[U-Boot] [PATCH] mtd: nand: revive "nand scrub" command
Since commit ff94bc40af34 (mtd, ubi, ubifs: resync with Linux-3.14), the "nand scrub" command has not been working.
The scrub is a U-Boot extension and we have to modify nand_base.c that originates in Linux.
Mark the code with #ifdef __UBOOT__ so we will never accidentally drop it when we re-sync the NAND framework with Linux in the future.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Scott Wood scottwood@freescale.com Cc: Heiko Schocher hs@denx.de ---
drivers/mtd/nand/nand_base.c | 5 +++++ include/linux/mtd/mtd.h | 2 ++ 2 files changed, 7 insertions(+)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 70e780c..83bd033 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2905,8 +2905,13 @@ int nand_erase_nand(struct mtd_info *mtd, struct erase_info *instr, WATCHDOG_RESET();
/* Check if we have a bad block, we do not erase bad blocks! */ +#ifdef __UBOOT__ + if (!instr->scrub && nand_block_checkbad(mtd, ((loff_t) page) << + chip->page_shift, 0, allowbbt)) { +#else if (nand_block_checkbad(mtd, ((loff_t) page) << chip->page_shift, 0, allowbbt)) { +#endif pr_warn("%s: attempt to erase a bad block at page 0x%08x\n", __func__, page); instr->state = MTD_ERASE_FAILED; diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 8666413..2b4e218 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -52,7 +52,9 @@ struct erase_info { u_long priv; u_char state; struct erase_info *next; +#ifdef __UBOOT__ int scrub; +#endif };
struct mtd_erase_region_info {
No more "#ifdef __UBOOT__" please. Instead, never again do a "start from scratch" resync the way that the above commit was done.
-Scott
Do you happen to have a helpful suggestion how to clearly mark those bits of code then please ?
This was already discussed, no need to revive this topic here now.
Best regards, Marek Vasut
This was already discussed. :-)
See the archives for why I think this is bad.
Sorry, but these patches fixing breakages that resulted from that merge demonstrate that there is a need to revive it, if there's anyone that still thinks it's a good idea -- Heiko seemed to be in agreement that there's no need to do that for future syncs: http://lists.denx.de/pipermail/u-boot/2014-November/194256.html
-Scott
Hello Scott,
Am 11.12.2014 22:43, schrieb Scott Wood:
Yes, I hope a resync works now fine ... but I prefer to mark the differences between linux and u-boot somehow, because, you immediately see the differences between linux and u-boot, when you read the u-boot code ...
And this mark should not disturb the resync process, or?
bye, Heiko
On Fri, 12 Dec 2014 07:19:21 +0100 Heiko Schocher hs@denx.de wrote:
Hello Scott,
I agree with Heiko.
Best Regards Masahiro Yamada
Hello Scott,
I agree with Heiko.
I second that.
Hello Scott,
On Thu, 2014-12-11 at 19:49 +0900, Masahiro Yamada wrote: > Since commit ff94bc40af34 (mtd, ubi, ubifs: resync with Linux-3.14), > the "nand scrub" command has not been working. > > The scrub is a U-Boot extension and we have to modify nand_base.c > that originates in Linux. > > Mark the code with #ifdef __UBOOT__ so we will never accidentally > drop it when we re-sync the NAND framework with Linux in the future.
I agree with Heiko.
I second that.
If you or Heiko want to take over NAND custodianship, the offer is still there.
I find these ifdefs to be harmful to code legibility, editability, and searchability.
I find these ifdefs to be harmful to merging from Linux, especially when the ifndef section is large enough that the ifndef itself doesn't conflict with the diff context. This can lead to silent mismerges if the U-Boot alternative needed to be updated.
I find these ifdefs to be unreliable, because not every change is going to end up getting marked (e.g. commit 35c204d8a9d0). This can be actively harmful if people see some changes marked, and rely on the markers rather than checking with a diff. And yes, that means I need to send a patch to strip out the ifdefs from NAND files, just like I did back in commit 5b8e6bb517ea4.
-Scott
Hello Scott,
On Thursday, December 11, 2014 at 09:37:10 PM, Scott Wood wrote: > On Thu, 2014-12-11 at 19:49 +0900, Masahiro Yamada wrote: >> Since commit ff94bc40af34 (mtd, ubi, ubifs: resync with Linux-3.14), >> the "nand scrub" command has not been working. >> >> The scrub is a U-Boot extension and we have to modify nand_base.c >> that originates in Linux. >> >> Mark the code with #ifdef __UBOOT__ so we will never accidentally >> drop it when we re-sync the NAND framework with Linux in the future. > > No more "#ifdef __UBOOT__" please.
> Instead, never again do a "start > from scratch" resync the way that the above commit was done.
I agree with Heiko.
I second that.
As we're neck deep in "See? Scott was right" I'm inclined to go with what Scott is saying. We tried it, it actively didn't work, lets step back, evaluate and move along.
Hello Tom, Scott,
Am 16.12.2014 02:26, schrieb Tom Rini:
Hello Scott,
On Thu, 2014-12-11 at 22:37 +0100, Marek Vasut wrote: > On Thursday, December 11, 2014 at 09:37:10 PM, Scott Wood wrote: >> On Thu, 2014-12-11 at 19:49 +0900, Masahiro Yamada wrote: >>> Since commit ff94bc40af34 (mtd, ubi, ubifs: resync with Linux-3.14), >>> the "nand scrub" command has not been working. >>> >>> The scrub is a U-Boot extension and we have to modify nand_base.c >>> that originates in Linux. >>> >>> Mark the code with #ifdef __UBOOT__ so we will never accidentally >>> drop it when we re-sync the NAND framework with Linux in the future. >> >> No more "#ifdef __UBOOT__" please. > > Do you happen to have a helpful suggestion how to clearly mark those > bits of code then please ?
>> Instead, never again do a "start >> from scratch" resync the way that the above commit was done. > > This was already discussed, no need to revive this topic here now.
I agree with Heiko.
I second that.
Ok, I have no objections against that, it was just my point of view ...
And yes, I missed here and there some pieces when syncing with linux 3.14 ... sorry for that, but I could not test every scenario for every board ... and we had no clean base for using git, which at last in my attempt ended in a big mess when syncing with linux ... so I started more or less from scratch ...
So ...
Who will send a "delete ifdef" patch? Who will test, how a resync with linux (saying 3.17 ?) work now with git?
If this test is done, we can decide, which way is the "way to go" ... ?
bye, Heiko
On Tue, 2014-12-16 at 07:21 +0100, Heiko Schocher wrote:
Hello Tom, Scott,
I understand that for some of the mtd parts, but the nand code did have a relatively clean base.
So ...
I will.
I'll try a 3.18 sync soon.
-Scott
Hello Scott,
Am 16.12.2014 07:24, schrieb Scott Wood:
Hello Tom, Scott,
Yes, the problem was in the mtd and most notably in the ubi/ubifs code, IIRC.
So ...
I will.
Thanks!
Thanks! Please add a little description how you did the resync.
bye, Heiko
Hi Scott,
Hello Tom, Scott,
So ...
I will.
Given that we have made a decision to turn around, no point of adding the ifdefs by this patch.
V2 is now on our patchwork. http://patchwork.ozlabs.org/patch/421803/
participants (5)
Heiko Schocher
Masahiro Yamada
Scott Wood
