[U-Boot] [PATCH v2] cmd: usb_mass_storage: add protection for block_dev
solve data abort for the command "ums 0 ubi 0" because result of case blk_get_device_part_str() result is OK but with block_dev = 0 when CONFIG_CMD_UBIFS is activate and ubi volume is mounted
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com --- I check and the issue is still present on U-Boot v2018.09, on my board stm32mp1 (with NAND device and UBI volume):
STM32MP> ubi part UBI STM32MP> ubifsmount ubi0:boot STM32MP> ums 0 ubi 0 data abort pc : [<ffc60abc>] lr : [<ffc60ab3>] reloc pc : [<c0110abc>] lr : [<c0110ab3>] sp : fdc3e460 ip : fdc3e518 fp : fdcf06a8 r10: fdcf06b8 r9 : fdc4eed8 r8 : 00000000 r7 : ffce3d84 r6 : fdcf0740 r5 : fdcf0740 r4 : ffce3d88 r3 : 00000000 r2 : 00000000 r1 : 0000003a r0 : 00000000 Flags: nZCv IRQs off FIQs off Mode SVC_32 Code: f04f4628 9b06fd2a bf082800 0800f04f (f5b3695b) Resetting CPU ...
Even If the command is invalid (ums not allowed on ubi device), the data abort can be avoid by this patch.
Changes in v2: - Rebase on master branch
cmd/usb_mass_storage.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index 26b41b4c4..a3a338c 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -85,7 +85,7 @@ static int ums_init(const char *devtype, const char *devnums_part_str) partnum = 0;
/* f_mass_storage.c assumes SECTOR_SIZE sectors */ - if (block_dev->blksz != SECTOR_SIZE) + if (!block_dev || block_dev->blksz != SECTOR_SIZE) goto cleanup;
ums_new = realloc(ums, (ums_count + 1) * sizeof(*ums));
I don't quite understand the commit message, can you reword it?
Also, when is this ever called with block_dev == NULL ? What's the condition to trigger this and why ?
Ok, I prepare a V3
To reproduce the issue you need to have a ubifs already mounted, for example with the command: ubi part UBI ubifsmount ubi0:boot
I investigate the point, the call stack before the crash is caused by the ubi support in ./disk/part.c:425 = blk_get_device_part_str()
Some part of code here are under CONFIG_CMD_UBIFS with the comment : "ubi goes through a mtd, rathen then through a regular block device"
So the the function return a pointer to disk_partition_t : info->type = BOOT_PART_TYPE info->name = "UBI" but without block device information ! *dev_desc = NULL
So the issue occurs because, when the ubifs volume is mounted, The code in cmd/usb_mass_storage.c
static int ums_init(const char *devtype, const char *devnums_part_str) { ... for (;;) { ... partnum = blk_get_device_part_str(devtype, devnum_part_str, &block_dev, &info, 1); .... // With devnum_part_str = "ubi 0" // This function don't return a error and return a valid partnum // So the function continue until block_dev = NULL is used ..... if (partnum < 0) goto cleanup;
/* Check if the argument is in legacy format. If yes, * expose all partitions by setting the partnum = 0 * e.g. ums 0 mmc 0 */ if (!strchr(devnum_part_str, ':')) partnum = 0;
/* f_mass_storage.c assumes SECTOR_SIZE sectors */ if (block_dev->blksz != SECTOR_SIZE) goto cleanup;
=> crash occur here (on my board) because block_dev = NULL
*devnums_part_str)
partnum = 0; /* f_mass_storage.c assumes SECTOR_SIZE sectors */
-- Best regards, Marek Vasut
Regards Patrick
Ok, I prepare a V3
Sending a V3 while discussion is ongoing is pointless.
Would it rather make sense to fix it here , so it has a valid dev_desc ?
Hi Marek,
From: Marek Vasut marex@denx.de Sent: dimanche 30 septembre 2018 10:09
Ok, I prepare a V3
Sorry, I already sent it Friday only with more clear commit message. Because I really ashamed by of my this fist comment... Even me, I can't understand that I wrote.
I am not confident that can be done easily, if I correctly understood the code, because UBI is not really a regular block device but only directly connected to MTD to allow simple access to generic fs support for ubifs volume.
So NULL block devicedescriptor is "normal" for UBIFS.
To solve the issue at this level, a fake block device should be implemented for the UBI case.... And I don't sure that I can propose something here without breaking all the other commands using blk_get_device_part_str () function.
See in ./fs/fs.c, the null dev desc is allowed for UBI
struct fstype_info fstypes[]
#ifdef CONFIG_CMD_UBIFS { .fstype = FS_TYPE_UBIFS, .name = "ubifs", .null_dev_desc_ok = true,
Regards
Patrick
On 10/02/2018 09:54 AM, Patrick DELAUNAY wrote:
Hi Marek,
Ok, I prepare a V3
Happens to everyone.
Thanks for clarifying.
Simon, thoughts ?
Patrick DELAUNAY
Patrick Delaunay
