[RFC PATCH 0/2] Add TI K3 PCIe Controller support for J7200
Hello,
This series adds support for the Cadence PCIe controller on TI's K3 family of SoCs which J7200 belongs to. The driver is an adaptation of the Linux driver (drivers/pci/controller/cadence/pci-j721e.c) and has been implemented specifically for Root-Complex mode of operation on J7200. A minor set of changes will be sufficient to support other K3 SoCs as well, which has been indicated with "TODO"s added in the driver code.
Series is based on commit d2067c3ea5 Merge tag 'u-boot-dfu-next-20240820' of https://source.denx.de/u-boot/custodians/u-boot-dfu into next of the next branch of U-Boot.
I have posted this series as an RFC for feedback regarding the implementation. I plan to implement the remaining changes to truly support all K3 SoCs that are currently supported by the pci-j721e.c driver in Linux in Root-Complex mode of operation. I have tested this series with the following changes made to the device-tree for J7200: https://gist.github.com/Siddharth-Vadapalli-at-TI/1a498722ebb332da6f88abe05a...
The device-tree changes are required since the "reg-mux" driver is not currently implemented in U-Boot. I will work on porting the "reg-mux" driver support from Linux.
The logs corresponding to validating PCI Root-Complex functionality with an NVMe SSD connected to the PCIe Connector on J7200-EVM, with this series and the aforementioned device-tree changes applied are: https://gist.github.com/Siddharth-Vadapalli-at-TI/bbcbfa0b7d593795726c81fb41...
Regards, Siddharth.
Siddharth Vadapalli (2): pci: Add TI K3 Cadence PCIe Controller configs: j7200_evm_a72_defconfig: Enable configs for PCI support
configs/j7200_evm_a72_defconfig | 4 + drivers/pci/Kconfig | 6 + drivers/pci/Makefile | 1 + drivers/pci/pcie_cdns_ti.c | 645 ++++++++++++++++++++++++++++++++ 4 files changed, 656 insertions(+) create mode 100644 drivers/pci/pcie_cdns_ti.c
Add support for the Cadence PCIe Controller present on TI's K3 SoCs. This driver is an adaptation of the Linux driver.
Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com --- drivers/pci/Kconfig | 6 + drivers/pci/Makefile | 1 + drivers/pci/pcie_cdns_ti.c | 645 +++++++++++++++++++++++++++++++++++++ 3 files changed, 652 insertions(+) create mode 100644 drivers/pci/pcie_cdns_ti.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 22a56f4ca3..876a5fa57e 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -137,6 +137,12 @@ config PCI_GT64120 bool "GT64120 PCI support" depends on MIPS
+config PCIE_CDNS_TI + bool "TI K3 PCIe support" + help + Say Y here to enable support for the Cadence PCIe Controller + on TI's K3 SoCs. + config PCI_PHYTIUM bool "Phytium PCIe support" help diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 5b2d296980..bf361cd0fb 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -14,6 +14,7 @@ obj-$(CONFIG_PCI) += pci_auto_common.o pci_common.o obj-$(CONFIG_PCIE_ECAM_GENERIC) += pcie_ecam_generic.o obj-$(CONFIG_PCIE_ECAM_SYNQUACER) += pcie_ecam_synquacer.o obj-$(CONFIG_PCIE_APPLE) += pcie_apple.o +obj-$(CONFIG_PCIE_CDNS_TI) += pcie_cdns_ti.o obj-$(CONFIG_PCI_FTPCI100) += pci_ftpci100.o obj-$(CONFIG_PCI_GT64120) += pci_gt64120.o obj-$(CONFIG_PCI_MPC85XX) += pci_mpc85xx.o diff --git a/drivers/pci/pcie_cdns_ti.c b/drivers/pci/pcie_cdns_ti.c new file mode 100644 index 0000000000..2b9bba19b4 --- /dev/null +++ b/drivers/pci/pcie_cdns_ti.c @@ -0,0 +1,645 @@ +// SPDX-License-Identifier: GPL-2.0-only OR MIT +/* + * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com + * + * PCIe controller driver for TI's K3 SoCs with Cadence PCIe controller + * + * Ported from the Linux driver - drivers/pci/controller/cadence/pci-j721e.c + * + * Author: Siddharth Vadapalli s-vadapalli@ti.com + * + */ + +#include <asm/global_data.h> +#include <asm/gpio.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <generic-phy.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <linux/io.h> +#include <linux/log2.h> +#include <log.h> +#include <pci.h> +#include <power-domain.h> +#include <regmap.h> +#include <syscon.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define CDNS_PCIE_LM_BASE 0x00100000 +#define CDNS_PCIE_LM_ID (CDNS_PCIE_LM_BASE + 0x0044) +#define CDNS_PCIE_LTSSM_CTRL_CAP (CDNS_PCIE_LM_BASE + 0x0054) +#define CDNS_PCIE_LM_RC_BAR_CFG (CDNS_PCIE_LM_BASE + 0x0300) + +#define CDNS_PCIE_LM_ID_VENDOR_MASK GENMASK(15, 0) +#define CDNS_PCIE_LM_ID_VENDOR_SHIFT 0 +#define CDNS_PCIE_LM_ID_VENDOR(vid) \ + (((vid) << CDNS_PCIE_LM_ID_VENDOR_SHIFT) & CDNS_PCIE_LM_ID_VENDOR_MASK) +#define CDNS_PCIE_LM_ID_SUBSYS_MASK GENMASK(31, 16) +#define CDNS_PCIE_LM_ID_SUBSYS_SHIFT 16 +#define CDNS_PCIE_LM_ID_SUBSYS(sub) \ + (((sub) << CDNS_PCIE_LM_ID_SUBSYS_SHIFT) & CDNS_PCIE_LM_ID_SUBSYS_MASK) + +#define CDNS_PCIE_LM_RC_BAR_CFG_BAR0_CTRL_MASK GENMASK(8, 6) +#define CDNS_PCIE_LM_RC_BAR_CFG_BAR0_CTRL(c) \ + (((c) << 6) & CDNS_PCIE_LM_RC_BAR_CFG_BAR0_CTRL_MASK) +#define CDNS_PCIE_LM_RC_BAR_CFG_BAR1_CTRL_MASK GENMASK(16, 14) +#define CDNS_PCIE_LM_RC_BAR_CFG_BAR1_CTRL(c) \ + (((c) << 14) & CDNS_PCIE_LM_RC_BAR_CFG_BAR1_CTRL_MASK) +#define CDNS_PCIE_LM_RC_BAR_CFG_PREFETCH_MEM_ENABLE BIT(17) +#define CDNS_PCIE_LM_RC_BAR_CFG_PREFETCH_MEM_64BITS BIT(18) +#define CDNS_PCIE_LM_RC_BAR_CFG_IO_ENABLE BIT(19) +#define CDNS_PCIE_LM_RC_BAR_CFG_IO_32BITS BIT(20) + +#define CDNS_PCIE_LM_BAR_CFG_CTRL_DISABLED 0x0 + +#define CDNS_PCIE_RP_BASE 0x00200000 + +/* + * Address Translation Registers + */ +#define CDNS_PCIE_AT_BASE 0x00400000 + +/* Region r Outbound AXI to PCIe Address Translation Register 0 */ +#define CDNS_PCIE_AT_OB_REGION_PCI_ADDR0(r) \ + (CDNS_PCIE_AT_BASE + 0x0000 + ((r) & 0x1f) * 0x0020) +#define CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_NBITS_MASK GENMASK(5, 0) +#define CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_NBITS(nbits) \ + (((nbits) - 1) & CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_NBITS_MASK) +#define CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_DEVFN_MASK GENMASK(19, 12) +#define CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_DEVFN(devfn) \ + (((devfn) << 12) & CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_DEVFN_MASK) +#define CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_BUS_MASK GENMASK(27, 20) +#define CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_BUS(bus) \ + (((bus) << 20) & CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_BUS_MASK) + +/* Region r Outbound AXI to PCIe Address Translation Register 1 */ +#define CDNS_PCIE_AT_OB_REGION_PCI_ADDR1(r) \ + (CDNS_PCIE_AT_BASE + 0x0004 + ((r) & 0x1f) * 0x0020) + +/* Region r Outbound PCIe Descriptor Register 0 */ +#define CDNS_PCIE_AT_OB_REGION_DESC0(r) \ + (CDNS_PCIE_AT_BASE + 0x0008 + ((r) & 0x1f) * 0x0020) +#define CDNS_PCIE_AT_OB_REGION_DESC0_TYPE_MEM 0x2 +#define CDNS_PCIE_AT_OB_REGION_DESC0_TYPE_IO 0x6 +#define CDNS_PCIE_AT_OB_REGION_DESC0_TYPE_CONF_TYPE0 0xa +#define CDNS_PCIE_AT_OB_REGION_DESC0_TYPE_CONF_TYPE1 0xb + +/* Bit 23 MUST be set in RC mode. */ +#define CDNS_PCIE_AT_OB_REGION_DESC0_HARDCODED_RID BIT(23) +#define CDNS_PCIE_AT_OB_REGION_DESC0_DEVFN_MASK GENMASK(31, 24) +#define CDNS_PCIE_AT_OB_REGION_DESC0_DEVFN(devfn) \ + (((devfn) << 24) & CDNS_PCIE_AT_OB_REGION_DESC0_DEVFN_MASK) + +/* Region r Outbound PCIe Descriptor Register 1 */ +#define CDNS_PCIE_AT_OB_REGION_DESC1(r) \ + (CDNS_PCIE_AT_BASE + 0x000c + ((r) & 0x1f) * 0x0020) +#define CDNS_PCIE_AT_OB_REGION_DESC1_BUS_MASK GENMASK(7, 0) +#define CDNS_PCIE_AT_OB_REGION_DESC1_BUS(bus) \ + ((bus) & CDNS_PCIE_AT_OB_REGION_DESC1_BUS_MASK) + +/* Region r AXI Region Base Address Register 0 */ +#define CDNS_PCIE_AT_OB_REGION_CPU_ADDR0(r) \ + (CDNS_PCIE_AT_BASE + 0x0018 + ((r) & 0x1f) * 0x0020) +#define CDNS_PCIE_AT_OB_REGION_CPU_ADDR0_NBITS_MASK GENMASK(5, 0) +#define CDNS_PCIE_AT_OB_REGION_CPU_ADDR0_NBITS(nbits) \ + (((nbits) - 1) & CDNS_PCIE_AT_OB_REGION_CPU_ADDR0_NBITS_MASK) + +/* Region r AXI Region Base Address Register 1 */ +#define CDNS_PCIE_AT_OB_REGION_CPU_ADDR1(r) \ + (CDNS_PCIE_AT_BASE + 0x001c + ((r) & 0x1f) * 0x0020) + +/* AXI link down register */ +#define CDNS_PCIE_AT_LINKDOWN (CDNS_PCIE_AT_BASE + 0x0824) + +#define CDNS_PCIE_DETECT_QUIET_MIN_DELAY_MASK GENMASK(2, 1) +#define CDNS_PCIE_DETECT_QUIET_MIN_DELAY_SHIFT 1 +#define CDNS_PCIE_DETECT_QUIET_MIN_DELAY(delay) \ + (((delay) << CDNS_PCIE_DETECT_QUIET_MIN_DELAY_SHIFT) & \ + CDNS_PCIE_DETECT_QUIET_MIN_DELAY_MASK) + +#define LINK_TRAINING_ENABLE BIT(0) +#define LINK_WAIT_MAX_RETRIES 10 +#define LINK_WAIT_USLEEP_MIN 90000 +#define LINK_WAIT_USLEEP_MAX 100000 + +#define PCIE_USER_CMD_STATUS_REG_OFFSET 0x4 +#define PCIE_USER_LINK_STATUS_REG_OFFSET 0x14 +#define PCIE_USER_LINK_STATUS_MASK GENMASK(1, 0) + +#define PCIE_MODE_SEL_MASK BIT(7) +#define PCIE_GEN_SEL_MASK GENMASK(1, 0) +#define PCIE_LINK_WIDTH_MASK GENMASK(9, 8) + +#define usleep_range(a, b) udelay((b)) + +enum link_status { + NO_RECEIVERS_DETECTED, + LINK_TRAINING_IN_PROGRESS, + LINK_UP_DL_IN_PROGRESS, + LINK_UP_DL_COMPLETED, +}; + +struct pcie_cdns_ti { + struct udevice *dev; + void __iomem *intd_cfg_base; + void __iomem *user_cfg_base; + void __iomem *reg_base; + void __iomem *cfg_base; + fdt_size_t cfg_size; + struct regmap *syscon_base; + struct pci_controller *host_bridge; + u32 device_id; + u32 max_link_speed; + u32 num_lanes; + u32 pcie_ctrl_offset; + u32 vendor_id; + + /* IO, MEM & PREFETCH PCI regions */ + struct pci_region io; + struct pci_region mem; + struct pci_region prefetch; +}; + +/* Cadence PCIe Controller register access helpers */ +static inline void pcie_cdns_ti_writel(struct pcie_cdns_ti *pcie, u32 reg, u32 val) +{ + writel(val, pcie->reg_base + reg); +} + +static inline u32 pcie_cdns_ti_readl(struct pcie_cdns_ti *pcie, u32 reg) +{ + return readl(pcie->reg_base + reg); +} + +/* Root Port register access helpers */ +static inline void pcie_cdns_ti_rp_writeb(struct pcie_cdns_ti *pcie, + u32 reg, u8 val) +{ + void __iomem *addr = pcie->reg_base + CDNS_PCIE_RP_BASE + reg; + + writeb(val, addr); +} + +static inline void pcie_cdns_ti_rp_writew(struct pcie_cdns_ti *pcie, + u32 reg, u16 val) +{ + void __iomem *addr = pcie->reg_base + CDNS_PCIE_RP_BASE + reg; + + writew(val, addr); +} + +/* User register access helpers */ +static inline u32 pcie_cdns_ti_user_readl(struct pcie_cdns_ti *pcie, u32 offset) +{ + return readl(pcie->user_cfg_base + offset); +} + +static inline void pcie_cdns_ti_user_writel(struct pcie_cdns_ti *pcie, u32 offset, + u32 val) +{ + writel(val, pcie->user_cfg_base + offset); +} + +void __iomem *pcie_cdns_ti_map_bus(struct pcie_cdns_ti *pcie, pci_dev_t bdf, + uint offset) +{ + int busnr, devnr, funcnr, devfn; + u32 addr0, desc0; + + busnr = PCI_BUS(bdf); + devnr = PCI_DEV(bdf); + funcnr = PCI_FUNC(bdf); + devfn = (devnr << 3) | funcnr; + + if (busnr == 0) { + if (devfn) + return NULL; + return pcie->reg_base + (offset & 0xfff); + } + + if (!(pcie_cdns_ti_readl(pcie, CDNS_PCIE_LM_BASE) & 0x1)) + return NULL; + + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_LINKDOWN, 0x0); + + addr0 = CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_NBITS(12) | + CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_DEVFN(devfn) | + CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_BUS(busnr); + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_PCI_ADDR0(0), addr0); + + desc0 = CDNS_PCIE_AT_OB_REGION_DESC0_HARDCODED_RID | + CDNS_PCIE_AT_OB_REGION_DESC0_DEVFN(0); + + if (busnr == 1) + desc0 |= CDNS_PCIE_AT_OB_REGION_DESC0_TYPE_CONF_TYPE0; + else + desc0 |= CDNS_PCIE_AT_OB_REGION_DESC0_TYPE_CONF_TYPE1; + + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_DESC0(0), desc0); + + return pcie->cfg_base + (offset & 0xfff); +} + +static int pcie_cdns_ti_read_config(const struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + struct pcie_cdns_ti *pcie = dev_get_priv(bus); + void __iomem *addr; + ulong value; + + addr = pcie_cdns_ti_map_bus(pcie, bdf, offset & ~0x3); + if (!addr) { + debug("%s: bdf out of range\n", __func__); + *valuep = pci_get_ff(size); + return 0; + } + + value = readl(addr); + *valuep = pci_conv_32_to_size(value, offset, size); + + return 0; +} + +static int pcie_cdns_ti_write_config(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + struct pcie_cdns_ti *pcie = dev_get_priv(bus); + void __iomem *addr; + ulong prev; + + addr = pcie_cdns_ti_map_bus(pcie, bdf, offset & ~0x3); + if (!addr) { + debug("%s: bdf out of range\n", __func__); + return 0; + } + + prev = readl(addr); + value = pci_conv_size_to_32(prev, value, offset, size); + writel(value, addr); + + return 0; +} + +static int pcie_cdns_ti_ctrl_init(struct pcie_cdns_ti *pcie) +{ + struct regmap *syscon = pcie->syscon_base; + + /* Set mode of operation */ + regmap_update_bits(syscon, pcie->pcie_ctrl_offset, PCIE_MODE_SEL_MASK, + BIT(7)); + + /* Set link speed */ + regmap_update_bits(syscon, pcie->pcie_ctrl_offset, PCIE_GEN_SEL_MASK, + pcie->max_link_speed - 1); + + /* Set link width */ + regmap_update_bits(syscon, pcie->pcie_ctrl_offset, PCIE_LINK_WIDTH_MASK, + (pcie->num_lanes - 1) << 8); + return 0; +} + +static void pcie_cdns_ti_detect_quiet_quirk(struct pcie_cdns_ti *pcie) +{ + u32 delay = 0x3; + u32 ltssm_ctrl_cap; + + ltssm_ctrl_cap = pcie_cdns_ti_readl(pcie, CDNS_PCIE_LTSSM_CTRL_CAP); + ltssm_ctrl_cap = ((ltssm_ctrl_cap & + ~CDNS_PCIE_DETECT_QUIET_MIN_DELAY_MASK) | + CDNS_PCIE_DETECT_QUIET_MIN_DELAY(delay)); + + pcie_cdns_ti_writel(pcie, CDNS_PCIE_LTSSM_CTRL_CAP, ltssm_ctrl_cap); + ltssm_ctrl_cap = pcie_cdns_ti_readl(pcie, CDNS_PCIE_LTSSM_CTRL_CAP); +} + +static void pcie_cdns_ti_start_user_link(struct pcie_cdns_ti *pcie) +{ + u32 reg; + + reg = pcie_cdns_ti_user_readl(pcie, PCIE_USER_CMD_STATUS_REG_OFFSET); + reg |= LINK_TRAINING_ENABLE; + pcie_cdns_ti_user_writel(pcie, PCIE_USER_CMD_STATUS_REG_OFFSET, reg); +} + +static bool pcie_cdns_ti_user_link_up(struct pcie_cdns_ti *pcie) +{ + u32 reg; + + reg = pcie_cdns_ti_user_readl(pcie, PCIE_USER_LINK_STATUS_REG_OFFSET); + reg &= PCIE_USER_LINK_STATUS_MASK; + if (reg == LINK_UP_DL_COMPLETED) + return true; + + return false; +} + +static int pcie_cdns_ti_host_wait_for_link(struct pcie_cdns_ti *pcie) +{ + int retries; + + for (retries = 0; retries < LINK_WAIT_MAX_RETRIES; retries++) { + if (pcie_cdns_ti_user_link_up(pcie)) { + dev_info(pcie->dev, "link up\n"); + return 0; + } + usleep_range(LINK_WAIT_USLEEP_MIN, LINK_WAIT_USLEEP_MAX); + } + + dev_err(pcie->dev, "failed to bring up link\n"); + return -ETIMEDOUT; +} + +static int pcie_cdns_ti_start_host_link(struct pcie_cdns_ti *pcie) +{ + int ret; + + ret = pcie_cdns_ti_host_wait_for_link(pcie); + /* TODO: Handle Gen2 Link retrain quirk for J721E */ + + return ret; +} + +static void pcie_cdns_ti_init_root_port(struct pcie_cdns_ti *pcie) +{ + u32 val, ctrl, id; + + ctrl = CDNS_PCIE_LM_BAR_CFG_CTRL_DISABLED; + val = CDNS_PCIE_LM_RC_BAR_CFG_BAR0_CTRL(ctrl) | + CDNS_PCIE_LM_RC_BAR_CFG_BAR1_CTRL(ctrl) | + CDNS_PCIE_LM_RC_BAR_CFG_PREFETCH_MEM_ENABLE | + CDNS_PCIE_LM_RC_BAR_CFG_PREFETCH_MEM_64BITS | + CDNS_PCIE_LM_RC_BAR_CFG_IO_ENABLE | + CDNS_PCIE_LM_RC_BAR_CFG_IO_32BITS; + pcie_cdns_ti_writel(pcie, CDNS_PCIE_LM_RC_BAR_CFG, val); + + if (pcie->vendor_id != 0xffff) { + id = CDNS_PCIE_LM_ID_VENDOR(pcie->vendor_id) | + CDNS_PCIE_LM_ID_SUBSYS(pcie->vendor_id); + pcie_cdns_ti_writel(pcie, CDNS_PCIE_LM_ID, id); + } + + if (pcie->device_id != 0xffff) + pcie_cdns_ti_rp_writew(pcie, PCI_DEVICE_ID, pcie->device_id); + + pcie_cdns_ti_rp_writeb(pcie, PCI_CLASS_REVISION, 0); + pcie_cdns_ti_rp_writeb(pcie, PCI_CLASS_PROG, 0); + pcie_cdns_ti_rp_writew(pcie, PCI_CLASS_DEVICE, PCI_CLASS_BRIDGE_PCI); +} + +void pcie_cdns_ti_set_outbound_region(struct pcie_cdns_ti *pcie, u8 busnr, + u8 fn, u32 r, bool is_io, u64 cpu_addr, + u64 pci_addr, u32 size) +{ + u64 sz = 1ULL << fls64(size - 1); + int nbits = ilog2(sz); + u32 addr0, addr1, desc0, desc1; + + if (nbits < 8) + nbits = 8; + + addr0 = CDNS_PCIE_AT_OB_REGION_PCI_ADDR0_NBITS(nbits) | + (lower_32_bits(pci_addr) & GENMASK(31, 8)); + addr1 = upper_32_bits(pci_addr); + + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_PCI_ADDR0(r), addr0); + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_PCI_ADDR1(r), addr1); + + if (is_io) + desc0 = CDNS_PCIE_AT_OB_REGION_DESC0_TYPE_IO; + else + desc0 = CDNS_PCIE_AT_OB_REGION_DESC0_TYPE_MEM; + desc1 = 0; + + desc0 |= CDNS_PCIE_AT_OB_REGION_DESC0_HARDCODED_RID | + CDNS_PCIE_AT_OB_REGION_DESC0_DEVFN(0); + desc1 |= CDNS_PCIE_AT_OB_REGION_DESC1_BUS(busnr); + + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_DESC0(r), desc0); + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_DESC1(r), desc1); + + addr0 = CDNS_PCIE_AT_OB_REGION_CPU_ADDR0_NBITS(nbits) | + (lower_32_bits(cpu_addr) & GENMASK(31, 8)); + addr1 = upper_32_bits(cpu_addr); + + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_CPU_ADDR0(r), addr0); + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_CPU_ADDR1(r), addr1); +} + +static void pcie_cdns_ti_init_address_translation(struct pcie_cdns_ti *pcie) +{ + struct pci_controller *hb = pcie->host_bridge; + u32 addr0, addr1, desc1, region = 1; + u64 cpu_addr = (u64)pcie->cfg_base; + int i, busnr = 0; + + /* + * Reserve region 0 for PCI configure space accesses: + * OB_REGION_PCI_ADDR0 and OB_REGION_DESC0 are updated dynamically by + * cdns_pci_map_bus(), other region registers are set here once for all. + */ + addr1 = 0; /* Should be programmed to zero. */ + desc1 = CDNS_PCIE_AT_OB_REGION_DESC1_BUS(busnr); + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_PCI_ADDR1(0), addr1); + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_DESC1(0), desc1); + + addr0 = CDNS_PCIE_AT_OB_REGION_CPU_ADDR0_NBITS(12) | + (lower_32_bits(cpu_addr) & GENMASK(31, 8)); + addr1 = upper_32_bits(cpu_addr); + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_CPU_ADDR0(0), addr0); + pcie_cdns_ti_writel(pcie, CDNS_PCIE_AT_OB_REGION_CPU_ADDR1(0), addr1); + + for (i = 0; i < hb->region_count; i++) { + if (hb->regions[i].flags == PCI_REGION_IO) { + pcie->io.phys_start = hb->regions[i].phys_start; /* IO base */ + pcie->io.bus_start = hb->regions[i].bus_start; /* IO_bus_addr */ + pcie->io.size = hb->regions[i].size; /* IO size */ + + pcie_cdns_ti_set_outbound_region(pcie, busnr, 0, region, + true, pcie->io.phys_start, + pcie->io.bus_start, + pcie->io.size); + } else { + pcie->mem.phys_start = hb->regions[i].phys_start; /* MEM base */ + pcie->mem.bus_start = hb->regions[i].bus_start; /* MEM_bus_addr */ + pcie->mem.size = hb->regions[i].size; /* MEM size */ + + pcie_cdns_ti_set_outbound_region(pcie, busnr, 0, region, + false, pcie->mem.phys_start, + pcie->mem.bus_start, + pcie->mem.size); + } + region++; + } +} + +static void pcie_cdns_ti_host_init(struct pcie_cdns_ti *pcie) +{ + pcie_cdns_ti_init_root_port(pcie); + pcie_cdns_ti_init_address_translation(pcie); +} + +static int pcie_cdns_ti_setup_host(struct pcie_cdns_ti *pcie) +{ + int ret; + + /* TODO: The following is only required for J7200 */ + pcie_cdns_ti_detect_quiet_quirk(pcie); + + pcie_cdns_ti_start_user_link(pcie); + + ret = pcie_cdns_ti_start_host_link(pcie); + if (ret) + return ret; + + pcie_cdns_ti_host_init(pcie); + + return 0; +} + +static int pcie_cdns_ti_probe(struct udevice *dev) +{ + struct pcie_cdns_ti *pcie = dev_get_priv(dev); + struct udevice *pci_ctlr = pci_get_controller(dev); + struct pci_controller *host_bridge = dev_get_uclass_priv(pci_ctlr); + struct power_domain pci_pwrdmn; + struct gpio_desc *gpiod; + struct phy serdes; + struct clk *clk; + int ret; + + pcie->dev = dev; + pcie->host_bridge = host_bridge; + + ret = power_domain_get_by_index(dev, &pci_pwrdmn, 0); + if (ret) { + dev_err(dev, "failed to get power domain\n"); + return ret; + } + + ret = power_domain_on(&pci_pwrdmn); + if (ret) { + dev_err(dev, "failed to power on\n"); + return ret; + } + + clk = devm_clk_get(dev, "fck"); + if (IS_ERR(clk)) { + ret = PTR_ERR(clk); + dev_err(dev, "failed to get functional clock\n"); + return ret; + } + + ret = generic_phy_get_by_name(dev, "pcie-phy", &serdes); + if (ret) { + dev_err(dev, "unable to get serdes"); + return ret; + } + generic_phy_reset(&serdes); + generic_phy_init(&serdes); + generic_phy_power_on(&serdes); + + ret = pcie_cdns_ti_ctrl_init(pcie); + if (ret) + return ret; + + gpiod = devm_gpiod_get_optional(dev, "reset", GPIOD_IS_OUT); + if (IS_ERR(gpiod)) { + ret = PTR_ERR(gpiod); + if (ret != -EPROBE_DEFER) + dev_err(dev, "Failed to get reset GPIO\n"); + return ret; + } + + if (gpiod) { + ret = dm_gpio_set_value(gpiod, 0); + usleep_range(100, 200); + ret = dm_gpio_set_value(gpiod, 1); + if (ret) + return ret; + } + + ret = pcie_cdns_ti_setup_host(pcie); + if (ret) + return ret; + + return 0; +} + +static int pcie_cdns_ti_of_to_plat(struct udevice *dev) +{ + struct pcie_cdns_ti *pcie = dev_get_priv(dev); + struct regmap *syscon; + u32 offset; + int ret; + + pcie->intd_cfg_base = dev_remap_addr_name(dev, "intd_cfg"); + if (!pcie->intd_cfg_base) + return -EINVAL; + + pcie->user_cfg_base = dev_remap_addr_name(dev, "user_cfg"); + if (!pcie->user_cfg_base) + return -EINVAL; + + pcie->reg_base = dev_remap_addr_name(dev, "reg"); + if (!pcie->reg_base) + return -EINVAL; + + pcie->cfg_base = dev_remap_addr_name(dev, "cfg"); + if (!pcie->cfg_base) + return -EINVAL; + + pcie->vendor_id = 0xffff; + pcie->device_id = 0xffff; + dev_read_u32(dev, "vendor-id", &pcie->vendor_id); + dev_read_u32(dev, "device-id", &pcie->device_id); + + ret = dev_read_u32(dev, "num-lanes", &pcie->num_lanes); + if (ret) + return ret; + + ret = dev_read_u32(dev, "max-link-speed", &pcie->max_link_speed); + if (ret) + return ret; + + syscon = syscon_regmap_lookup_by_phandle(dev, "ti,syscon-pcie-ctrl"); + if (IS_ERR(syscon)) { + if (PTR_ERR(syscon) == -ENODEV) + return 0; + return PTR_ERR(syscon); + } + + ret = dev_read_u32_index(dev, "ti,syscon-pcie-ctrl", 1, &offset); + if (ret) + return ret; + + pcie->syscon_base = syscon; + pcie->pcie_ctrl_offset = offset; + + return 0; +} + +static const struct dm_pci_ops pcie_cdns_ti_ops = { + .read_config = pcie_cdns_ti_read_config, + .write_config = pcie_cdns_ti_write_config, +}; + +static const struct udevice_id pcie_cdns_ti_ids[] = { + { .compatible = "ti,j7200-pcie-host" }, + { } +}; + +U_BOOT_DRIVER(pcie_cdns_ti) = { + .name = "pcie_cdns_ti", + .id = UCLASS_PCI, + .of_match = pcie_cdns_ti_ids, + .ops = &pcie_cdns_ti_ops, + .of_to_plat = pcie_cdns_ti_of_to_plat, + .probe = pcie_cdns_ti_probe, + .priv_auto = sizeof(struct pcie_cdns_ti), +};
[snip]
- Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com
- PCIe controller driver for TI's K3 SoCs with Cadence PCIe controller
- Ported from the Linux driver - drivers/pci/controller/cadence/pci-j721e.c
- Author: Siddharth Vadapalli s-vadapalli@ti.com
Please audit this list to make sure you need everything because..
You don't reference gd in this code at all, so don't need this.
So please also make sure the giant list of defines is needed.
Per checkpatch.pl.conf: # Not Linux, so we don't recommend usleep_range() over udelay()
I missed dropping this. I had checked that the rest of the includes are required, but I will re-check when I post the v2 patch.
During the development of this driver, I had committed the changes with around 15 commits that had the defines added only when needed. Therefore I am positive that they are required. I squashed those commits into a single one which is this patch. Nevertheless, I will double check before posting the v2 patch.
Sure, I will switch to udelay().
Thank you for reviewing this patch and providing feedback. I will implement your suggestions in the v2 patch.
Regards, Siddharth.
TI's J7200 SoC has a single instance of PCIe Controller namely PCIe1 which is a Cadence PCIe Controller. To support PCI functionality with the PCIe1 instance of PCIe, enable the corresponding configs.
Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com --- configs/j7200_evm_a72_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index fcfa926599..5a8cc0e6a7 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y # CONFIG_PSCI_RESET is not set +CONFIG_PCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 @@ -72,6 +73,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y +CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_UFS=y CONFIG_CMD_USB=y @@ -154,6 +156,8 @@ CONFIG_MUX_MMIO=y CONFIG_PHY_TI_DP83869=y CONFIG_PHY_FIXED=y CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_PCI_CONFIG_HOST_BRIDGE=y +CONFIG_PCIE_CDNS_TI=y CONFIG_PHY=y CONFIG_SPL_PHY=y CONFIG_PHY_CADENCE_TORRENT=y
Siddharth Vadapalli
