[U-Boot] [PATCH v2] tools: moveconfig: support wildcards in --defconfigs file
Supporting shell-style wildcards for the --defconfigs option will be useful to run the moveconfig tool against a specific platform. For example, "uniphier*" in the file passed by --defconfigs option will be expanded to defconfig files that start with "uniphier". This is easier than listing out all defconfig files you are interested in.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - Warn when a pattern does not match any defconfig. (suggested by Joe)
tools/moveconfig.py | 30 ++++++++++++++++++++++-------- 1 file changed, 22 insertions(+), 8 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 87e2bb2..228d098 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -127,7 +127,8 @@ Available options standard commit message is used which may need to be edited.
-d, --defconfigs - Specify a file containing a list of defconfigs to move + Specify a file containing a list of defconfigs to move. The defconfig + files can be given with shell-style wildcards.
-n, --dry-run Perform a trial run that does not make any changes. It is useful to @@ -180,6 +181,7 @@ import copy import difflib import filecmp import fnmatch +import glob import multiprocessing import optparse import os @@ -284,6 +286,24 @@ def get_make_cmd(): sys.exit('GNU Make not found') return ret[0].rstrip()
+def get_matched_defconfigs(defconfigs_file): + """Get all the defconfig files that match the patterns in a file.""" + defconfigs = [] + for i, line in enumerate(open(defconfigs_file)): + line = line.strip() + if not line: + continue # skip blank lines silently + pattern = os.path.join('configs', line) + matched = glob.glob(pattern) + glob.glob(pattern + '_defconfig') + if not matched: + print >> sys.stderr, "warning: %s:%d: no defconfig matched '%s'" % \ + (defconfigs_file, i + 1, line) + + defconfigs += matched + + # use set() to drop multiple matching + return [ defconfig[len('configs') + 1:] for defconfig in set(defconfigs) ] + def get_all_defconfigs(): """Get all the defconfig files under the configs/ directory.""" defconfigs = [] @@ -1204,13 +1224,7 @@ def move_config(configs, options): reference_src_dir = None
if options.defconfigs: - defconfigs = [line.strip() for line in open(options.defconfigs)] - for i, defconfig in enumerate(defconfigs): - if not defconfig.endswith('_defconfig'): - defconfigs[i] = defconfig + '_defconfig' - if not os.path.exists(os.path.join('configs', defconfigs[i])): - sys.exit('%s - defconfig does not exist. Stopping.' % - defconfigs[i]) + defconfigs = get_matched_defconfigs(options.defconfigs) else: defconfigs = get_all_defconfigs()
On Wed, Oct 19, 2016 at 12:39 AM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Joe Hershberger
Masahiro Yamada
