[PATCH] Convert CONFIG_MTD_CONCAT to Kconfig
This converts the following to Kconfig: CONFIG_MTD_CONCAT
Signed-off-by: Chris Packham judge.packham@gmail.com --- This touches octeontx_common.h but only to remove a line that is already commented out. Other than that etamin was the only board that had this enabled.
configs/etamin_defconfig | 1 + drivers/mtd/Kconfig | 8 ++++++++ include/configs/etamin.h | 1 - include/configs/octeontx_common.h | 1 - scripts/config_whitelist.txt | 1 - 5 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index ba7a0665dedb..34b9fff5ded2 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -87,6 +87,7 @@ CONFIG_SPL_SYS_I2C_LEGACY=y # CONFIG_SPL_DM_MMC is not set CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y +CONFIG_MTD_CONCAT=y CONFIG_MTD_RAW_NAND=y CONFIG_NAND_OMAP_ECCSCHEME_BCH16_CODE_HW=y CONFIG_SYS_NAND_BLOCK_SIZE=0x80000 diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index 588ebe9119b9..4088267dd111 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -22,6 +22,14 @@ config MTD_NOR_FLASH help Enable support for parallel NOR flash.
+config MTD_CONCAT + bool "Enable MTD device concatenation" + depends on MTD + help + Enable support for concatenating multiple physical MTD devices + into a single logical device. The larger logical device can then + be partitioned. + config SYS_MTDPARTS_RUNTIME bool "Allow MTDPARTS to be configured at runtime" depends on MTD diff --git a/include/configs/etamin.h b/include/configs/etamin.h index dc83ab71908b..9cf93924df93 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -151,7 +151,6 @@ #define ETAMIN_NAND_GPMC_CONFIG4 0x16051807 #define ETAMIN_NAND_GPMC_CONFIG5 0x00151e1e #define ETAMIN_NAND_GPMC_CONFIG6 0x16000f80 -#define CONFIG_MTD_CONCAT
/* Default env settings */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/octeontx_common.h b/include/configs/octeontx_common.h index bcf8b41cfb63..81dbff2d672f 100644 --- a/include/configs/octeontx_common.h +++ b/include/configs/octeontx_common.h @@ -64,7 +64,6 @@ /** EMMC specific defines */
#if defined(CONFIG_NAND_OCTEONTX) -/*#define CONFIG_MTD_CONCAT */ #define CONFIG_SYS_MAX_NAND_DEVICE 8 #endif
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 5b882b2670ca..cecdda678191 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -389,7 +389,6 @@ CONFIG_MMC_SUNXI_SLOT CONFIG_MONITOR_IS_IN_RAM CONFIG_MPC85XX_FEC CONFIG_MPC85XX_FEC_NAME -CONFIG_MTD_CONCAT CONFIG_MTD_NAND_VERIFY_WRITE CONFIG_MTD_PARTITION CONFIG_MVGBE_PORTS
Thanks, Stefan
+config MTD_CONCAT
- bool "Enable MTD device concatenation"
- depends on MTD
- help
be partitioned.
- config SYS_MTDPARTS_RUNTIME bool "Allow MTDPARTS to be configured at runtime" depends on MTD
Viele Grüße, Stefan Roese
Signed-off-by: Chris Packham judge.packham@gmail.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Stefan Roese sr@denx.de
Chris Packham
Stefan Roese
