 +#define DDRSS_PHY_870_DATA 0x00000000 +#define DDRSS_PHY_871_DATA 0x00000000 +#define DDRSS_PHY_872_DATA 0x00000000 +#define DDRSS_PHY_873_DATA 0x00000000 +#define DDRSS_PHY_874_DATA 0x00000000 +#define DDRSS_PHY_875_DATA 0x00000000 +#define DDRSS_PHY_876_DATA 0x00000000 +#define DDRSS_PHY_877_DATA 0x00000000 +#define DDRSS_PHY_878_DATA 0x00000000 +#define DDRSS_PHY_879_DATA 0x00000000 +#define DDRSS_PHY_880_DATA 0x00000000 +#define DDRSS_PHY_881_DATA 0x00000000 +#define DDRSS_PHY_882_DATA 0x00000000 +#define DDRSS_PHY_883_DATA 0x00000000 +#define DDRSS_PHY_884_DATA 0x00000000 +#define DDRSS_PHY_885_DATA 0x00000000 +#define DDRSS_PHY_886_DATA 0x00000000 +#define DDRSS_PHY_887_DATA 0x00000000 +#define DDRSS_PHY_888_DATA 0x00000000 +#define DDRSS_PHY_889_DATA 0x00000000 +#define DDRSS_PHY_890_DATA 0x00000000 +#define DDRSS_PHY_891_DATA 0x00000000 +#define DDRSS_PHY_892_DATA 0x00000000 +#define DDRSS_PHY_893_DATA 0x00000000 +#define DDRSS_PHY_894_DATA 0x00000000 +#define DDRSS_PHY_895_DATA 0x00000000 +#define DDRSS_PHY_896_DATA 0x00000000 +#define DDRSS_PHY_897_DATA 0x00000000 +#define DDRSS_PHY_898_DATA 0x00000000 +#define DDRSS_PHY_899_DATA 0x00000000 +#define DDRSS_PHY_900_DATA 0x00000000 +#define DDRSS_PHY_901_DATA 0x00000000 +#define DDRSS_PHY_902_DATA 0x00000000 +#define DDRSS_PHY_903_DATA 0x00000000 +#define DDRSS_PHY_904_DATA 0x00000000 +#define DDRSS_PHY_905_DATA 0x00000000 +#define DDRSS_PHY_906_DATA 0x00000000 +#define DDRSS_PHY_907_DATA 0x00000000 +#define DDRSS_PHY_908_DATA 0x00000000 +#define DDRSS_PHY_909_DATA 0x00000000 +#define DDRSS_PHY_910_DATA 0x00000000 +#define DDRSS_PHY_911_DATA 0x00000000 +#define DDRSS_PHY_912_DATA 0x00000000 +#define DDRSS_PHY_913_DATA 0x00000000 +#define DDRSS_PHY_914_DATA 0x00000000 +#define DDRSS_PHY_915_DATA 0x00000000 +#define DDRSS_PHY_916_DATA 0x00000000 +#define DDRSS_PHY_917_DATA 0x00000000 +#define DDRSS_PHY_918_DATA 0x00000000 +#define DDRSS_PHY_919_DATA 0x00000000 +#define DDRSS_PHY_920_DATA 0x00000000 +#define DDRSS_PHY_921_DATA 0x00000000 +#define DDRSS_PHY_922_DATA 0x00000000 +#define DDRSS_PHY_923_DATA 0x00000000 +#define DDRSS_PHY_924_DATA 0x00000000 +#define DDRSS_PHY_925_DATA 0x00000000 +#define DDRSS_PHY_926_DATA 0x00000000 +#define DDRSS_PHY_927_DATA 0x00000000 +#define DDRSS_PHY_928_DATA 0x00000000 +#define DDRSS_PHY_929_DATA 0x00000000 +#define DDRSS_PHY_930_DATA 0x00000000 +#define DDRSS_PHY_931_DATA 0x00000000 +#define DDRSS_PHY_932_DATA 0x00000000 +#define DDRSS_PHY_933_DATA 0x00000000 +#define DDRSS_PHY_934_DATA 0x00000000 +#define DDRSS_PHY_935_DATA 0x00000000 +#define DDRSS_PHY_936_DATA 0x00000000 +#define DDRSS_PHY_937_DATA 0x00000000 +#define DDRSS_PHY_938_DATA 0x00000000 +#define DDRSS_PHY_939_DATA 0x00000000 +#define DDRSS_PHY_940_DATA 0x00000000 +#define DDRSS_PHY_941_DATA 0x00000000 +#define DDRSS_PHY_942_DATA 0x00000000 +#define DDRSS_PHY_943_DATA 0x00000000 +#define DDRSS_PHY_944_DATA 0x00000000 +#define DDRSS_PHY_945_DATA 0x00000000 +#define DDRSS_PHY_946_DATA 0x00000000 +#define DDRSS_PHY_947_DATA 0x00000000 +#define DDRSS_PHY_948_DATA 0x00000000 +#define DDRSS_PHY_949_DATA 0x00000000 +#define DDRSS_PHY_950_DATA 0x00000000 +#define DDRSS_PHY_951_DATA 0x00000000 +#define DDRSS_PHY_952_DATA 0x00000000 +#define DDRSS_PHY_953_DATA 0x00000000 +#define DDRSS_PHY_954_DATA 0x00000000 +#define DDRSS_PHY_955_DATA 0x00000000 +#define DDRSS_PHY_956_DATA 0x00000000 +#define DDRSS_PHY_957_DATA 0x00000000 +#define DDRSS_PHY_958_DATA 0x00000000 +#define DDRSS_PHY_959_DATA 0x00000000 +#define DDRSS_PHY_960_DATA 0x00000000 +#define DDRSS_PHY_961_DATA 0x00000000 +#define DDRSS_PHY_962_DATA 0x00000000 +#define DDRSS_PHY_963_DATA 0x00000000 +#define DDRSS_PHY_964_DATA 0x00000000 +#define DDRSS_PHY_965_DATA 0x00000000 +#define DDRSS_PHY_966_DATA 0x00000000 +#define DDRSS_PHY_967_DATA 0x00000000 +#define DDRSS_PHY_968_DATA 0x00000000 +#define DDRSS_PHY_969_DATA 0x00000000 +#define DDRSS_PHY_970_DATA 0x00000000 +#define DDRSS_PHY_971_DATA 0x00000000 +#define DDRSS_PHY_972_DATA 0x00000000 +#define DDRSS_PHY_973_DATA 0x00000000 +#define DDRSS_PHY_974_DATA 0x00000000 +#define DDRSS_PHY_975_DATA 0x00000000 +#define DDRSS_PHY_976_DATA 0x00000000 +#define DDRSS_PHY_977_DATA 0x00000000 +#define DDRSS_PHY_978_DATA 0x00000000 +#define DDRSS_PHY_979_DATA 0x00000000 +#define DDRSS_PHY_980_DATA 0x00000000 +#define DDRSS_PHY_981_DATA 0x00000000 +#define DDRSS_PHY_982_DATA 0x00000000 +#define DDRSS_PHY_983_DATA 0x00000000 +#define DDRSS_PHY_984_DATA 0x00000000 +#define DDRSS_PHY_985_DATA 0x00000000 +#define DDRSS_PHY_986_DATA 0x00000000 +#define DDRSS_PHY_987_DATA 0x00000000 +#define DDRSS_PHY_988_DATA 0x00000000 +#define DDRSS_PHY_989_DATA 0x00000000 +#define DDRSS_PHY_990_DATA 0x00000000 +#define DDRSS_PHY_991_DATA 0x00000000 +#define DDRSS_PHY_992_DATA 0x00000000 +#define DDRSS_PHY_993_DATA 0x00000000 +#define DDRSS_PHY_994_DATA 0x00000000 +#define DDRSS_PHY_995_DATA 0x00000000 +#define DDRSS_PHY_996_DATA 0x00000000 +#define DDRSS_PHY_997_DATA 0x00000000 +#define DDRSS_PHY_998_DATA 0x00000000 +#define DDRSS_PHY_999_DATA 0x00000000 +#define DDRSS_PHY_1000_DATA 0x00000000 +#define DDRSS_PHY_1001_DATA 0x00000000 +#define DDRSS_PHY_1002_DATA 0x00000000 +#define DDRSS_PHY_1003_DATA 0x00000000 +#define DDRSS_PHY_1004_DATA 0x00000000 +#define DDRSS_PHY_1005_DATA 0x00000000 +#define DDRSS_PHY_1006_DATA 0x00000000 +#define DDRSS_PHY_1007_DATA 0x00000000 +#define DDRSS_PHY_1008_DATA 0x00000000 +#define DDRSS_PHY_1009_DATA 0x00000000 +#define DDRSS_PHY_1010_DATA 0x00000000 +#define DDRSS_PHY_1011_DATA 0x00000000 +#define DDRSS_PHY_1012_DATA 0x00000000 +#define DDRSS_PHY_1013_DATA 0x00000000 +#define DDRSS_PHY_1014_DATA 0x00000000 +#define DDRSS_PHY_1015_DATA 0x00000000 +#define DDRSS_PHY_1016_DATA 0x00000000 +#define DDRSS_PHY_1017_DATA 0x00000000 +#define DDRSS_PHY_1018_DATA 0x00000000 +#define DDRSS_PHY_1019_DATA 0x00000000 +#define DDRSS_PHY_1020_DATA 0x00000000 +#define DDRSS_PHY_1021_DATA 0x00000000 +#define DDRSS_PHY_1022_DATA 0x00000000 +#define DDRSS_PHY_1023_DATA 0x00000000 +#define DDRSS_PHY_1024_DATA 0x00000100 +#define DDRSS_PHY_1025_DATA 0x00000000 +#define DDRSS_PHY_1026_DATA 0x00000000 +#define DDRSS_PHY_1027_DATA 0x00000000 +#define DDRSS_PHY_1028_DATA 0x00000000 +#define DDRSS_PHY_1029_DATA 0x00000100 +#define DDRSS_PHY_1030_DATA 0x00000000 +#define DDRSS_PHY_1031_DATA 0x00000000 +#define DDRSS_PHY_1032_DATA 0x00000000 +#define DDRSS_PHY_1033_DATA 0x00000000 +#define DDRSS_PHY_1034_DATA 0x00000000 +#define DDRSS_PHY_1035_DATA 0x00000000 +#define DDRSS_PHY_1036_DATA 0x00000000 +#define DDRSS_PHY_1037_DATA 0x00DCBA98 +#define DDRSS_PHY_1038_DATA 0x00000000 +#define DDRSS_PHY_1039_DATA 0x00000000 +#define DDRSS_PHY_1040_DATA 0x00000000 +#define DDRSS_PHY_1041_DATA 0x00000000 +#define DDRSS_PHY_1042_DATA 0x00000000 +#define DDRSS_PHY_1043_DATA 0x00000000 +#define DDRSS_PHY_1044_DATA 0x00000000 +#define DDRSS_PHY_1045_DATA 0x00000000 +#define DDRSS_PHY_1046_DATA 0x00000000 +#define DDRSS_PHY_1047_DATA 0x00000000 +#define DDRSS_PHY_1048_DATA 0x00000000 +#define DDRSS_PHY_1049_DATA 0x00000000 +#define DDRSS_PHY_1050_DATA 0x00000000 +#define DDRSS_PHY_1051_DATA 0x00000000 +#define DDRSS_PHY_1052_DATA 0x2307B9AC +#define DDRSS_PHY_1053_DATA 0x10030000 +#define DDRSS_PHY_1054_DATA 0x000F0000 +#define DDRSS_PHY_1055_DATA 0x0000000F +#define DDRSS_PHY_1056_DATA 0x020002CC +#define DDRSS_PHY_1057_DATA 0x00030000 +#define DDRSS_PHY_1058_DATA 0x00000300 +#define DDRSS_PHY_1059_DATA 0x00000300 +#define DDRSS_PHY_1060_DATA 0x00000300 +#define DDRSS_PHY_1061_DATA 0x00000300 +#define DDRSS_PHY_1062_DATA 0x00000300 +#define DDRSS_PHY_1063_DATA 0x42080010 +#define DDRSS_PHY_1064_DATA 0x0000003E +#define DDRSS_PHY_1065_DATA 0x00000000 +#define DDRSS_PHY_1066_DATA 0x00000000 +#define DDRSS_PHY_1067_DATA 0x00000000 +#define DDRSS_PHY_1068_DATA 0x00000000 +#define DDRSS_PHY_1069_DATA 0x00000000 +#define DDRSS_PHY_1070_DATA 0x00000000 +#define DDRSS_PHY_1071_DATA 0x00000000 +#define DDRSS_PHY_1072_DATA 0x00000000 +#define DDRSS_PHY_1073_DATA 0x00000000 +#define DDRSS_PHY_1074_DATA 0x00000000 +#define DDRSS_PHY_1075_DATA 0x00000000 +#define DDRSS_PHY_1076_DATA 0x00000000 +#define DDRSS_PHY_1077_DATA 0x00000000 +#define DDRSS_PHY_1078_DATA 0x00000000 +#define DDRSS_PHY_1079_DATA 0x00000000 +#define DDRSS_PHY_1080_DATA 0x00000000 +#define DDRSS_PHY_1081_DATA 0x00000000 +#define DDRSS_PHY_1082_DATA 0x00000000 +#define DDRSS_PHY_1083_DATA 0x00000000 +#define DDRSS_PHY_1084_DATA 0x00000000 +#define DDRSS_PHY_1085_DATA 0x00000000 +#define DDRSS_PHY_1086_DATA 0x00000000 +#define DDRSS_PHY_1087_DATA 0x00000000 +#define DDRSS_PHY_1088_DATA 0x00000000 +#define DDRSS_PHY_1089_DATA 0x00000000 +#define DDRSS_PHY_1090_DATA 0x00000000 +#define DDRSS_PHY_1091_DATA 0x00000000 +#define DDRSS_PHY_1092_DATA 0x00000000 +#define DDRSS_PHY_1093_DATA 0x00000000 +#define DDRSS_PHY_1094_DATA 0x00000000 +#define DDRSS_PHY_1095_DATA 0x00000000 +#define DDRSS_PHY_1096_DATA 0x00000000 +#define DDRSS_PHY_1097_DATA 0x00000000 +#define DDRSS_PHY_1098_DATA 0x00000000 +#define DDRSS_PHY_1099_DATA 0x00000000 +#define DDRSS_PHY_1100_DATA 0x00000000 +#define DDRSS_PHY_1101_DATA 0x00000000 +#define DDRSS_PHY_1102_DATA 0x00000000 +#define DDRSS_PHY_1103_DATA 0x00000000 +#define DDRSS_PHY_1104_DATA 0x00000000 +#define DDRSS_PHY_1105_DATA 0x00000000 +#define DDRSS_PHY_1106_DATA 0x00000000 +#define DDRSS_PHY_1107_DATA 0x00000000 +#define DDRSS_PHY_1108_DATA 0x00000000 +#define DDRSS_PHY_1109_DATA 0x00000000 +#define DDRSS_PHY_1110_DATA 0x00000000 +#define DDRSS_PHY_1111_DATA 0x00000000 +#define DDRSS_PHY_1112_DATA 0x00000000 +#define DDRSS_PHY_1113_DATA 0x00000000 +#define DDRSS_PHY_1114_DATA 0x00000000 +#define DDRSS_PHY_1115_DATA 0x00000000 +#define DDRSS_PHY_1116_DATA 0x00000000 +#define DDRSS_PHY_1117_DATA 0x00000000 +#define DDRSS_PHY_1118_DATA 0x00000000 +#define DDRSS_PHY_1119_DATA 0x00000000 +#define DDRSS_PHY_1120_DATA 0x00000000 +#define DDRSS_PHY_1121_DATA 0x00000000 +#define DDRSS_PHY_1122_DATA 0x00000000 +#define DDRSS_PHY_1123_DATA 0x00000000 +#define DDRSS_PHY_1124_DATA 0x00000000 +#define DDRSS_PHY_1125_DATA 0x00000000 +#define DDRSS_PHY_1126_DATA 0x00000000 +#define DDRSS_PHY_1127_DATA 0x00000000 +#define DDRSS_PHY_1128_DATA 0x00000000 +#define DDRSS_PHY_1129_DATA 0x00000000 +#define DDRSS_PHY_1130_DATA 0x00000000 +#define DDRSS_PHY_1131_DATA 0x00000000 +#define DDRSS_PHY_1132_DATA 0x00000000 +#define DDRSS_PHY_1133_DATA 0x00000000 +#define DDRSS_PHY_1134_DATA 0x00000000 +#define DDRSS_PHY_1135_DATA 0x00000000 +#define DDRSS_PHY_1136_DATA 0x00000000 +#define DDRSS_PHY_1137_DATA 0x00000000 +#define DDRSS_PHY_1138_DATA 0x00000000 +#define DDRSS_PHY_1139_DATA 0x00000000 +#define DDRSS_PHY_1140_DATA 0x00000000 +#define DDRSS_PHY_1141_DATA 0x00000000 +#define DDRSS_PHY_1142_DATA 0x00000000 +#define DDRSS_PHY_1143_DATA 0x00000000 +#define DDRSS_PHY_1144_DATA 0x00000000 +#define DDRSS_PHY_1145_DATA 0x00000000 +#define DDRSS_PHY_1146_DATA 0x00000000 +#define DDRSS_PHY_1147_DATA 0x00000000 +#define DDRSS_PHY_1148_DATA 0x00000000 +#define DDRSS_PHY_1149_DATA 0x00000000 +#define DDRSS_PHY_1150_DATA 0x00000000 +#define DDRSS_PHY_1151_DATA 0x00000000 +#define DDRSS_PHY_1152_DATA 0x00000000 +#define DDRSS_PHY_1153_DATA 0x00000000 +#define DDRSS_PHY_1154_DATA 0x00000000 +#define DDRSS_PHY_1155_DATA 0x00000000 +#define DDRSS_PHY_1156_DATA 0x00000000 +#define DDRSS_PHY_1157_DATA 0x00000000 +#define DDRSS_PHY_1158_DATA 0x00000000 +#define DDRSS_PHY_1159_DATA 0x00000000 +#define DDRSS_PHY_1160_DATA 0x00000000 +#define DDRSS_PHY_1161_DATA 0x00000000 +#define DDRSS_PHY_1162_DATA 0x00000000 +#define DDRSS_PHY_1163_DATA 0x00000000 +#define DDRSS_PHY_1164_DATA 0x00000000 +#define DDRSS_PHY_1165_DATA 0x00000000 +#define DDRSS_PHY_1166_DATA 0x00000000 +#define DDRSS_PHY_1167_DATA 0x00000000 +#define DDRSS_PHY_1168_DATA 0x00000000 +#define DDRSS_PHY_1169_DATA 0x00000000 +#define DDRSS_PHY_1170_DATA 0x00000000 +#define DDRSS_PHY_1171_DATA 0x00000000 +#define DDRSS_PHY_1172_DATA 0x00000000 +#define DDRSS_PHY_1173_DATA 0x00000000 +#define DDRSS_PHY_1174_DATA 0x00000000 +#define DDRSS_PHY_1175_DATA 0x00000000 +#define DDRSS_PHY_1176_DATA 0x00000000 +#define DDRSS_PHY_1177_DATA 0x00000000 +#define DDRSS_PHY_1178_DATA 0x00000000 +#define DDRSS_PHY_1179_DATA 0x00000000 +#define DDRSS_PHY_1180_DATA 0x00000000 +#define DDRSS_PHY_1181_DATA 0x00000000 +#define DDRSS_PHY_1182_DATA 0x00000000 +#define DDRSS_PHY_1183_DATA 0x00000000 +#define DDRSS_PHY_1184_DATA 0x00000000 +#define DDRSS_PHY_1185_DATA 0x00000000 +#define DDRSS_PHY_1186_DATA 0x00000000 +#define DDRSS_PHY_1187_DATA 0x00000000 +#define DDRSS_PHY_1188_DATA 0x00000000 +#define DDRSS_PHY_1189_DATA 0x00000000 +#define DDRSS_PHY_1190_DATA 0x00000000 +#define DDRSS_PHY_1191_DATA 0x00000000 +#define DDRSS_PHY_1192_DATA 0x00000000 +#define DDRSS_PHY_1193_DATA 0x00000000 +#define DDRSS_PHY_1194_DATA 0x00000000 +#define DDRSS_PHY_1195_DATA 0x00000000 +#define DDRSS_PHY_1196_DATA 0x00000000 +#define DDRSS_PHY_1197_DATA 0x00000000 +#define DDRSS_PHY_1198_DATA 0x00000000 +#define DDRSS_PHY_1199_DATA 0x00000000 +#define DDRSS_PHY_1200_DATA 0x00000000 +#define DDRSS_PHY_1201_DATA 0x00000000 +#define DDRSS_PHY_1202_DATA 0x00000000 +#define DDRSS_PHY_1203_DATA 0x00000000 +#define DDRSS_PHY_1204_DATA 0x00000000 +#define DDRSS_PHY_1205_DATA 0x00000000 +#define DDRSS_PHY_1206_DATA 0x00000000 +#define DDRSS_PHY_1207_DATA 0x00000000 +#define DDRSS_PHY_1208_DATA 0x00000000 +#define DDRSS_PHY_1209_DATA 0x00000000 +#define DDRSS_PHY_1210_DATA 0x00000000 +#define DDRSS_PHY_1211_DATA 0x00000000 +#define DDRSS_PHY_1212_DATA 0x00000000 +#define DDRSS_PHY_1213_DATA 0x00000000 +#define DDRSS_PHY_1214_DATA 0x00000000 +#define DDRSS_PHY_1215_DATA 0x00000000 +#define DDRSS_PHY_1216_DATA 0x00000000 +#define DDRSS_PHY_1217_DATA 0x00000000 +#define DDRSS_PHY_1218_DATA 0x00000000 +#define DDRSS_PHY_1219_DATA 0x00000000 +#define DDRSS_PHY_1220_DATA 0x00000000 +#define DDRSS_PHY_1221_DATA 0x00000000 +#define DDRSS_PHY_1222_DATA 0x00000000 +#define DDRSS_PHY_1223_DATA 0x00000000 +#define DDRSS_PHY_1224_DATA 0x00000000 +#define DDRSS_PHY_1225_DATA 0x00000000 +#define DDRSS_PHY_1226_DATA 0x00000000 +#define DDRSS_PHY_1227_DATA 0x00000000 +#define DDRSS_PHY_1228_DATA 0x00000000 +#define DDRSS_PHY_1229_DATA 0x00000000 +#define DDRSS_PHY_1230_DATA 0x00000000 +#define DDRSS_PHY_1231_DATA 0x00000000 +#define DDRSS_PHY_1232_DATA 0x00000000 +#define DDRSS_PHY_1233_DATA 0x00000000 +#define DDRSS_PHY_1234_DATA 0x00000000 +#define DDRSS_PHY_1235_DATA 0x00000000 +#define DDRSS_PHY_1236_DATA 0x00000000 +#define DDRSS_PHY_1237_DATA 0x00000000 +#define DDRSS_PHY_1238_DATA 0x00000000 +#define DDRSS_PHY_1239_DATA 0x00000000 +#define DDRSS_PHY_1240_DATA 0x00000000 +#define DDRSS_PHY_1241_DATA 0x00000000 +#define DDRSS_PHY_1242_DATA 0x00000000 +#define DDRSS_PHY_1243_DATA 0x00000000 +#define DDRSS_PHY_1244_DATA 0x00000000 +#define DDRSS_PHY_1245_DATA 0x00000000 +#define DDRSS_PHY_1246_DATA 0x00000000 +#define DDRSS_PHY_1247_DATA 0x00000000 +#define DDRSS_PHY_1248_DATA 0x00000000 +#define DDRSS_PHY_1249_DATA 0x00000000 +#define DDRSS_PHY_1250_DATA 0x00000000 +#define DDRSS_PHY_1251_DATA 0x00000000 +#define DDRSS_PHY_1252_DATA 0x00000000 +#define DDRSS_PHY_1253_DATA 0x00000000 +#define DDRSS_PHY_1254_DATA 0x00000000 +#define DDRSS_PHY_1255_DATA 0x00000000 +#define DDRSS_PHY_1256_DATA 0x00000000 +#define DDRSS_PHY_1257_DATA 0x00000000 +#define DDRSS_PHY_1258_DATA 0x00000000 +#define DDRSS_PHY_1259_DATA 0x00000000 +#define DDRSS_PHY_1260_DATA 0x00000000 +#define DDRSS_PHY_1261_DATA 0x00000000 +#define DDRSS_PHY_1262_DATA 0x00000000 +#define DDRSS_PHY_1263_DATA 0x00000000 +#define DDRSS_PHY_1264_DATA 0x00000000 +#define DDRSS_PHY_1265_DATA 0x00000000 +#define DDRSS_PHY_1266_DATA 0x00000000 +#define DDRSS_PHY_1267_DATA 0x00000000 +#define DDRSS_PHY_1268_DATA 0x00000000 +#define DDRSS_PHY_1269_DATA 0x00000000 +#define DDRSS_PHY_1270_DATA 0x00000000 +#define DDRSS_PHY_1271_DATA 0x00000000 +#define DDRSS_PHY_1272_DATA 0x00000000 +#define DDRSS_PHY_1273_DATA 0x00000000 +#define DDRSS_PHY_1274_DATA 0x00000000 +#define DDRSS_PHY_1275_DATA 0x00000000 +#define DDRSS_PHY_1276_DATA 0x00000000 +#define DDRSS_PHY_1277_DATA 0x00000000 +#define DDRSS_PHY_1278_DATA 0x00000000 +#define DDRSS_PHY_1279_DATA 0x00000000 +#define DDRSS_PHY_1280_DATA 0x00000000 +#define DDRSS_PHY_1281_DATA 0x00000100 +#define DDRSS_PHY_1282_DATA 0x00000000 +#define DDRSS_PHY_1283_DATA 0x00000000 +#define DDRSS_PHY_1284_DATA 0x00000000 +#define DDRSS_PHY_1285_DATA 0x00000000 +#define DDRSS_PHY_1286_DATA 0x00050000 +#define DDRSS_PHY_1287_DATA 0x04000100 +#define DDRSS_PHY_1288_DATA 0x00000055 +#define DDRSS_PHY_1289_DATA 0x00000000 +#define DDRSS_PHY_1290_DATA 0x00000000 +#define DDRSS_PHY_1291_DATA 0x00000000 +#define DDRSS_PHY_1292_DATA 0x00000000 +#define DDRSS_PHY_1293_DATA 0x01002000 +#define DDRSS_PHY_1294_DATA 0x00004001 +#define DDRSS_PHY_1295_DATA 0x00020028 +#define DDRSS_PHY_1296_DATA 0x00010100 +#define DDRSS_PHY_1297_DATA 0x00000001 +#define DDRSS_PHY_1298_DATA 0x00000000 +#define DDRSS_PHY_1299_DATA 0x0F0F0E06 +#define DDRSS_PHY_1300_DATA 0x00010101 +#define DDRSS_PHY_1301_DATA 0x010F0004 +#define DDRSS_PHY_1302_DATA 0x00000000 +#define DDRSS_PHY_1303_DATA 0x00000000 +#define DDRSS_PHY_1304_DATA 0x00000064 +#define DDRSS_PHY_1305_DATA 0x00000000 +#define DDRSS_PHY_1306_DATA 0x00000000 +#define DDRSS_PHY_1307_DATA 0x01020103 +#define DDRSS_PHY_1308_DATA 0x0F020102 +#define DDRSS_PHY_1309_DATA 0x03030303 +#define DDRSS_PHY_1310_DATA 0x03030303 +#define DDRSS_PHY_1311_DATA 0x00040000 +#define DDRSS_PHY_1312_DATA 0x00004201 +#define DDRSS_PHY_1313_DATA 0x00000000 +#define DDRSS_PHY_1314_DATA 0x00000000 +#define DDRSS_PHY_1315_DATA 0x00000000 +#define DDRSS_PHY_1316_DATA 0x00000000 +#define DDRSS_PHY_1317_DATA 0x00000000 +#define DDRSS_PHY_1318_DATA 0x00000000 +#define DDRSS_PHY_1319_DATA 0x07070001 +#define DDRSS_PHY_1320_DATA 0x00005400 +#define DDRSS_PHY_1321_DATA 0x000040A2 +#define DDRSS_PHY_1322_DATA 0x00024410 +#define DDRSS_PHY_1323_DATA 0x00004410 +#define DDRSS_PHY_1324_DATA 0x00004410 +#define DDRSS_PHY_1325_DATA 0x00004410 +#define DDRSS_PHY_1326_DATA 0x00004410 +#define DDRSS_PHY_1327_DATA 0x00004410 +#define DDRSS_PHY_1328_DATA 0x00004410 +#define DDRSS_PHY_1329_DATA 0x00004410 +#define DDRSS_PHY_1330_DATA 0x00004410 +#define DDRSS_PHY_1331_DATA 0x00004410 +#define DDRSS_PHY_1332_DATA 0x00000000 +#define DDRSS_PHY_1333_DATA 0x00000046 +#define DDRSS_PHY_1334_DATA 0x00000400 +#define DDRSS_PHY_1335_DATA 0x00000008 +#define DDRSS_PHY_1336_DATA 0x00000000 +#define DDRSS_PHY_1337_DATA 0x00000000 +#define DDRSS_PHY_1338_DATA 0x00000000 +#define DDRSS_PHY_1339_DATA 0x00000000 +#define DDRSS_PHY_1340_DATA 0x00000000 +#define DDRSS_PHY_1341_DATA 0x03000000 +#define DDRSS_PHY_1342_DATA 0x00000000 +#define DDRSS_PHY_1343_DATA 0x00000000 +#define DDRSS_PHY_1344_DATA 0x00000000 +#define DDRSS_PHY_1345_DATA 0x04102006 +#define DDRSS_PHY_1346_DATA 0x00041020 +#define DDRSS_PHY_1347_DATA 0x01C98C98 +#define DDRSS_PHY_1348_DATA 0x3F400000 +#define DDRSS_PHY_1349_DATA 0x3F3F1F3F +#define DDRSS_PHY_1350_DATA 0x0000001F +#define DDRSS_PHY_1351_DATA 0x00000000 +#define DDRSS_PHY_1352_DATA 0x00000000 +#define DDRSS_PHY_1353_DATA 0x00000000 +#define DDRSS_PHY_1354_DATA 0x00000001 +#define DDRSS_PHY_1355_DATA 0x00000000 +#define DDRSS_PHY_1356_DATA 0x00000000 +#define DDRSS_PHY_1357_DATA 0x00000000 +#define DDRSS_PHY_1358_DATA 0x00000000 +#define DDRSS_PHY_1359_DATA 0x76543210 +#define DDRSS_PHY_1360_DATA 0x00000098 +#define DDRSS_PHY_1361_DATA 0x00000000 +#define DDRSS_PHY_1362_DATA 0x00000000 +#define DDRSS_PHY_1363_DATA 0x00000000 +#define DDRSS_PHY_1364_DATA 0x00040700 +#define DDRSS_PHY_1365_DATA 0x00000000 +#define DDRSS_PHY_1366_DATA 0x00000000 +#define DDRSS_PHY_1367_DATA 0x00000000 +#define DDRSS_PHY_1368_DATA 0x00000002 +#define DDRSS_PHY_1369_DATA 0x00000100 +#define DDRSS_PHY_1370_DATA 0x00000000 +#define DDRSS_PHY_1371_DATA 0x00000FC3 +#define DDRSS_PHY_1372_DATA 0x00020002 +#define DDRSS_PHY_1373_DATA 0x00000000 +#define DDRSS_PHY_1374_DATA 0x00001142 +#define DDRSS_PHY_1375_DATA 0x03020400 +#define DDRSS_PHY_1376_DATA 0x00000080 +#define DDRSS_PHY_1377_DATA 0x03900390 +#define DDRSS_PHY_1378_DATA 0x03900390 +#define DDRSS_PHY_1379_DATA 0x03900390 +#define DDRSS_PHY_1380_DATA 0x03900390 +#define DDRSS_PHY_1381_DATA 0x03900390 +#define DDRSS_PHY_1382_DATA 0x03900390 +#define DDRSS_PHY_1383_DATA 0x00000300 +#define DDRSS_PHY_1384_DATA 0x00000300 +#define DDRSS_PHY_1385_DATA 0x00000300 +#define DDRSS_PHY_1386_DATA 0x00000300 +#define DDRSS_PHY_1387_DATA 0x31823FC7 +#define DDRSS_PHY_1388_DATA 0x00000000 +#define DDRSS_PHY_1389_DATA 0x0C000D3F +#define DDRSS_PHY_1390_DATA 0x30000D3F +#define DDRSS_PHY_1391_DATA 0x300D3F11 +#define DDRSS_PHY_1392_DATA 0x01990000 +#define DDRSS_PHY_1393_DATA 0x000D3FCC +#define DDRSS_PHY_1394_DATA 0x00000C11 +#define DDRSS_PHY_1395_DATA 0x300D3F11 +#define DDRSS_PHY_1396_DATA 0x01990000 +#define DDRSS_PHY_1397_DATA 0x300C3F11 +#define DDRSS_PHY_1398_DATA 0x01990000 +#define DDRSS_PHY_1399_DATA 0x300C3F11 +#define DDRSS_PHY_1400_DATA 0x01990000 +#define DDRSS_PHY_1401_DATA 0x300D3F11 +#define DDRSS_PHY_1402_DATA 0x01990000 +#define DDRSS_PHY_1403_DATA 0x300D3F11 +#define DDRSS_PHY_1404_DATA 0x01990000 +#define DDRSS_PHY_1405_DATA 0x20040004 diff --git a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi new file mode 100644 index 000000000000..f8c04e8a300a --- /dev/null +++ b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi @@ -0,0 +1,195 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * https://beagleboard.org/play + * + * Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2022-2023 Robert Nelson, BeagleBoard.org Foundation + */ + +#include "k3-am625-sk-binman.dtsi" + +/ { + chosen { + tick-timer = &main_timer0; + }; + + memory@80000000 { + bootph-pre-ram; + }; + + /* Keep the LEDs on by default to indicate life */ + leds { + bootph-pre-ram; + led-0 { + default-state = "on"; + bootph-pre-ram; + }; + + led-1 { + default-state = "on"; + bootph-pre-ram; + }; + + led-2 { + default-state = "on"; + bootph-pre-ram; + }; + + led-3 { + default-state = "on"; + bootph-pre-ram; + }; + + led-4 { + default-state = "on"; + bootph-pre-ram; + }; + }; +}; + +&cbass_main { + bootph-pre-ram; +}; + +&main_timer0 { + clock-frequency = <25000000>; + bootph-pre-ram; +}; + +&dmss { + bootph-pre-ram; +}; + +&secure_proxy_main { + bootph-pre-ram; +}; + +&dmsc { + bootph-pre-ram; +}; + +&k3_pds { + bootph-pre-ram; +}; + +&k3_clks { + bootph-pre-ram; +}; + +&k3_reset { + bootph-pre-ram; +}; + +&dmsc { + bootph-pre-ram; + k3_sysreset: sysreset-controller { + compatible = "ti,sci-sysreset"; + bootph-pre-ram; + }; +}; + +&wkup_conf { + bootph-pre-ram; +}; + +&chipid { + bootph-pre-ram; +}; + +&main_pmx0 { + bootph-pre-ram; +}; + +&main_uart0 { + bootph-pre-ram; +}; + +&console_pins_default { + bootph-pre-ram; +}; + +&cbass_mcu { + bootph-pre-ram; +}; + +&cbass_wakeup { + bootph-pre-ram; +}; + +&mcu_pmx0 { + bootph-pre-ram; +}; + +&main_i2c0 { + bootph-pre-ram; +}; + +&local_i2c_pins_default { + bootph-pre-ram; +}; + +&gpio0_pins_default { + bootph-pre-ram; +}; + +&main_gpio0 { + bootph-pre-ram; +}; + +&main_gpio1 { + bootph-pre-ram; +}; + +&sdhci0 { + /* EMMC */ + bootph-pre-ram; +}; + +&emmc_pins_default { + bootph-pre-ram; +}; + +&sd_pins_default { + bootph-pre-ram; + /* Force to use SDCD card detect pin */ + pinctrl-single,pins = < + AM62X_IOPAD(0x023c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ + AM62X_IOPAD(0x0234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ + AM62X_IOPAD(0x0230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */ + AM62X_IOPAD(0x022c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */ + AM62X_IOPAD(0x0228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */ + AM62X_IOPAD(0x0224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */ + AM62X_IOPAD(0x0240, PIN_INPUT, 0) /* (D17) MMC1_SDCD.MMC1_SDCD */ + >; +}; + +&tps65219 { + bootph-pre-ram; +}; + +&sdhci1 { + bootph-pre-ram; +}; + +#ifdef CONFIG_TARGET_AM625_A53_EVM + +#define SPL_AM625_BEAGLEPLAY_DTB "spl/dts/k3-am625-beagleplay.dtb" +#define AM625_BEAGLEPLAY_DTB "arch/arm/dts/k3-am625-beagleplay.dtb" + +&spl_am625_sk_dtb { + filename = SPL_AM625_BEAGLEPLAY_DTB; +}; + +&am625_sk_dtb { + filename = AM625_BEAGLEPLAY_DTB; +}; + +&spl_am625_sk_dtb_unsigned { + filename = SPL_AM625_BEAGLEPLAY_DTB; +}; + +&am625_sk_dtb_unsigned { + filename = AM625_BEAGLEPLAY_DTB; +}; + +#endif diff --git a/arch/arm/dts/k3-am625-beagleplay.dts b/arch/arm/dts/k3-am625-beagleplay.dts new file mode 100644 index 000000000000..589bf998bc52 --- /dev/null +++ b/arch/arm/dts/k3-am625-beagleplay.dts @@ -0,0 +1,758 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * https://beagleplay.org/ + * + * Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2022-2023 Robert Nelson, BeagleBoard.org Foundation + */ + +/dts-v1/; + +#include <dt-bindings/leds/common.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include "k3-am625.dtsi" + +/ { + compatible = "beagle,am625-beagleplay", "ti,am625"; + model = "BeagleBoard.org BeaglePlay"; + + aliases { + ethernet0 = &cpsw_port1; + ethernet1 = &cpsw_port2; + gpio0 = &main_gpio0; + gpio1 = &main_gpio1; + gpio2 = &mcu_gpio0; + i2c0 = &main_i2c0; + i2c1 = &main_i2c1; + i2c2 = &main_i2c2; + i2c3 = &main_i2c3; + i2c4 = &wkup_i2c0; + i2c5 = &mcu_i2c0; + mdio-gpio0 = &mdio0; + mmc0 = &sdhci0; + mmc1 = &sdhci1; + mmc2 = &sdhci2; + rtc0 = &rtc; + serial0 = &main_uart5; + serial1 = &main_uart6; + serial2 = &main_uart0; + usb0 = &usb0; + usb1 = &usb1; + }; + + chosen { + stdout-path = "serial2:115200n8"; + }; + + memory@80000000 { + device_type = "memory"; + /* 2G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + ramoops: ramoops@9ca00000 { + compatible = "ramoops"; + reg = <0x00 0x9c700000 0x00 0x00100000>; + record-size = <0x8000>; + console-size = <0x8000>; + ftrace-size = <0x00>; + pmsg-size = <0x8000>; + }; + + secure_tfa_ddr: tfa@9e780000 { + reg = <0x00 0x9e780000 0x00 0x80000>; + no-map; + }; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; + no-map; + }; + + wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 { + compatible = "shared-dma-pool"; + reg = <0x00 0x9db00000 0x00 0xc00000>; + no-map; + }; + }; + + vsys_5v0: regulator-1 { + compatible = "regulator-fixed"; + regulator-name = "vsys_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_3v3: regulator-2 { + /* output of TLV62595DMQR-U12 */ + compatible = "regulator-fixed"; + regulator-name = "vdd_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vsys_5v0>; + regulator-always-on; + regulator-boot-on; + }; + + wlan_en: regulator-3 { + /* OUTPUT of SN74AVC2T244DQMR */ + compatible = "regulator-fixed"; + regulator-name = "wlan_en"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + enable-active-high; + regulator-always-on; + vin-supply = <&vdd_3v3>; + gpio = <&main_gpio0 38 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_en_pins_default>; + }; + + vdd_3v3_sd: regulator-4 { + /* output of TPS22918DBVR-U21 */ + pinctrl-names = "default"; + pinctrl-0 = <&vdd_3v3_sd_pins_default>; + + compatible = "regulator-fixed"; + regulator-name = "vdd_3v3_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + enable-active-high; + regulator-always-on; + vin-supply = <&vdd_3v3>; + gpio = <&main_gpio1 19 GPIO_ACTIVE_HIGH>; + }; + + vdd_sd_dv: regulator-5 { + compatible = "regulator-gpio"; + regulator-name = "sd_hs200_switch"; + pinctrl-names = "default"; + pinctrl-0 = <&vdd_sd_dv_pins_default>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + vin-supply = <&ldo1_reg>; + gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>; + states = <1800000 0x0>, + <3300000 0x1>; + }; + + leds { + compatible = "gpio-leds"; + + led-0 { + gpios = <&main_gpio0 3 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + function = LED_FUNCTION_HEARTBEAT; + default-state = "off"; + }; + + led-1 { + gpios = <&main_gpio0 4 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "disk-activity"; + function = LED_FUNCTION_DISK_ACTIVITY; + default-state = "keep"; + }; + + led-2 { + gpios = <&main_gpio0 5 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_CPU; + }; + + led-3 { + gpios = <&main_gpio0 6 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_LAN; + }; + + led-4 { + gpios = <&main_gpio0 9 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_WLAN; + }; + }; + + gpio_keys: gpio-keys { + compatible = "gpio-keys"; + autorepeat; + pinctrl-names = "default"; + pinctrl-0 = <&usr_button_pins_default>; + + usr: button-usr { + label = "User Key"; + linux,code = <BTN_0>; + gpios = <&main_gpio0 18 GPIO_ACTIVE_LOW>; + }; + + }; + + /* Workaround for errata i2329 - just use mdio bitbang */ + mdio0: mdio { + compatible = "virtual,mdio-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&mdio0_pins_default>; + gpios = <&main_gpio0 86 GPIO_ACTIVE_HIGH>, /* MDC */ + <&main_gpio0 85 GPIO_ACTIVE_HIGH>; /* MDIO */ + #address-cells = <1>; + #size-cells = <0>; + + cpsw3g_phy0: ethernet-phy@0 { + reg = <0>; + }; + + cpsw3g_phy1: ethernet-phy@1 { + reg = <1>; + reset-gpios = <&main_gpio1 5 GPIO_ACTIVE_LOW>; + reset-assert-us = <25>; + reset-deassert-us = <60000>; /* T2 */ + }; + }; +}; + +&main_pmx0 { + gpio0_pins_default: gpio0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0004, PIN_INPUT, 7) /* (G25) OSPI0_LBCLKO.GPIO0_1 */ + AM62X_IOPAD(0x0008, PIN_INPUT, 7) /* (J24) OSPI0_DQS.GPIO0_2 */ + AM62X_IOPAD(0x000c, PIN_INPUT, 7) /* (E25) OSPI0_D0.GPIO0_3 */ + AM62X_IOPAD(0x0010, PIN_INPUT, 7) /* (G24) OSPI0_D1.GPIO0_4 */ + AM62X_IOPAD(0x0014, PIN_INPUT, 7) /* (F25) OSPI0_D2.GPIO0_5 */ + AM62X_IOPAD(0x0018, PIN_INPUT, 7) /* (F24) OSPI0_D3.GPIO0_6 */ + AM62X_IOPAD(0x0024, PIN_INPUT, 7) /* (H25) OSPI0_D6.GPIO0_9 */ + AM62X_IOPAD(0x0028, PIN_INPUT, 7) /* (J22) OSPI0_D7.GPIO0_10 */ + AM62X_IOPAD(0x002c, PIN_INPUT, 7) /* (F23) OSPI0_CSn0.GPIO0_11 */ + AM62X_IOPAD(0x0030, PIN_INPUT, 7) /* (G21) OSPI0_CSn1.GPIO0_12 */ + AM62X_IOPAD(0x0034, PIN_INPUT, 7) /* (H21) OSPI0_CSn2.GPIO0_13 */ + AM62X_IOPAD(0x0038, PIN_INPUT, 7) /* (E24) OSPI0_CSn3.GPIO0_14 */ + AM62X_IOPAD(0x00a4, PIN_INPUT, 7) /* (M22) GPMC0_DIR.GPIO0_40 */ + AM62X_IOPAD(0x00ac, PIN_INPUT, 7) /* (L21) GPMC0_CSn1.GPIO0_42 */ + >; + }; + + vdd_sd_dv_pins_default: vdd-sd-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0244, PIN_OUTPUT, 7) /* (C17) MMC1_SDWP.GPIO1_49 */ + >; + }; + + usr_button_pins_default: usr-button-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0048, PIN_INPUT, 7) /* (N25) GPMC0_AD3.GPIO0_18 */ + >; + }; + + grove_pins_default: grove-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */ + AM62X_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */ + >; + }; + + local_i2c_pins_default: local-i2c-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */ + AM62X_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */ + >; + }; + + i2c2_1v8_pins_default: i2c2-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */ + AM62X_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */ + >; + }; + + mdio0_pins_default: mdio0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0160, PIN_OUTPUT, 7) /* (AD24) MDIO0_MDC.GPIO0_86 */ + AM62X_IOPAD(0x015c, PIN_INPUT, 7) /* (AB22) MDIO0_MDIO.GPIO0_85 */ + >; + }; + + rgmii1_pins_default: rgmii1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x014c, PIN_INPUT, 0) /* (AB17) RGMII1_RD0 */ + AM62X_IOPAD(0x0150, PIN_INPUT, 0) /* (AC17) RGMII1_RD1 */ + AM62X_IOPAD(0x0154, PIN_INPUT, 0) /* (AB16) RGMII1_RD2 */ + AM62X_IOPAD(0x0158, PIN_INPUT, 0) /* (AA15) RGMII1_RD3 */ + AM62X_IOPAD(0x0148, PIN_INPUT, 0) /* (AD17) RGMII1_RXC */ + AM62X_IOPAD(0x0144, PIN_INPUT, 0) /* (AE17) RGMII1_RX_CTL */ + AM62X_IOPAD(0x0134, PIN_OUTPUT, 0) /* (AE20) RGMII1_TD0 */ + AM62X_IOPAD(0x0138, PIN_OUTPUT, 0) /* (AD20) RGMII1_TD1 */ + AM62X_IOPAD(0x013c, PIN_OUTPUT, 0) /* (AE18) RGMII1_TD2 */ + AM62X_IOPAD(0x0140, PIN_OUTPUT, 0) /* (AD18) RGMII1_TD3 */ + AM62X_IOPAD(0x0130, PIN_OUTPUT, 0) /* (AE19) RGMII1_TXC */ + AM62X_IOPAD(0x012c, PIN_OUTPUT, 0) /* (AD19) RGMII1_TX_CTL */ + >; + }; + + emmc_pins_default: emmc-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */ + AM62X_IOPAD(0x0218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */ + AM62X_IOPAD(0x0214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */ + AM62X_IOPAD(0x0210, PIN_INPUT, 0) /* (AA1) MMC0_DAT1 */ + AM62X_IOPAD(0x020c, PIN_INPUT, 0) /* (AA3) MMC0_DAT2 */ + AM62X_IOPAD(0x0208, PIN_INPUT, 0) /* (Y4) MMC0_DAT3 */ + AM62X_IOPAD(0x0204, PIN_INPUT, 0) /* (AB2) MMC0_DAT4 */ + AM62X_IOPAD(0x0200, PIN_INPUT, 0) /* (AC1) MMC0_DAT5 */ + AM62X_IOPAD(0x01fc, PIN_INPUT, 0) /* (AD2) MMC0_DAT6 */ + AM62X_IOPAD(0x01f8, PIN_INPUT, 0) /* (AC2) MMC0_DAT7 */ + >; + }; + + vdd_3v3_sd_pins_default: vdd-3v3-sd-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01c4, PIN_INPUT, 7) /* (B14) SPI0_D1_GPIO1_19 */ + >; + }; + + sd_pins_default: sd-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x023c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ + AM62X_IOPAD(0x0234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ + AM62X_IOPAD(0x0230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */ + AM62X_IOPAD(0x022c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */ + AM62X_IOPAD(0x0228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */ + AM62X_IOPAD(0x0224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */ + AM62X_IOPAD(0x0240, PIN_INPUT, 7) /* (D17) MMC1_SDCD.GPIO1_48 */ + >; + }; + + wifi_pins_default: wifi-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0120, PIN_INPUT, 0) /* (C24) MMC2_CMD */ + AM62X_IOPAD(0x0118, PIN_INPUT, 0) /* (D25) MMC2_CLK */ + AM62X_IOPAD(0x0114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */ + AM62X_IOPAD(0x0110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */ + AM62X_IOPAD(0x010c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */ + AM62X_IOPAD(0x0108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */ + AM62X_IOPAD(0x0124, PIN_INPUT, 0) /* (A23) MMC2_SDCD */ + AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */ + >; + }; + + wifi_en_pins_default: wifi-en-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x009c, PIN_OUTPUT, 7) /* (V25) GPMC0_WAIT1.GPIO0_38 */ + >; + }; + + wifi_wlirq_pins_default: wifi-wlirq-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x00a8, PIN_INPUT, 7) /* (M21) GPMC0_CSn0.GPIO0_41 */ + >; + }; + + spe_pins_default: spe-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0168, PIN_INPUT, 1) /* (AE21) RGMII2_TXC.RMII2_CRS_DV */ + AM62X_IOPAD(0x0180, PIN_INPUT, 1) /* (AD23) RGMII2_RXC.RMII2_REF_CLK */ + AM62X_IOPAD(0x0184, PIN_INPUT, 1) /* (AE23) RGMII2_RD0.RMII2_RXD0 */ + AM62X_IOPAD(0x0188, PIN_INPUT, 1) /* (AB20) RGMII2_RD1.RMII2_RXD1 */ + AM62X_IOPAD(0x017c, PIN_INPUT, 1) /* (AD22) RGMII2_RX_CTL.RMII2_RX_ER */ + AM62X_IOPAD(0x016c, PIN_INPUT, 1) /* (Y18) RGMII2_TD0.RMII2_TXD0 */ + AM62X_IOPAD(0x0170, PIN_INPUT, 1) /* (AA18) RGMII2_TD1.RMII2_TXD1 */ + AM62X_IOPAD(0x0164, PIN_INPUT, 1) /* (AA19) RGMII2_TX_CTL.RMII2_TX_EN */ + AM62X_IOPAD(0x018c, PIN_OUTPUT, 7) /* (AC21) RGMII2_RD2.GPIO1_5 */ + AM62X_IOPAD(0x0190, PIN_INPUT, 7) /* (AE22) RGMII2_RD3.GPIO1_6 */ + AM62X_IOPAD(0x01f0, PIN_OUTPUT, 5) /* (A18) EXT_REFCLK1.CLKOUT0 */ + >; + }; + + mikrobus_i2c_pins_default: mikrobus-i2c-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01d0, PIN_INPUT_PULLUP, 2) /* (A15) UART0_CTSn.I2C3_SCL */ + AM62X_IOPAD(0x01d4, PIN_INPUT_PULLUP, 2) /* (B15) UART0_RTSn.I2C3_SDA */ + >; + }; + + mikrobus_uart_pins_default: mikrobus-uart-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01d8, PIN_INPUT, 1) /* (C15) MCAN0_TX.UART5_RXD */ + AM62X_IOPAD(0x01dc, PIN_OUTPUT, 1) /* (E15) MCAN0_RX.UART5_TXD */ + >; + }; + + mikrobus_spi_pins_default: mikrobus-spi-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01b0, PIN_INPUT, 1) /* (A20) MCASP0_ACLKR.SPI2_CLK */ + AM62X_IOPAD(0x01ac, PIN_INPUT, 1) /* (E19) MCASP0_AFSR.SPI2_CS0 */ + AM62X_IOPAD(0x0194, PIN_INPUT, 1) /* (B19) MCASP0_AXR3.SPI2_D0 */ + AM62X_IOPAD(0x0198, PIN_INPUT, 1) /* (A19) MCASP0_AXR2.SPI2_D1 */ + >; + }; + + mikrobus_gpio_pins_default: mikrobus-gpio-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x019c, PIN_INPUT, 7) /* (B18) MCASP0_AXR1.GPIO1_9 */ + AM62X_IOPAD(0x01a0, PIN_INPUT, 7) /* (E18) MCASP0_AXR0.GPIO1_10 */ + AM62X_IOPAD(0x01a8, PIN_INPUT, 7) /* (D20) MCASP0_AFSX.GPIO1_12 */ + >; + }; + + console_pins_default: console-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01c8, PIN_INPUT, 0) /* (D14) UART0_RXD */ + AM62X_IOPAD(0x01cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ + >; + }; + + wifi_debug_uart_pins_default: wifi-debug-uart-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x001c, PIN_INPUT, 3) /* (J23) OSPI0_D4.UART6_RXD */ + AM62X_IOPAD(0x0020, PIN_OUTPUT, 3) /* (J25) OSPI0_D5.UART6_TXD */ + >; + }; + + usb1_pins_default: usb1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x0258, PIN_INPUT, 0) /* (F18) USB1_DRVVBUS */ + >; + }; + + pmic_irq_pins_default: pmic-irq-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01f4, PIN_INPUT_PULLUP, 0) /* (D16) EXTINTn */ + >; + }; +}; + +&mcu_pmx0 { + i2c_qwiic_pins_default: i2c-qwiic-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0044, PIN_INPUT, 0) /* (A8) MCU_I2C0_SCL */ + AM62X_MCU_IOPAD(0x0048, PIN_INPUT, 0) /* (D10) MCU_I2C0_SDA */ + >; + }; + + gbe_pmx_obsclk: gbe-pmx-clk-default { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0004, PIN_OUTPUT, 1) /* (B8) MCU_SPI0_CS1.MCU_OBSCLK0 */ + >; + }; + + i2c_csi_pins_default: i2c-csi-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x004c, PIN_INPUT_PULLUP, 0) /* (B9) WKUP_I2C0_SCL */ + AM62X_MCU_IOPAD(0x0050, PIN_INPUT_PULLUP, 0) /* (A9) WKUP_I2C0_SDA */ + >; + }; + + wifi_32k_clk: mcu-clk-out-default-pins { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x0084, PIN_OUTPUT, 0) /* (A12) WKUP_CLKOUT0 */ + >; + }; +}; + +&a53_opp_table { + /* Requires VDD_CORE to be at 0.85V */ + opp-1400000000 { + opp-hz = /bits/ 64 <1400000000>; + opp-supported-hw = <0x01 0x0004>; + }; +}; + +&wkup_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c_csi_pins_default>; + clock-frequency = <400000>; + /* Enable with overlay for camera sensor */ +}; + +&mcu_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c_qwiic_pins_default>; + clock-frequency = <100000>; + status = "okay"; +}; + +&usbss0 { + ti,vbus-divider; + status = "okay"; +}; + +&usb0 { + dr_mode = "peripheral"; +}; + +&usbss1 { + ti,vbus-divider; + status = "okay"; +}; + +&usb1 { + dr_mode = "host"; + pinctrl-names = "default"; + pinctrl-0 = <&usb1_pins_default>; +}; + +&cpsw3g { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii1_pins_default>, <&spe_pins_default>, + <&gbe_pmx_obsclk>; + assigned-clocks = <&k3_clks 157 70>, <&k3_clks 157 20>; + assigned-clock-parents = <&k3_clks 157 72>, <&k3_clks 157 22>; +}; + +&cpsw_port1 { + phy-mode = "rgmii-rxid"; + phy-handle = <&cpsw3g_phy0>; +}; + +&cpsw_port2 { + phy-mode = "rmii"; + phy-handle = <&cpsw3g_phy1>; +}; + +&cpsw3g_mdio { + /* Workaround for errata i2329 - Use mdio bitbang */ + status = "disabled"; +}; + +&main_gpio0 { + pinctrl-names = "default"; + pinctrl-0 = <&gpio0_pins_default>; + gpio-line-names = "BL_EN_3V3", "SPE_PO_EN", "RTC_INT", /* 0-2 */ + "USR0", "USR1", "USR2", "USR3", "", "", "USR4", /* 3-9 */ + "EEPROM_WP", /* 10 */ + "CSI2_CAMERA_GPIO1", "CSI2_CAMERA_GPIO2", /* 11-12 */ + "CC1352P7_BOOT", "CC1352P7_RSTN", "", "", "", /* 13-17 */ + "USR_BUTTON", "", "", "", "", "", "", "", "", /* 18-26 */ + "", "", "", "", "", "", "", "", "", "HDMI_INT", /* 27-36 */ + "", "VDD_WLAN_EN", "", "", "WL_IRQ", "GBE_INTN",/* 37-42 */ + "", "", "", "", "", "", "", "", "", "", "", "", /* 43-54 */ + "", "", "", "", "", "", "", "", "", "", "", "", /* 55-66 */ + "", "", "", "", "", "", "", "", "", "", "", "", /* 67-78 */ + "", "", "", "", "", "", /* 79-84 */ + "BITBANG_MDIO_DATA", "BITBANG_MDIO_CLK", /* 85-86 */ + "", "", "", "", ""; /* 87-91 */ +}; + +&main_gpio1 { + pinctrl-names = "default"; + pinctrl-0 = <&mikrobus_gpio_pins_default>; + gpio-line-names = "", "", "", "", "", /* 0-4 */ + "SPE_RSTN", "SPE_INTN", "MIKROBUS_GPIO1_7", /* 5-7 */ + "MIKROBUS_GPIO1_8", "MIKROBUS_GPIO1_9", /* 8-9 */ + "MIKROBUS_GPIO1_10", "MIKROBUS_GPIO1_11", /* 10-11 */ + "MIKROBUS_GPIO1_12", "MIKROBUS_W1_GPIO0", /* 12-13 */ + "MIKROBUS_GPIO1_14", /* 14 */ + "", "", "", "", "VDD_3V3_SD", "", "", /* 15-21 */ + "MIKROBUS_GPIO1_22", "MIKROBUS_GPIO1_23", /* 22-23 */ + "MIKROBUS_GPIO1_24", "MIKROBUS_GPIO1_25", /* 24-25 */ + "", "", "", "", "", "", "", "", "", "", "", "", /* 26-37 */ + "", "", "", "", "", "", "", "", "", "", /* 38-47 */ + "SD_CD", "SD_VOLT_SEL", "", ""; /* 48-51 */ +}; + +&main_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&local_i2c_pins_default>; + clock-frequency = <400000>; + status = "okay"; + + eeprom@50 { + compatible = "atmel,24c32"; + reg = <0x50>; + }; + + rtc: rtc@68 { + compatible = "ti,bq32000"; + reg = <0x68>; + interrupt-parent = <&main_gpio0>; + interrupts = <2 IRQ_TYPE_EDGE_FALLING>; + }; + + tps65219: pmic@30 { + compatible = "ti,tps65219"; + reg = <0x30>; + buck1-supply = <&vsys_5v0>; + buck2-supply = <&vsys_5v0>; + buck3-supply = <&vsys_5v0>; + ldo1-supply = <&vdd_3v3>; + ldo2-supply = <&buck2_reg>; + ldo3-supply = <&vdd_3v3>; + ldo4-supply = <&vdd_3v3>; + + pinctrl-names = "default"; + pinctrl-0 = <&pmic_irq_pins_default>; + interrupt-parent = <&gic500>; + interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <1>; + + system-power-controller; + ti,power-button; + + regulators { + buck1_reg: buck1 { + regulator-name = "VDD_CORE"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-boot-on; + regulator-always-on; + }; + + buck2_reg: buck2 { + regulator-name = "VDD_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + buck3_reg: buck3 { + regulator-name = "VDD_1V2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: ldo1 { + /* + * Regulator is left as is unused, vdd_sd + * is controlled via GPIO with bypass config + * as per the NVM configuration + */ + regulator-name = "VDD_SD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-allow-bypass; + regulator-boot-on; + regulator-always-on; + }; + + ldo2_reg: ldo2 { + regulator-name = "VDDA_0V85"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo3_reg: ldo3 { + regulator-name = "VDDA_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4_reg: ldo4 { + regulator-name = "VDD_2V5"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; + +&main_i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&grove_pins_default>; + clock-frequency = <100000>; + status = "okay"; +}; + +&main_i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_1v8_pins_default>; + clock-frequency = <100000>; + status = "okay"; +}; + +&main_i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&mikrobus_i2c_pins_default>; + clock-frequency = <400000>; + status = "okay"; +}; + +&main_spi2 { + pinctrl-names = "default"; + pinctrl-0 = <&mikrobus_spi_pins_default>; + status = "okay"; +}; + +&sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&emmc_pins_default>; + ti,driver-strength-ohm = <50>; + disable-wp; + status = "okay"; +}; + +&sdhci1 { + /* SD/MMC */ + pinctrl-names = "default"; + pinctrl-0 = <&sd_pins_default>; + + vmmc-supply = <&vdd_3v3_sd>; + vqmmc-supply = <&vdd_sd_dv>; + ti,driver-strength-ohm = <50>; + disable-wp; + cd-gpios = <&main_gpio1 48 GPIO_ACTIVE_LOW>; + cd-debounce-delay-ms = <100>; + ti,fails-without-test-cd; + status = "okay"; +}; + +&sdhci2 { + vmmc-supply = <&wlan_en>; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_pins_default>, <&wifi_32k_clk>; + bus-width = <4>; + non-removable; + ti,fails-without-test-cd; + cap-power-off-card; + keep-power-in-suspend; + ti,driver-strength-ohm = <50>; + assigned-clocks = <&k3_clks 157 158>; + assigned-clock-parents = <&k3_clks 157 160>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + wlcore: wlcore@2 { + compatible = "ti,wl1807"; + reg = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_wlirq_pins_default>; + interrupt-parent = <&main_gpio0>; + interrupts = <41 IRQ_TYPE_EDGE_FALLING>; + }; +}; + +&main_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&console_pins_default>; + status = "okay"; +}; + +&main_uart1 { + /* Main UART1 is used by TIFS firmware */ + status = "reserved"; +}; + +&main_uart5 { + pinctrl-names = "default"; + pinctrl-0 = <&mikrobus_uart_pins_default>; + status = "okay"; +}; + +&main_uart6 { + pinctrl-names = "default"; + pinctrl-0 = <&wifi_debug_uart_pins_default>; + status = "okay"; +}; diff --git a/arch/arm/dts/k3-am625-r5-beagleplay.dts b/arch/arm/dts/k3-am625-r5-beagleplay.dts new file mode 100644 index 000000000000..9c9d0570592a --- /dev/null +++ b/arch/arm/dts/k3-am625-r5-beagleplay.dts @@ -0,0 +1,86 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * https://beagleboard.org/play + * + * Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2022-2023 Robert Nelson, BeagleBoard.org Foundation + */ + +#include "k3-am625-beagleplay.dts" +#include "k3-am625-beagleplay-ddr4-1600MTs.dtsi" +#include "k3-am62-ddr.dtsi" + +#include "k3-am625-beagleplay-u-boot.dtsi" + +/ { + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a53_0; + }; + + a53_0: a53@0 { + compatible = "ti,am654-rproc"; + reg = <0x00 0x00a90000 0x00 0x10>; + power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 135 TI_SCI_PD_EXCLUSIVE>; + resets = <&k3_reset 135 0>; + clocks = <&k3_clks 61 0>; + assigned-clocks = <&k3_clks 61 0>, <&k3_clks 135 0>; + assigned-clock-parents = <&k3_clks 61 2>; + assigned-clock-rates = <200000000>, <1250000000>; + ti,sci = <&dmsc>; + ti,sci-proc-id = <32>; + ti,sci-host-id = <10>; + bootph-pre-ram; + }; + + dm_tifs: dm-tifs { + compatible = "ti,j721e-dm-sci"; + ti,host-id = <36>; + ti,secure-host; + mbox-names = "rx", "tx"; + mboxes= <&secure_proxy_main 22>, + <&secure_proxy_main 23>; + bootph-pre-ram; + }; +}; + +&dmsc { + mboxes= <&secure_proxy_main 0>, + <&secure_proxy_main 1>, + <&secure_proxy_main 0>; + mbox-names = "rx", "tx", "notify"; + ti,host-id = <35>; + ti,secure-host; +}; + +&mcu_esm { + bootph-pre-ram; +}; + +&secure_proxy_sa3 { + bootph-pre-ram; + /* We require this for boot handshake */ + status = "okay"; +}; + +&cbass_main { + sysctrler: sysctrler { + compatible = "ti,am654-system-controller"; + mboxes= <&secure_proxy_main 1>, <&secure_proxy_main 0>, <&secure_proxy_sa3 0>; + mbox-names = "tx", "rx", "boot_notify"; + bootph-pre-ram; + }; +}; + +&main_esm { + bootph-pre-ram; +}; + +&main_pktdma { + ti,sci = <&dm_tifs>; +}; + +&main_bcdma { + ti,sci = <&dm_tifs>; +}; diff --git a/board/ti/am62x/MAINTAINERS b/board/ti/am62x/MAINTAINERS index 105e741995ed..6ac4e65f5afc 100644 --- a/board/ti/am62x/MAINTAINERS +++ b/board/ti/am62x/MAINTAINERS @@ -6,3 +6,10 @@ F: board/ti/am62x/ F: include/configs/am62x_evm.h F: configs/am62x_evm_r5_defconfig F: configs/am62x_evm_a53_defconfig + +BEAGLEPLAY BOARD +M: Nishanth Menon nm@ti.com +M: Robert Nelson robertcnelson@gmail.com +M: Tom Rini trini@konsulko.com +S: Maintained +N: beagleplay
Add defconfig fragments for am625 based beagleplay and corresponding customized environment file for beagleplay.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- No major changes other than explicitly calling out script in the crafted bootmeths
V5: https://lore.kernel.org/r/20230824031101.3460411-17-nm@ti.com V4: https://lore.kernel.org/r/20230822184135.2328409-8-nm@ti.com V3: https://lore.kernel.org/all/20230815164440.2713726-4-nm@ti.com/ V2: https://lore.kernel.org/u-boot/20230727234446.3651836-4-nm@ti.com/ V1: https://lore.kernel.org/all/20230725185253.2123433-6-nm@ti.com/
board/ti/am62x/beagleplay.env | 19 ++++++++++ board/ti/am62x/beagleplay_a53.config | 55 ++++++++++++++++++++++++++++ board/ti/am62x/beagleplay_r5.config | 15 ++++++++ 3 files changed, 89 insertions(+) create mode 100644 board/ti/am62x/beagleplay.env create mode 100644 board/ti/am62x/beagleplay_a53.config create mode 100644 board/ti/am62x/beagleplay_r5.config
diff --git a/board/ti/am62x/beagleplay.env b/board/ti/am62x/beagleplay.env new file mode 100644 index 000000000000..4f0a94a8113e --- /dev/null +++ b/board/ti/am62x/beagleplay.env @@ -0,0 +1,19 @@ +#include <env/ti/ti_common.env> +#include <env/ti/default_findfdt.env> +#include <env/ti/mmc.env> + +name_kern=Image +console=ttyS2,115200n8 +args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 +run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr} +set_led_state_fail_load= led led-0 off; led led-1 on; + led led-2 off; led led-3 on; led led-4 off +set_led_state_start_load=led led-0 on; led led-1 off; + led led-2 on; led led-3 off; led led-4 on +boot=mmc +mmcdev=1 +bootpart=1:1 +bootdir=/boot +boot_targets=mmc1 mmc0 usb pxe +bootmeths=script extlinux efi pxe +rd_spec=- diff --git a/board/ti/am62x/beagleplay_a53.config b/board/ti/am62x/beagleplay_a53.config new file mode 100644 index 000000000000..f0380416cc5e --- /dev/null +++ b/board/ti/am62x/beagleplay_a53.config @@ -0,0 +1,55 @@ +# Defconfig fragment to apply on top of am62x_evm_a53_defconfig + +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-beagleplay" +CONFIG_OF_LIST="k3-am625-beagleplay" +CONFIG_SPL_OF_LIST="k3-am625-beagleplay" +CONFIG_BOOTCOMMAND="run set_led_state_start_load;run findfdt; run envboot; bootflow scan -lb;run set_led_state_fail_load" +CONFIG_EXT4_WRITE=y +CONFIG_LZO=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +# Use the Beagleplay env file +CONFIG_ENV_SOURCE_FILE="beagleplay" +# Do not use emmc boot - we will use FS only +CONFIG_SUPPORT_EMMC_BOOT=n +CONFIG_MMC_IO_VOLTAGE=y +# CONFIG_SPL_MMC_IO_VOLTAGE is not set +CONFIG_MMC_UHS_SUPPORT=y +# CONFIG_SPL_MMC_UHS_SUPPORT is not set +CONFIG_MMC_HS200_SUPPORT=y +# CONFIG_SPL_MMC_HS200_SUPPORT is not set +# Enable GPIO control +CONFIG_DM_GPIO=y +CONFIG_SPL_GPIO=y +CONFIG_DA8XX_GPIO=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPIO_READ=y +# Enable LEDs +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_SPL_LED=y +CONFIG_SPL_LED_GPIO=y +# Enable I2C bus +CONFIG_SPL_I2C=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_OMAP24XX=y +CONFIG_CMD_I2C=y +# Regulator +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_CMD_REGULATOR=y +CONFIG_DM_REGULATOR_TPS65219=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65219=y +CONFIG_CMD_PMIC=y +# Uses Realtek phy rather than TI phy +CONFIG_PHY_TI_DP83867=n +CONFIG_PHY_REALTEK=y +# No SPI flash on Beagleplay +CONFIG_SPI=n +CONFIG_SPI_FLASH=n +CONFIG_SPL_DM_SPI_FLASH=n +CONFIG_SPL_SPI_FLASH_SUPPORT=n diff --git a/board/ti/am62x/beagleplay_r5.config b/board/ti/am62x/beagleplay_r5.config new file mode 100644 index 000000000000..4ee0375a2a1d --- /dev/null +++ b/board/ti/am62x/beagleplay_r5.config @@ -0,0 +1,15 @@ +# Defconfig fragment to apply on top of: +# am62x_evm_r5_defconfig +# +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-r5-beagleplay" +CONFIG_OF_LIST="k3-am625-r5-beagleplay" +CONFIG_SPL_OF_LIST="k3-am625-r5-beagleplay" +# Do spl board init +CONFIG_SPL_BOARD_INIT=y +# Do not use emmc boot - we will use FS only +CONFIG_SUPPORT_EMMC_BOOT=n +# No SPI flash on Beagleplay +CONFIG_SPI=n +CONFIG_SPI_FLASH=n +CONFIG_SPL_DM_SPI_FLASH=n +CONFIG_SPL_SPI_FLASH_SUPPORT=n
Add base documentation for BeaglePlay
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com Signed-off-by: Nishanth Menon nm@ti.com --- Cc: Heinrich Schuchardt heinrich.schuchardt@canonical.com Since V5: - Updated to point at how to get serial console - Introduce on using sd card and some tips and tricks I personally learnt from others including trying to calm fears that U-Boot development is risky.
V5: https://lore.kernel.org/r/20230824031101.3460411-18-nm@ti.com V4: https://lore.kernel.org/r/20230822184135.2328409-9-nm@ti.com V3: https://lore.kernel.org/all/20230815164440.2713726-5-nm@ti.com/ V2: https://lore.kernel.org/u-boot/20230727234446.3651836-5-nm@ti.com/ V1: https://lore.kernel.org/all/20230725185253.2123433-7-nm@ti.com/
doc/board/ti/am62x_beagleplay.rst | 322 +++++++++++++ doc/board/ti/img/beagleplay_emmc.svg | 697 +++++++++++++++++++++++++++ doc/board/ti/k3.rst | 1 + 3 files changed, 1020 insertions(+) create mode 100644 doc/board/ti/am62x_beagleplay.rst create mode 100644 doc/board/ti/img/beagleplay_emmc.svg
diff --git a/doc/board/ti/am62x_beagleplay.rst b/doc/board/ti/am62x_beagleplay.rst new file mode 100644 index 000000000000..39913b29ab2c --- /dev/null +++ b/doc/board/ti/am62x_beagleplay.rst @@ -0,0 +1,322 @@ +.. SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +.. sectionauthor:: Nishanth Menon nm@ti.com + +AM62x Beagleboard.org Beagleplay +================================ + +Introduction: +------------- + +BeagleBoard.org BeaglePlay is an easy to use, affordable open source +hardware single board computer based on the Texas Instruments AM625 +SoC that allows you to create connected devices that work even at long +distances using IEEE 802.15.4g LR-WPAN and IEEE 802.3cg 10Base-T1L. +Expansion is provided over open standards based mikroBUS, Grove and +QWIIC headers among other interfaces. + +Further information can be found at: + +* Product Page: https://beagleplay.org/ +* Hardware documentation: https://git.beagleboard.org/beagleplay/beagleplay + +Boot Flow: +---------- +Below is the pictorial representation of boot flow: + +.. image:: img/boot_diagram_k3_current.svg + :alt: Boot flow diagram + +- On this platform, 'TI Foundational Security' (TIFS) functions as the + security enclave master while 'Device Manager' (DM), also known as the + 'TISCI server' in "TI terminology", offers all the essential services. + The A53 or M4F (Aux core) sends requests to TIFS/DM to accomplish these + services, as illustrated in the diagram above. + +Sources: +-------- +.. include:: k3.rst + :start-after: .. k3_rst_include_start_boot_sources + :end-before: .. k3_rst_include_end_boot_sources + +Build procedure: +---------------- +0. Setup the environment variables: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_desc + :end-before: .. k3_rst_include_end_common_env_vars_desc + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_board_env_vars_desc + :end-before: .. k3_rst_include_end_board_env_vars_desc + +Set the variables corresponding to this platform: + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_defn + :end-before: .. k3_rst_include_end_common_env_vars_defn +.. code-block:: bash + + $ export UBOOT_CFG_CORTEXR="am62x_evm_r5_defconfig beagleplay_r5.config" + $ export UBOOT_CFG_CORTEXA="am62x_evm_a53_defconfig beagleplay_a53.config" + $ export TFA_BOARD=lite + $ # we dont use any extra TFA parameters + $ unset TFA_EXTRA_ARGS + $ export OPTEE_PLATFORM=k3-am62x + $ export OPTEE_EXTRA_ARGS="CFG_WITH_SOFTWARE_PRNG=y" + +.. include:: am62x_sk.rst + :start-after: .. am62x_evm_rst_include_start_build_steps + :end-before: .. am62x_evm_rst_include_end_build_steps + +Target Images +-------------- +Copy the below images to an SD card and boot: + +* tiboot3-am62x-gp-evm.bin from R5 build as tiboot3.bin +* tispl.bin_unsigned from Cortex-A build as tispl.bin +* u-boot.img_unsigned from Cortex-A build as u-boot.img + +Image formats +------------- + +- tiboot3.bin + +.. image:: img/multi_cert_tiboot3.bin.svg + :alt: tiboot3.bin image format + +- tispl.bin + +.. image:: img/dm_tispl.bin.svg + :alt: tispl.bin image format + +Additional hardware for U-Boot development +------------------------------------------ + +* Serial Console is critical for U-Boot development on BeaglePlay. See + `BeaglePlay serial console documentation + https://docs.beagleboard.org/latest/boards/beagleplay/demos-and-tutorials/using-serial-console.html`_. +* uSD is preferred option over eMMC, and a SD/MMC reader will be needed. +* (optionally) JTAG is useful when working with very early stages of boot. + +Default storage options +----------------------- + +There are multiple storage media options on BeaglePlay, but primarily: + +* Onboard eMMC (default) - reliable, fast and meant for deployment use. +* SD/MMC card interface (hold 'USR' switch and power on) - Entirely + depends on the SD card quality. + +Flash to uSD card or how to deal with "bricked" Board +-------------------------------------------------------- + +When deploying or working on Linux, it's common to use the onboard +eMMC. However, avoiding the eMMC and using the uSD card is safer when +working with U-Boot. + +If you choose to hand format your own bootable uSD card, be +aware that it can be difficult. The following information +may be helpful, but remember that it is only sometimes +reliable, and partition options can cause issues. These +can potentially help: + +* https://git.ti.com/cgit/arago-project/tisdk-setup-scripts/tree/create-sdcard... +* https://elinux.org/Beagleboard:Expanding_File_System_Partition_On_A_microSD + +The simplest option is to start with a standard distribution +image like those in `BeagleBoard.org Distros Page +https://www.beagleboard.org/distros`_ and download a disk image for +BeaglePlay. Pick a 16GB+ uSD card to be on the safer side. + +With an SD/MMC Card reader and `Balena Etcher +https://etcher.balena.io/`_, having a functional setup in minutes is +a trivial matter, and it works on almost all Host Operating Systems. +Yes Windows users, Windows Subsystem for Linux(WSL) based development +with U-Boot and update uSD card is practical. + +Updating U-Boot is a matter of copying the tiboot3.bin, tispl.bin and +u-boot.img to the "BOOT" partition of the uSD card. Remember to sync +and unmount (or Eject - depending on the Operating System) the uSD +card prior to physically removing from SD card reader. + +Also see following section on switch setting used for booting using +uSD card. + +.. note:: + Great news! If the board has not been damaged physically, there's no + need to worry about it being "bricked" on this platform. You only have + to flash an uSD card, plug it in, and reinstall the image on eMMC. This + means that even if you make a mistake, you can quickly fix it and rest + easy. + + If you are frequently working with uSD cards, you might find the + following useful: + + * `USB-SD-Mux https://www.linux-automation.com/en/products/usb-sd-mux.html`_ + * `SD-Wire https://wiki.tizen.org/SDWire`_ + +Flash to eMMC +------------- + +The eMMC layout selected is user-friendly for developers. The +boot hardware partition of the eMMC only contains the fixed-size +tiboot3.bin image. This is because the contents of the boot partitions +need to run from the SoC's internal SRAM, which remains a fixed size +constant. The other components of the boot sequence, such as tispl.bin +and u-boot.img, are located in the /BOOT partition in the User Defined +Area (UDA) hardware partition of the eMMC. These components can vary +significantly in size. The choice of keeping tiboot3.bin in boot0 or +boot1 partition depends on A/B update requirements. + +.. image:: img/beagleplay_emmc.svg + :alt: eMMC partitions and boot file organization for BeaglePlay + +The following are the steps from Linux shell to program eMMC: + +.. code-block:: bash + + # # Enable Boot0 boot + # mmc bootpart enable 1 2 /dev/mmcblk0 + # mmc bootbus set single_backward x1 x8 /dev/mmcblk0 + # mmc hwreset enable /dev/mmcblk0 + + # # Clear eMMC boot0 + # echo '0' >> /sys/class/block/mmcblk0boot0/force_ro + # dd if=/dev/zero of=/dev/mmcblk0boot0 count=32 bs=128k + # # Write tiboot3.bin + # dd if=tiboot3.bin of=/dev/mmcblk0boot0 bs=128k + + # # Copy the rest of the boot binaries + # mount /dev/mmcblk0p1 /boot/firmware + # cp tispl.bin /boot/firmware + # cp u-boot.img /boot/firmware + # sync + +.. warning :: + + U-Boot is configured to prioritize booting from an SD card if it + detects a valid boot partition and boot files on it, even if the + system initially booted from eMMC. The boot order is set as follows: + + * SD/MMC + * eMMC + * USB + * PXE + +LED patterns during boot +------------------------ + +.. list-table:: USR LED status indication + :widths: 16 16 + :header-rows: 1 + + * - USR LEDs (012345) + - Indicates + + * - 00000 + - Boot failure or R5 image not started up + + * - 11111 + - A53 SPL/U-boot has started up + + * - 10101 + - OS boot process has been initiated + + * - 01010 + - OS boot process failed and drops to U-Boot shell + +.. note :: + + In the table above, 0 indicates LED switched off and 1 indicates LED + switched ON. + +.. warning :: + + If the "red" power LED is not glowing, the system power supply is not + functional. Please refer to `BeaglePlay documentation + https://beagleplay.org/`_ for further information. + +A53 SPL DDR Memory Layout +------------------------- + +.. include:: am62x_sk.rst + :start-after: .. am62x_evm_rst_include_start_ddr_mem_layout + :end-before: .. am62x_evm_rst_include_end_ddr_mem_layout + +Switch Setting for Boot Mode +---------------------------- + +The boot time option is configured via "USR" button on the board. +See `Beagleplay Schematics https://git.beagleboard.org/beagleplay/beagleplay/-/blob/main/BeaglePlay_sch.pdf`_ +for details. + +.. list-table:: Boot Modes + :widths: 16 16 16 + :header-rows: 1 + + * - USR Switch Position + - Primary Boot + - Secondary Boot + + * - Not Pressed + - eMMC + - UART + + * - Pressed + - SD/MMC File System (FS) mode + - USB Device Firmware Upgrade (DFU) mode + +To switch to SD card boot mode, hold the USR button while powering on +with Type-C power supply, then release when power LED lights up. + +Debugging U-Boot +---------------- + +See :ref:`Common Debugging environment - OpenOCD<k3_rst_refer_openocd>`: for +detailed setup and debugging information. + +.. warning:: + + **OpenOCD support since**: v0.12.0 + + If the default package version of OpenOCD in your development + environment's distribution needs to be updated, it might be necessary to + build OpenOCD from the source. + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_openocd_connect_tag_connect + :end-before: .. k3_rst_include_end_openocd_connect_tag_connect + +.. include:: k3.rst + :start-after: .. k3_rst_include_start_openocd_cfg_external_intro + :end-before: .. k3_rst_include_end_openocd_cfg_external_intro + +For example, with BeaglePlay (AM62X platform), the openocd_connect.cfg: + +.. code-block:: tcl + + # TUMPA example: + # http://www.tiaowiki.com/w/TIAO_USB_Multi_Protocol_Adapter_User%27s_Manual + source [find interface/ftdi/tumpa.cfg] + + transport select jtag + + # default JTAG configuration has only SRST and no TRST + reset_config srst_only srst_push_pull + + # delay after SRST goes inactive + adapter srst delay 20 + + if { ![info exists SOC] } { + # Set the SoC of interest + set SOC am625 + } + + source [find target/ti_k3.cfg] + + ftdi tdo_sample_edge falling + + # Speeds for FT2232H are in multiples of 2, and 32MHz is tops + # max speed we seem to achieve is ~20MHz.. so we pick 16MHz + adapter speed 16000 diff --git a/doc/board/ti/img/beagleplay_emmc.svg b/doc/board/ti/img/beagleplay_emmc.svg new file mode 100644 index 000000000000..c6ff19b77384 --- /dev/null +++ b/doc/board/ti/img/beagleplay_emmc.svg @@ -0,0 +1,697 @@ +<?xml version="1.0" encoding="UTF-8" standalone="no"?> +<!--SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause--> + +<!--Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/--> + +<svg + version="1.1" + width="771px" + height="351px" + viewBox="-0.5 -0.5 771 351" + id="svg142" + sodipodi:docname="beagleplay_emmc.svg" + inkscape:version="1.1.2 (0a00cf5339, 2022-02-04)" + xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape" + xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd" + xmlns:xlink="http://www.w3.org/1999/xlink" + xmlns="http://www.w3.org/2000/svg" + xmlns:svg="http://www.w3.org/2000/svg" + xmlns:xhtml="http://www.w3.org/1999/xhtml%22%3E + <sodipodi:namedview + id="namedview144" + pagecolor="#ffffff" + bordercolor="#666666" + borderopacity="1.0" + inkscape:pageshadow="2" + inkscape:pageopacity="0.0" + inkscape:pagecheckerboard="0" + showgrid="false" + inkscape:zoom="1.460441" + inkscape:cx="380.0222" + inkscape:cy="175.28952" + inkscape:window-width="3440" + inkscape:window-height="1416" + inkscape:window-x="0" + inkscape:window-y="0" + inkscape:window-maximized="1" + inkscape:current-layer="g18" /> + <defs + id="defs2" /> + <g + id="g132"> + <rect + x="90" + y="0" + width="120" + height="60" + fill="rgb(255, 255, 255)" + stroke="rgb(0, 0, 0)" + pointer-events="all" + id="rect4" /> + <rect + x="210" + y="0" + width="120" + height="60" + fill="rgb(255, 255, 255)" + stroke="rgb(0, 0, 0)" + pointer-events="all" + id="rect6" /> + <rect + x="330" + y="0" + width="120" + height="60" + fill="rgb(255, 255, 255)" + stroke="rgb(0, 0, 0)" + pointer-events="all" + id="rect8" /> + <rect + x="450" + y="0" + width="320" + height="60" + fill="rgb(255, 255, 255)" + stroke="rgb(0, 0, 0)" + pointer-events="all" + id="rect10" /> + <rect + x="120" + y="15" + width="60" + height="30" + fill="none" + stroke="none" + pointer-events="all" + id="rect12" /> + <g + transform="translate(-0.5 -0.5)" + id="g18"> + <switch + id="switch16"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 58px; height: 1px; padding-top: 30px; margin-left: 121px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">Boot0</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="150" + y="34" + fill="#000000" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text14">Boot0</text> + </switch> + </g> + <rect + x="240" + y="15" + width="60" + height="30" + fill="none" + stroke="none" + pointer-events="all" + id="rect20" /> + <g + transform="translate(-0.5 -0.5)" + id="g26"> + <switch + id="switch24"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 58px; height: 1px; padding-top: 30px; margin-left: 241px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">Boot1</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="270" + y="34" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text22">Boot1</text> + </switch> + </g> + <rect + x="360" + y="15" + width="60" + height="30" + fill="none" + stroke="none" + pointer-events="all" + id="rect28" /> + <g + transform="translate(-0.5 -0.5)" + id="g34"> + <switch + id="switch32"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 58px; height: 1px; padding-top: 30px; margin-left: 361px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">RPMB</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="390" + y="34" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text30">RPMB</text> + </switch> + </g> + <rect + x="480" + y="15" + width="280" + height="30" + fill="none" + stroke="none" + pointer-events="all" + id="rect36" /> + <g + transform="translate(-0.5 -0.5)" + id="g42"> + <switch + id="switch40"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 278px; height: 1px; padding-top: 30px; margin-left: 481px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">User Defined Area (UDA)</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="620" + y="34" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text38">User Defined Area (UDA)</text> + </switch> + </g> + <rect + x="450" + y="60" + width="70" + height="60" + rx="9" + ry="9" + fill="rgb(255, 255, 255)" + stroke="rgb(0, 0, 0)" + pointer-events="all" + id="rect44" /> + <g + transform="translate(-0.5 -0.5)" + id="g50"> + <switch + id="switch48"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 68px; height: 1px; padding-top: 90px; margin-left: 451px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">BOOT</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="485" + y="94" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text46">BOOT</text> + </switch> + </g> + <rect + x="520" + y="60" + width="120" + height="60" + rx="9" + ry="9" + fill="rgb(255, 255, 255)" + stroke="rgb(0, 0, 0)" + pointer-events="all" + id="rect52" /> + <g + transform="translate(-0.5 -0.5)" + id="g58"> + <switch + id="switch56"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 118px; height: 1px; padding-top: 90px; margin-left: 521px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">rootfs</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="580" + y="94" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text54">rootfs</text> + </switch> + </g> + <rect + x="700" + y="60" + width="70" + height="60" + rx="9" + ry="9" + fill="rgb(255, 255, 255)" + stroke="rgb(0, 0, 0)" + pointer-events="all" + id="rect60" /> + <g + transform="translate(-0.5 -0.5)" + id="g66"> + <switch + id="switch64"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 68px; height: 1px; padding-top: 90px; margin-left: 701px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">swap</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="735" + y="94" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text62">swap</text> + </switch> + </g> + <rect + x="640" + y="60" + width="60" + height="60" + rx="9" + ry="9" + fill="rgb(255, 255, 255)" + stroke="rgb(0, 0, 0)" + pointer-events="all" + id="rect68" /> + <g + transform="translate(-0.5 -0.5)" + id="g74"> + <switch + id="switch72"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 58px; height: 1px; padding-top: 90px; margin-left: 641px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">...</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="670" + y="94" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text70">...</text> + </switch> + </g> + <path + d="M 130 130 L 180 130 L 180 180 L 100 180 L 100 160 Z" + fill="#ffe6cc" + stroke="#d79b00" + stroke-miterlimit="10" + pointer-events="all" + id="path76" /> + <g + transform="translate(-0.5 -0.5)" + id="g82"> + <switch + id="switch80"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 78px; height: 1px; padding-top: 155px; margin-left: 101px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">tiboot3.bin</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="140" + y="159" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text78">tiboot3.bin</text> + </switch> + </g> + <path + d="M 470 130 L 520 130 L 520 180 L 440 180 L 440 160 Z" + fill="#d5e8d4" + stroke="#82b366" + stroke-miterlimit="10" + pointer-events="all" + id="path84" /> + <g + transform="translate(-0.5 -0.5)" + id="g90"> + <switch + id="switch88"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 78px; height: 1px; padding-top: 155px; margin-left: 441px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">tispl.bin</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="480" + y="159" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text86">tispl.bin</text> + </switch> + </g> + <path + d="M 470 180 L 520 180 L 520 230 L 440 230 L 440 210 Z" + fill="#d5e8d4" + stroke="#82b366" + stroke-miterlimit="10" + pointer-events="all" + id="path92" /> + <g + transform="translate(-0.5 -0.5)" + id="g98"> + <switch + id="switch96"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 78px; height: 1px; padding-top: 205px; margin-left: 441px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">u-boot.img</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="480" + y="209" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text94">u-boot.img</text> + </switch> + </g> + <path + d="M 420 300 L 520 300 L 520 350 L 390 350 L 390 330 Z" + fill="#e1d5e7" + stroke="#9673a6" + stroke-miterlimit="10" + pointer-events="all" + id="path100" /> + <g + transform="translate(-0.5 -0.5)" + id="g106"> + <switch + id="switch104"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 128px; height: 1px; padding-top: 325px; margin-left: 391px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">extlinux/extlinux.conf</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="455" + y="329" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text102">extlinux/extlinux.conf</text> + </switch> + </g> + <path + d="M 420 240 L 520 240 L 520 290 L 390 290 L 390 270 Z" + fill="#dae8fc" + stroke="#6c8ebf" + stroke-miterlimit="10" + pointer-events="all" + id="path108" /> + <g + transform="translate(-0.5 -0.5)" + id="g114"> + <switch + id="switch112"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 128px; height: 1px; padding-top: 265px; margin-left: 391px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">uEnv.txt / boot.scr<xhtml:br /> +(optional)</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="455" + y="269" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text110">uEnv.txt / boot.scr...</text> + </switch> + </g> + <rect + x="0" + y="15" + width="60" + height="30" + fill="none" + stroke="none" + pointer-events="all" + id="rect116" /> + <g + transform="translate(-0.5 -0.5)" + id="g122"> + <switch + id="switch120"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 58px; height: 1px; padding-top: 30px; margin-left: 1px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">eMMC<xhtml:br /> +hardware partitions</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="30" + y="34" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text118">eMMC...</text> + </switch> + </g> + <rect + x="365" + y="75" + width="60" + height="30" + fill="none" + stroke="none" + pointer-events="all" + id="rect124" /> + <g + transform="translate(-0.5 -0.5)" + id="g130"> + <switch + id="switch128"> + <foreignObject + pointer-events="none" + width="100%" + height="100%" + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + style="overflow: visible; text-align: left;"> + <xhtml:div + style="display: flex; align-items: unsafe center; justify-content: unsafe center; width: 58px; height: 1px; padding-top: 90px; margin-left: 366px;"> + <xhtml:div + data-drawio-colors="color: rgb(0, 0, 0); " + style="box-sizing: border-box; font-size: 0px; text-align: center;"> + <xhtml:div + style="display: inline-block; font-size: 12px; font-family: Helvetica; color: rgb(0, 0, 0); line-height: 1.2; pointer-events: all; white-space: normal; overflow-wrap: normal;">UDA partitions</xhtml:div> + </xhtml:div> + </xhtml:div> + </foreignObject> + <text + x="395" + y="94" + fill="rgb(0, 0, 0)" + font-family="Helvetica" + font-size="12px" + text-anchor="middle" + id="text126">UDA partit...</text> + </switch> + </g> + </g> + <switch + id="switch140"> + <g + requiredFeatures="http://www.w3.org/TR/SVG11/feature#Extensibility" + id="g134" /> + <a + transform="translate(0,-5)" + xlink:href="https://www.diagrams.net/doc/faq/svg-export-text-problems" + target="_blank" + id="a138"> + <text + text-anchor="middle" + font-size="10px" + x="50%" + y="100%" + id="text136">Text is not SVG - cannot display</text> + </a> + </switch> +</svg> diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index 5f9bd4dfcbe9..ef31ccd12a42 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -30,6 +30,7 @@ K3 Based SoCs .. toctree:: :maxdepth: 1
+ am62x_beagleplay am62x_sk ../toradex/verdin-am62 am64x_evm
On ven., août 25, 2023 at 13:02, Nishanth Menon nm@ti.com wrote:
Alright, 6th time is a charm ;) Hopefully this takes care of all the un-addressed concerns we have had. Thanks all for pitching in, reviewing and improving and I will stop finding things to cleanup (promise).
Baseline: 7c6b18fb5494 (origin/next) Merge branch '2023-08-24-enable-more-features-in-qemu-arm' into next Full series available: https://github.com/nmenon/fix-k3-dt-u-boot/commits/beagleplay-v6 Boot Logs: https://gist.github.com/nmenon/8be4106e2d0b572aa5e77d93476095b4
Caveats:
- Networking: pending https://lore.kernel.org/all/20230822121350.51324-1-rogerq@kernel.org/
- 32kclk and usb: pending: https://lore.kernel.org/u-boot/20230725185253.2123433-4-nm@ti.com/ OR https://github.com/nmenon/fix-k3-dt-u-boot/commit/853b29d63c1ca642be316f1afb... being properly resolved (NOTE: without this patch, wlan is broken in Linux as the 32kclk from SoC is incorrectly supplied to wlan as 25MHz)
- There seems to be a bug in Linux kernel with sdhci that seems to depend on u-boot initialization of sdhci for functionality (TI internal actions already triggered).
- buildman discussion about config fragments: https://lore.kernel.org/all/CAPnjgZ14CUVt=rM943hh9PQUhK9LJDgZYPxUsATYQe3wwOU...
- Documentation that we can copy paste: https://lore.kernel.org/all/20230824154036.3650607-1-nm@ti.com/ and followon in kernel.org: https://lore.kernel.org/all/149528e1-062b-ebed-aa25-d37be5fe5894@iogearbox.n... if it all percolates back down to u-boot tree, should be trivial cleanup.
- Build fails with binman implementation for TI SoCs - Neha will take care of https://lore.kernel.org/all/227d74cf-9e95-4f5f-af96-49d054cde7aa@ti.com/
- This series picks up Jan's patch for working around Device Manager not compliant with EFI specification reqs and applies it to am62x_sk (TI internal action already triggered) https://lore.kernel.org/all/20230825011623.c74qqidp6wgvc5kl@plaza/
- I noticed that when drivers like the am654_sdhci.c uses deffered_probe, the default probe function does'nt fail https://source.denx.de/u-boot/u-boot/-/blob/master/boot/bootflow.c#L279 So ends up attempting for each of the boot_targets even if mmc dev dev_id would fail. Not really sure how to solve it, so will leave it here. (the https://gist.github.com/nmenon/8be4106e2d0b572aa5e77d93476095b4#file-beaglep... should show a bunch of 'MMC: no card present' each of which costs around 1 second.
Changes since V5:
- New patches to clean up mmc.env to sync with BOOTSTD operations yet enable easier non-U-Boot developer experience for uEnv.txt and optimize access to non-plugged in sd-card.
- Picked up Jan's patch[1] as part of this series.
- Introduced default_findfdt.env as review comment
- Saw Simon's feedback on uSD boot, and documented that as well, will be good for new devs to have that info in one flow.
- Quick overall diff: https://gist.github.com/nmenon/6d934f4e1092aa293a771d26b0f2bff7
V5: https://lore.kernel.org/all/20230824031101.3460411-1-nm@ti.com/ V4: https://lore.kernel.org/all/20230822184135.2328409-1-nm@ti.com/ V3: https://lore.kernel.org/all/20230815164440.2713726-1-nm@ti.com/ V2: https://lore.kernel.org/u-boot/20230727234446.3651836-1-nm@ti.com/ V1: https://lore.kernel.org/all/20230725185253.2123433-1-nm@ti.com/
Jan Kiszka (1): configs: am62x_evm_a53_defconfig: Disable semi-functional PSCI reset support
Nishanth Menon (18): include: env: ti: mmc: envboot/mmcboot: Check result of mmc dev before proceeding include: env: ti: mmc: envboot: Only attempt boot.scr if BOOTSTD is not enabled include: configs: ti_armv7_common: Add documentation for protected section include: configs: am62x_evm: Drop unused SDRAM address include: configs: am62x_evm: Wrap distroboot with CONFIG_DISTRO_DEFAULTS board: ti: am62x: am62x.env: Add explicit boot_targets configs: am62x_evm_a53_defconfig: Switch to bootstd include: configs: am62x_evm: Drop distro_bootcmd usage include: env: ti: ti_armv7_common.env: Rename to ti_common.env include: env: ti: Add a generic default_findfdt.env board: ti: am62x: am62x.env: Use default findfdt arm: mach-k3: am625_init: Use IS_ENABLED() arm: mach-k3: am625_init: Convert rtc_erratumi2327_init to static configs: am62x_evm*: Enable EMMC_BOOT configuration arm: mach-k3: am625: Add support for UDA FS arm: dts: k3-am625-sk-binman: Add labels for unsigned binary board: ti: am62x: Add am62x_beagleplay_* defconfigs and env file doc: board: ti: Add BeaglePlay documentation
Robert Nelson (1): arm: dts: Add k3-am625-beagleplay
I re-tested v6.
Using baseline 11cf91f755c7 ("Merge branch '2023-08-26-bootstd-chromeos-impreovements-and-move-to-gcc-13.2' into next") I could boot all the way to U-boot proper shell.
And the LEDs work for me as well with:
=> led led-0 toggle
So for the whole series:
Note that I did not tried any boot related commands since I mostly work on Android booting and I have not rebased my wip-branch yet.
arch/arm/dts/Makefile | 2 + .../dts/k3-am625-beagleplay-ddr4-1600MTs.dtsi | 2195 +++++++++++++++++ arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 195 ++ arch/arm/dts/k3-am625-beagleplay.dts | 758 ++++++ arch/arm/dts/k3-am625-r5-beagleplay.dts | 86 + arch/arm/dts/k3-am625-sk-binman.dtsi | 4 +- arch/arm/mach-k3/am625_init.c | 49 +- board/siemens/iot2050/iot2050.env | 2 +- board/ti/am62ax/am62ax.env | 2 +- board/ti/am62x/MAINTAINERS | 7 + board/ti/am62x/am62x.env | 8 +- board/ti/am62x/beagleplay.env | 19 + board/ti/am62x/beagleplay_a53.config | 55 + board/ti/am62x/beagleplay_r5.config | 15 + board/ti/am64x/am64x.env | 2 +- board/ti/am65x/am65x.env | 2 +- board/ti/j721e/j721e.env | 2 +- board/ti/j721s2/j721s2.env | 2 +- board/ti/ks2_evm/k2e_evm.env | 2 +- board/ti/ks2_evm/k2g_evm.env | 2 +- board/ti/ks2_evm/k2hk_evm.env | 2 +- board/ti/ks2_evm/k2l_evm.env | 2 +- configs/am62x_evm_a53_defconfig | 7 +- configs/am62x_evm_r5_defconfig | 1 + doc/board/ti/am62x_beagleplay.rst | 322 +++ doc/board/ti/img/beagleplay_emmc.svg | 697 ++++++ doc/board/ti/k3.rst | 1 + include/configs/am62x_evm.h | 6 - include/configs/ti_armv7_common.h | 2 +- include/env/ti/default_findfdt.env | 12 + include/env/ti/mmc.env | 12 +- .../ti/{ti_armv7_common.env => ti_common.env} | 0 32 files changed, 4419 insertions(+), 54 deletions(-) create mode 100644 arch/arm/dts/k3-am625-beagleplay-ddr4-1600MTs.dtsi create mode 100644 arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-beagleplay.dts create mode 100644 arch/arm/dts/k3-am625-r5-beagleplay.dts create mode 100644 board/ti/am62x/beagleplay.env create mode 100644 board/ti/am62x/beagleplay_a53.config create mode 100644 board/ti/am62x/beagleplay_r5.config create mode 100644 doc/board/ti/am62x_beagleplay.rst create mode 100644 doc/board/ti/img/beagleplay_emmc.svg create mode 100644 include/env/ti/default_findfdt.env rename include/env/ti/{ti_armv7_common.env => ti_common.env} (100%)
[1] https://lore.kernel.org/all/c93b19ed-43fe-44a2-9726-371fb9d2f825@web.de/
2.40.0
participants (6)
Alexander Sverdlin
Francesco Dolcini
Jan Kiszka
Mattijs Korpershoek
Nishanth Menon
