[U-Boot] Please pull u-boot-amlogic-20181126
Hi Tom,
The following changes since commit 5830791d91d1200854ef78fcb32f808c8080f0f0:
Merge tag 'pull-tg18' of git://git.denx.de/u-boot-dm (2018-11-23 17:25:27 -0500)
git://git.denx.de/u-boot-amlogic.git tags/u-boot-amlogic-20181126
for you to fetch changes up to d96a782d09dbdc4a28ece3d18dc17a572e39d4f2:
ARM: meson: Add boot device discovery (2018-11-26 14:40:52 +0100)
---------------------------------------------------------------- Cleanup and update towards support for Amlogic Meson AXG SoCs : - mmc: meson-gx: Add AXG compatible - net: designware: add meson meson compatibles - Amlogic Meson cleanup for AXG SoC support
---------------------------------------------------------------- Jerome Brunet (12): ARM: meson: clean-up platform selection configs: meson: remove unnecessary MESON_FDTFILE_SETTING board: amlogic: remove p212 derivatives board: amlogic: factorise gxbb boards ARM: rework amlogic configuration configs: meson: change default load addresses pinctrl: meson: rework gx pmx function pinctrl: meson: select generic pinctrl pinctrl: meson: add axg support clk: meson: silence debug print ARM: meson: rework soc arch file to prepare for new SoC ARM: meson: factorize common code out amlogic's boards
Neil Armstrong (10): mmc: meson-gx: Add AXG compatible net: designware: add meson meson gxbb compatible net: designware: add meson meson axg compatible board: amlogic: move khadas-vim2 as q200 ref board clk: meson: add static to meson_gates table ARM: meson: Add support for AXG family ARM: dts: Sync Amlogic Meson AXG DT from Linux 4.20-rc1 clk: Add clock driver for AXG board: amlogic: add support for S400 board ARM: meson: Add boot device discovery
arch/arm/dts/Makefile | 3 +- arch/arm/dts/meson-axg-s400.dts | 554 +++++++ arch/arm/dts/meson-axg.dtsi | 1589 ++++++++++++++++++++ arch/arm/include/asm/arch-meson/axg.h | 52 + arch/arm/include/asm/arch-meson/boot.h | 20 + arch/arm/include/asm/arch-meson/clock-axg.h | 104 ++ .../include/asm/arch-meson/{clock.h => clock-gx.h} | 4 +- arch/arm/include/asm/arch-meson/eth.h | 6 +- arch/arm/include/asm/arch-meson/gx.h | 1 + arch/arm/include/asm/arch-meson/mem.h | 3 +- arch/arm/mach-meson/Kconfig | 132 +- arch/arm/mach-meson/Makefile | 4 +- arch/arm/mach-meson/board-axg.c | 118 ++ arch/arm/mach-meson/board-common.c | 117 ++ arch/arm/mach-meson/{board.c => board-gx.c} | 106 +- arch/arm/mach-meson/eth.c | 53 - arch/arm/mach-meson/sm.c | 1 - board/amlogic/khadas-vim/Kconfig | 12 - board/amlogic/khadas-vim/MAINTAINERS | 6 - board/amlogic/khadas-vim/khadas-vim.c | 57 - board/amlogic/khadas-vim2/Kconfig | 12 - board/amlogic/libretech-cc/Kconfig | 12 - board/amlogic/libretech-cc/MAINTAINERS | 6 - board/amlogic/libretech-cc/Makefile | 6 - board/amlogic/libretech-cc/libretech-cc.c | 57 - board/amlogic/nanopi-k2/Kconfig | 12 - board/amlogic/nanopi-k2/MAINTAINERS | 6 - board/amlogic/nanopi-k2/Makefile | 7 - board/amlogic/nanopi-k2/nanopi-k2.c | 55 - board/amlogic/odroid-c2/Kconfig | 12 - board/amlogic/odroid-c2/MAINTAINERS | 1 + .../README => odroid-c2/README.nanopi-k2} | 0 .../amlogic/odroid-c2/{README => README.odroid-c2} | 0 board/amlogic/odroid-c2/odroid-c2.c | 16 +- board/amlogic/p212/Kconfig | 12 - .../{khadas-vim/README => p212/README.khadas-vim} | 0 .../README => p212/README.libretech-cc} | 0 board/amlogic/p212/{README => README.p212} | 0 board/amlogic/p212/p212.c | 16 +- board/amlogic/{khadas-vim2 => q200}/MAINTAINERS | 6 +- board/amlogic/{khadas-vim => q200}/Makefile | 2 +- .../README => q200/README.khadas-vim2} | 0 board/amlogic/q200/README.q200 | 102 ++ .../{khadas-vim2/khadas-vim2.c => q200/q200.c} | 14 +- board/amlogic/s400/MAINTAINERS | 6 + board/amlogic/{khadas-vim2 => s400}/Makefile | 2 +- board/amlogic/s400/README | 110 ++ board/amlogic/s400/s400.c | 21 + configs/khadas-vim2_defconfig | 1 - configs/khadas-vim_defconfig | 1 - configs/libretech-cc_defconfig | 1 - configs/nanopi-k2_defconfig | 2 - configs/odroid-c2_defconfig | 1 - configs/p212_defconfig | 1 - configs/s400_defconfig | 38 + drivers/clk/Makefile | 2 +- drivers/clk/clk_meson.c | 6 +- drivers/clk/clk_meson_axg.c | 316 ++++ drivers/mmc/meson_gx_mmc.c | 1 + drivers/net/designware.c | 2 + drivers/pinctrl/meson/Kconfig | 18 +- drivers/pinctrl/meson/Makefile | 3 + drivers/pinctrl/meson/pinctrl-meson-axg-pmx.c | 125 ++ drivers/pinctrl/meson/pinctrl-meson-axg.c | 979 ++++++++++++ drivers/pinctrl/meson/pinctrl-meson-axg.h | 66 + drivers/pinctrl/meson/pinctrl-meson-gx-pmx.c | 97 ++ drivers/pinctrl/meson/pinctrl-meson-gx.h | 48 + drivers/pinctrl/meson/pinctrl-meson-gxbb.c | 6 +- drivers/pinctrl/meson/pinctrl-meson-gxl.c | 6 +- drivers/pinctrl/meson/pinctrl-meson.c | 109 +- drivers/pinctrl/meson/pinctrl-meson.h | 37 +- include/configs/khadas-vim.h | 16 - include/configs/khadas-vim2.h | 18 - include/configs/libretech-cc.h | 16 - include/configs/{meson-gx-common.h => meson64.h} | 49 +- include/configs/nanopi-k2.h | 16 - include/configs/odroid-c2.h | 16 - include/configs/p212.h | 18 - include/dt-bindings/clock/axg-aoclkc.h | 26 + include/dt-bindings/clock/axg-audio-clkc.h | 94 ++ include/dt-bindings/clock/axg-clkc.h | 76 + include/dt-bindings/gpio/meson-axg-gpio.h | 116 ++ .../reset/amlogic,meson-axg-audio-arb.h | 17 + .../dt-bindings/reset/amlogic,meson-axg-reset.h | 124 ++ include/dt-bindings/reset/axg-aoclkc.h | 20 + 85 files changed, 5169 insertions(+), 754 deletions(-) create mode 100644 arch/arm/dts/meson-axg-s400.dts create mode 100644 arch/arm/dts/meson-axg.dtsi create mode 100644 arch/arm/include/asm/arch-meson/axg.h create mode 100644 arch/arm/include/asm/arch-meson/boot.h create mode 100644 arch/arm/include/asm/arch-meson/clock-axg.h rename arch/arm/include/asm/arch-meson/{clock.h => clock-gx.h} (98%) create mode 100644 arch/arm/mach-meson/board-axg.c create mode 100644 arch/arm/mach-meson/board-common.c rename arch/arm/mach-meson/{board.c => board-gx.c} (59%) delete mode 100644 arch/arm/mach-meson/eth.c delete mode 100644 board/amlogic/khadas-vim/Kconfig delete mode 100644 board/amlogic/khadas-vim/MAINTAINERS delete mode 100644 board/amlogic/khadas-vim/khadas-vim.c delete mode 100644 board/amlogic/khadas-vim2/Kconfig delete mode 100644 board/amlogic/libretech-cc/Kconfig delete mode 100644 board/amlogic/libretech-cc/MAINTAINERS delete mode 100644 board/amlogic/libretech-cc/Makefile delete mode 100644 board/amlogic/libretech-cc/libretech-cc.c delete mode 100644 board/amlogic/nanopi-k2/Kconfig delete mode 100644 board/amlogic/nanopi-k2/MAINTAINERS delete mode 100644 board/amlogic/nanopi-k2/Makefile delete mode 100644 board/amlogic/nanopi-k2/nanopi-k2.c delete mode 100644 board/amlogic/odroid-c2/Kconfig rename board/amlogic/{nanopi-k2/README => odroid-c2/README.nanopi-k2} (100%) rename board/amlogic/odroid-c2/{README => README.odroid-c2} (100%) delete mode 100644 board/amlogic/p212/Kconfig rename board/amlogic/{khadas-vim/README => p212/README.khadas-vim} (100%) rename board/amlogic/{libretech-cc/README => p212/README.libretech-cc} (100%) rename board/amlogic/p212/{README => README.p212} (100%) rename board/amlogic/{khadas-vim2 => q200}/MAINTAINERS (54%) rename board/amlogic/{khadas-vim => q200}/Makefile (85%) rename board/amlogic/{khadas-vim2/README => q200/README.khadas-vim2} (100%) create mode 100644 board/amlogic/q200/README.q200 rename board/amlogic/{khadas-vim2/khadas-vim2.c => q200/q200.c} (85%) create mode 100644 board/amlogic/s400/MAINTAINERS rename board/amlogic/{khadas-vim2 => s400}/Makefile (84%) create mode 100644 board/amlogic/s400/README create mode 100644 board/amlogic/s400/s400.c create mode 100644 configs/s400_defconfig create mode 100644 drivers/clk/clk_meson_axg.c create mode 100644 drivers/pinctrl/meson/pinctrl-meson-axg-pmx.c create mode 100644 drivers/pinctrl/meson/pinctrl-meson-axg.c create mode 100644 drivers/pinctrl/meson/pinctrl-meson-axg.h create mode 100644 drivers/pinctrl/meson/pinctrl-meson-gx-pmx.c create mode 100644 drivers/pinctrl/meson/pinctrl-meson-gx.h delete mode 100644 include/configs/khadas-vim.h delete mode 100644 include/configs/khadas-vim2.h delete mode 100644 include/configs/libretech-cc.h rename include/configs/{meson-gx-common.h => meson64.h} (51%) delete mode 100644 include/configs/nanopi-k2.h delete mode 100644 include/configs/odroid-c2.h delete mode 100644 include/configs/p212.h create mode 100644 include/dt-bindings/clock/axg-aoclkc.h create mode 100644 include/dt-bindings/clock/axg-audio-clkc.h create mode 100644 include/dt-bindings/clock/axg-clkc.h create mode 100644 include/dt-bindings/gpio/meson-axg-gpio.h create mode 100644 include/dt-bindings/reset/amlogic,meson-axg-audio-arb.h create mode 100644 include/dt-bindings/reset/amlogic,meson-axg-reset.h create mode 100644 include/dt-bindings/reset/axg-aoclkc.h
Thanks, Neil
On Tue, Nov 27, 2018 at 02:56:16PM +0100, Neil Armstrong wrote:
Hi Tom,
FWIW, please make sure to put me in the to: line next time as well.
Also, I fixed it up this time but please run: $ ./tools/genboardscfg.py -f
to make sure no new configs show up that aren't listed in MAINTAINERS. I've added the boards added here to the relevant spots.
Neil Armstrong
