[U-Boot] [PATCH] am335x_evm_usbspl_defconfig: Fix USB RNDIS boot
It seems few config options are missing in the current am335x_evm_usbspl_defconfig causing USB RNDIS boot to fail on AM335x EVM. Fix this by adding required configs.
Signed-off-by: Vignesh R vigneshr@ti.com --- configs/am335x_evm_usbspl_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index a79470e88685..0a32d41eae67 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -44,3 +44,7 @@ CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 CONFIG_OF_LIBFDT=y +CONFIG_SPL_ETH_SUPPORT=y +CONFIG_SPL_USB_GADGET_SUPPORT=y +CONFIG_SPL_USBETH_SUPPORT=y +CONFIG_SPL_NET_VCI_STRING="AM335x U-Boot SPL"
Any thing that is blocking to use am335x_evm_defconfig for usb eth boot mode? Eventually we will have make single defconfig for all boot modes.
Thanks and regards, Lokesh
Yes, I guess first thing needed is would be SPL_DM support as AFAIK, DM_ETH forces to use DM in both SPL and U-Boot.
I guess, this should be possible once SPL_DM support is added.
okay. am335x has its own problems enabling SPL_DM on which I am working on. Can you check am43xx which has SPL_DM enabled?(I understand there is no am43xx_evm_usbspl_defconfig but wanted to know what is blocking to use am43xx_evm_defconfig for usb_eth mode?)
Thanks.
Regards, Lokesh
dwc3 usb peripheral needs be converted to DM as first step. Need to revisit: http://lists.denx.de/pipermail/u-boot/2016-March/250115.html
This is something that I have in my list of TODOs.
Lokesh,
Could you ack this patch, its still relevant to get USB RNDIS to work.
Lokesh Vutla
Vignesh R
