[U-Boot] Please pull u-boot-sunxi/master into master
Hi Tom,
Please pull u-boot-sunxi/master into master, highlights:
1) hdmi console (with usb keyboard) support with simplefb support so the kernel can use the framebuffer too 2) A small bugfix for ahci support
The following changes since commit f196044dfd64745a163773c6c746f9e149ace127:
ARM: atmel: add sama5d4 xplained ultra board support (2014-11-17 08:47:18 -0500)
http://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to 4de8eaa34fd2b74636eba9962889daf996175633:
sunxi: Add usb keyboard Kconfig option (2014-11-20 21:35:20 +0100)
---------------------------------------------------------------- Hans de Goede (8): sun7i: Drop CONFIG_ARMV7_PSCI_NR_CPUS sunxi: ahci: Add a delay after enabling target power sun4i: Rename dram_clk_cfg to dram_clk_gate sunxi: Add video pll clock functions sunxi: video: Add sun6i support fdt_support: Add a fdt_setup_simplefb_node helper function common/lcd: Make lcd_dt_simplefb_configure_node use fdt_setup_simplefb_node sunxi: Add usb keyboard Kconfig option
Luc Verhaegen (2): sunxi: video: Add cfb console driver for sunxi sunxi: video: Add simplefb support
arch/arm/cpu/armv7/sunxi/clock_sun4i.c | 27 ++ arch/arm/cpu/armv7/sunxi/clock_sun6i.c | 29 ++ arch/arm/cpu/armv7/sunxi/dram_sun4i.c | 4 +- arch/arm/include/asm/arch-sunxi/clock.h | 2 + arch/arm/include/asm/arch-sunxi/clock_sun4i.h | 47 ++- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 59 +++- arch/arm/include/asm/arch-sunxi/display.h | 200 ++++++++++++ board/sunxi/Kconfig | 14 + board/sunxi/ahci.c | 2 + board/sunxi/board.c | 10 + common/fdt_support.c | 62 ++++ common/lcd.c | 47 +-- configs/A13-OLinuXinoM_defconfig | 2 + configs/A13-OLinuXino_defconfig | 2 + configs/Colombus_defconfig | 1 + configs/Ippo_q8h_v5_defconfig | 2 + drivers/video/Makefile | 1 + drivers/video/sunxi_display.c | 451 ++++++++++++++++++++++++++ include/configs/sun7i.h | 1 - include/configs/sunxi-common.h | 62 ++++ include/fdt_support.h | 3 + 21 files changed, 981 insertions(+), 47 deletions(-) create mode 100644 arch/arm/include/asm/arch-sunxi/display.h create mode 100644 drivers/video/sunxi_display.c
Regards,
Hans
Hans de Goede
