[U-Boot] [PATCH] ppc4xx: Fixed compilation warning in 4xx_enet.c
This patch fixes a compilation warning for some Ethernet PHY-less PPC4xx platforms (440SPE based ones) and a potential compilation error for 440SP platforms (use of undefined 'ethgroup' variable). In the original code and in case of 440SPE platforms, 'ethgroup' is initialized to -1 and never modified. Later in the function, within an #ifdef statement, an 'if statement' executes code only if 'ethgroup' is set to 4, therefore it is harmless to avoid executing the 'if statement' by removing the CONFIG_440SPE from the affected #ifdefs. In case of 440SP platforms with on-board Ethernet PHY, 'ethgroup' is undefined but used (there are not such platforms in the repository yet). All other architectures are not affected by this change.
Signed-off-by: Alessio Centazzo acpatin@yahoo.com --- drivers/net/4xx_enet.c | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/drivers/net/4xx_enet.c b/drivers/net/4xx_enet.c index 587605d..c020048 100644 --- a/drivers/net/4xx_enet.c +++ b/drivers/net/4xx_enet.c @@ -870,7 +870,7 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) defined(CONFIG_405EX) u32 opbfreq; sys_info_t sysinfo; -#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ +#if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) @@ -1119,7 +1119,6 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis)
#if defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ - defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX)
Hi Ben,
This patch falls into your responsibility now. I have no objections, so:
Acked-by: Stefan Roese sr@denx.de
Thanks.
Best regards, Stefan
Stefan,
Can I get an ACK from you on this? Sorry if you already did and I missed it.
regards, Ben
Ben,
I thought that I already ack'ed it. But hey, I have more than one ;)
Stefan Roese wrote:
Ben,
You probably did, but it got lost somewhere in my mountain of e-mails.
thanks, Ben
Alessio Centazzo
Ben Warren
Stefan Roese
