[U-Boot] [PATCH] api: Disable api_net when DM is used
When CONFIG_API is selected with DM_ETH this error is present: api/api_net.c: In function 'dev_enum_net': api/api_net.c:61:35: warning: initialization from incompatible pointer type struct eth_device *eth_current = eth_get_dev(); ^ api/api_net.c:68:39: error: dereferencing pointer to incomplete type memcpy(di->di_net.hwaddr, eth_current->enetaddr, 6); ^ Disable api_net functions when ETH_DM is selected.
Signed-off-by: Chris Johns chrisj@rtems.org Signed-off-by: Michal Simek michal.simek@xilinx.com ---
api/api_net.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/api/api_net.c b/api/api_net.c index 04e4f4a44eff..67c291682a65 100644 --- a/api/api_net.c +++ b/api/api_net.c @@ -25,7 +25,7 @@ DECLARE_GLOBAL_DATA_PTR;
#define errf(fmt, args...) do { printf("ERROR @ %s(): ", __func__); printf(fmt, ##args); } while (0)
-#ifdef CONFIG_CMD_NET +#if defined(CONFIG_CMD_NET) && !defined(CONFIG_DM_ETH)
static int dev_valid_net(void *cookie) {
Michal Simek
