[U-Boot] [PATCH] 85xx: Drop FIT support to allow u-boot image to fit in 512k
The 36-bit build exceeds the 512k size we have. Removing FIT type image support allows us to fit and we dont really use it.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/P2020DS.h | 4 ---- 1 files changed, 0 insertions(+), 4 deletions(-)
diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index f4509bd..30a5a31 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -400,10 +400,6 @@ extern unsigned long calculate_board_ddr_clk(unsigned long dummy); #define CONFIG_OF_BOARD_SETUP 1 #define CONFIG_OF_STDOUT_VIA_ALIAS 1
-/* new uImage format support */ -#define CONFIG_FIT 1 -#define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ - /* I2C */ #define CONFIG_FSL_I2C /* Use FSL common I2C driver */ #define CONFIG_HARD_I2C /* I2C with hardware support */
Dear Kumar Gala,
In message 1268263008-31505-1-git-send-email-galak@kernel.crashing.org you wrote:
Applied directly to fix the curent build problem. Hope this is OK with you.
On Mar 11, 2010, at 5:27 PM, Wolfgang Denk wrote:
Dear Kumar Gala,
Yep, that was the idea :)
- k
Kumar Gala
