[U-Boot] [PATCH] MTD:NAND Enable nand lock, unlock feature
Enable nand lock, unlock and status of lock feature. Not every device and platform requires this, hence, it is under define for CONFIG_CMD_NAND_LOCK_UNLOCK
Nand unlock and status operate on block boundary instead of page boundary. Details in: http://www.micron.com/products/partdetail?part=MT29C2G24MAKLAJG-6%20IT
Intial solution provided by Vikram Pandita vikram.pandita@ti.com Includes preliminary suggestions from Scott Wood
Signed-off-by: Nishanth Menon nm@ti.com --- common/cmd_nand.c | 96 +++++++++++++++++++++-------------------- drivers/mtd/nand/nand_util.c | 79 +++++++++++++++++++---------------- 2 files changed, 92 insertions(+), 83 deletions(-)
diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 0a366d3..a240c37 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -164,6 +164,47 @@ out: return 0; }
+#ifdef CONFIG_CMD_NAND_LOCK_UNLOCK +static void print_status(ulong start, ulong end, ulong erasesize, int status) +{ + printf("%08lx - %08lx: %08lx blocks %s%s%s\n", + start, + end - 1, + (end - start) / erasesize, + ((status & NAND_LOCK_STATUS_TIGHT) ? "TIGHT " : ""), + ((status & NAND_LOCK_STATUS_LOCK) ? "LOCK " : ""), + ((status & NAND_LOCK_STATUS_UNLOCK) ? "UNLOCK " : "")); +} + +static void do_nand_status(nand_info_t *nand) +{ + ulong block_start = 0; + ulong off; + int last_status = -1; + + struct nand_chip *nand_chip = nand->priv; + /* check the WP bit */ + nand_chip->cmdfunc(nand, NAND_CMD_STATUS, -1, -1); + printf("device is %swrite protected\n", + (nand_chip->read_byte(nand) & 0x80 ? + "NOT " : "")); + + for (off = 0; off < nand->size; off += nand->erasesize) { + int s = nand_get_lock_status(nand, off); + + /* print message only if status has changed */ + if (s != last_status && off != 0) { + print_status(block_start, off, nand->erasesize, + last_status); + block_start = off; + } + last_status = s; + } + /* Print the last block info */ + print_status(block_start, off, nand->erasesize, last_status); +} +#endif + int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) { int i, dev, ret = 0; @@ -383,8 +424,9 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) return 1; }
+#ifdef CONFIG_CMD_NAND_LOCK_UNLOCK if (strcmp(cmd, "lock") == 0) { - int tight = 0; + int tight = 0; int status = 0; if (argc == 3) { if (!strcmp("tight", argv[2])) @@ -392,44 +434,8 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) if (!strcmp("status", argv[2])) status = 1; } -/* - * ! BROKEN ! - * - * TODO: must be implemented and tested by someone with HW - */ -#if 0 if (status) { - ulong block_start = 0; - ulong off; - int last_status = -1; - - struct nand_chip *nand_chip = nand->priv; - /* check the WP bit */ - nand_chip->cmdfunc (nand, NAND_CMD_STATUS, -1, -1); - printf("device is %swrite protected\n", - (nand_chip->read_byte(nand) & 0x80 ? - "NOT " : "")); - - for (off = 0; off < nand->size; off += nand->writesize) { - int s = nand_get_lock_status(nand, off); - - /* print message only if status has changed - * or at end of chip - */ - if (off == nand->size - nand->writesize - || (s != last_status && off != 0)) { - - printf("%08lx - %08lx: %8d pages %s%s%s\n", - block_start, - off-1, - (off-block_start)/nand->writesize, - ((last_status & NAND_LOCK_STATUS_TIGHT) ? "TIGHT " : ""), - ((last_status & NAND_LOCK_STATUS_LOCK) ? "LOCK " : ""), - ((last_status & NAND_LOCK_STATUS_UNLOCK) ? "UNLOCK " : "")); - } - - last_status = s; - } + do_nand_status(nand); } else { if (!nand_lock(nand, tight)) { puts("NAND flash successfully locked\n"); @@ -438,7 +444,6 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) return 1; } } -#endif return 0; }
@@ -446,12 +451,6 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) if (arg_off_size(argc - 2, argv + 2, nand, &off, &size) < 0) return 1;
-/* - * ! BROKEN ! - * - * TODO: must be implemented and tested by someone with HW - */ -#if 0 if (!nand_unlock(nand, off, size)) { puts("NAND flash successfully unlocked\n"); } else { @@ -459,9 +458,9 @@ int do_nand(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) "write and erase will probably fail\n"); return 1; } -#endif return 0; } +#endif
usage: printf("Usage:\n%s\n", cmdtp->usage); @@ -483,9 +482,12 @@ U_BOOT_CMD(nand, 5, 1, do_nand, "nand scrub - really clean NAND erasing bad blocks (UNSAFE)\n" "nand markbad off - mark bad block at offset (UNSAFE)\n" "nand biterr off - make a bit error at offset (UNSAFE)\n" +#ifdef CONFIG_CMD_NAND_LOCK_UNLOCK "nand lock [tight] [status]\n" " bring nand to lock state or display locked pages\n" - "nand unlock [offset] [size] - unlock section\n"); + "nand unlock [offset] [size] - unlock section\n" +#endif +);
static int nand_load_image(cmd_tbl_t *cmdtp, nand_info_t *nand, ulong offset, ulong addr, char *cmd) diff --git a/drivers/mtd/nand/nand_util.c b/drivers/mtd/nand/nand_util.c index 149af83..48507e5 100644 --- a/drivers/mtd/nand/nand_util.c +++ b/drivers/mtd/nand/nand_util.c @@ -238,7 +238,8 @@ static struct nand_ecclayout autoplace_ecclayout = { #endif
/* XXX U-BOOT XXX */ -#if 0 +#ifdef CONFIG_CMD_NAND_LOCK_UNLOCK + /****************************************************************************** * Support for locking / unlocking operations of some NAND devices *****************************************************************************/ @@ -253,7 +254,7 @@ static struct nand_ecclayout autoplace_ecclayout = { * nand_lock: Set all pages of NAND flash chip to the LOCK or LOCK-TIGHT * state * - * @param meminfo nand mtd instance + * @param mtd nand mtd instance * @param tight bring device in lock tight mode * * @return 0 on success, -1 in case of error @@ -270,21 +271,21 @@ static struct nand_ecclayout autoplace_ecclayout = { * calls will fail. It is only posible to leave lock-tight state by * an hardware signal (low pulse on _WP pin) or by power down. */ -int nand_lock(nand_info_t *meminfo, int tight) +int nand_lock(struct mtd_info *mtd, int tight) { int ret = 0; int status; - struct nand_chip *this = meminfo->priv; + struct nand_chip *chip = mtd->priv;
/* select the NAND device */ - this->select_chip(meminfo, 0); + chip->select_chip(mtd, 0);
- this->cmdfunc(meminfo, + chip->cmdfunc(mtd, (tight ? NAND_CMD_LOCK_TIGHT : NAND_CMD_LOCK), -1, -1);
/* call wait ready function */ - status = this->waitfunc(meminfo, this, FL_WRITING); + status = chip->waitfunc(mtd, chip);
/* see if device thinks it succeeded */ if (status & 0x01) { @@ -292,7 +293,7 @@ int nand_lock(nand_info_t *meminfo, int tight) }
/* de-select the NAND device */ - this->select_chip(meminfo, -1); + chip->select_chip(mtd, -1); return ret; }
@@ -300,7 +301,7 @@ int nand_lock(nand_info_t *meminfo, int tight) * nand_get_lock_status: - query current lock state from one page of NAND * flash * - * @param meminfo nand mtd instance + * @param mtd nand mtd instance * @param offset page address to query (muss be page aligned!) * * @return -1 in case of error @@ -311,19 +312,19 @@ int nand_lock(nand_info_t *meminfo, int tight) * NAND_LOCK_STATUS_UNLOCK: page unlocked * */ -int nand_get_lock_status(nand_info_t *meminfo, ulong offset) +int nand_get_lock_status(struct mtd_info *mtd, ulong offset) { int ret = 0; int chipnr; int page; - struct nand_chip *this = meminfo->priv; + struct nand_chip *chip = mtd->priv;
/* select the NAND device */ - chipnr = (int)(offset >> this->chip_shift); - this->select_chip(meminfo, chipnr); + chipnr = (int)(offset >> chip->chip_shift); + chip->select_chip(mtd, chipnr);
- if ((offset & (meminfo->writesize - 1)) != 0) { + if ((offset & (mtd->writesize - 1)) != 0) { printf ("nand_get_lock_status: " "Start address must be beginning of " "nand page!\n"); @@ -332,16 +333,16 @@ int nand_get_lock_status(nand_info_t *meminfo, ulong offset) }
/* check the Lock Status */ - page = (int)(offset >> this->page_shift); - this->cmdfunc(meminfo, NAND_CMD_LOCK_STATUS, -1, page & this->pagemask); + page = (int)(offset >> chip->page_shift); + chip->cmdfunc(mtd, NAND_CMD_LOCK_STATUS, -1, page & chip->pagemask);
- ret = this->read_byte(meminfo) & (NAND_LOCK_STATUS_TIGHT + ret = chip->read_byte(mtd) & (NAND_LOCK_STATUS_TIGHT | NAND_LOCK_STATUS_LOCK | NAND_LOCK_STATUS_UNLOCK);
out: /* de-select the NAND device */ - this->select_chip(meminfo, -1); + chip->select_chip(mtd, -1); return ret; }
@@ -349,59 +350,65 @@ int nand_get_lock_status(nand_info_t *meminfo, ulong offset) * nand_unlock: - Unlock area of NAND pages * only one consecutive area can be unlocked at one time! * - * @param meminfo nand mtd instance + * @param mtd nand mtd instance * @param start start byte address * @param length number of bytes to unlock (must be a multiple of * page size nand->writesize) * * @return 0 on success, -1 in case of error */ -int nand_unlock(nand_info_t *meminfo, ulong start, ulong length) +int nand_unlock(struct mtd_info *mtd, ulong start, ulong length) { int ret = 0; int chipnr; int status; int page; - struct nand_chip *this = meminfo->priv; + struct nand_chip *chip = mtd->priv; printf ("nand_unlock: start: %08x, length: %d!\n", (int)start, (int)length);
/* select the NAND device */ - chipnr = (int)(start >> this->chip_shift); - this->select_chip(meminfo, chipnr); + chipnr = (int)(start >> chip->chip_shift); + chip->select_chip(mtd, chipnr);
/* check the WP bit */ - this->cmdfunc(meminfo, NAND_CMD_STATUS, -1, -1); - if ((this->read_byte(meminfo) & 0x80) == 0) { + chip->cmdfunc(mtd, NAND_CMD_STATUS, -1, -1); + if (!(chip->read_byte(mtd) & NAND_STATUS_WP)) { printf ("nand_unlock: Device is write protected!\n"); ret = -1; goto out; }
- if ((start & (meminfo->writesize - 1)) != 0) { + if ((start & (mtd->erasesize - 1)) != 0) { printf ("nand_unlock: Start address must be beginning of " - "nand page!\n"); + "nand block!\n"); ret = -1; goto out; }
- if (length == 0 || (length & (meminfo->writesize - 1)) != 0) { - printf ("nand_unlock: Length must be a multiple of nand page " - "size!\n"); + if (length == 0 || (length & (mtd->erasesize - 1)) != 0) { + printf ("nand_unlock: Length must be a multiple of nand block " + "size %08x!\n", mtd->erasesize); ret = -1; goto out; }
+ /* + * Set length so that the last address is set to the + * starting address of the last block + */ + length -= mtd->erasesize; + /* submit address of first page to unlock */ - page = (int)(start >> this->page_shift); - this->cmdfunc(meminfo, NAND_CMD_UNLOCK1, -1, page & this->pagemask); + page = (int)(start >> chip->page_shift); + chip->cmdfunc(mtd, NAND_CMD_UNLOCK1, -1, page & chip->pagemask);
/* submit ADDRESS of LAST page to unlock */ - page += (int)(length >> this->page_shift) - 1; - this->cmdfunc(meminfo, NAND_CMD_UNLOCK2, -1, page & this->pagemask); + page += (int)(length >> chip->page_shift); + chip->cmdfunc(mtd, NAND_CMD_UNLOCK2, -1, page & chip->pagemask);
/* call wait ready function */ - status = this->waitfunc(meminfo, this, FL_WRITING); + status = chip->waitfunc(mtd, chip); /* see if device thinks it succeeded */ if (status & 0x01) { /* there was an error */ @@ -411,7 +418,7 @@ int nand_unlock(nand_info_t *meminfo, ulong start, ulong length)
out: /* de-select the NAND device */ - this->select_chip(meminfo, -1); + chip->select_chip(mtd, -1); return ret; } #endif
Applied to u-boot-nand-flash/next, thanks!
-Scott
Nishanth Menon
Scott Wood
