[U-Boot] [PATCH v3 0/5] at91: 9x5: Enable PMECC(Programmable Multibit ECC controller) support
This patch series will add PMECC support for atmel at91sam9x5ek in u-boot.
The NAND flash driver patch is ported from kernel patch. The main different from kernel patch is the modification about registers access part. in this version it via a register structure to access.
It is tested in atmel AT919G25EK board.
Changes since v2: adapt atmel nand driver to CONFIG_SYS_NAND_SELF_INIT. It use a new board_nand_init(void) function. Add README doc for Atmel PMECC. Add timeout for PMECC read hw status. refine code according to Andreas and Scott's comments.
Josh Wu (5): at91: atmel_nand: extract HWECC initialization code into one function: atmel_hw_nand_init_param(). at91: atmel_nand: remove unused variables. at91: atmel_nand: Update driver to support Programmable Multibit ECC controller at91: 9x5: change SMC config timing that both works for PMECC & non-PMECC. at91: 9x5: Enable PMECC for 5series ek board.
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 12 +- doc/README.atmel_pmecc | 44 ++ drivers/mtd/nand/atmel_nand.c | 828 ++++++++++++++++++++++++++++--- drivers/mtd/nand/atmel_nand_ecc.h | 113 +++++ include/configs/at91sam9x5ek.h | 7 + include/nand.h | 2 +- 6 files changed, 938 insertions(+), 68 deletions(-) create mode 100644 doc/README.atmel_pmecc
This patch 1. extract the hwecc initialization code into one function. It is a preparation for adding atmel PMECC support. 2. enable CONFIG_SYS_NAND_SELF_INIT. Which make us can configurate the ecc parameters between nand_scan_ident() and nand_scan_tail().
Signed-off-by: Josh Wu josh.wu@atmel.com --- Changes since v2: adapt to CONFIG_SYS_NAND_SELF_INIT.
drivers/mtd/nand/atmel_nand.c | 145 ++++++++++++++++++++++++----------------- include/nand.h | 2 +- 2 files changed, 88 insertions(+), 59 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index de66382..21dc4f5 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -232,6 +232,60 @@ static int atmel_nand_correct(struct mtd_info *mtd, u_char *dat, static void atmel_nand_hwctl(struct mtd_info *mtd, int mode) { } + +int atmel_hwecc_nand_init_param(struct nand_chip *nand, struct mtd_info *mtd) +{ + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.calculate = atmel_nand_calculate; + nand->ecc.correct = atmel_nand_correct; + nand->ecc.hwctl = atmel_nand_hwctl; + nand->ecc.read_page = atmel_nand_read_page; + nand->ecc.bytes = 4; + + if (nand->ecc.mode == NAND_ECC_HW) { + /* ECC is calculated for the whole page (1 step) */ + nand->ecc.size = mtd->writesize; + + /* set ECC page size and oob layout */ + switch (mtd->writesize) { + case 512: + nand->ecc.layout = &atmel_oobinfo_small; + ecc_writel(CONFIG_SYS_NAND_ECC_BASE, MR, + ATMEL_ECC_PAGESIZE_528); + break; + case 1024: + nand->ecc.layout = &atmel_oobinfo_large; + ecc_writel(CONFIG_SYS_NAND_ECC_BASE, MR, + ATMEL_ECC_PAGESIZE_1056); + break; + case 2048: + nand->ecc.layout = &atmel_oobinfo_large; + ecc_writel(CONFIG_SYS_NAND_ECC_BASE, MR, + ATMEL_ECC_PAGESIZE_2112); + break; + case 4096: + nand->ecc.layout = &atmel_oobinfo_large; + ecc_writel(CONFIG_SYS_NAND_ECC_BASE, MR, + ATMEL_ECC_PAGESIZE_4224); + break; + default: + /* page size not handled by HW ECC */ + /* switching back to soft ECC */ + nand->ecc.mode = NAND_ECC_SOFT; + nand->ecc.calculate = NULL; + nand->ecc.correct = NULL; + nand->ecc.hwctl = NULL; + nand->ecc.read_page = NULL; + nand->ecc.postpad = 0; + nand->ecc.prepad = 0; + nand->ecc.bytes = 0; + break; + } + } + + return 0; +} + #endif
static void at91_nand_hwcontrol(struct mtd_info *mtd, @@ -267,12 +321,20 @@ static int at91_nand_ready(struct mtd_info *mtd) } #endif
-int board_nand_init(struct nand_chip *nand) -{ -#ifdef CONFIG_ATMEL_NAND_HWECC - static int chip_nr = 0; - struct mtd_info *mtd; +#ifndef CONFIG_SYS_NAND_BASE_LIST +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #endif +static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE]; +static ulong base_addr[CONFIG_SYS_MAX_NAND_DEVICE] = CONFIG_SYS_NAND_BASE_LIST; + +int atmel_nand_chip_init(int devnum, ulong base_addr) +{ + int ret; + struct mtd_info *mtd = &nand_info[devnum]; + struct nand_chip *nand = &nand_chip[devnum]; + + mtd->priv = nand; + nand->IO_ADDR_R = nand->IO_ADDR_W = (void __iomem *)base_addr;
nand->ecc.mode = NAND_ECC_SOFT; #ifdef CONFIG_SYS_NAND_DBW_16 @@ -284,62 +346,29 @@ int board_nand_init(struct nand_chip *nand) #endif nand->chip_delay = 20;
-#ifdef CONFIG_ATMEL_NAND_HWECC - nand->ecc.mode = NAND_ECC_HW; - nand->ecc.calculate = atmel_nand_calculate; - nand->ecc.correct = atmel_nand_correct; - nand->ecc.hwctl = atmel_nand_hwctl; - nand->ecc.read_page = atmel_nand_read_page; - nand->ecc.bytes = 4; -#endif + ret = nand_scan_ident(mtd, CONFIG_SYS_NAND_MAX_CHIPS, NULL); + if (ret) + return ret;
#ifdef CONFIG_ATMEL_NAND_HWECC - mtd = &nand_info[chip_nr++]; - mtd->priv = nand; + ret = atmel_hwecc_nand_init_param(nand, mtd); +#endif + if (ret) + return ret;
- /* Detect NAND chips */ - if (nand_scan_ident(mtd, 1, NULL)) { - printk(KERN_WARNING "NAND Flash not found !\n"); - return -ENXIO; - } + ret = nand_scan_tail(mtd); + if (!ret) + nand_register(devnum);
- if (nand->ecc.mode == NAND_ECC_HW) { - /* ECC is calculated for the whole page (1 step) */ - nand->ecc.size = mtd->writesize; - - /* set ECC page size and oob layout */ - switch (mtd->writesize) { - case 512: - nand->ecc.layout = &atmel_oobinfo_small; - ecc_writel(CONFIG_SYS_NAND_ECC_BASE, MR, ATMEL_ECC_PAGESIZE_528); - break; - case 1024: - nand->ecc.layout = &atmel_oobinfo_large; - ecc_writel(CONFIG_SYS_NAND_ECC_BASE, MR, ATMEL_ECC_PAGESIZE_1056); - break; - case 2048: - nand->ecc.layout = &atmel_oobinfo_large; - ecc_writel(CONFIG_SYS_NAND_ECC_BASE, MR, ATMEL_ECC_PAGESIZE_2112); - break; - case 4096: - nand->ecc.layout = &atmel_oobinfo_large; - ecc_writel(CONFIG_SYS_NAND_ECC_BASE, MR, ATMEL_ECC_PAGESIZE_4224); - break; - default: - /* page size not handled by HW ECC */ - /* switching back to soft ECC */ - nand->ecc.mode = NAND_ECC_SOFT; - nand->ecc.calculate = NULL; - nand->ecc.correct = NULL; - nand->ecc.hwctl = NULL; - nand->ecc.read_page = NULL; - nand->ecc.postpad = 0; - nand->ecc.prepad = 0; - nand->ecc.bytes = 0; - break; - } - } -#endif + return ret; +}
- return 0; +void board_nand_init(void) +{ + int i; + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) + if (atmel_nand_chip_init(i, base_addr[i])) + printk(KERN_ERR "atmel_nand: Fail to initialize #%d chip", + i); } + diff --git a/include/nand.h b/include/nand.h index a48b1b8..c554c55 100644 --- a/include/nand.h +++ b/include/nand.h @@ -31,7 +31,7 @@ * at the same time, so do it here. When all drivers are * converted, this will go away. */ -#if defined(CONFIG_NAND_FSL_ELBC) +#if defined(CONFIG_NAND_FSL_ELBC) || defined(CONFIG_NAND_ATMEL) #define CONFIG_SYS_NAND_SELF_INIT #endif
Dear Josh Wu,
On 23.08.2012 12:05, Josh Wu wrote:
This patch
- extract the hwecc initialization code into one function. It is a preparation for adding atmel PMECC support.
- enable CONFIG_SYS_NAND_SELF_INIT. Which make us can configurate the ecc parameters between nand_scan_ident() and nand_scan_tail().
applied to u-boot-atmel/master with two minor changes (read on).
case 512:
break;
case 1024:
break;
case 2048:
break;
case 4096:
break;
default:
break;
#endif
int ret;
mtd->priv = nand;
-#endif
if (ret)
return ret;
- mtd->priv = nand;
- ret = atmel_hwecc_nand_init_param(nand, mtd);
- if (ret)
return ret;
put this return value check into the ifdef, run time tested on at91sam9260ek with HWECC enabled in board config.
return -ENXIO;
- ret = nand_scan_tail(mtd);
- if (!ret)
case 512:
break;
case 1024:
break;
case 2048:
break;
case 4096:
break;
default:
break;
-#endif
- return ret;
- int i;
- for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++)
}i);
removed this empty newline at EOF.
- at the same time, so do it here. When all drivers are
- converted, this will go away.
Best regards
Andreas Bießmann
Signed-off-by: Josh Wu josh.wu@atmel.com Acked-by: Scott Wood scottwood@freescale.com --- drivers/mtd/nand/atmel_nand.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 21dc4f5..05a6317 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -79,7 +79,6 @@ static struct nand_ecclayout atmel_oobinfo_small = { static int atmel_nand_calculate(struct mtd_info *mtd, const u_char *dat, unsigned char *ecc_code) { - struct nand_chip *nand_chip = mtd->priv; unsigned int ecc_value;
/* get the first 2 ECC bytes */ @@ -167,7 +166,7 @@ static int atmel_nand_correct(struct mtd_info *mtd, u_char *dat, u_char *read_ecc, u_char *isnull) { struct nand_chip *nand_chip = mtd->priv; - unsigned int ecc_status, ecc_parity, ecc_mode; + unsigned int ecc_status; unsigned int ecc_word, ecc_bit;
/* get the status from the Status Register */
Dear Josh Wu,
applied to u-boot-atmel/master, thanks!
Best regards
Andreas Bießmann
The Programmable Multibit ECC (PMECC) controller is a programmable binary BCH(Bose, Chaudhuri and Hocquenghem) encoder and decoder. This controller can be used to support both SLC and MLC NAND Flash devices. It supports to generate ECC to correct 2, 4, 8, 12 or 24 bits of error per sector of data.
To use PMECC in this driver, the user needs to set the PMECC correction capability, the sector size and ROM lookup table offsets in board config file.
This driver is ported from Linux kernel atmel_nand PMECC patch. The main difference is in this version it uses registers structure access hardware instead of using macros. It is tested in 9x5 serial boards.
Signed-off-by: Josh Wu josh.wu@atmel.com --- Changes since v2: add timeout when read hardware register. add README document for atmel pmecc. according to Scott and Andreas' suggestion, refined the pmecc_get_sigma() function and add more comments for the function.
doc/README.atmel_pmecc | 44 +++ drivers/mtd/nand/atmel_nand.c | 680 ++++++++++++++++++++++++++++++++++++- drivers/mtd/nand/atmel_nand_ecc.h | 113 ++++++ 3 files changed, 836 insertions(+), 1 deletion(-) create mode 100644 doc/README.atmel_pmecc
diff --git a/doc/README.atmel_pmecc b/doc/README.atmel_pmecc new file mode 100644 index 0000000..b483744 --- /dev/null +++ b/doc/README.atmel_pmecc @@ -0,0 +1,44 @@ +How to enable PMECC(Programmable Multibit ECC) for nand on Atmel SoCs +----------------------------------------------------------- +2012-08-22 Josh Wu josh.wu@atmel.com + +The Programmable Multibit ECC (PMECC) controller is a programmable binary +BCH(Bose, Chaudhuri and Hocquenghem) encoder and decoder. This controller +can be used to support both SLC and MLC NAND Flash devices. It supports to +generate ECC to correct 2, 4, 8, 12 or 24 bits of error per sector (512 or +1024 bytes) of data. + +Following Atmel AT91 products support PMECC. +- AT91SAM9X25, X35, G25, G15, G35 (tested) +- AT91SAM9N12 (not tested, Should work) + +As soon as your nand flash software ECC works, you can enable PMECC. + +To use PMECC in this driver, the user needs to set: + 1. the PMECC correction error bits capability: CONFIG_PMECC_CAP. + It can be 2, 4, 8, 12 or 24. + 2. The PMECC sector size: CONFIG_PMECC_SECTOR_SIZE. + It only can be 512 or 1024. + 3. The PMECC index lookup table's offsets in ROM code: CONFIG_PMECC_INDEX_TABLE_OFFSET. + In the chip datasheet section "Boot Stragegies", you can find + two Galois Field Table in the ROM code. One table is for 512-bytes + sector. Another is for 1024-byte sector. Each Galois Field includes + two sub-table: indext table & alpha table. + In the beginning of each Galois Field Table is the index table, + Alpha table is in the following. + So the index table's offset is same as the Galois Field Table. + + Please set CONFIG_PMECC_INDEX_TABLE_OFFSET correctly according the + Galois Field Table's offset base on the sector size you used. + +Take AT91SAM9X5EK as an example, the board definition file likes: + +/* PMECC & PMERRLOC */ +#define CONFIG_ATMEL_NAND_HWECC 1 +#define CONFIG_ATMEL_NAND_HW_PMECC 1 +#define CONFIG_PMECC_CAP 2 +#define CONFIG_PMECC_SECTOR_SIZE 512 +#define CONFIG_PMECC_INDEX_TABLE_OFFSET 0x8000 + +NOTE: If you use 1024 as the sector size, then need set 0x10000 as the + CONFIG_PMECC_INDEX_TABLE_OFFSET diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c index 05a6317..70b3ce4 100644 --- a/drivers/mtd/nand/atmel_nand.c +++ b/drivers/mtd/nand/atmel_nand.c @@ -5,6 +5,9 @@ * * (C) Copyright 2006 ATMEL Rousset, Lacressonniere Nicolas * + * Add Programmable Multibit ECC support for various AT91 SoC + * (C) Copyright 2012 ATMEL, Hong Xu + * * See file CREDITS for list of people who contributed to this * project. * @@ -30,6 +33,7 @@ #include <asm/arch/at91_pio.h>
#include <nand.h> +#include <watchdog.h>
@@ -41,6 +45,674 @@
#include "atmel_nand_ecc.h" /* Hardware ECC registers */
+#ifdef CONFIG_ATMEL_NAND_HW_PMECC + +struct atmel_nand_host { + struct pmecc_regs __iomem *pmecc; + struct pmecc_errloc_regs __iomem *pmerrloc; + void __iomem *pmecc_rom_base; + + u8 pmecc_corr_cap; + u16 pmecc_sector_size; + u32 pmecc_index_table_offset; + + int pmecc_bytes_per_sector; + int pmecc_sector_number; + int pmecc_degree; /* Degree of remainders */ + int pmecc_cw_len; /* Length of codeword */ + + /* lookup table for alpha_to and index_of */ + void __iomem *pmecc_alpha_to; + void __iomem *pmecc_index_of; + + /* data for pmecc computation */ + int16_t pmecc_smu[(CONFIG_PMECC_CAP + 2) * (2 * CONFIG_PMECC_CAP + 1)]; + int16_t pmecc_partial_syn[2 * CONFIG_PMECC_CAP + 1]; + int16_t pmecc_si[2 * CONFIG_PMECC_CAP + 1]; + int16_t pmecc_lmu[CONFIG_PMECC_CAP + 1]; /* polynomal order */ + int pmecc_mu[CONFIG_PMECC_CAP + 1]; + int pmecc_dmu[CONFIG_PMECC_CAP + 1]; + int pmecc_delta[CONFIG_PMECC_CAP + 1]; +}; + +static struct atmel_nand_host pmecc_host; +static struct nand_ecclayout atmel_pmecc_oobinfo; + +/* + * Return number of ecc bytes per sector according to sector size and + * correction capability + * + * Following table shows what at91 PMECC supported: + * Correction Capability Sector_512_bytes Sector_1024_bytes + * ===================== ================ ================= + * 2-bits 4-bytes 4-bytes + * 4-bits 7-bytes 7-bytes + * 8-bits 13-bytes 14-bytes + * 12-bits 20-bytes 21-bytes + * 24-bits 39-bytes 42-bytes + */ +static int pmecc_get_ecc_bytes(int cap, int sector_size) +{ + int m = 12 + sector_size / 512; + return (m * cap + 7) / 8; +} + +static void pmecc_config_ecc_layout(struct nand_ecclayout *layout, + int oobsize, int ecc_len) +{ + int i; + + layout->eccbytes = ecc_len; + + /* ECC will occupy the last ecc_len bytes continuously */ + for (i = 0; i < ecc_len; i++) + layout->eccpos[i] = oobsize - ecc_len + i; + + layout->oobfree[0].offset = 2; + layout->oobfree[0].length = + oobsize - ecc_len - layout->oobfree[0].offset; +} + +static void __iomem *pmecc_get_alpha_to(struct atmel_nand_host *host) +{ + int table_size; + + table_size = host->pmecc_sector_size == 512 ? + PMECC_INDEX_TABLE_SIZE_512 : PMECC_INDEX_TABLE_SIZE_1024; + + /* the ALPHA lookup table is right behind the INDEX lookup table. */ + return host->pmecc_rom_base + host->pmecc_index_table_offset + + table_size * sizeof(int16_t); +} + +static void pmecc_gen_syndrome(struct mtd_info *mtd, int sector) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + int i; + uint32_t value; + + /* Fill odd syndromes */ + for (i = 0; i < host->pmecc_corr_cap; i++) { + value = readl(&host->pmecc->rem_port[sector].rem[i / 2]); + if (i & 1) + value >>= 16; + value &= 0xffff; + host->pmecc_partial_syn[(2 * i) + 1] = (int16_t)value; + } +} + +static void pmecc_substitute(struct mtd_info *mtd) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + int16_t __iomem *alpha_to = host->pmecc_alpha_to; + int16_t __iomem *index_of = host->pmecc_index_of; + int16_t *partial_syn = host->pmecc_partial_syn; + const int cap = host->pmecc_corr_cap; + int16_t *si; + int i, j; + + /* si[] is a table that holds the current syndrome value, + * an element of that table belongs to the field + */ + si = host->pmecc_si; + + memset(&si[1], 0, sizeof(int16_t) * (2 * cap - 1)); + + /* Computation 2t syndromes based on S(x) */ + /* Odd syndromes */ + for (i = 1; i < 2 * cap; i += 2) { + for (j = 0; j < host->pmecc_degree; j++) { + if (partial_syn[i] & (0x1 << j)) + si[i] = readw(alpha_to + i * j) ^ si[i]; + } + } + /* Even syndrome = (Odd syndrome) ** 2 */ + for (i = 2, j = 1; j <= cap; i = ++j << 1) { + if (si[j] == 0) { + si[i] = 0; + } else { + int16_t tmp; + + tmp = readw(index_of + si[j]); + tmp = (tmp * 2) % host->pmecc_cw_len; + si[i] = readw(alpha_to + tmp); + } + } +} + +/* + * This function defines a Berlekamp iterative procedure for + * finding the value of the error location polynomial. + * The input is si[], initialize by pmecc_substitute(). + * The output is smu[][]. + * + * This function is written according to chip datasheet Chapter: + * Find the Error Location Polynomial Sigma(x) of Section: + * Programmable Multibit ECC Control (PMECC). + */ +static void pmecc_get_sigma(struct mtd_info *mtd) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + + int16_t *lmu = host->pmecc_lmu; + int16_t *si = host->pmecc_si; + int *mu = host->pmecc_mu; + int *dmu = host->pmecc_dmu; /* Discrepancy */ + int *delta = host->pmecc_delta; /* Delta order */ + int cw_len = host->pmecc_cw_len; + const int16_t cap = host->pmecc_corr_cap; + const int num = 2 * cap + 1; + int16_t __iomem *index_of = host->pmecc_index_of; + int16_t __iomem *alpha_to = host->pmecc_alpha_to; + int i, j, k; + uint32_t dmu_0_count, tmp; + int16_t *smu = host->pmecc_smu; + + /* index of largest delta */ + int ro; + int largest; + int diff; + + /* Init the Sigma(x) */ + memset(smu, 0, sizeof(int16_t) * ARRAY_SIZE(smu)); + + dmu_0_count = 0; + + /* First Row */ + + /* Mu */ + mu[0] = -1; + + smu[0] = 1; + + /* discrepancy set to 1 */ + dmu[0] = 1; + /* polynom order set to 0 */ + lmu[0] = 0; + /* delta[0] = (mu[0] * 2 - lmu[0]) >> 1; */ + delta[0] = -1; + + /* Second Row */ + + /* Mu */ + mu[1] = 0; + /* Sigma(x) set to 1 */ + smu[num] = 1; + + /* discrepancy set to S1 */ + dmu[1] = si[1]; + + /* polynom order set to 0 */ + lmu[1] = 0; + + /* delta[1] = (mu[1] * 2 - lmu[1]) >> 1; */ + delta[1] = 0; + + for (i = 1; i <= cap; i++) { + mu[i + 1] = i << 1; + /* Begin Computing Sigma (Mu+1) and L(mu) */ + /* check if discrepancy is set to 0 */ + if (dmu[i] == 0) { + dmu_0_count++; + + tmp = ((cap - (lmu[i] >> 1) - 1) / 2); + if ((cap - (lmu[i] >> 1) - 1) & 0x1) + tmp += 2; + else + tmp += 1; + + if (dmu_0_count == tmp) { + for (j = 0; j <= (lmu[i] >> 1) + 1; j++) + smu[(cap + 1) * num + j] = + smu[i * num + j]; + + lmu[cap + 1] = lmu[i]; + return; + } + + /* copy polynom */ + for (j = 0; j <= lmu[i] >> 1; j++) + smu[(i + 1) * num + j] = smu[i * num + j]; + + /* copy previous polynom order to the next */ + lmu[i + 1] = lmu[i]; + } else { + ro = 0; + largest = -1; + /* find largest delta with dmu != 0 */ + for (j = 0; j < i; j++) { + if ((dmu[j]) && (delta[j] > largest)) { + largest = delta[j]; + ro = j; + } + } + + /* compute difference */ + diff = (mu[i] - mu[ro]); + + /* Compute degree of the new smu polynomial */ + if ((lmu[i] >> 1) > ((lmu[ro] >> 1) + diff)) + lmu[i + 1] = lmu[i]; + else + lmu[i + 1] = ((lmu[ro] >> 1) + diff) * 2; + + /* Init smu[i+1] with 0 */ + for (k = 0; k < num; k++) + smu[(i + 1) * num + k] = 0; + + /* Compute smu[i+1] */ + for (k = 0; k <= lmu[ro] >> 1; k++) { + int16_t a, b, c; + + if (!(smu[ro * num + k] && dmu[i])) + continue; + a = readw(index_of + dmu[i]); + b = readw(index_of + dmu[ro]); + c = readw(index_of + smu[ro * num + k]); + tmp = a + (cw_len - b) + c; + a = readw(alpha_to + tmp % cw_len); + smu[(i + 1) * num + (k + diff)] = a; + } + + for (k = 0; k <= lmu[i] >> 1; k++) + smu[(i + 1) * num + k] ^= smu[i * num + k]; + } + + /* End Computing Sigma (Mu+1) and L(mu) */ + /* In either case compute delta */ + delta[i + 1] = (mu[i + 1] * 2 - lmu[i + 1]) >> 1; + + /* Do not compute discrepancy for the last iteration */ + if (i >= cap) + continue; + + for (k = 0; k <= (lmu[i + 1] >> 1); k++) { + tmp = 2 * (i - 1); + if (k == 0) { + dmu[i + 1] = si[tmp + 3]; + } else if (smu[(i + 1) * num + k] && si[tmp + 3 - k]) { + int16_t a, b, c; + a = readw(index_of + + smu[(i + 1) * num + k]); + b = si[2 * (i - 1) + 3 - k]; + c = readw(index_of + b); + tmp = a + c; + tmp %= cw_len; + dmu[i + 1] = readw(alpha_to + tmp) ^ + dmu[i + 1]; + } + } + } +} + +static int pmecc_err_location(struct mtd_info *mtd) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + const int cap = host->pmecc_corr_cap; + const int num = 2 * cap + 1; + int sector_size = host->pmecc_sector_size; + int err_nbr = 0; /* number of error */ + int roots_nbr; /* number of roots */ + int i; + uint32_t val; + int16_t *smu = host->pmecc_smu; + int timeout = PMECC_MAX_TIMEOUT_US; + + writel(PMERRLOC_DISABLE, &host->pmerrloc->eldis); + + for (i = 0; i <= host->pmecc_lmu[cap + 1] >> 1; i++) { + writel(smu[(cap + 1) * num + i], &host->pmerrloc->sigma[i]); + err_nbr++; + } + + val = PMERRLOC_ELCFG_NUM_ERRORS(err_nbr - 1); + if (sector_size == 1024) + val |= PMERRLOC_ELCFG_SECTOR_1024; + + writel(val, &host->pmerrloc->elcfg); + writel(sector_size * 8 + host->pmecc_degree * cap, + &host->pmerrloc->elen); + + while (--timeout) { + if (readl(&host->pmerrloc->elisr) & PMERRLOC_CALC_DONE) + break; + WATCHDOG_RESET(); + udelay(1); + } + + if (!timeout) { + printk(KERN_ERR "atmel_nand : Timeout to calculate PMECC error location\n"); + return -1; + } + + roots_nbr = (readl(&host->pmerrloc->elisr) & PMERRLOC_ERR_NUM_MASK) + >> 8; + /* Number of roots == degree of smu hence <= cap */ + if (roots_nbr == host->pmecc_lmu[cap + 1] >> 1) + return err_nbr - 1; + + /* Number of roots does not match the degree of smu + * unable to correct error */ + return -1; +} + +static void pmecc_correct_data(struct mtd_info *mtd, uint8_t *buf, uint8_t *ecc, + int sector_num, int extra_bytes, int err_nbr) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + int i = 0; + int byte_pos, bit_pos, sector_size, pos; + uint32_t tmp; + uint8_t err_byte; + + sector_size = host->pmecc_sector_size; + + while (err_nbr) { + tmp = readl(&host->pmerrloc->el[i]) - 1; + byte_pos = tmp / 8; + bit_pos = tmp % 8; + + if (byte_pos >= (sector_size + extra_bytes)) + BUG(); /* should never happen */ + + if (byte_pos < sector_size) { + err_byte = *(buf + byte_pos); + *(buf + byte_pos) ^= (1 << bit_pos); + + pos = sector_num * host->pmecc_sector_size + byte_pos; + printk(KERN_INFO "Bit flip in data area, byte_pos: %d, bit_pos: %d, 0x%02x -> 0x%02x\n", + pos, bit_pos, err_byte, *(buf + byte_pos)); + } else { + /* Bit flip in OOB area */ + tmp = sector_num * host->pmecc_bytes_per_sector + + (byte_pos - sector_size); + err_byte = ecc[tmp]; + ecc[tmp] ^= (1 << bit_pos); + + pos = tmp + nand_chip->ecc.layout->eccpos[0]; + printk(KERN_INFO "Bit flip in OOB, oob_byte_pos: %d, bit_pos: %d, 0x%02x -> 0x%02x\n", + pos, bit_pos, err_byte, ecc[tmp]); + } + + i++; + err_nbr--; + } + + return; +} + +static int pmecc_correction(struct mtd_info *mtd, u32 pmecc_stat, uint8_t *buf, + u8 *ecc) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + int i, err_nbr, eccbytes; + uint8_t *buf_pos; + + eccbytes = nand_chip->ecc.bytes; + for (i = 0; i < eccbytes; i++) + if (ecc[i] != 0xff) + goto normal_check; + /* Erased page, return OK */ + return 0; + +normal_check: + for (i = 0; i < host->pmecc_sector_number; i++) { + err_nbr = 0; + if (pmecc_stat & 0x1) { + buf_pos = buf + i * host->pmecc_sector_size; + + pmecc_gen_syndrome(mtd, i); + pmecc_substitute(mtd); + pmecc_get_sigma(mtd); + + err_nbr = pmecc_err_location(mtd); + if (err_nbr == -1) { + printk(KERN_ERR "PMECC: Too many errors\n"); + mtd->ecc_stats.failed++; + return -EIO; + } else { + pmecc_correct_data(mtd, buf_pos, ecc, i, + host->pmecc_bytes_per_sector, err_nbr); + mtd->ecc_stats.corrected += err_nbr; + } + } + pmecc_stat >>= 1; + } + + return 0; +} + +static int atmel_nand_pmecc_read_page(struct mtd_info *mtd, + struct nand_chip *chip, uint8_t *buf, int page) +{ + struct atmel_nand_host *host = chip->priv; + int eccsize = chip->ecc.size; + uint8_t *oob = chip->oob_poi; + uint32_t *eccpos = chip->ecc.layout->eccpos; + uint32_t stat; + int timeout = PMECC_MAX_TIMEOUT_US; + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_RST); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DISABLE); + pmecc_writel(host->pmecc, cfg, ((pmecc_readl(host->pmecc, cfg)) + & ~PMECC_CFG_WRITE_OP) | PMECC_CFG_AUTO_ENABLE); + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_ENABLE); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DATA); + + chip->read_buf(mtd, buf, eccsize); + chip->read_buf(mtd, oob, mtd->oobsize); + + while (--timeout) { + if (!(pmecc_readl(host->pmecc, sr) & PMECC_SR_BUSY)) + break; + WATCHDOG_RESET(); + udelay(1); + } + + if (!timeout) { + printk(KERN_ERR "atmel_nand : Timeout to read PMECC page\n"); + return -1; + } + + stat = pmecc_readl(host->pmecc, isr); + if (stat != 0) + if (pmecc_correction(mtd, stat, buf, &oob[eccpos[0]]) != 0) + return -EIO; + + return 0; +} + +static void atmel_nand_pmecc_write_page(struct mtd_info *mtd, + struct nand_chip *chip, const uint8_t *buf) +{ + struct atmel_nand_host *host = chip->priv; + uint32_t *eccpos = chip->ecc.layout->eccpos; + int i, j; + int timeout = PMECC_MAX_TIMEOUT_US; + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_RST); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DISABLE); + + pmecc_writel(host->pmecc, cfg, (pmecc_readl(host->pmecc, cfg) | + PMECC_CFG_WRITE_OP) & ~PMECC_CFG_AUTO_ENABLE); + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_ENABLE); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DATA); + + chip->write_buf(mtd, (u8 *)buf, mtd->writesize); + + while (--timeout) { + if (!(pmecc_readl(host->pmecc, sr) & PMECC_SR_BUSY)) + break; + WATCHDOG_RESET(); + udelay(1); + } + + if (!timeout) { + printk(KERN_ERR "atmel_nand : Timeout to read PMECC status, fail to write PMECC in oob\n"); + return; + } + + for (i = 0; i < host->pmecc_sector_number; i++) { + for (j = 0; j < host->pmecc_bytes_per_sector; j++) { + int pos; + + pos = i * host->pmecc_bytes_per_sector + j; + chip->oob_poi[eccpos[pos]] = + readb(&host->pmecc->ecc_port[i].ecc[j]); + } + } + chip->write_buf(mtd, chip->oob_poi, mtd->oobsize); +} + +static void atmel_pmecc_core_init(struct mtd_info *mtd) +{ + struct nand_chip *nand_chip = mtd->priv; + struct atmel_nand_host *host = nand_chip->priv; + uint32_t val = 0; + struct nand_ecclayout *ecc_layout; + + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_RST); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_DISABLE); + + switch (host->pmecc_corr_cap) { + case 2: + val = PMECC_CFG_BCH_ERR2; + break; + case 4: + val = PMECC_CFG_BCH_ERR4; + break; + case 8: + val = PMECC_CFG_BCH_ERR8; + break; + case 12: + val = PMECC_CFG_BCH_ERR12; + break; + case 24: + val = PMECC_CFG_BCH_ERR24; + break; + } + + if (host->pmecc_sector_size == 512) + val |= PMECC_CFG_SECTOR512; + else if (host->pmecc_sector_size == 1024) + val |= PMECC_CFG_SECTOR1024; + + switch (host->pmecc_sector_number) { + case 1: + val |= PMECC_CFG_PAGE_1SECTOR; + break; + case 2: + val |= PMECC_CFG_PAGE_2SECTORS; + break; + case 4: + val |= PMECC_CFG_PAGE_4SECTORS; + break; + case 8: + val |= PMECC_CFG_PAGE_8SECTORS; + break; + } + + val |= (PMECC_CFG_READ_OP | PMECC_CFG_SPARE_DISABLE + | PMECC_CFG_AUTO_DISABLE); + pmecc_writel(host->pmecc, cfg, val); + + ecc_layout = nand_chip->ecc.layout; + pmecc_writel(host->pmecc, sarea, mtd->oobsize - 1); + pmecc_writel(host->pmecc, saddr, ecc_layout->eccpos[0]); + pmecc_writel(host->pmecc, eaddr, + ecc_layout->eccpos[ecc_layout->eccbytes - 1]); + /* See datasheet about PMECC Clock Control Register */ + pmecc_writel(host->pmecc, clk, PMECC_CLK_133MHZ); + pmecc_writel(host->pmecc, idr, 0xff); + pmecc_writel(host->pmecc, ctrl, PMECC_CTRL_ENABLE); +} + +static int atmel_pmecc_nand_init_params(struct nand_chip *nand, + struct mtd_info *mtd) +{ + struct atmel_nand_host *host; + int cap, sector_size; + + host = nand->priv = &pmecc_host; + + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.calculate = NULL; + nand->ecc.correct = NULL; + nand->ecc.hwctl = NULL; + + cap = host->pmecc_corr_cap = CONFIG_PMECC_CAP; + sector_size = host->pmecc_sector_size = CONFIG_PMECC_SECTOR_SIZE; + host->pmecc_index_table_offset = CONFIG_PMECC_INDEX_TABLE_OFFSET; + + printk(KERN_INFO "Initialize PMECC params, cap: %d, sector: %d\n", + cap, sector_size); + + host->pmecc = (struct pmecc_regs __iomem *) ATMEL_BASE_PMECC; + host->pmerrloc = (struct pmecc_errloc_regs __iomem *) + ATMEL_BASE_PMERRLOC; + host->pmecc_rom_base = (void __iomem *) ATMEL_BASE_ROM; + + /* ECC is calculated for the whole page (1 step) */ + nand->ecc.size = mtd->writesize; + + /* set ECC page size and oob layout */ + switch (mtd->writesize) { + case 2048: + case 4096: + host->pmecc_degree = PMECC_GF_DIMENSION_13; + host->pmecc_cw_len = (1 << host->pmecc_degree) - 1; + host->pmecc_sector_number = mtd->writesize / sector_size; + host->pmecc_bytes_per_sector = pmecc_get_ecc_bytes( + cap, sector_size); + host->pmecc_alpha_to = pmecc_get_alpha_to(host); + host->pmecc_index_of = host->pmecc_rom_base + + host->pmecc_index_table_offset; + + nand->ecc.steps = 1; + nand->ecc.bytes = host->pmecc_bytes_per_sector * + host->pmecc_sector_number; + if (nand->ecc.bytes > mtd->oobsize - 2) { + printk(KERN_ERR "No room for ECC bytes\n"); + return -EINVAL; + } + pmecc_config_ecc_layout(&atmel_pmecc_oobinfo, + mtd->oobsize, + nand->ecc.bytes); + nand->ecc.layout = &atmel_pmecc_oobinfo; + break; + case 512: + case 1024: + /* TODO */ + printk(KERN_ERR "Unsupported page size for PMECC, use Software ECC\n"); + default: + /* page size not handled by HW ECC */ + /* switching back to soft ECC */ + nand->ecc.mode = NAND_ECC_SOFT; + nand->ecc.read_page = NULL; + nand->ecc.postpad = 0; + nand->ecc.prepad = 0; + nand->ecc.bytes = 0; + return 0; + } + + nand->ecc.read_page = atmel_nand_pmecc_read_page; + nand->ecc.write_page = atmel_nand_pmecc_write_page; + + atmel_pmecc_core_init(mtd); + + return 0; +} + +#else + /* oob layout for large page size * bad block info is on bytes 0 and 1 * the bytes have to be consecutives to avoid @@ -285,7 +957,9 @@ int atmel_hwecc_nand_init_param(struct nand_chip *nand, struct mtd_info *mtd) return 0; }
-#endif +#endif /* CONFIG_ATMEL_NAND_HW_PMECC */ + +#endif /* CONFIG_ATMEL_NAND_HWECC */
static void at91_nand_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) @@ -350,8 +1024,12 @@ int atmel_nand_chip_init(int devnum, ulong base_addr) return ret;
#ifdef CONFIG_ATMEL_NAND_HWECC +#ifdef CONFIG_ATMEL_NAND_HW_PMECC + ret = atmel_pmecc_nand_init_params(nand, mtd); +#else ret = atmel_hwecc_nand_init_param(nand, mtd); #endif +#endif if (ret) return ret;
diff --git a/drivers/mtd/nand/atmel_nand_ecc.h b/drivers/mtd/nand/atmel_nand_ecc.h index 1ee7f99..4732582 100644 --- a/drivers/mtd/nand/atmel_nand_ecc.h +++ b/drivers/mtd/nand/atmel_nand_ecc.h @@ -33,4 +33,117 @@ #define ATMEL_ECC_NPR 0x10 /* NParity register */ #define ATMEL_ECC_NPARITY (0xffff << 0) /* NParity */
+/* Register access macros for PMECC */ +#define pmecc_readl(addr, reg) \ + readl(&addr->reg) + +#define pmecc_writel(addr, reg, value) \ + writel((value), &addr->reg) + +/* PMECC Register Definitions */ +#define PMECC_MAX_SECTOR_NUM 8 +struct pmecc_regs { + u32 cfg; /* 0x00 PMECC Configuration Register */ + u32 sarea; /* 0x04 PMECC Spare Area Size Register */ + u32 saddr; /* 0x08 PMECC Start Address Register */ + u32 eaddr; /* 0x0C PMECC End Address Register */ + u32 clk; /* 0x10 PMECC Clock Control Register */ + u32 ctrl; /* 0x14 PMECC Control Register */ + u32 sr; /* 0x18 PMECC Status Register */ + u32 ier; /* 0x1C PMECC Interrupt Enable Register */ + u32 idr; /* 0x20 PMECC Interrupt Disable Register */ + u32 imr; /* 0x24 PMECC Interrupt Mask Register */ + u32 isr; /* 0x28 PMECC Interrupt Status Register */ + u32 reserved0[5]; /* 0x2C-0x3C Reserved */ + + /* 0x40 + sector_num * (0x40), Redundancy Registers */ + struct { + u8 ecc[44]; /* PMECC Generated Redundancy Byte Per Sector */ + u32 reserved1[5]; + } ecc_port[PMECC_MAX_SECTOR_NUM]; + + /* 0x240 + sector_num * (0x40) Remainder Registers */ + struct { + u32 rem[12]; + u32 reserved2[4]; + } rem_port[PMECC_MAX_SECTOR_NUM]; + u32 reserved3[16]; /* 0x440-0x47C Reserved */ +}; + +/* For PMECC Configuration Register */ +#define PMECC_CFG_BCH_ERR2 (0 << 0) +#define PMECC_CFG_BCH_ERR4 (1 << 0) +#define PMECC_CFG_BCH_ERR8 (2 << 0) +#define PMECC_CFG_BCH_ERR12 (3 << 0) +#define PMECC_CFG_BCH_ERR24 (4 << 0) + +#define PMECC_CFG_SECTOR512 (0 << 4) +#define PMECC_CFG_SECTOR1024 (1 << 4) + +#define PMECC_CFG_PAGE_1SECTOR (0 << 8) +#define PMECC_CFG_PAGE_2SECTORS (1 << 8) +#define PMECC_CFG_PAGE_4SECTORS (2 << 8) +#define PMECC_CFG_PAGE_8SECTORS (3 << 8) + +#define PMECC_CFG_READ_OP (0 << 12) +#define PMECC_CFG_WRITE_OP (1 << 12) + +#define PMECC_CFG_SPARE_ENABLE (1 << 16) +#define PMECC_CFG_SPARE_DISABLE (0 << 16) + +#define PMECC_CFG_AUTO_ENABLE (1 << 20) +#define PMECC_CFG_AUTO_DISABLE (0 << 20) + +/* For PMECC Clock Control Register */ +#define PMECC_CLK_133MHZ (2 << 0) + +/* For PMECC Control Register */ +#define PMECC_CTRL_RST (1 << 0) +#define PMECC_CTRL_DATA (1 << 1) +#define PMECC_CTRL_USER (1 << 2) +#define PMECC_CTRL_ENABLE (1 << 4) +#define PMECC_CTRL_DISABLE (1 << 5) + +/* For PMECC Status Register */ +#define PMECC_SR_BUSY (1 << 0) +#define PMECC_SR_ENABLE (1 << 4) + +/* PMERRLOC Register Definitions */ +struct pmecc_errloc_regs { + u32 elcfg; /* 0x00 Error Location Configuration Register */ + u32 elprim; /* 0x04 Error Location Primitive Register */ + u32 elen; /* 0x08 Error Location Enable Register */ + u32 eldis; /* 0x0C Error Location Disable Register */ + u32 elsr; /* 0x10 Error Location Status Register */ + u32 elier; /* 0x14 Error Location Interrupt Enable Register */ + u32 elidr; /* 0x08 Error Location Interrupt Disable Register */ + u32 elimr; /* 0x0C Error Location Interrupt Mask Register */ + u32 elisr; /* 0x20 Error Location Interrupt Status Register */ + u32 reserved0; /* 0x24 Reserved */ + u32 sigma[25]; /* 0x28-0x88 Error Location Sigma Registers */ + u32 el[24]; /* 0x8C-0xE8 Error Location Registers */ + u32 reserved1[5]; /* 0xEC-0xFC Reserved */ +}; + +/* For Error Location Configuration Register */ +#define PMERRLOC_ELCFG_SECTOR_512 (0 << 0) +#define PMERRLOC_ELCFG_SECTOR_1024 (1 << 0) +#define PMERRLOC_ELCFG_NUM_ERRORS(n) ((n) << 16) + +/* For Error Location Disable Register */ +#define PMERRLOC_DISABLE (1 << 0) + +/* For Error Location Interrupt Status Register */ +#define PMERRLOC_ERR_NUM_MASK (0x1f << 8) +#define PMERRLOC_CALC_DONE (1 << 0) + +/* Galois field dimension */ +#define PMECC_GF_DIMENSION_13 13 +#define PMECC_GF_DIMENSION_14 14 + +#define PMECC_INDEX_TABLE_SIZE_512 0x2000 +#define PMECC_INDEX_TABLE_SIZE_1024 0x4000 + +#define PMECC_MAX_TIMEOUT_US (100 * 1000) + #endif
Dear Josh Wu,
applied to u-boot-atmel/master (slightly modified due to required rebase cause of change in 1/5), thanks!
Best regards
Andreas Bießmann
Signed-off-by: Josh Wu josh.wu@atmel.com --- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 88b3478..ae408bc 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -65,13 +65,13 @@ static void at91sam9x5ek_nand_hw_init(void) writel(csa, &matrix->ebicsa);
/* Configure SMC CS3 for NAND/SmartMedia */ - writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | - AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), &smc->cs[3].setup); - writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) | - AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(4), + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(5) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(6), &smc->cs[3].pulse); - writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7), + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(6), &smc->cs[3].cycle); writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | AT91_SMC_MODE_EXNW_DISABLE | @@ -80,7 +80,7 @@ static void at91sam9x5ek_nand_hw_init(void) #else /* CONFIG_SYS_NAND_DBW_8 */ AT91_SMC_MODE_DBW_8 | #endif - AT91_SMC_MODE_TDF_CYCLE(3), + AT91_SMC_MODE_TDF_CYCLE(1), &smc->cs[3].mode);
writel(1 << ATMEL_ID_PIOCD, &pmc->pcer);
Hi Josh,
- writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) |
&smc->cs[3].setup);AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0),
- writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(5) |
&smc->cs[3].pulse);AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(6),
- writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(6), &smc->cs[3].cycle); writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | AT91_SMC_MODE_EXNW_DISABLE |
&smc->cs[3].mode);AT91_SMC_MODE_TDF_CYCLE(1),
Test these parameters for NAND using software ECC. It works well.
Tested-by: voice.shen@atmel.com
Dear Josh Wu,
applied to u-boot-atmel/master, thnaks!
Best regards
Andreas Bießmann
Signed-off-by: Josh Wu josh.wu@atmel.com --- include/configs/at91sam9x5ek.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 82f6b48..3a5a7e6 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -120,6 +120,13 @@ #define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD4 #define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PD5
+/* PMECC & PMERRLOC */ +#define CONFIG_ATMEL_NAND_HWECC 1 +#define CONFIG_ATMEL_NAND_HW_PMECC 1 +#define CONFIG_PMECC_CAP 2 +#define CONFIG_PMECC_SECTOR_SIZE 512 +#define CONFIG_PMECC_INDEX_TABLE_OFFSET 0x8000 + #define CONFIG_MTD_DEVICE #define CONFIG_CMD_MTDPARTS #define CONFIG_MTD_PARTITIONS
Dear Josh Wu,
Best regards
Andreas Bießmann
Hi, All
Is any feedback for this rev3 patch series.
Best Regards, Josh Wu
Dear Josh Wu,
On 31.08.2012 05:23, Josh Wu wrote:
Hi, All
sorry, had no time yet, I will send feedback this evening (CEST).
Best regards
Andreas Bießmann
Andreas Bießmann
Bo Shen
Josh Wu
