[U-Boot] [PATCH] Fix typo: commmand -> command.
Signed-off-by: Vagrant Cascadian vagrant@debian.org ---
doc/README.nand | 2 +- doc/README.update | 2 +- drivers/block/ahci.c | 4 ++-- drivers/block/fsl_sata.c | 2 +- include/configs/astro_mcf5373l.h | 2 +- 5 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/doc/README.nand b/doc/README.nand index 0ff5633..545d88c 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -94,7 +94,7 @@ Configuration Options: address of u-boot MTD partition in NAND.
CONFIG_CMD_NAND - Enables NAND support and commmands. + Enables NAND support and commands.
CONFIG_CMD_NAND_TORTURE Enables the torture command (see description of this command below). diff --git a/doc/README.update b/doc/README.update index eab124c..d37f2c4 100644 --- a/doc/README.update +++ b/doc/README.update @@ -51,7 +51,7 @@ the mkimage tool. dtc tool with support for binary includes, e.g. in version to be prepared. Refer to the doc/uImage.FIT/ directory for more details on FIT images.
-This mechanism can be also triggered by the commmand "fitupd". +This mechanism can be also triggered by the command "fitupd". If an optional, non-zero address is provided as argument, the TFTP transfer is skipped and the image at this address is used. The fitupd command is enabled by CONFIG_CMD_FITUPD. diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 1ad638e..734fdcc 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -818,7 +818,7 @@ static int ata_scsiop_read_capacity10(ccb *pccb) if (!ataid[pccb->target]) { printf("scsi_ahci: SCSI READ CAPACITY10 command failure. " "\tNo ATA info!\n" - "\tPlease run SCSI commmand INQUIRY firstly!\n"); + "\tPlease run SCSI command INQUIRY firstly!\n"); return -EPERM; }
@@ -847,7 +847,7 @@ static int ata_scsiop_read_capacity16(ccb *pccb) if (!ataid[pccb->target]) { printf("scsi_ahci: SCSI READ CAPACITY16 command failure. " "\tNo ATA info!\n" - "\tPlease run SCSI commmand INQUIRY firstly!\n"); + "\tPlease run SCSI command INQUIRY firstly!\n"); return -EPERM; }
diff --git a/drivers/block/fsl_sata.c b/drivers/block/fsl_sata.c index 208a0ae..e000ebf 100644 --- a/drivers/block/fsl_sata.c +++ b/drivers/block/fsl_sata.c @@ -398,7 +398,7 @@ static int fsl_ata_exec_ata_cmd(struct fsl_sata *sata, struct sata_fis_h2d *cfis debug("attribute = %08x\n\r", val32); cmd_hdr->attribute = cpu_to_le32(val32);
- /* Make sure cmd desc and cmd slot valid before commmand issue */ + /* Make sure cmd desc and cmd slot valid before command issue */ sync();
/* PMP*/ diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 8606151..828bc60 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -57,7 +57,7 @@ #define ENABLE_JFFS 1 #endif
-/* Define which commmands should be available at u-boot command prompt */ +/* Define which commands should be available at u-boot command prompt */
#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
On Tue, Nov 24, 2015 at 02:45:02PM -0800, Vagrant Cascadian wrote:
Signed-off-by: Vagrant Cascadian vagrant@debian.org Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Joe Hershberger
Vagrant Cascadian
